PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. time for me to spray
  2. Venturi = Boost?
  3. what plugs with FJO controller?
  4. New noids and nozzle installed,What you think
  5. bottles
  6. THANK YOU Cold Fusion Nitrous
  7. Nitrous Upgrades???
  8. Few more steps!!!!!!
  9. what wires are you using
  10. Advantages and Disadvantages if SS vs Aluminum lines
  11. What pills (NX maf kit)
  12. how much nitrous on stock 99 trans am
  13. new test:nx noid vs dynotune
  14. hidden system purge?
  15. tnt 2 stage ?
  16. nitrous for your speakers NX get in here
  17. My doesn't like nitrous anymore!
  18. Vette bottle mounting location?
  19. N20 Relay help
  20. Nitrous and cops. What kind of punishments?
  21. Parts to convert single stage wet into dual stage dry/wet?
  22. can a 15 lb bottle fit in spare tire area?
  23. distribution block question
  24. Is dry safer than wet for a 100sht?
  25. nitrous fill station
  26. just got the 50 dry shot working last night!!
  27. Which window switch?
  28. Wheres the plate kit pics guys? WTF?
  29. timing tuner/electronic tps help
  30. Tried both stages of dry tonight.....
  31. Need help figuring out wiring relays
  32. building my own direct port plumbing questions
  33. which direct port?
  34. nitrous ?'s
  35. Help with NOS 5177 Nozzle
  36. Looking for PDF for the timingtuner
  37. change jets?
  38. what dry shot with this set up?
  39. nx 90210-10 wet kit to dry?
  40. direct port nozzle question
  41. Purge Ideas/Pics
  42. Need help on NX jets
  43. Polyline Purge
  44. Fuel Pressure?
  45. 140k Bottom end Still Sprayable?
  46. Need C5 direct port pics...fustration sits in quick...
  47. Best nitrous guages?
  48. Hard hitting Dry kit?
  49. Idea on prices
  50. 125rwhp (dry) too much for stock fuel system?
  51. T-Rex cam and Nitrous
  52. NX Bottle Label
  53. Dry 50 shot...
  54. digital msd window have first gear lockout?
  55. Moving the IAT? good or bad?
  56. ? about NOS
  57. What are your thoughts about the NX Dual Nozzle, Smooth bellow kit?
  58. NX jets
  59. Largest shot through Halo?
  60. 5177 kit jet size
  61. Diamond or Mahle forged pistons...how much spray?
  62. Any pics of the TNT F2 power ring installed?
  63. Tune Question
  64. Visited DynoTune Last nite
  65. N2O Busting MAF wire
  66. NOS NOSzle kit for sale!!
  67. More parts!!!!!
  68. some issues
  69. FAST 90mm Intake - Burst Panels?
  70. optimizeing my dry kit
  71. NX maf ends...
  72. Is 1/4" line sufficient as a stand alone fuel system for 250 shot?
  73. dfi gen 7 cntrling nitrous?????
  74. quick ? about NOS jets
  75. Check this out!
  76. Nitrous fill station ?s
  77. Halo Bar vs. Dual Nozzle?
  78. max timing retard
  79. Question on psi guage that came with kit
  80. Anyone running wet with the MTI G1 Cam?
  81. whats needed for a 100 shot wet?
  82. wet kits
  83. February Nitrous Specials!!!
  84. yet another newb with a couple ?'s
  85. Nitrous Instal Gone Bad Help!
  86. My fuel trims are way off...
  87. Custom Dry Kit
  88. direct port lines/block/nozzle questions
  89. For thoes of you who havent met my dog yet
  90. timing issue
  91. BMN Controller
  92. Nitro Dave's bottle mount
  93. Sparying with this cam...
  94. Dual stage question- Dry shot out of the hole?
  95. nitrous gotta go....
  96. Pictures
  97. where shoud i hide fpss on dry kit
  98. which is the best spark plugs for nitrous
  99. will inline work with 150?
  100. direct port for FAST
  101. new to N2O
  102. Compression Test first or Spray and Pray?
  103. Nitrous activation switches/panel
  104. wet with bbk vs. ls6
  105. purge valves
  106. Holley black pumps?
  107. Harlan Window Switch?
  108. NX and Nitrous Outlet
  109. TR224 and Spray
  110. Well decided to go to.....
  111. 2 nozzles vs 1 nozzle any benys?
  112. jet size
  113. MS3 cam and PRC DART heads
  114. biggest shot question
  115. Sprayed for the first time today! WOW!
  116. Nitrous wet kit prices?
  117. nitrous newbie...
  118. Dry Kit Tuning?
  119. Purge valve question
  120. buying nitrous
  121. can i spray on my cam
  122. I need jet sizes for nos
  123. fuel pressure saftey switch
  124. Some Guidance?
  125. AFR going nuts N/A!!!!!!!!!!!
  126. what will i run?
