View Full Version : Nitrous Oxide
- Warning!!!!! : Manufacturers recomended jetting
- 382 stroker how much can i spray?
- Tnt Lt1 F-2 Nitrous Kit For Sale!!
- Nitrous Blows Up My Motor
- What cam would be safe????
- C-5 Z06 Cam & Heads w/ NOS Runs 9.94 @ 143
- help with tnt 90 f1 kit
- Nitrous converter
- Nitrous cylinder head
- Tnt F2
- what pistons can handle mega shots?
- Enough nitrous or need more?...heh...
- No TPS??
- 402/408 nitrous users in here!!
- Witch Nitrous lt1 kit?
- Autometer Nitrous Sender (Electric)
- MSD Window Switch
- Big Thanks to Josh over at NX! They put me on the bumper (video)
- Problem after spraying for first time...
- Problems
- arming switch connection question
- Blowtorch + fille n2o bottle = bad?..right
- Dynotune vs. CFN?
- 1/4 mile gains just spraying 100 2nd gear on?
- Well hope for the best! 300 then 400 going at it! Its the end of the year "Blow out"
- nitrous stuff 4 sale
- NOS fuel solenoid sticking open please help
- max shot through -4an and -6an
- Cam only, 100 shot ?
- FJO Controller
- some easy nitrous questions
- bumb idea, but as you guys seem so nice..... :)
- ordering the final pieces... got ???'s
- Couple quick questions
- Happy Thanksgiving
- Spark plug wires advance timing?
- Teflon paste?
- Proper nozzle placement on a Z28/TA airlid ???
- stock bottom end lt1 juice?
- Should Bottle Be Closed When Parked?
- NX Ricky, Dave or Jeremy...nitrous/fuel issue.
- What's the Main Killer?
- finally a gp on hsw's stand alone
- tnt purple ring!!
- i dont know
- Can you run a 100 dry shot on a bone stock 2000 Z28?
- a few questions for the people with big nuts, lol.
- How long will 75 hp shot last?
- Different Types of N2O Kits?
- what to expect to pay for a nitrous system
- Any problems running colder plugs on daily driver
- Dry kit instalation?
- NX Automatic Bottle Heater Transducer???
- Quick n' Easy TNT Questions...
- What size fitting is the line?
- ls1 + n2o = timing??
- Window switch and WOT switch question
- new PB in the GTO!
- Threw my little dry kit back on....
- Bottle won't get over 700lbs???
- New B Question
- GURUs !!! Help, problem with DIY setup
- what type of kit? direct port, or nozzle?
- FJO Progressive Controller Settings?
- Nitrous kit im buying
- some results on the black car
- nitrous missing on top end R's
- Nitrous on stock rods
- Window switch with NX Wet kit??
- Nitro Dave and HSW i need pics
- My N20 install.
- NX Rail Upgrade, What size tap for fittings???
- need to know NX 125 pills ASAP
- Corvette Bottle Install Animation
- Money Maker
- To flycut pistons w/ nitrous or not!!!
- Nitrous help PLEASE
- Nitrous Questions
- Injector Size ??
- Injector size ?'s
- Would i be able to slide by with a cast seel crank
- 200 shot gonna work?
- 402 with N2O
- Lets get a GP going on a standalone fuel system-Harris speed works
- Harris Speedworks! Can I at least get a free tshirt now?
- bottle in the spare tire compartment(vert's)
- All those who run dry post your shot size and Af
- Timing control for the LS1
- 175 shot + stock block?
- Spraying this weekend...NERVOUS
- is nitrous not the in thing?
- Is something wrong?
- FJO mini question
- where to set the window switch?
- 347 with forged pistions/rods can handle how much spray?
- Direct port using Edelbrock victor jr intake?
- !!!!!!!!!!new Open Pics.!!!!!!!!!!!!
- Progressive Controller BLOWOUT SALE
- Is anybody just doing spray + stall?
- Got an idea, tell me what you think....
- Switching to WET have Qs
- which heads?
- nx switch panel problem maybe.
- Finally Figured Out How To Post Some Pics..tnt Install...houston Raceway
- Nitrous parts
- Newb TPS/WOT question
- Dry Nitrous Jet Question
- stock fuel pump?
- BTL pressure for 2 stages?
- Nitrous Filling
- Before Posting: Look Over The Threads, Possibly Search Key?
- Free Airbrushed Nitrous Bottle.
- bottle pressure
- Nitrous Song
- Stock Bottom End or Forged?
- RWHP gains with a "nitrous" cam?
- Hey Dave! Thanks
- WOT switch Bracket?
- Would you do boost if you could?
- Dynotune
- Help for a MB
- Anyone in MI area help me set FPSS???
