PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Is this cam OK for 125 dry shot?
  2. Popping (backfire?) after letting off...
  3. ok lets get this straight
  4. Name that nitrous kit...
  5. TNT users-how many out there with no return fuel line?
  6. Hiding N2O from Insurance inspector & DAD
  7. what jets do i need?
  8. All those running an Electric Fuel Pressure Gauge
  9. Will a 15lb bottle fit in the spare tire/jack area?
  10. Questions on TNT nitrous solenoid
  11. To all the nitrous supply sponsors...
  12. TSP lid and NOS 5177 kit??? Jet Placement
  13. Anyone have their stock bellow collapse under WOT???
  14. ANy one use NGK -7 plugs with nitrous??
  15. Jets sizes for cold fusion kit
  16. Have to cut lid for TNT power ring?
  17. Timing Tuner questions...
  18. stupid NOS question
  19. Nitrous Wiring Help Needed
  20. Doing nitrous w/95k on the odometer?
  21. Who uses the DynoTune A/F switch?
  22. 'small’ nitrous question…
  23. Few questions?
  24. Gained
  25. Gotta ?
  26. Nitrous Cam?
  27. Low fuel pressure DP jet sizes?
  28. Pocket Bike N2O, long term!!! thanks Dave!
  29. rpm pill question
  30. Best looking A-Pillar Pods?
  31. I have 4:10s what do I do?
  32. Colder than stock spark plugs and their affect on N/A performance discussion....
  33. September Nitrous Specials!!!
  34. Question for Accel Gen 7 and FAST users
  35. knock retard and questions.
  36. 120 shot what gains at the track
  37. Can someone point me in the right direction?
  38. Just an Idea need opinions
  39. safe???
  40. Need Advice on the PE for Nitrous Car
  41. What will it run on the hose?
  42. Jets with the NX MAF kit?
  43. Very cool new tuning/datalogging product: wideband, egt, nitrous pressure,etc
  44. jet sizes
  45. Timing Tuner and plugs.
  46. Nxl Customers Time Critical
  47. New Member with Nitrous Questions
  48. spray & 04 Z06
  49. Which dry to wet kit to go with???
  50. Anyone know a site to locate nitrous fill stations?
  51. How much RWHP?
  52. Newbie nitrous ?'s
  53. Added a FPSS and a window switch and got probs
  54. Will all brands of bottle fit my 5177 kit??
  55. Any need for PCV mods (i.e., breather) with 200 shot on LS1???
  56. How much will I have to spray to get 700rwhp?
  57. I installed my TNT kit....Now I'm having window switch problems!?
  58. TNT F1-can I spray more than 150 with it?
  59. Got a dyno sheet for you guys to look at.
  60. Questions for Nitro Dave
  61. Hide Nitrous or not?
  62. Wet vs. Dry.
  63. N20 System Reconditions? Few questions…
  64. Looking to start a "Spare Bottle" Group Purchase
  65. Looking for a switched 12v under the hood...
  66. purge tube ?
  67. i only gained .5 from a t.n.t 100 shot,is somethind wrong?
  68. 12 volt source in console??..cigarette lighter?
  69. For those who are not electronically challenged:
  70. something is very wrong
  71. 5177 Noid
  72. NOS 8301 DP kit, who`s using it?
  73. car is tuned to spray a 100shot but i want to spray a 150 shot??
  74. New times with 100 dry shot!
  75. Timing Tuner's Window Switch Function
  76. Anyone with dedicated fuel system in the rear?
  77. NX jetting question
  78. 300 Wet shot?
  79. nozzle placement
  80. Building 402 for nitrous, do I want high or low compression?
  81. how important is fuel pressure safety switch
  82. Stand Alone Fuel System?
  83. timing tuner/ nitrous wiring help!
  84. Hong long does it take to install TNT Wet kit?
  85. What HP level is a #67 jet on a NOS dry system?
  86. And The Free Nitrous Kit Goes To......
  87. Does anyone know where I can buy only NX MAF ends?
  88. Would a dry shot + rich tuning be = wet shot?
  89. DPI and jetting Q
  90. Safe to shoot with my setup?
  91. Help! Want to run nitrous on my mercedes.
  92. lost compression
  93. What's Safe
  94. purge button question, please help..
  95. dynoed with nitrous ??????????
  96. nitrous a/f ??? on a stock motor
  97. 2 Step
  98. wont spray
  99. The best defeat (BEST FRIEND FINALLY GOES DOWN HARD!)
  100. Nitrous Plates I started making
  101. An old idea but perhaps interesting
  102. Need a 28 Fuel Jet
  103. 11:1 cr and a 50 or 100 shot.
  104. How much timing do I really need to pull?Need some help from the NOS guys
  105. How Loose can I go ?
  106. TNT Direct Port kit or NOS Noszle kit?
  107. custom dry shot help needed
  108. ok I am disapointed
  109. Very happy with my new set up!!!
  110. got my first 3 N2O passes!!!!!!!!!!!
  111. Anyone wire up a trans brake and nitrous inline together?
  112. All 9 second daily drivin N2O powered cars come in here.
  113. Bottle temp vs. Bottle pressure?
  114. Wiring Two step with Timing Tuner?
  115. How do you install an rpm window switch?
  116. BMR 4000lb GTO runs 10's - stock internals
  117. Dry vs Wet
  118. universal NX dry kit $200 good deal?