  127. should i back it down
  128. how does the length of line AFTER sullenoid effect performance?
  129. What AFR do yall shoot for a 100HP wet shot?
  130. Guys with remote pressure gauges?
  131. Problem after TNT wet kit install..
  132. Guage wires?
  133. blanket
  134. i have bmw e30 m3 nos kit installed
  135. Ls2 Power!
  136. Where to run main N2O line?
  137. Installing MSD Inline booster pump
  138. how much to spray on a cammed car
  139. window switch tach input...
  140. Only Motorhomes in GA! N20 illegal
  141. dry kit on a LS2
  142. Hidden Direct Port from Car Craft
  143. For all you bench racers
  144. Whats more vital ? Bottle guage or Window switch
  145. How streetable is nitrous actually?
  146. advice on the zex kit
  147. NX purge solenoid orifice
  148. Nitrous Guru's needed
  149. Roll Cage mounted bottles...
  150. Best/Cheapest Bottle Heater Kit
  151. freeze and fill method?
  152. A little twist.
  153. mounting
  154. Direct Port... hard vs. braided lines
  155. what else???
  156. nitrous ???
  157. Ordered my new intake. adding stage 2 soon!!!
  158. NXL kit question
  159. Bellow for TNT kit???
  160. I want to build one of these
  161. Does anybody have any pictures of any kit on a camaro/transam
  162. expected1/4 mile time??
  163. 1/4 mile times??
  164. FJO Controller Question
  165. Purge solenoid ?
  166. New to Nitrous
  167. New Drink Fountains at Work.
  168. Fire & Ice bottle heater blanket?
  169. Another Custom Directport..
  170. Lean Spike?? Bigger Rails?? More Fuel??
  171. Nitrous Questions!
  172. How much can the Walbro push?
  173. Nitrous newb (already searched)
  174. Stock Rev Limiter
  175. M6 guys: At what RPM do you start to spray?
  176. Help!
  177. Flow pics
  178. ZEX smart shot...wet...or dry
  179. finally ordered my kit
  180. Dyno Tuning with Nitrous
  181. Progress Freguency explained. maybe?
  182. Wot switch voltage ???? -9?
  183. TNT install pics
  184. 150 or 200/shot
  185. Piston Ring Gap
  186. Throttle Position Sensor Location
  187. New spot for single fogger?
  188. Dry kit fueling
  189. Playing catch up
  190. Cleaning a Bottle Heater/Blanket melting
  191. VID: Honda that could... 250 shot to a stock honda
  192. FJO 2stage Mini-progressive Review...
  193. Finally Got My Car Allmost Back Together
  194. nitrous pressure gauge?
  195. Talk About Cust. Service (NXRICKY)!!!
  196. cam help please
  197. N20 and methanol wet system
  198. Wet or dry on stock?
  199. Oppinion on cam please.........
  200. Need FJO Pro. Wiring help!!!!
  201. Nitrous backfires
  202. Can a relay go bad?
  203. bottle size
  204. wet. vs. dry ( first shot )
  205. 2 Stage NOS on LS2
  206. Anybody using the NX NXL kit? LS1 or LS6?
  207. fuel rail question
  208. NX Maf Kit on a GTO
  209. RAM HD+Fidenza+200 Shot= OK?
  210. Maf less tuning
  211. Who mentioned to shift earlier when Spraying???
  212. N20 question
  213. Very Basic Nitrous Question
  214. Question about NX kits
  215. dyno sheet with 100 dry shot, low power?
  216. Dave....Solenoid info please :)
  217. Finally made the 10's...NPB
  218. N20 and a stall
  219. what all needed to run a 100 shot wet!!
  220. how to install nitrous?
  221. Painting A bottle?
  222. Those of you with plate systems post installs PLEASE
  223. lots of extra Nitrous parts Cheep
  224. 75 shot = 10 bolt
  225. which plugs #2
  226. DynoTune's New 300HP Wet/Dry Two Stage Kit
  227. How much should I ask for my used 20920-10 NX kit?
  228. retard timing?
  229. Running NOS 5177 dual stage jet sizes?
  230. Dynotune N2O kit - which solenoid is which?
  231. How much nitrous?
  232. fuel pump
  233. What plugs with a 200 shot?
  234. NOS Solenoid Frequency!?
  235. 200 shot?
  236. Questions
  237. Daves Plate system vs. NX MAF
  238. Boost-A-Pump Wiring
  239. Nitrous Direct Goodies Hot Off The Press Or Sewing Machine?
  240. trap/et time
  241. Black heaters??
  242. what amp fuse?
  243. Puddle-ing? This Video has nothing to do with nitrous sort of...
  244. small bottle in air bad location?
  245. who sprays with stock head bolts
  246. Going Fast
  247. NOS Plate
  248. can you run a half wet/ half dry shot.
  249. solenoid mounting?
  250. Can I spray a dry shot with a wet nozzle?
