View Full Version : Nitrous Oxide
- new to nitrous
- z06 and nitrous suggestions
- NOZzle kit???
- RPM Window Switches, Who makes the best?
- 10's ?
- Is it safe to ?
- spraying with an m6
- Pics of my TNT F1
- What heads for nitrous setup?
- Painting my bottle
- s/c vs nitrous
- What kind of power do you guys forcast for my vette w/a 408
- anyone have a direct port install how-to?
- lt1 install complete w/ pics
- Pls advise, wet or dry shot on MP112?
- Lets get this whole spark plug gap and temp issue straight for us nitrous newbies.
- How to hook up MSD Digital Window Switch
- -7 plugs for nitrous
- dave some info
- Purge noid didnt work when purchased
- NX MAF kit with a 90mm TB/Intake
- Need some new Nitrous parts...DAVE
- bottle fitment
- NX Nitrous Express set up FOR SALE!!!!
- Can someone help me with a electric N20 guage
- Looking For a cam
- Hang time video
- Question about mounting nozzle
- Timing Tuner..Or BMN Window Switch?
- Mounting the Shark Nozzle
- any one hace PIC's of spark plugs?
- Yes Boys And Girls This Is Why You Get The Right Spark Plugs
- New Rapid Fire Purge!!
- Dry Vs. Wet
- Help w/ nitrous setup for street car please...
- Safe to spray?
- 2 stage upgrade
- Dry to wet conversion ... TNT LS1 Conversion all I need?
- Price of NOS in Northern VA???
- For you guys running nitrous on stock motors...
- MTI G1 make a good N20 cam??
- 150 Shot
- nx heater adjustment?
- cheapest tnt f1 kit-new?
- ok guys i tried search and not much where to mount NX wet solenoids ?
- Nitrous with my cam
- 175 shot?
- Spraying with gas gage on E
- Largest shots used on 346/347???
- Nitrous Pump Question
- Removing MAF SCREEN for dry shot..
- Got Board: Nitrous for your RC car.
- TECH TIP: Blow off fitting. Why it’s important.
- 10lb bottle or 15?
- differen't oil for nitrous?
- 250 shot on a stock block with a progressive controller?
- looked everywhere.. diff b/t tnt f1 and f2 is?
- What type of plugs?
- Help tuning nitrous
- Single stage 250 shot or 100 NOS "Dry" & 150 TNT "Wet" 2 stage
- What jets and what timing with F2 TNT?
- supercharge w/ nitrous?
- Dynotune Gauges - Custom Applications!!!!
- How does the MAF compensate for the dry shot?
- can i get a 2 port accessory for 2 pressure sensors?
- cant decide on plugs
- Direct port pros and cons?
- NOS LS1 Kit
- Compucar Nitros Systems
- decisions,decisions
- I started ordering parts today!!!
- TR6 idle problems in d
- What would happen if.....
- How do you do it?
- Engine upgrades that aide N2O application
- A Few nitrous ???
- Im running NOS kit.. looking for heads
- 9.92 Video (Dec run)
- inline pump question
- LS2 direct port pics...
- 150 tnt shot an 5.3
- DRY - WET Conversion
- Missfire on Nitrous, Help me chase down the gremlin!
- Which kit NX 80010 or 90006?
- Is there a non-"pulsing" progressive controller out there?
- how much to spray on a forged rod/pistons 346 with mild n2o cam?
- Introduction
- Nitrous Question
- Help me pick a tire for nitrous.
- Things to think about.
- What is a good dry kit for a small shot?
- Jimmy Jams ?
- who sells the lowest price TNT f1 kit?(new)
- Bottle Heater/Bottle Opener Question
- Someone shed some light on spraying past 4th gear..
- LS1 Build for Nitrous - Clean Slate
- when running the lines for the bottle where do you come into the trunk?
- what size tap do i need for the n/x nozzle
- NX Purge Solenoid
- quick ??? about painting a bottle
- Nitrous gone VERY BAD!!! -VID-
- Tuning question
- Question for 383LQ4SS
- Pro flow 45 valve question
- FPSS install
- opinions on how much of a shot i can run.
- Any pics of a TNT wet kit, with a purge system installed???
- Need NX dual shark nozzle jetting - for nitro daves ring
- broken fitting on nozzle, easy fix with an easy out?
- Nitrous Systems Review!!!
- who does not run nitrous with a filter
- TECH TIP “KEEPING your nitrous supply clean.”
- Future setup
- FS TNT F2 Kit FS
- to those running a 150 shot or higher, come inside!
- Purging! Where? And a "How to"
- A good amount of people have been asking to see this video. So here it is
- Gauge Pics
- dual stage help
- NitrousWorks 2-state PowerWing™ system
- Tach output help (window switch)
- ok what a i missing
- Popping after a Nitrous run??
