PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 [111] 112 113 114 115
  1. Car still surges on Dry shot!!
  2. Bought the NX purge kit & bottle heater....
  3. bad idea to spray a 111 LSA? or does it matter really?
  4. how important are bottle heaters and purge sols?
  5. Thinking of Spraying the Car.....
  6. Best N2O kit
  7. Bottle Pressure and Fuel Pressure?
  8. Danger of spraying below 2500 rpms?
  9. 'GO' button, WOT Switch mount and FPSS
  10. Where did you Put your bottle?
  11. Design for spare tire well bottle holder
  12. Can i run a 250 shot??STOCK MOTOR!
  13. Nitrous+ T tops = problems?
  14. Do H/C cars not respond well to n20??(car doesn't do what it should)
  15. Nitrous Spark Plugs for Brodix BBC Heads. What ones???
  16. N2O...Crank or Rear Wheel HP?
  17. NOS 5177 purge question
  18. Will NOs jets work with a tnt f2 setup
  19. WHAT U THINK BOUT THIS SETUP????
  20. HC Nitrous. 480 HP, how much more can I run?
  21. What happens if you get hit...
  22. Nitrous maintenance...
  23. Anyone know where I can find a T-Fitting adaptor that fits......
  24. Where do I run my Nitrous line
  25. NX pill sizes
  26. Do you have to use race gas when spraying?
  27. Juicing a 70,000 miles LS1, what do I need to check?
  28. TR55's and TR6's...
  29. What is the Nitrous combo?
  30. Help and questions installing a TNT wet Kit.
  31. TNT wet kit jets?
  32. Spark plug gap?
  33. NEED HELP QUICK!
  34. How could this be done?
  35. Hooking up...BFG Radials Vs. M/T Sportsman "I"
  36. TNT kit doesn't fit??
  37. H/C and nitrous
  38. Estimated e.t , & mph
  39. What kinda power will i make?
  40. do you guys even HOOK?
  41. Need help finding somewhere to install my nitrous system
  42. 300 Shot on 99TA
  43. When to push the little red button
  44. wet / dry dual stage thought
  45. Lost fuel pressure..What to check???
  46. TNT 150itty shots on stock motors......Fuel pumps?
  47. Compression Ratio Question.
  48. People with the Dynotune nitrous pressure guage... NEED HELP!
  49. question on nitrous
  50. blown ls1
  51. NX 20920 Jetting Size Chart
  52. Sprayed car value?
  53. Race Fuel ?
  54. What HP will a 28(nitrous) and a 26(fuel) pill make?
  55. Anyone spraying w/ the GM Hot cam?
  56. 3.9 degrees of KR too much?
  57. what do i need!!!???!
  58. Trying to find a new place for my shark nozzle.
  59. Where can I get JUST the TNT Power Ring and Nozzles?
  60. NEW BEST...1st time out on the 12 bolt!
  61. New RPM based progressive controller
  62. Pics of setups
  63. Rewiring Horn for N2O
  64. Anyone know what Toluene is?
  65. Anyone know what Toluene is?
  66. anybody have a vemon 2000 nitrous kit yet
  67. How to adjust w.o.t. timing with edit?
  68. Should I be concerned?? Blue flame
  69. need inline fuel pump help
  70. nozzles placement
  71. New fuel system for H/C/I + 75 dry shot?
  72. I can't believe it >>>>>>
  73. B4 I GET N20, I NEED YOUR HELP!!!!!!!!!!!!!!!!!
  74. Fuel System Setup that a friend suggested???
  75. Which makes more power??(another wet vs dry argument) Need nitros gurus!!!
  76. Yet another AutoTap question? No really
  77. What happen when you pull too much timings?
  78. 5176 LT1 kit converted to work on a LS1 HOW!!??? help
  79. NOS at highway speed??
  80. Please post pics of where you mounted your NOS tank.
  81. Question for the Kernel!
  82. New Best!
  83. attn:383lq4ss
  84. anyone running 2 maft???
  85. If the engine does blow up...
  86. precautions
  87. Is a 125 shot dry ok?
  88. Gears with N2O
  89. Connecting multiple bottles
  90. Need instructions/install manual for TNT LS1 F1 dry..
  91. What size injectores do I need ?
  92. Looking for a Dry Nitrous kit
  93. How much rwhp would one lose only running 700psi on a 100 dry shot??
  94. Poeple with 150-shot, do you retard your timings at all?
  95. TNT wet kit users, I need some measurements!
  96. WOT Switch Question
  97. N2O question for all ya
  98. What fuel setup, engine mods to run a 200+ wet shot?
  99. are these atap numbers ok for spray??
  100. Let's talk about: Nitrous and LSA
  101. sell me your bottle
  102. Am I right in assuming...
  103. Direct port NOS question.....
  104. Regular N2O maintenance...
  105. TR224...
  106. is 3000-6000 good for a 3500 stall?
  107. Whats the stock 98 injector good up to? do i need more injector for h/c/juice?
  108. nx kit what to do
  109. NX dry kit experimentation
  110. Why does it feel like my car skips/slips when spraying?
  111. People with fuel pressure gauge.....
  112. #1 cylinder burnt plug?
  113. fpss, were to get one?
  114. 900 shot
  115. Back Fires - long but I think worth reading
  116. guys with nx panel switch?
  117. Nos ok on a stock engine???
  118. NOS 5177 orfice size on the solenoid
  119. Need Part# for ASR or Foglamp switch >>>
  120. How much is the TNT wet kit coversion?
  121. is the hotcam good for NX kit?
  122. Lets talk bottle pressure
  123. Need instruction/install manual for LS1 F1 dry..
  124. NEED HELP Purge won't seal...bad Nitrous leak..
  125. Why am I running so lean???
  126. 200 shot ok?
