PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. What plugs for me?
  2. Okay to run two solenoids for dry shot?
  3. fuel pressure and jetting question
  4. New to Nitrous
  5. Running a NX wet 100 shot....power?
  6. The last of Nitrous Outlets 90mm collar!!
  7. tps switch
  8. Suggestions on Nitrous Setup for 408
  9. Harlan Window Switch Wiring Question...
  10. Here's What I Got.
  11. Which timing tuner are most people using?
  12. Where to get the cheapest universal dry kit?
  13. NX shark nozzle – what sized nut / thread type and washer to use?
  14. Alternative to a Blown down tube
  15. got an idea
  16. HELP: wet or dry shot for my supercharged Mercedes
  17. Nitrous fitting question, identify this part (PIC)
  18. HELP NX wet kit install
  19. Disadvantages of nitrous fuel cell in rear?
  20. what are yalls opinions on MSD digital Window Switch?
  21. Tech Tip "Pusher systems"
  22. what would happen if i sprayed a fm14 112
  23. quick jet ?
  24. Building 408 For N/A Now/Nitrous Later?'s
  25. *dynograph* am i safe to run nitrous?
  26. WTT: Sport Comp Nitrous Pressure Guage
  27. Noid question
  28. .093 inch N2O Jet in NX?
  29. Got the window switch working, but I have another problem.
  30. Purge Question
  31. Nitrous Problem
  32. good nitrous cam?
  33. Speed Density Mode and Dry kits
  34. Routing Nitrous Line
  35. What ever happened to the NX 85mm LS1 intake?
  36. Can I spray 100 shot with this NGK spark plug
  37. For a friend
  38. Edelbrock Bottle Mount
  39. Opinions PLS: NX MAF vs TNT
  40. Noid Pictures
  41. Quick Question
  42. How big of shot before you had to start pulling timing?
  43. Dry 100 shot, what else should i do to be safe
  44. Nitrous Question
  45. Need an All In One Box....
  46. Best NOS Install Shop
  47. 200 Shot
  48. Nozzle placement
  49. Who makes a 120 Volt AC bottle heater to plug into my house outlet
  50. a way to pull timeing without a controller
  51. 8-second nitrous lt1 rumors
  52. Mercedes superchrgd ?
  53. nos 5177 jet placement
  54. anyone spraying with a Vig????
  55. anyone need a smooth bellow for your nozzle?
  56. jet ???????????
  57. NEW window switch from FJO.
  58. DynoTune Fully Automatic Nitrous Bottle Warmer Kit – $119!!!!
  59. Nitrous kit help
  60. Looking for a tuner
  61. unusual check engine light after using N20 on 2004 GTO...
  62. Another "where do I mount this" question???
  63. These pictures might help convince someone that Nitrous is safe, done properly.
  64. How can I change NOS heater on/off temps.
  65. Which bottle heater will stay around 1100psi?
  66. wiring the FPSS on a LT1?
  67. NX MAF kit question?
  68. Which kit?
  69. 75 shot question....
  70. Blow Down Tube ?
  71. Will I be safe
  72. How much can i spray ?
  73. purge question need some help
  74. Local SoCal - Wanna trade bottles? My 15 for your 10!
  75. Choices in window switches!!!!
  76. How will a car run....
  77. LT1 Electronic Nitrous TPS Switch
  78. Carb NOS microswitch
  79. Nitrous kick out idea
  80. Any of you guys........
  81. Bottle Heaters
  82. Window switch ???
  83. putting WOT switch under dash (gas pedal)
  84. before or after?
  85. Who sells variety packs off jets?
  86. i think i mounted my FPSS on the wrong side?
  87. mounting the WOT switch?
  88. stock 10 bolt on the juice
  89. Harlen Window switch
  90. Can someone explain this setup to me?
  91. Nitrous Gauge
  92. Help on nos tune.
  93. dyno numbers on a 100 dry shot?
  94. Quick Wiring Question
  95. zex nitrous system
  96. Tech Tip "Fuel flow Test"
  97. Dynotune bottle heater
  98. Optimum engine temp for nitrous?
  99. Switch location??
  100. Tech Tip: Fpss Reposted
  101. How much does a full 15lb NOS bottle weigh?
  102. Racing classes
  103. 20 Shot????
  104. Vararam with nozzles Problems?
  105. NIB NX direct port for sale
  106. nitrous
  107. where can I buy these switches?
  108. sprayed 150 shot on 04 GTO tonight, interesting results
  109. Bottle Mounting
  110. Easy way to retard timing for spray?
  111. Dumb ?, Where are the jets on my Gemini kit?
  112. Nitrous bottle exploded. Why?
  113. How sensitive are noids to heat??
  114. cam+forged internals+150 shot+timing tuner HELP NEEDED
  115. Jet size dry shot
  116. what octane to run for 150 shot
  117. Direct port nitrous
  118. Will I be okay for now?
  119. Z06 and TNT kit Install HELP
  120. How Much Does Your PREMAF Shot Peak...??
  121. Need some help
  122. Need some Tech Ideas.
  123. Ordered my kit from Dave
  124. Would running SVO 30# injectors hurt me in any way?
  125. a dumb question maybe
  126. I need wiring help / MSD adjustable (pill) window switch and NX FPSS.
  127. Completed Sx2 Direct Port on Sheetmetal Intake...Finally
  128. what is the best rear end for N2o?
