View Full Version : Nitrous Oxide
- MSD Digital Window switches INSTOCK
- Spark plug after 75 shot popping out exhaust.
- There must be a big difference in wet to dry nozzles...
- Looking in to No2 and have a few qs
- jetting and plugs
- help me decide
- Had to blueprint my new NX remote opener.
- 3 New Bests this weekend!!!!!!!
- So with the Zex kit....?
- Gauge lights
- Nitrous tune
- Wet kit fuel line question
- problem with nitrous
- Nitrous cam
- TNT help quick.....
- Fuel Pressure Question
- what Kit to chose and not hurt the engine
- Tr6 Plugs!!??
- what size jets?
- Nitrous Causing Problems... Help!!!
- Valve Stem Again..
- leaks
- Checked my plugs today.....
- Dynotune Electric Nitrous Pressure Gauge Sale!!!!
- just got my nitrous hooked up!
- Remote Bottle Opener Control Module. NEW U can use a reg switch.
- feels like it is running out of nitrous?!?
- 427 into the 9's? Nitrous Question
- Nitrous with 11 or 11.5:1 compression?
- stock fuel?
- FS: NX Kit w/ Accessories
- 112 LOS on spray
- Can I hit the N20 before 3k RPM's with a Dry Shot?
- CR question...
- 28.8# injectors ok with 150 wet shot??
- 340RW but wanna shoot 100 dry....
- Nitrous and other goodies for sale!
- BMN Window Switch Wiring ?
- Who is using NX Maximizer with FJO Wideband?
- fog light electrical pins?
- NX/Nitrous Outlet EFI System Installation Help Needed!
- How much can rear handle?
- Help!! Tach wire on the C6 Auto!
- TNT F1 kit..
- A few pics of my bracket for solenoids...
- Should I do spray on my engine? Will it hurt it?
- Anyone using a TNT ring w/ smooth bellows?
- Cheap Dry nozzle...
- bellows for 85mm maf -> power ring
- old style NX maximizer, is it worth it to wire it up?
- "Wet" to "Dry" Trend...?
- finally got my nitrous working...
- Dave@tnt q's?
- #10 wire on a 2000 z28?
- relay wiring
- Some N20 ?s
- NOS Pressure Guage leaking...help
- how accurate are the shots??
- bottle refills
- Halo Kit Users
- dry nitrous
- 100 shot??
- nozzle drill
- Solenoid Mounting help?
- The Most A Stock LS1 Can Take...
- Any links or sites, writeups for dry shot jetting?
- Is nitrous an oxidiser?
- Valve stem
- nos cheater noids
- Harlan Window Switch question
- direct port pics
- Dry nozzle placement
- Where can I get higher thermostats for a NOS heater?
- What happens to the nitros?
- Dry shot of 200 to 300????
- Talk about lucky....
- NX Maximizer... Is it worth the $640.
- Nitrous newbie: Need lots of wiring help
- (FPSS) Fuel Pressure Safety Switch Are they GOOD?
- Need NX Parts Help!
- nitrous newbie ???
- 75 or 100
- bottle opener
- Tach line
- Opener and Jimmy Jams
- detonating/misfiring/cutting out on 75 shot, help!!
- Questions about tnt F1 kit..
- Opinions needed for rear gear selection!
- just bought the bottle CANT WAIT!!! few questions
- Nitrous wiring
- 100 Or 150 Shot
- To those with dry kits do you have a purge?
- My 4.8Ler on the hose
- nitrous line run insie of car, or outside of car?
- Will I run lean?
- NOS Purge solenoid overheating / overpressured???
- New best times!!
- The time is here...
- How much spray? NX wet kit
- Question about N2O Filter
- anyone try this n2o plate?
- Not happy with HPE Nitrous Ring.....
- Opinions needed on stand alone system parts
- Where to put Purge Solenoid
- ONLY TEN DAYS UNTIL NORTH VS SOUTH >>>>>>
- tnt 150shot wiring diagram with timing tuner
- nx fpss setup psi
- FPSS Fittings
- Tnt 75hp Shot Race Results
- removing my big block plate and DP.. what can the ls1 use
- Nitrous not working, need help with msd window switch problem
- Ok here it is, my hood purge pics
- New Nitrous Express kit coming soon!
- what should a/f be when spraying a t.n.t 150 shot?
- Brand new Dynotune 75-150 Horsepower wet kit
- Quick Question, input appreciated
- Selling my kit...
- help
- my bottle mnounted in the spare tire well. pics.
- comparing nos nozzle kit to nxl kit
- Building a 327 N20 motor
- nitrious 5117
- zex vs. NX....