  127. 230/224 .569/.563 111 with nos, please read
  128. Breaking up on high rpm's
  129. Best Times on ALL STOCK Car and Nitrous
  130. NX warehouse
  131. Bottle Locations
  132. Running Rich...
  133. HELP SPARKPLUG ELECTRODE IS BLUE?
  134. yet another question...
  135. are these numbers safe ?
  136. why are my TR6's green!?
  137. Holy seeping solenoids, Batman!
  138. Window Switch question
  139. T.P.S. Activation Switch Wiring
  140. Running lean on NOS?
  141. Anybody run 9's yet with heads/cam/spray?
  142. Crank and Chrome
  143. Two NOS brackets for sale.
  144. NX bottle warmer, how do you have it wired?
  145. How much RWHP can a Walbro 255 inline pump support?
  146. inline pump install document somewhere?
  147. **Plug Indexing**
  148. Which N2o Kit? Wet or Dry?
  149. Trade?
  150. Dry kit and no filter Track times
  151. Is N2O worth it or not?
  152. Billet Aluminum Double Bottle Bracket
  153. C&C
  154. Crank & Chrome SS this Mornnig
  155. Who has the best prices on NX GM EFI kit & Gen X II?
  156. Okay, I'm lost
  157. OK........Takeing my noids apart to clean them
  158. fuel system??? Full boltons +cam+NOS 5177 & 38 pills
  159. Paging 'RICH' from Chicago
  160. ? about nitrous tuning
  161. first time at track with n20
  162. Poll: 150 shot too much?
  163. Can I use NGK TR-55's with NOS?
  164. compu car nitrous?
  165. bottle in rear seat area?
  166. Is this a good price?
  167. ? sbout fuel for a 100 shot on a H/C
  168. OK i wanna spray my vette.
  169. Check out the Group Purchase section for AUTOTAP deal!!
  170. Do I need 104 Octane?
  171. I'm stupid - Help me
  172. no2 shopping list (need help)
  173. Timing drops on the jug. Does this happen with everyone else?
  174. What spark plugs & gap?
  175. Fuel Pressure Safety Switch
  176. do I have too much timing on the spray??
  177. anyone trust air/fuel gauge? is one better than others?
  178. nitrous pressure guage prob.
  179. Fred/Maximer Questions Need some details about capabilities guys.
  180. Just installed kit ,NOW?
  181. Check out the install..:)
  182. anyone seen or have the new NX MAF kit?
  183. Help!!!!!!...........TNT install
  184. Autolite 103 NGK TR6
  185. 38# injectors okay???
  186. NX fogger
  187. what is minimum o2 #'s when spraying safe?
  188. what pressure is FPSS set?
  189. Anyone using diodes in your circuits?
  190. solenoids
  191. Bottle in spare tire well pics
  192. FS: NX Dual Stage with NX Heater, purge, window switch
  193. TNT customers
  194. dry nitrous set-up question
  195. Bought the TNT kit........now I need a bottle opener.......who sells one?
  196. would ls1edit alone without fuel upgrades enough for 100 TNT wet shot?
  197. Cam
  198. I want to upgrade my fuel system before I spray. Shopping list?
  199. Will my SLP 85mm MAF be ok with my TNT kit?
  200. What happens when the bottle runs out w/ a wet shot???
  201. how often is a refill neccessary
  202. spark plug gap with bigger shots of N2o?
  203. Any good places to hide the Nozzle?
  204. With a 100 shot what should one do at the track?
  205. Anyone with Heads/cam N2O please enter..
  206. does anyone here run a Sneeky Pete system?
  207. Dyno pics of NX kit, a little problem
  208. Looking for a couple specific install pics..
  209. Running rich. Will MAF ends lean me out w/N20?
  210. Whats Safer: Smaller shot or shorter duration shot?
  211. A/F ratio
  212. TNT dynos
  213. TNT Install help
  214. What the hell shot is this jet size?
  215. Check my sig and help me out
  216. NOS picture or video wanted
  217. Anyone heard of this? Guru's take a look!
  218. Nitrous Hiding
  219. Need suggestions on complete nitrous system.
  220. can you jet as much on a dry as you can on a wet?(read for insight on this assumption
  221. How to wire a Mallory Window switch with a TNT wet kit?
  222. wet vs. dry system on a Head/Cam car ??
  223. NOS question............I bought kit used have ???'s
  224. Your thoughts on rebuilds and NOS....
  225. Is 6100rpm a little too high for nitrous cut-off point?
  226. Who makes electric botle pressure gauges?
  227. What bottles will work with NX remote opener?
  228. Where can I buy firewall grommets?
  229. Newby NOS ?'s
  230. what is needed to convert my NOS system to a wet TNT?
  231. ok N20 guru's. how about a helpful checklist for those new to 200 plus shots of N2o.
  232. 75 or 100 shot for stock ls1
  233. 100 Shot What Next
  234. MAFT and 100 shot
  235. NOS again
  236. Dry users, Do you leave your MAFT rich just in case?
  237. Dynoed yesterday
  238. Anyone have any good TNT F1 install pages....
  239. Bending pushrods in an A4
  240. NEED ADVICE FAST FROM NOS USERS
  241. Breaking Intakes – It happens!!!
  242. Spark plug gap
  243. best price for tnt kit
  244. Backfire questions
  245. What remote bottle opener will fit a TNT kit
  246. Selling my current converter, what would be a good range to get for NOS?
  247. shot size ???
  248. ALL YOU NITROUS GUYS HOW ABOUT THIS?
  249. TNT customer service rocks!
  250. TNT Kit, is there a bottle opener that works with it.
