View Full Version : Nitrous Oxide
- nitrous shop in illinois
- couple dumb questions N2O?
- Dumbass problem, cannot get my ball valve to stop leaking
- Question about nitrous tune
- i need a list of most common needed nitrous fittings and accesories,
- NANO On a Banshee
- Damn it, WHY DID I DO IT
- Running pig rich, increase the nitrous jet or reduce the fuel jet? Nano user
- My N2O installHere's a
- Nitrous Outlet 92mm Plate System Issue
- Lights Went Out In Georgia
- Another Spark Plug Question
- looking for spare 10lb NOS Bottle with Hi Flo Valve
- Why won't my bottle heat up
- Convertible guys - where did you mount your bottle? (Pics Please!)
- Bolt ons, stall, 75 pill...
- spark plug ?
- First time in the 10s on 200 shot
- Real world numbers.
- Rebuild Kit for TNT noids?
- Homemade Spare Tire Bottle Mount Pictures
- What plugs/ gap/ size shot are you running?
- Where to mount nozzle on dry system?
- wideband o2 went bad
- It's time to heat it up
- n2o cutoff rpm
- Couldn't get down the track on the jug last night
- Soon to be new best?
- Who is going to LSX?
- Great Nitrous tuner needed...
- can someone help me stop detnating
- Well, Im going to get back to it!!!
- Fire jacket rules... Who knows 'em?
- help with inj. size for dry shot
- gapping tr6's
- Nitrous
- Brand New Autometer Nexus Nitrous and Voltage gauges, Dynotune nitrous control center
- Traction control timing retard?
- Pulled the trigger on the hsw dry plate kit!
- Nitrous cam for a 5.3
- How close to exhaust outlet is it OK to wount WB sensor to?
- Clearence Items @ Nitrous Outlet
- When to use two bottles?
- WIll my 04 z06 handle a dry 150 rwhp shot?
- My switch panel and micro edge
- Taking bets on what my set up willl run!
- timing twister help
- Nitrous Outlets 92mm plate
- Is a hotwire kit and a bottle heater needed?
- my complete Nitrous Outlet setup is done
- New Eye Candy
- tr55s for juice?
- msd 2 step?
- Dual Stage: Plate on top of progressive money maker - analyze my setup please!
- RWHP or Flywheel HP?
- Whats the deal with back cyl starvation under a 150 shot?
- nitrous
- New best .....
- Best nos system
- What do you have your window switch set too??
- What HP should i Expect
- Iridums or not
- Considering adding a 100-shot
- New Best 5.07@139 on 275's
- Nitrous outlet---can I buy a jet pack?
- Manual VB guys: Spray through shifts?
- Gained .5 and 7 mph in the 1/8 on 100 shit, sound right?
- Don't laugh but...
- single nozzle w/ a Victor Jr
- 200 shot, check out my plugs and tune...
- We were robbed and we are asking for your help.
- hooking to streeing
- Thinking about a dual stage setup...idea inside...thoughts?
- Thanks FLP, Finally a Dyno Vid of the new Combo...
- wiring widow switch
- Question about Pill style MSD WS
- nitrous cam
- Nitrous surging, hesitation, hiccup, problems, window tps wiring problems look here
- 12.2 AFR on WB, 100 shot, change jet or FP?
- need help with this new setup
- nitrous jet question
- alternate WOT switch mounting points
- Just makin sure im ready....
- Check My Setup!!
- Anyone putting together a serious N20 motor should read...
- PCV on a nitrous motor.....bad idea?
- Anyone have some pills for the MSD window switch?
- can this be done.......
- 2 questions, window switch and WOT switch
- I keep knocking out #7 plug
- what do i need for 150 shot?
- Using Methanol as fuel for nitrous?
- So Im thinking about stepping into the nitrous world.
- Getting There.... Finally in the 9's
- Buying a Used Bottle, What to Look Out For??
- Wet or Dry Kit?
- hesitation in the kit
- Found a kit is it worth it?
- iridium plug and 100 shot
- Head Gasket selection
- bottle positioning
- got bored...my mind is wandering. idea inside.
- What do I need to spray a TBI engine?
- NX kit with NOS plate?
- 4500 style dry plate?
- lt1 fogger jet placement?
- My nitrous install pics (1st time)
- chacklist for a qucik 100 hit
- 116 fuel vs 93 octane
- Nitrous + Tire ?
- bottle valves
- FS Dynotune Round 2-1/16" Nitrous Switch Center
- Looking for a good kit on a 99 trans am with stock bottom end.Which is the best?
- Delay when i spray
- Front two cylinders leanest on plate setup?
- I hit it w/ 200....
- Harlan 2 Step question.
- What plugs??
- Labor Day Sale
- will a NOS bottle knob fit a NX pure flow valve?
- Fuel Pump
- What is the max for an LS1?
- NANO/dual bottle questions.
- wet shot location question
- what plugs
- TR7 plug right for me?