- Dyno'd TNT Kit, 150 shot on 123,xxx mile LS1
- Timing Help
- Melting #7 and #8 plugs on 250 shot single Fogger SHO ?'s
- **pics**Installed NX SX2 kit from Nitro Dave (56k beware)
- question about NX bottle heater.
- do i need plugs
- Opinions on 150 shot on stock bottom end
- Nick,Here are the final Pics...
- dynoed my t.n.t kit.
- Quick question on the NX bottle heater.
- cam only z06 need N20 advice.
- Dual nozzle 200 on a truck intake. OK?
- nitro not making as much power as stated
- Direct Port Help...
- Nitrous On An Eagle Rot.assy.
- Running Lean?
- What sponsors have direct port parts.
- Reseller
- used wet kit
- Ramchargers timing tuner with MSD window switch box question
- Corvette Window switch help.
- 150hp jets
- Where's the mph???
- back firing?
- Innovate Wide Band Controller Sale!!!!
- spraying 150 shot what to expect!!
- WOT switch and button?
- NX or Dynotune??
- Safe to spray 150HP shot with this combo?
- What else should be needed for my setup?
- NOS 10LB High Polished Bottle with high flow valve
- few pics!!
- FREE acessories with Nitrous Express kit purchase!
- N20 w/ INDIVIDUAL TB's
- (DYNOTUNE) Air/Fuel Ratio Nitrous shut-down switch
- What kind of Race Gas do you use???
- Nitrous fill in S. Jersey?
- Bottle Heater conversion
- 150 shot on stock injectors??
- New N2O setup pics
- fuel and spark
- Digital MSD mounting
- How much timing should I pull?
- will 20lb bottle fit in the spare tire well?
- New best ET + MPH!!!!!!!!
- nitrous? concerning maf and tps
- A Couple Electrical Questions...
- How to figure Injectors vs Dry Shots?
- nx wet kit nossle installation
- Running lean 13.9 what to do B4 nitrous install?
- Its Finished!!!!!!!!!
- New clutch for the spray?
- Where are some good nitrous refill stations in DFW?
- What's considered the minimum safe fuel pressure to spray at?
- My new purge setup
- Bigger nos noids??
- Thinking of getting a 3 guage pillar.
- Dyno Tune remote bottle opener
- basic questions
- BEST NITROUS tuning insruction manual.
- drill threw the throttle body?
- Nitrous help!!!
- spray through gears with 75hp shot?
- what kind of brackets are these...?
- high mileage and spray
- Jet size
- me again...look at bottles need experianced advice QUICK
- anyone have this??
- wahts the best setup for....
- hot box nitrous bottle warmers?
- Does this power seem right?
- Bandit's Nitrous Video Link Inside.
- anyone put the fuel solenoid here?
- Fpss
- Wont work!
- I need a Steel Fuel Rail Fitting.
- Fuel Pump?
- Puyallup,wa Moderator?
- Maximizer II question
- purge ?????ahh
- tune rich and spray after the maf
- switches and relays and tigers, oh my
- A few pics of the new MAF kit.
- money is no object BEST KIT?
- No puddling with LS2 Intake.
- considering n20
- Does every 100hose shot of nitrous equal 10,000 miles>>>
- Don't know which setup to go with, help
- Suggestions Placement Nozzle(s) NX Wet Kit(Pics inside)
- Purge 12v question
- NX Remote Opener problems....
- need help
- Is a purge absolutely necessary?
- Update MAF kit SPY Photo.
- solenoid style bottle opener leaks?
- what size bottle in spare tire well "00ta
- how the HELL
- How to determine what octaine is needed for a 300 dp shot
- Noid question
- dry kit questions
- purge on the radiator?
- OK to spray at 2750 or 2500 RPMS?
- Will a 100 dry shot max out stock injectors on a 98 Z28?
- Does anyone have the MSD Digital Window Switch?
- Two stage wiring problems.
- What happened to the thread on the New NX Controller
- NOS's New LS1 Plate System
- Can someone look at my autotap logs and see if its ok?
- NX's NEW Nittrous Pres. Gauge, lights up at night?
- Dual Stage Dry or One Stage Dry and One Wet
- I need a fairly quick answer.
- what should i use to make my nitrous set-up as safe as possible
- Is This A Good Cam For N20?
- wiring question
- Meth Kit
- nitrous and car accidents?
- nx single fogger nozzle
- what pill to use for my window switch i got a 3800 stall
- Spray bar rocket science?
- what kit
- recomendations
- Want to spray ontop of the charger.....
- Nitrous in Conjunction with a Turbo
- Need help?
- 01 SS Nitrous ?
- What Tuning After a WET KIT?(What to check?)
- NOS jet sizes??