  129. Got alot of nitrous questions, TNT guys please help
  130. A ? about direct port with inject spacer.
  131. is a 250 shot too much???? for stock bottem end
  132. ok new to n20, need tips on install?
  133. Ramcharger nitrous controller
  134. Need help with cam spec on built N20 402
  135. What shot causes head lifting
  136. nitrous trouble help...
  137. Who sells 1/8" nozzles
  138. injectors on 5177/ dyno results
  139. Accel Digital Nitrous Processor
  140. searched...and left hanging. how to get 100 shot on TNT wet kit?
  141. NX Ricky 90mm Update??
  142. Going to do it
  143. plumbing fuel line
  144. Billet fuel rails and mounting fuel solenoid
  145. Question about the billet mount...
  146. Nitrous Question
  147. looking for a 97 ss black with ttops thanks
  148. TNT wiring Q.
  149. Spark plugs
  150. 5177 vs. Halo Ring
  151. When should I cut off the spray?
  152. Stand Alone Fuel System...LOOK!!!
  153. Nitrous feed line and wiring
  154. Part Number: NX-20109-10 (NX @ nitro Dave's)
  155. fuel pump question
  156. Where Are You Running Your Lines/wires
  157. Timing Tuner question....upper rpm limit....
  158. i need instructions for a dynotune remote opener to an NX switch panel
  159. NX Maximizer Q
  160. Tech Tip "Testing your electrical with all Safety intact.
  161. TNT f1 kit for sale
  162. Anyone with a nos brand remote opener I have a question for ya.
  163. Nitrous Refill Station
  164. Trying to decide on Nitrous Kit
  165. Different MSD window switch pills?
  166. Plugs for Nitrous??
  167. What Gap to Run on a 2003 Silverado??
  168. Plug gap NEEDED ASAP
  169. 150 shot- advantages of DP over wet kit?
  170. Question about wet kits??
  171. Just got my 5177
  172. Does any one know how to set up a LT1 intake for direct nitrious?
  173. Full Bolt ons + heads and cam... Dry shot? or not worth the trouble?
  174. Timing tuner
  175. Harlan window switch
  176. how long did it take to hook up your full nitrous kit?
  177. Went to the dyno...Need advice?
  178. FPSS and rev limiter?
  179. Spraying tnt 100 should I move up to 150?
  180. Purge Kit?????
  181. Pics and a vid
  182. Wiring MSD Window (pill)Switch
  183. Best wet nozzle setup?
  184. In case you missed it....FOR SALE: 12# carbon fiber bottle
  185. factoring in my cost.....
  186. some no2 stuff for sale
  187. More power: No2 vs. timing
  188. My newfound philosophy...agree?
  189. Newb to nitrous, have some questions.
  190. heater wiring question
  191. Can a nitrous bottle blow up?
  192. what is a good nitrous cam?
  193. LS2 Direct Port Pics
  194. How did you mount your solenoids?
  195. Replacing Blowdown tube with ss braided hose, size?
  196. Harlan 2-step Plan of attack
  197. is my cam good for a small shot???
  198. N20 install help!!!!!!
  199. M6 Owners please...
  200. no2 ?
  201. TTP Equalizer v3 cam, how is it on spray?
  202. A4 spraying through shifts...
  203. Does anyone have.....
  204. Aluminum cage bottle mounting brackets?
  205. Nitrous Instructions??!?!?!
  206. jimmy jams controllers???
  207. Tech Tip "Heaters yes or no"
  208. Easiest way to retard timing? Other Q's too
  209. what do you think?
  210. High Octane leaded - O2 sensor Q?
  211. LS1 based nitrous record
  212. NX Rickey
  213. Gotta a question to all nitrous users, curious on how many use safety equipment
  214. When tuning wet kit AFR with fuel jets...
  215. New to Nitrous
  216. Question for N2O people
  217. SES light on nitrous?
  218. Nitrous Express MAF plate system??
  219. March Nitrous Madness Sell!!!!
  220. G5x3 or TTP Equalizer v3.
  221. Mounting Question
  222. G5x3 on a 112 or 114 for best n/a and spray setup?
  223. how safe
  224. who sprays 150 on stock axle and tranny?
  225. Mounting bottle
  226. is it dumb to run 150 shot without checkin your air fuel ratio?
  227. Should I use a Fuse with an NX Bottle Opener??
  228. Best pump for a 150 shot
  229. dumb to run 150 shot without checkin your air fuel ratio?
  230. Pics of my bottle setup
  231. NX Remote Opener
  232. Spark Plug
  233. Where to get jets????
  234. Question on TNT Power Ring
  235. timing in a box... let me make sure i get this straight
  236. Where do I inject nitrous on Z06, K&N FIPK & 5177?
  237. FM9 with a direct port- 150-200 shot
  238. What exactly does a blow down tube do?
  239. nitrous
  240. Timing Retard with NOS
  241. Anyone above 700rwhp/800rwtq?
  242. Help with NX bottle heater
  243. Fuel Pump with nitrous??
  244. Question About Mounting Solenoids
  245. First Spray...Nervous?
  246. are air/fuel gauge worthless?
  247. will nx pills work on the msd window switch?
  248. Fast Set Up And Full Throddle Switch
  249. Sorry Guys
  250. how to improve your nitrous efficiency ten-fold...