- Direct port set up.... pics inside
- NEW Autometer Nexus Nitrous pressure gauge
- NOS launcher- who's using it?
- Better to lower F/P or change jet to adjust A/F?
- Standalone / Direct Port
- Anyone wanna play "Pass Time" here on LS1Tech???
- nitrous botle location
- Plug gap on ngk8s!!
- turbocharged + nitrous question
- NEW! The MicroEDGE gets a buddy!
- Newb question. Jet sizing?
- Uncorfortable with nitrous tune
- Got my bottle mounted. ($7 spare tire mount)
- NOS mini progressive and 2 step help
- Just double checking: Lingenfelter 2 step question...
- Before and After (Pic) NANO Install
- 5.3 2008 silverado and 75 hp nitrous
- direct port 4 vs 2 solenoids?
- NOS Newbie bottle mounting Q's
- what companies make the TUNNEL MOUNT BRACKET???
- how and where did you guys move your fuse box?
- nitrous ?
- 175 shot, upgrade pump & injectors?? Suggestions please.
- cometic gasket N2O controller any1 use it?
- Interesting article on Nitrous Oxide
- second stage?
- Direct Port & Bottle Mounting Q's???
- Shark Nozzle on Stock C5 Airbridge
- To TR6, or not to TR6?
- 2 stage nitrous question
- 306 cam+150 shot require more than 93 octane? Also when using racing fuel...?
- 100/125 shot coming - what else do I need
- Will a 7 be cold enough?
- help with nitrous
- Anybody make a "long" nozzle?
- Considering going to Turbo... Nitrous guys i want your opinion
- Spray Intercoolers on P1SC setup
- Nitrous specific parts in the for sale section.
- 200 to a 250 shot...how much more drama?
- NANO's FREE NITROUS BOTTLE SPECIAL!!!
- Few more N2O questions
- Sprayed for the first time.
- All Jets the same?
- Cyl 8 lean can i upjet 1cyl on dp
- what 1/4mi should I run with 75 jets
- Will it make a diffrence??
- Questions on what nitrous kit to buy!
- NA to Spray, how much MPH did you gain on a 100/150 shot?
- CSMRE LT1 goes 9.20@151
- New best on motor then I tried to spray it.
- NOS launcher or NX max 3
- does anybody make a 100mm plate kit???
- What brand?
- timing tuner issues
- NX wet kit install pics!
- i just need more
- Nitro Dave, thanks for the new oil pan
- LMR's Nitrous Firebird runs 8.64 @159mph!!
- 4150 Style kit for sale. Will part out. Price Neg.
- Nitrous problem frustrating me!! someone help me or something!
- 20# bottle in spare tire well
- Nano gains
- Intake Burst Panel for Plastic Intakes
- Stronger bottom end for nitrious...
- Interface problems...
- So I want to hide my zex kit..
- F-body's post pics of your bottles!
- Question about my set up
- Who Has Dual bottle Brackets in the Rear mounted sideways?
- NOS plate kit bog...
- Purge Solenoid Malfunction??
- Quick Nitrous Wiring Question
- can i use these?
- Looking for the ultimate nitrous system. Check it out here
- Solenoid LEAKING
- Nitrious Bottle Install?
- 90/92 set up, which plate size?
- Anyone have an NX wet nozzle laying around?
- Mallory 685 Violet wire only handle 10 amps, fuse possibly needed?
- 90mm NOS Plate ?????
- Looking for recommendations and info, please help
- One bottle ran through it!!!!! Bs!!!!!
- Standalone fuel systems...
- NX 125 shot?
- M6 guys, who are spraying!!
- TR7IX or BR7EF
- Quick question!!
- HSW MicroEdge Controller question
- nitrous stuff
- pleas guys help, microedge and o2 problems
- guys with dataloggers, does your car go fat on gear shifts?
- Sprayed for the 1st time!!!
- switch panel
- Window switch question
- New best in the HEAT 5.40 @ 131.5 mph
- dual nozzle nitrous setups.
- n2o not working first couple trys
- Looking for a n20 kit have a few qeustions
- New Purge setup
- Ideas for blow down tube?
- Adding a 150 Shot....Q1. what shift points best? Q2. How much nitrous can I handle?
- What gains are you seeing over your motor passes?
- Safest nitrous setup?
- Nitrous is acting weird!! Need help.
- 90 mm plate, for wet kit.
- At the track: need nano help
- finally perfected my purge system
- Do it all nitrous controller. Who's using what
- solenoid ?
- delay ?
- Way to rich on spray
- Stock 09 Z06 vs SS big bottle
- 20 pound bottle dimention
- 90mm Nitro Dave's Wet kit for sale
- Bottle Is Leaking Need Help.
- microedge lean cut off.
- Bottle filling questions...
- Is my wiring right?
- question about nitrous parts,,,
- How much timeing do i need to pull??please help
- Q 16 Oxygenated fuel?
- How much can I spray my setup?
- What should I Gap my steel Rings at for heavy spray?
- nitrous nozzel question