- Boltons + Cam + Nitrous + Stock Bottom End?!
- How to check fuel system? Just planning winter mods. DRY
- Anyone have some extra NOS jets laying around?
- tps wire question
- Just ran 100 shot.
- 125 dry shot w/ stock 28# injectors???
- jetting with direct port
- do i need a tune if i squueze?
- Jets for NX 20920 kit
- Nx 100 Shot Pills???
- which Nitrous to run???
- Activation switch question?
- NX gemini kit
- 2 stage wet and dry?
- Problems w/ NX TPS WOT switch?
- 250 Wet 100 Dry What Timing and Plugs?
- Progressive Control Question about Lean Condition...
- How to tell if high mileage motor/tranny is healthy enough for spray?
- Need help
- My very special 1,000th post!
- will a 100 shot be O.k
- Stock Injectors And A Dry Shot.
- I went to the dyno and found a problem. Help!
- wet or dry?
- Do I Have to get a tune for a 150 shot?
- Nitrous Install Tips and Tricks
- Nooby Nitrous Questions
- Will my stock tranny hold???
- Preventing Backfires
- Check this out! NEW Nitrous Product @ SEMA
- What is your favorite switch panel?
- !!!!!!!!GENX-2 for Christmas !!!!!!!!.
- Maybe done for the season
- NX solenoids (Maf Kit) Rebuild?
- NX solenoid leaking
- Help with nitrous activation.
- Corvette Tach Wire...
- tuning for nitrous??
- ?OLD style Power Ring?
- nitrous noid for opener
- 90k miles to many
- FJO Mini Problem
- What could be wrong??? z06 spray nutty!!!
- small shot???
- What gear are u guys running w/28" slicks!!
- bottle heater ?
- plate vs. nozzle
- Vid Of My New Best On The Spray
- HSW Trigger
- bottle bracket/mount for 20lber
- Video of my first ever nitrous pass!
- WTT: NX Bottle Opener
- Plate system
- N2O pressure guage question
- emissions?
- NX Single Nozzle 200shot Jets?
- My TNT Nitrous Install - Pics! 56K Beware
- Can I run 2 nozzles from one solonoid?
- Spark plugs...
- All Motor vs Nitrous shift points.....
- My first time spraying
- Want low 6's on the bottle
- Guage power supply
- nitrous cutting in and out
- Limits of the 4an main line?
- NOS question - jet size
- Re-wired some connections and now I am having problems.
- What size Jet for a 50 shot
- Compression and nitrous
- 1st time spraying at the track
- Nines Or Bust
- New shakedown run
- Problem with TNT fuel solenoid. Please help!!
- Direct port on ls1??
- Does it get too cold to run nitrous?
- Tuning for dry shots
- Nitrous Activation Question (Newbie)
- spray 100 shot on stock 100k tranny?
- new nod came in the mail today
- Ran 9's on stock bottom end
- Do I really need a tune for a 150 shot?
- Fuel Pressure Drop While Spraying?
- Nitrous?? HELP!!
- Give Me Ur Comments Please !!
- Who's hooking a 150 shot on radials?
- [Z06] Need some wiring help... (TPS switch and Digital MSD)
- Trac Cont. OFF automatically when N2O is ON. Interested?
- ** Hot Month Of November Specials!! **
- Post Pictures of your Fuel System!
- shift knob button
- Most miles on a stock motor + Spray
- Who has the cheapest wet kit w/o bottle?
- quick question??
- Iron 408 Nitrous Limits
- would you spray + heads + cam 100k motor?
- Can I use nitrous to cool IAT only?
- MSD digital window switch
- FJO help. Whats wrong??
- Progressive timing retard
- how much spray with forged mahle pistons?
- remote bottleopener ?
- Power wire question???
- Who's familiar with Ntirous Works "Power Wing"?
- Bottle Locations...
- Z06 fuel pump and nitrous
- who is running a TSP set up, not microswitch
- What all does it take to run 2 bottles?
- Help an ignorant man here...
- Free Free Free Free Free Free Free
- Nitrous being lugged
- LS7 w/200 shot = 8.90 VIDEO
- Anyone here use the Twisted Sanity N2O controllers?
- how good is nos
- C5 heater install question
- NEW ITEMS FOR 07. SOMe NEW, SOME IMPROVED;)
- thinking of spraying, how to get started
- Psi question
- NX Jet sizing
- Stock Bottom End LSx guys...
- n20 with 10 bolt
- new bottle location
- How many run in-line N20 solenoids on a wet shot?
- Where to buy Nitrous Express in Central America
- How The Heck Do I Change The Size Of Images To Post Pics!!!!
- I think I'm getting F'd!
- poping
- NX Parts List
- Bolt On nitrous guys...
