View Full Version : Nitrous Oxide
- Tell us about your system
- need a nitrous fitting
- pin # for tach install?
- Finally Hit the juice (kinda long)
- injector question
- TNT Dyno Graphs
- TNT WOT micro switch
- Paging AZZKICKER.........
- Just adjusted FPSS and I think I need some help...
- Puddle the intake??
- Need some advice
- Well I joined the dark side
- MSD LS1 conversion
- mallory wiring?'s
- What size injectors necessary?
- NOS and Dual Cutouts???
- How much is the TNT wetkit??
- Thinking of selling the AZZKICKER
- Descreened 85mm SLP MAF Question
- Nitrous experts...Fuel System Question
- Hey nitrous junkies....Fireball's N20 kit up for sale
- Would this be a problem.....
- How does the NOS brand RPM activated switch compare to a mallory??
- IS the NOS bottle heater not good enough for the 15lb bottle?
- useing propane
- TNT TPS Switch
- Just ordered TNT F2!
- Times w/100 dry shot, M6, with simple bolts ons....
- Cam question
- RPM window switch wiring for '00 Truck
- NOS in, First ride today
- My FIRST ride with my TNT system
- How long does it take your NX bottle heater to heat a bottle
- Merry Christmas Nitrous Junkies!
- NX wet Jets - - what numbers = what shot?
- Got the juice bug again! What kit NX wet or TNT?
- NOS remote bottle opener instructions.
- Need Help Wiring NOS opener to Nx Switch?
- tr55s and n20 use.....
- which purge and bottle opener to get?
- Will a 150 shot get me into the 10's
- What fittings come with the Nos remote bottle opener???
- $900 bucks a good deal for...
- Pics of NOS inline pump install
- Nitrous is a GO!
- N20 Install Finally
- I just had a f'ing wicked idea for a stealth setup!!!
- does ls1tech.com have an AAG forum?
- What can the bottom end take?
- dual 'noids
- purge systems
- Nozzle pointed away from maf???
- A few questions about Nitrous
- Anyone using alcohol instead of gasoline for fuel enrichment?
- do i need a window switch?
- Purge question...
- Fireball, about your schematic????
- Finally an intake that won’t crack….
- Bottle heater that works off pressure
- 125 hp Jets for TNT Wet??
- 100 SHOT TNT, Yes or No?
- why 5177?
- Fuel Pressure Guage PROBLEM!!! HELP
- who makes the best dry set up?
- 10.62 @ 130mph w/a TNT 100 Shot...Some Don't Believe The Jetting is Truely a 100 Shot
- TNT 100 vers NOS 100 – VIDEO inside
- ST-3500 with a 150-200 shot?
- First time to spray ??
- ***Paging Reckless***
- Wet Twin Gemini NX kits......post your pics!!!
- What happened to TNTs website?
- window switch
- Anyone have the Cartek Nitrous IAT mod?
- Best plug wires for N2O system
- My TNT Pix! (Purge, Smokey Burnout Etc.)
- Pics of my N2O system for those who asked
- question for the colonel...
- Where can I get this NOS part?
- RICE LOVERS UNITE!!!!!!!!!
- Just got nitrous...question about my spark plugs
- Fuel/Air ratio when using Dry kit on stock engine?
- converting the NOS dry kit into a wet kit?
- What size is the bottle nut on NOS Bottle?
- Moving boost related stuff
- Changed my name from Black LS1 T/A
- Finally got a purge video...
- 2-Stage Suggestions Needed
- Bottle mount Q's
- Where can I get a generic NOS relay?
- NOS & H/C?
- Show me your TNT install
- NX wet kit users, i need help
- I need the NX Remote Bottle opener wiring diagram?
- What is the 100 jet for the 5177 kit
- I have a question.
- What is the ideal compression when spraying 200 to 250 shot?
- Anyone running a direct shot on the manifold?
- Putting N2O system together need advice.
- I need the NX bottle heater schematic and Purge Schematic!
- TNT or NX??? Please help!!!
- People running 150 shot, what converter are you using?
- Solenoid redundancy ?
- Best way to test the Window Switch????
- favorite dry N2O system?
- Is a TP Extreme 4400 to much stall for a TNT 150 shot?
- We need a solenoid mount like the C5 for the TNT wet kit!
- NX Install On My SS(Pics)
- O-Ring the block, cost?
- Anyone with an MSD window switch Need ur Help
- Anyone have pitcures of a NX wet kit installed???
- How much timing is to much
- Question about converting dry kit to wet...
- Pros/Cons -- Inline pump vs Intank pump
- FPSS question...
- I have problems.
- Wet F2 or F1????
- would having plugs gapped WAY too narrow cause me to run rich?
- Just got a 5177 kit....got a couple questions
- Juice question?
- Ok got a maf/MAFT problem
- How big of a dry shot with SVO 30 #/hr injectors?
- how much nitrous can a 99 stock fuel system take????
- Is this the answer to out Timing/Knock Retard issues?
- Is a Walbro 255 Hi Pressure intank good enough for H/C/N2O?
- How do I inspect my solenoids?
- Does Nitrous effect compression?
