PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. nitrous question
  2. need help with buying the safest set up.
  3. Should I be running the 90mm plate on my LS6???
  4. suggestion on spark plugs and gap
  5. Stand Alone Fuel System Necessary?
  6. Question before I spray
  7. Nitrous Express Jets
  8. Wiring Diagram for Headlight Switch...
  9. Another surging issue w/questions
  10. WTT 78 mm nitrous mani for your 90 mm!
  11. Best timing tuner
  12. Cure for Sticking N2O Solenoid on Dry Hits, and maybe wet hits too?
  13. Putting together nitrous motor what pistons/rods?
  14. The true cost of n2o.....
  15. Plugs for street driven 500whp motor/200hp n20....
  16. 150 shot on top of a H/C + Stock bottom end car?
  17. NANO Ebay Items Listed!!!
  18. Bottle Exploded
  19. Anyone have the link to the dual bottle pics or could post some.
  20. Its done!!
  21. 2 stage help
  22. o2 variance under spray?
  23. 150 shot and gears?
  24. Wiring window switch
  25. Lifted a head
  26. ARP Bolts or Head Studs?
  27. Why nitrous NOW SUCKS for me...
  28. Went for more testing tonight, ran out the full 1/4 and got a new best!!!!!
  29. 2 stage plate system?
  30. 200 wet shot?
  31. No nitrous class at the LSX race...
  32. best place to mount the nozzle
  33. Nick@HSW
  34. Spark plug choice.
  35. hours of a Wet Nitrous install?
  36. complete noob to nitrous need help with fogger
  37. first nitrous install, need pics
  38. fuel line question
  39. Timing Tuner
  40. Dry before maf question
  41. Should I be scared of ramping up nitrous?
  42. Pics of Nitro Daves standalone system needed
  43. Help With the Mallory 685
  44. anyone with nitrous outlet rear hump bracket...
  45. NOOBIE AND I KNOW!! but somebody PLEASE!lol
  46. FJO progressive nitrous mini-controller
  47. plug gap
  48. ATTN: NANO Users Please come in!!
  49. FS 860 Bottle heater/bracket $160
  50. What nitrous i should get.
  51. Help me connect this solinoid to my system NX related
  52. RPM/Tach Wire for MicroEdge
  53. FS Nitrous Express SHARK/PRO-SHARK/SUPER SHARK NOZZLE
  54. Torquer 3 what LSA on 150?
  55. blow down tube?
  56. kit for sale
  57. Noob question
  58. Questions before I spray.
  59. Tire sellection for N2o??
  60. turbo/nitrous
  61. NANO Systems For Sale *Cheap*
  62. nitrous and a 5.3?
  63. How awful are the NOS wet nozzles?
  64. Nitrous Parts For Sale.
  65. Nitrous Preasure Gauge
  66. whats the best intake?
  67. Is nitrous illegal?
  68. microedge issues???
  69. How will my cam take to nitrous?
  70. A/F and Timing
  71. Painting N20 bottles
  72. Missing something???? PICS
  73. I'm keeping the 100 shot.
  74. budget fogger kit?anyone
  75. If you want to run a dual stage 300 shot ................
  76. BIG Giant DRY SHOT folks... how big is big and what is your setup?
  77. Thanks Futral and Nitro Dave's
  78. COMPLETE Nitrous systems on sale for 599.00!!!
  79. HSW single nozzle Install help
  80. anyone make an easy microswitch??
  81. Time to buy pistons for my nitrous 408 build
  82. New to nitrous...need advice please.
  83. Been away for a little while, wanted to stop in and give a few updates....
  84. 93-96 Firebird M6 ashtray switchplates now available!
  85. fjo first gear lockout
  86. Need some cam help
  87. throttle body?
  88. Best AN wrench Set ??
  89. How mush timing for a 150 Shot
  90. Will stock Head bolts and MLS gaskets hold a 250 shot?
  91. Hey just bought my first kit!!
  92. Thinking Of Adding Another Stage?!?!?
  93. My bird purging in action
  94. Nitrous Pill Question
  95. Pics of the direct port on Cary's LX intake ...
  96. fuel pressure
  97. wanting a dealership program
  98. need bottle filled
  99. Blow down tube install question
  100. Need help w/nitrous kit
  101. Spark Plugs
  102. LS1 Kit on LT1
  103. What Cam?
  104. Complete Install... HSW 150 Wet Kit
  105. Complete Nitrous package
  106. Timing retard for an LT1 on Nitous outlet plete 150 shot?
  107. Dynotune Lean cutoff module
  108. soft hit, and rich as well
  109. best place to hide a purge???
  110. Will NX jets work with HSW?
  111. Dry direct port
  112. Stock pump dry shot??
  113. best injectors for 125 shot on stock motor?
  114. Spare Tire nano setup :)
  115. NANO Used 3000psi system For Sale 10 or 15# nitrous bottles
  116. is it worth buying a voltage booster?
  117. How much Nitrous??
  118. nitrous question
  119. Lets talk direct port
  120. nitrous daves plate in action....full weight 99 ss goes 9.91
  121. head and spray question
  122. Cam + parts too much $ so I am upping the shot
  123. New noids?
  124. Does anyone make an LT1 specific bracket?
  125. from carb to efi?