  119. Hey Nitrous Guys, You need to see this
  120. NGK TR55's vs TR6's or a one step colder plug
  121. How long should a 10lb bottle last on a 200 shot?
  122. Slotcar plate spaces out TB too far, cruise cable won't work
  123. Co2 fake purge
  124. What nitrous kit for a 427ci?
  125. Custom NXL (pic inside)
  126. Open or Closed?
  127. LOOK: Special on 860 Bottle Heater/Bracket
  128. 3 switch panel by TCS switch
  129. FPSS Which one is everybody using
  130. Who Is Running A Nitrogen Push.
  131. A4 with Nitrous
  132. 400rwhp+100shot tnt
  133. Making as Direct Port from TNT Kit?
  134. I would like some feed back on ?
  135. where did you put your bottles, switches and purges?
  136. which pills to use for a 250 shot in a NX shark nozzle.
  137. nx n20 pressure guage no worky!
  138. Fire & Ice controller?
  139. Window switch vs. rev limiter
  140. TNT Nitrous Kit SPECIALS
  141. Got my pocket bike N2O From Dave!!!
  142. newbie here..who sells the most affordable 100 wet kit?
  143. What jets to use for a 125 shot!?
  144. Anyone running Zex wet kit???
  145. What do you use to retard your timing?
  146. TNT F2 users!
  147. Fuel system for 800+rwhp?
  148. 100-125Dry and 100-150wet systems
  149. TNT wiring ? PLEASE!!!!
  150. just to make sure...
  151. nitrous dont spray? i dont know
  152. Motivation: your opinion on nitrous results
  153. Reminder..FREE KIT!!!
  154. 5177 and split the noids?
  155. My first N2O experiance!!
  156. NXL Jetting
  157. Nitrous -- Spark Plug Question
  158. ANyone use breathers (PCV issues) with nitrous to vent pressure???
  159. Jet pattern & Big Shot Questions
  160. Is there potential problems spraying through the LS1 intake?
  161. At what temp is a n2o bottle unsafe?
  162. Jet Question??
  163. H & C + 150 shot...exhaust popping under...
  164. 150 shot w/ low bottle pressure
  165. Does the TNT F-1 come with n20 filter?
  166. question about the ZEX sparkplugs
  167. Plug question
  168. How to hook a Fuel Pressure Gauge up to NXL?
  169. opinions on cold fusion
  170. question about the bottle
  171. New to the LS1/6, few questions about N20 DPI setups on these motors...
  172. 860 Bottle Nut
  173. Walbro Pumps!
  174. bottle valves?
  175. need help installing, did search.
  176. Jetting the NX MAF kit?
  177. Those with Timing Tuner, please chime in...
  178. Nxl Re-testing Complete
  179. venom kit
  180. Power Ring or NX MAF kit
  181. OOPS I left my bottle open.
  182. Any tips on buying...
  183. How to protect an engine from missed shifts
  184. Anyone put their bottle on the trans tunnel?
  185. nitrous location????
  186. who is redLS12003 ??
  187. Nitrous Solenoids Question
  188. 10% sale at www.coldfusionnitrous.com
  189. F.Y.I. Black NX bottles
  190. 860 performance in GMHTP!!!!
  191. question about when to spray
  192. Wet? Dry? Or Direct?
  193. Nitrous Outlets Wet Nitrous Systems.....
  194. NEED HELP Goin to the track on friday
  195. Racenet EFI Wet Nitrous Kit?
  196. Bypass question
  197. Converting Dry to Wet
  198. Nitrous Experts - Does my wiring diagram look right??
  199. Methanol Injection With Nitrous?
  200. "nitrous john" gossen dies
  201. N2o Solenoid leaks?
  202. NOS 5177 kit conversion?
  203. Heads/Cam + All Bolt Ons Nitrous Noob.
  204. M6 Guys, How much hp = your ET
  205. nx wont warrenty brand new solenoid
  206. what should i jet for? need some help.
  207. Problems with sensors and NX MAF KIT
  208. NX Rail upgrade for DP kits
  209. How does your system know when...
  210. Selling my TNT kit
  211. NX jet sizes please.
  212. NX accumulator questions.
  213. LT1 Kit
  214. What are some typical numbers for these setups?
  215. Court Is Over
  216. Nitrous Converion Kit From Card To Ls1
  217. Hooked!
  218. 5177 question???
  219. timing tuner????
  220. How bad for the motor is it?
  221. Plug Color???
  222. Direct Port -- TNT Ring?
  223. 10.41 @ 130 with 125 shot NX MAF kit
  224. NX Tpas wiring question
  225. Where to get a good LS1 Window Switch
  226. Mutt wet kit
  227. Nitrous PROBLEMS!!
  228. Need Nitrous Help
  229. plug gap on NGK TR6???
  230. direct port ?s
  231. Newbie here with some questions
  232. What else for an A4?
  233. 5177 People Inside...
  234. hot rod april 2004 page 84
  235. two staging it how to
  236. Direct port problems, help.
  237. NEED Help!!
  238. Nitrous refills in Minnesota??
  239. Would spraying through ONE TNT nozzle be = to spraying through an NX shark?
  240. <PIC> What happens when you leave a bottle cracked open
  241. TNT F1 directions
  242. nitrous sponsors
  243. Anybody fouled up a plug before?
  244. TR6 Gapping
  245. What to upgrade before a f1 tnt kit?
  246. Solenoid Exchange Program Is Active!
  247. Pocket Bike Nitrous Systems! We have them too! $189.95 free shipping
  248. Beginner Kit: 5177 or Halo Kit
  249. n2o noob, have NX Gemini questions, any experience with?
  250. Tuning Question