- First time hitting the button.......what was it like???
- Adapting an L98 NOS system to an LS1
- hmm... o2s read .998-.999 on the top end on a 100shot??????
- Superchager, TT's or N2O for a daily driver?
- Newbie Nitrous Question
- Are .36 jets a 150 shot for the 5177?
- MSD Ignition needed or not needed????
- Best Nos Cam for a juiced stock motor?
- Question about a broken NOS line?
- What should I get???
- anyone???
- Just got the TNT F1 kit
- AZZKICKER..tell me about your fuel system
- New #s with the TNT kit on my H/C/I SS M6
- Sorry, but- DIFF BETWEEN WET NOS AND DRY?
- bottles in hot temps
- What is AGOSTINO doing to their heads???
- Fuel System for 600rwhp
- HPP3 opinions...
- Help me gap my plugs........
- Separate forums for Boost and Bottle
- Nitrous cheater system under intake manifold?
- AeroSpace Components Billet bottle bracket... worth the $$$?
- .035 Gap on TR6's for my H/C/Spray?
- OK someone tell me about a TNT wet kit??
- NOS???
- Bottle heater:
- Hit the TNT 100 shot with the New Macs Today
- Two technical questions, experts needed.
- Should I stay with my B1 Cam with my nitrous setup?
- FIREBALL or anyone else.....HELP!!!!!!
- problems wiring my wot switch (on gas pedal)
- Autolite 104 vs NGK TR6
- Times to expect from 150 shot????
- Need help w/the accessory Switch
- Tips for installing a NX wet kit
- Help!!!
- Ported my maf and went for a spin
- Pics of my N2O Install
- Which window switch to get??
- Installed NOS inline and Macs
- Soid or hydraulic cam for nitrous
- TNT 100 shot with a Yank 4500...
- where to mount nitrous switch
- wiring ??
- 58 HP off 125HP Shot with 5177, Dyno graphs within!! HELP ME!
- 2002 on a 150 dry shot???
- What happens if you get knock while on a 100shot
- HAHA, Just ordered my TNT Wet Kit!!
- How much spray?
- Bottle heater help...
- TNT F2 wet kit.....progressive controller?
- Fuel pump for 200 shot?
- blown fuse??
- Looking to start a TNT N2O Kit group purchase.
- 9:1 Compression and Nitrous ???
- How do I check my FPS switch
- Would it be alright to.....
- HELP...150 shot Surges really bad, but 100 shot Okay??
- All A4 guys with N02 get in here
- Surging Fixed, Misajusted Pressure Switch
- I HATE DEALERS I NEED HELP
- Best Nitrous set up for stock bottom?
- Post your ideas of the perfect nitrous setup:
- Nitrous cams... How big for stock cubes?
- Picks of a CarTek Nitrous install
- Custom Fuel System
- Injector size? for 2001 SS
- Quitting Turbo - Going Big Shot - Few Questions
- Another fuel system question! I know, I know! :-)
- Who's making over 450rwhp?
- Nitrous gauge questions!
- Generally, what's the average price for N2O install?
- N2O and hotcam
- 500+rwhp w/ a ST3500 through a 4L60E?
- New single Injection Picture with Clear Lid
- ?? about guys blowing out their MAF and intake w/ a wet shot
- Bottle blowing up
- Blew a fitting right off!!
- OK your thoughs on porting my MAF
- Can I use my purge solenoid as an alternative solenoid?
- Newbie to LS1 Tech! 1st post with question!
- arming switch question ?
- Educate me on the TNT PPE
- Spark gap.. Friend thinks .32 Please advise.
- Where do you shift on n2o?
- Stock injectors ok for H/C/I---TNT LS1???
- How much to get gears ?
- Wish me luck
- highest stall with NOS????
- need help?
- Happy Thanksgiving from the moderators
- A4 drivers + window switch
- 10.70 Video with TNT shot!
- TH400 Cheetah Shifter, and Nitrous Switch's pic!
- Aeromotive Fuel Pressure regulater Pic!
- 1 GAL fuel cell in front for N20 wet kit (Changing dry to wet as well)
- Wet/DRY dual stage
- Ok guys I want all you TNT users to sound off!
- TNT install Woes........
- Paging Harlan
- 524 RWHP/626 RWTQ = My Rear-End Has Left The Building
- Hiding a wet shot...
- ****** MARKER *******
- NOS 5177 15 lb bottle fit ok in spare tire well?
- surging/lights dimming on n20 shot
- Will open headers make me rich or lean?
- New Best! 10.70@124.79 TNT 150 shot!
- What would be an ideal set-up for a 200 shot of spray???
- ok 200 shot finally caught up to me....
- Anyone got a install info for MSD window switch?
- What to gap NGK TR 6 at?
- Spray and Fuel Syetem on Heads/Cam cars
- FI/N2O Guys.....your comments are needed
- Now nozzle location for dry kit. Single injection
- N2O Cam Question
- Great Forum!
- New To Nitrous... Need help.
- Any word on the MAF sprayer?
- Is anyone running a direct port system?
- Fastest NOS list here....
- Haveing thoughts of adding a second stage. Any suggestions?