  126. What does it take to deal nitrous?
  127. Piston Opinion
  128. Spraying off the line (M6)..
  129. Timing retard, and fuel pressure ??
  130. help
  131. new plans!
  132. spray the 305TPI
  133. Nitrous Problems ???
  134. Got bored, so i hard mounted my nitrous kit
  135. pics of dry kits
  136. any way to fix a broken knob on a bottle?
  137. Bottle Valve question
  138. HSW Revolution bottle heaters???
  139. anyone else have this problem?
  140. 275 dr = all 4 tires off the ground
  141. Show me how you set up your 2 stage activation buttons
  142. will this be enough
  143. Running lean on a 150 shot wet
  144. Few pictures of my Cold Fusion Fogger install pics...
  145. MS4 and nitrous fuel question
  146. Anyone out there running catch cans for w/ your pcv with your N20 MOTOR.
  147. Wideband ONLY 189.99 At Nitrous Outlet
  148. Introducing the Nitrous Outlet Bottle Opener.
  149. NX jets
  150. All black blow down tubes?
  151. dumb purge question
  152. MS4 guys , please come inside
  153. My first nitrous kit
  154. dave nitrous plate install woes
  155. best nozzle, for wet kit
  156. who here had dynotune wet kit ?
  157. Thinking the Pills
  158. Stock bottom N2O record???
  159. Just Got The N20 Kit
  160. ZEX NItrous Parts for sale NIB
  161. What Pistons for LT1 on spray?
  162. WTB Black Dynotune bottle, fittings for 2 bottle setup, 4 bottle brackets
  163. plate guys, Question
  164. Thankyou Nitro Dave's, I love nitrous!!!!
  165. Looking for timing controller/window switch
  166. FJO idea
  167. Trick Performance V-Gauge
  168. lean or not ?
  169. Looking for fitting....
  170. 4ft an line
  171. Getting Closer
  172. 150 wet shot on a Stock 03 Z06???
  173. bmn window switch rev settings
  174. 75 Shot Questions
  175. Contemplating 1st NOS install, your thoughts?
  176. speed pro hypers vs stock ls1 pitions
  177. Timing Tuner LEDs don't work.. Defective?
  178. Ngk tr6 v power?
  179. Need opinions.
  180. "Money maker"
  181. HSW jets
  182. Hey Dynotune. I have a Great idea again HAHA QTP cutout related :)
  183. best window switch
  184. how close should window switch be to rev limit?
  185. BIG nitrous explosion at Pinks All Out in Belle Rose, LA
  186. When Do You all Refill
  187. New to Nitrous: Need advice
  188. Curious!!! whats the purpose of pulling 16* timing out..
  189. Nitrous Cam
  190. First Nitrous Install 95% Complete *pics*
  191. Got the bottle mounted
  192. Vic jr Question
  193. Pink Radio Wire / 12v Switched
  194. What Stall Do You Run?
  195. jets for 175HP
  196. Bottle Heater Wiring Question
  197. Autolite 104's for a nitrous outlet 150 shot?
  198. Hav you checked you noids lately????look inside
  199. Mixing jets
  200. Nitrous GURU's including vendors
  201. 2 stage or progressive
  202. Had my Nitrous Bottle Air sprayed
  203. ls6 manifold ok....or should i go with weiand
  204. bottle warmer pressure switch question...
  205. Help Another nitrous newb..
  206. MS4 and Spray what times are you running?
  207. My Nano Setup.
  208. can i use 2 differnt noids?
  209. Some HSW tunnel mount pics.
  210. HMMM they say 275s dont work
  211. g8 resutlts
  212. Anyone using the Trick Progressive Controller/Gauge?
  213. What to build a small nitrous fuel cell out of?
  214. HSW MicroEdge related issue
  215. switch panel wiring question
  216. Who has the best Stand Alone fuel system on the market?
  217. Which Fitting????
  218. Rear hump mounting
  219. Selenoid wiring
  220. 2 1/8 to 2 1/4 headers
  221. n2o pros check over my set-up please!!
  222. direct port Nos
  223. NOS kits
  224. Timing Tuner
  225. My HSW install
  226. n20 outlet 92mm plate install pictures
  227. Im wet kit confused,
  228. Nitrous Relay Info Plz
  229. Max Bottle pressure?
  230. What is the differance between NOS, NX, etc... jets Educate us?
  231. NITROUS-How big of a shot before you concern yourself with tuning??
  232. install pictures (nitrous outlet plate kit)
  233. setup suggestions? ms4 200 dry shot
  234. need a few ideas
  235. Need jets for a nitrous express 150 shot lt1
  236. NX bottle opener on multiple bottles
  237. DIY intake plumbing......*pics*
  238. Nitro Dave plate- Help with jetting sizes
  239. Nitrous Outlet rpm switch
  240. ??stock crank and block??
  241. Progress Pics...Finished 430 LSX pics....
  242. How much timing to be pulled?
  243. Afr?
  244. Need funnel jets
  245. Biggest dry shot on a stock f body feed line
  246. Progress Pics... Mini tub, Firewall, weight reduction
  247. Newbie Question...How long should a bottle last purging???
  248. Is it safe to spray my car?
  249. Bottle warmer question
  250. First spray !!!!!!!!