- 100 wet kit with TR220/220 cam
- Windshield washer for race fuel for nitrous?Need input.
- thanks nitro dave
- LQ9 Truck and NOS 5177???
- Nitrous Laws...
- Any reason not to use aluminum fittings in a nitrous solenoids?
- is there such a thing as a 25lb NOS bottle
- Nitrous LS1?
- Single NX Shark Nozzle
- MSDwindowswitch/NOS gauge
- FS NX Fill Station..
- NX MAF Kit??
- Where can I find a straight single fan spray nozzle? (dry set up)
- NOS DRY GUYs Need your imput...
- NXL Question?????
- Running lines through interior.... any issues with this?
- How do i hook up an air/fuel gauge
- How to Go about building/designing a Stand alone Fuel system
- Which Cam for 100-150 shot
- Enrichment fuel supply for LS1
- Help plz, Any one have a copy of the NX TPAS diagram??
- Direct Port 200 shot tuning?
- MSD Digital Window Switch For Sale
- Pics of my LS1 plate setup w/solid lines
- NOS sticker/label?
- Places to fill bottles in SO. CAl
- Stand Alone Fuel System Good For 175+ Stock LT1?
- FPSS Settings
- NOS 5176 tips/trick/pics
- what happens when you spray on an empty bottle?
- TNT F-1 vs. NX MAF
- dry shot question. - spray until bottle is totally empty?
- RPM BASE Progessive Download ready
- Nitrous with your Hot Cam
- What Jets Work For TNT
- Look over my wiring scematic
- forged or not
- cam,100shot, & stock rear?
- STS and Nitrous??
- Pic of my DP setup
- who makes the plate that boes between the TB and intake?
- Safe shot for LT1??
- Nitrous Filter
- Nitro Dave/NXRicky
- super stealth nitrous kit?
- post up please!! best street strip converter
- Quick dp nitrous questions?
- NX fpss
- Which head gaskets for Nitrous?
- NX tech tip ( mounting the bottle)
- Hows My Setup Sound?
- Anyone spraying the LPE GT1-1 Camshaft (229/242, .631/.631, 114 lobe)
- nitro dave?
- Nitrous with the 231/237
- Fast 90mm intake + 90mm TB + modified TNT ring
- Bottle PSi
- ~850 HP 900TQ on 100 jets MARAO!!!
- Can a NOS 5177 dry kit be combined with a wet kit??
- NOS 5177 stock 1/4 times???
- NX MAF kit dyno numbers
- Needs opinions on Cold Fusion Nitrous please.
- Sticky suggestion
- Nitrous shot vs. mph gain?
- Bottle leaking need help
- NHRA approved bottles
- n20 and ecm tune up?
- Hey Nitrous guys
- nozzles or something else
- 90mm TB + TNT ring
- how much can i spray
- TNT bottle blowdown size?
- NX red thread sealer
- Spare tire bottle bracket
- You guys with bottle warmers come in!!
- nitrous videos
- Where to mount window switch and 6al????
- Here is my setup....
- 02 SS A4....large wet shot?
- NX Jetting for 427 vette
- Kicking Off The New Year Specials!!!!
- What resistor for IAT ????
- TNT Install Pictures
- Quick compression question
- For those with Direct Port...
- nos ?
- I put in the 75 shot today.....
- Nitro Dave???
- WOT switch or TPS switch???
- 2nd gear activation question for A4
- MAFT & timing?
- NX MAF + Tuning
- nitrous switches
- NOS cam for "Cam Only" LS1 car
- RPM BASE Progessive You ask it here!!!!
- Wet or Dry
- dry shot questions....
- Nitrous Question
- Nos and twin turbo
- Convinced on N2O
- what is needed for plumbing DP?
- Im back..
- Finished the TnT nitrous install :)
- NX DP or MAF kit?
- Whats got a 1st Gear Lock Out?
- Will this work as a window switch?
- spraying gas nitrous help
- Who is 9's or faster??
- What fuel system will handle 600 rwhp?
- tr6 gap for my needs?
- Thanks to Dean at dynotune
- Finished my first "complete" install...
- picking up my wet kit tomorrow....
- Direct port for sale on ebay
- How to hide 10lb. NX bottle?
- need opinions
- is 104+ octance booster Nitrous safe??
- Start a 2005 Nitrous List or delete/update one?
- Direct Port Plumbing labor cost
- how big on 255lph/42lb fuel set up
- need NX Pills Houston area buy or borrow
- spraying a cammed 98z
- higher octane question
- Help - Cobalt Gauge Problems
- Fogger Nozzle Questions
- Inputs needed
- Stock Clutch?
- Ok i'm doin standalone
