PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Nitrous 440
  2. estimate timing
  3. HSW Microedge vs NOS Mini
  4. Kit not fully working
  5. Quick question
  6. Cam
  7. 150 shot gain question
  8. Nitrous outlet halo system??
  9. Nitrous Controller?!?!
  10. anyone useing a electronic/digital nitrious level gauge?
  11. Nitrous kit questions with blown motor
  12. So....was it worth it to add nitrous???
  13. Best Fuel Pump For Current Setup + Nitrous
  14. Noob Nitrous Questions
  15. need dry kit info... fbody ls1
  16. Looking for 8.60's/5.40's on a 300 pill
  17. Stock Cube LS1 6 Spd Nitrous Build
  18. What split should I start with for my nitrous/fuel jets?
  19. relay question (wire colors)
  20. Estimated Cost?
  21. im ready to buy a nitrious kit for my 02 z06
  22. Extremely rich on nitrous and cant get it to lean out...HELP!
  23. nitrous 5.3
  24. What will work with my msd 2 step ???
  25. can i run a 100shot nitrious without useing a wideband?
  26. 150 shot vs 175 shot results
  27. How to control system
  28. Spray on L9H 6.2?
  29. low rpm nitrous
  30. Need some nitrous info please help
  31. 4th gen bottle mount location?
  32. 11.5:1 + nitrous on 93 octane ?
  33. Is 150 shot safe
  34. WOT Switch/Window Safety Swithch
  35. lq9 nitrous setup critique me please
  36. LS1 400 shot GO BIG OR go home
  37. Nitrous Jetting ?
  38. help pricing a used nitrous system?
  39. MSD 8625 Timing Twister
  40. Timing box wiring question
  41. Time for a fuel pump?
  42. nitrous noob with a used tnt power ring, NEED HELP!!!
  43. Nitrous Controller/Pulling Timing help for Nitrous setup
  44. LSX nitrous build
  45. Spark plugs
  46. 4an or 6an feed line question
  47. nitrous in NANO bottle?
  48. Help With Remote Opener
  49. some new pics of my switch panel
  50. Nitrous wiring with LNC-002 and RPM Window Switch
  51. NX fire/ice controller
  52. Going bigger question
  53. nitrous fuel pressure question (pic)
  54. notched pistons..
  55. autometer nitrous pressure gauge help!
  56. Any one need some extra bottles?
  57. What shot can a stock bottom end LS3 handle
  58. Dual stage noid mounting
  59. Nitrous outlet solenoid rebuild?
  60. help, Window switch problem (misreading rpm)
  61. RPM C6Z Goes 8.8@153 with nitrous
  62. Pure Evil - VR CTS-V Coupe, Heads/Cam, Nitrous, pulleys, Weld RTS & ADV1s...
  63. Nitrous plate-ring-fogger
  64. Holley HP EFI Engine Control Units 550-603
  65. Anyone running GM 12622033 gasket for n20?
  66. C5 nitrous install: ignition signal - which wire?
  67. power guesses ?
  68. Nitrous head recommendations
  69. NANO/nitrous jetting?
  70. what are these nitrous parts?
  71. Standalone fpss and fp Sensor questions
  72. Looking for 8.60-8.80@3200lbs. 6.0L Iron Block, 408 stroker w/nN2O. What other Parts?
  73. Plug vs Shot
  74. Hungry for more power
  75. ls3 vette
  76. Progressive controller help
  77. Cometic NOXBOX-1 Progressive Nitrous controller
  78. Can I safely run a 200 shot?
  79. Catch can setups with nitrous
  80. Cam for n2o 421cui
  81. C5 Z06 and a plate...
  82. LS1 nitrous triggering additional fuel and timing control for $50
  83. Pictures of super vic intake plumbed
  84. Direct port on 2JZ-GE with stupid intake manifold
  85. what rpm window switch to get??
  86. Nitrous backfire
  87. C5 nitrous guys come on in
  88. nitrous and dfco
  89. What noids for progressive NOS MINI.
  90. nitrous and breather/pcv set up??
  91. Question on the Lingenfelter LNC2000
  92. Wiring Mallory 685 with pic
  93. Another Beautiful NX Direct Port
  94. what gas in in the NANO system?
  95. Anyone here on Microsquirt and Nitrous?
  96. My N2O setup and story on 2JZ-GE engine
  97. Dry nozzle vs halo
  98. 365ci LS Nitrous Motor Header size
  99. Intake Porn-X275 Style!
  100. Jegs window switch ???
  101. AES is heading to the Middle East for round 3!!
  102. Nitrous 408
  103. Looking to give Nitrous a shot, but have some questions...
  104. thinking of spray
  105. Switches stoped working
  106. Purge not working
  107. Wilson Manifolds Nitrous Pro Flow Programmable TPS Activation wiring
  108. Nitrous Outlet Bottle Trade-In Program
  109. Vengeance Racing C7 | 739RWHP/739RWTQ |Currently the most powerful C7 in the world!
  110. Fuel pump question
  111. New to Spray - '04 GTO M6 H/C/LTs
  112. lnc-2000 wiring diagram for 2 step and timing retard
  113. 2 Stages?
  114. What fuel in my stand alone for a 200-250 shot?
  115. Msd timing retard box?
  116. First time with nitrous, could use some tips
  117. Nitrous Outlet ?
  118. fast xfi dry nitrous
  119. line in
  120. Nitrous help!!
  121. Spraying 200 shot.
  122. 98 trans am with nitrous ( recomendations please)
  123. Need Some Input...
  124. nitrous outlet internal spray bar or direct port
  125. Leash Controller anyone using it on 2 stages?
  126. Thinking of spraying the car
  127. Nitrous outlet dealers
  128. programmer
  129. Do I need a timing tuner?
  130. direct port
  131. Stroker car with dry kit for daily use?
  132. Nitrous Jet Boat
  133. question for Nitrous Express
  134. help on a good controller
  135. 2-step with a wide open throttle system
  136. push button on window switch
  137. nitrous cam gurus step inside
  138. nitrous
  139. Dynotune air fuel lean cutoff switch
  140. My new Holley Hi Ram Setup!
  141. wiring diagram needed please
  142. Nitrous didn't hit...
  143. Nitrous wiring trans brake/ MSD 2 step
  144. Nitrous questions
  145. Stock CI ls1 lots of nitrous e85 help
  146. Standalone vs taking fuel from rail
  147. 80mm BBK manifold, 78mm nitrous plates. Help!!!!
  148. Best Nitrous Brand ?
  149. Anybody? 370 c.i/4150/Super Vic/N2O results?
  150. first time nitrous user
  151. Stroked LS1 with 12.2:1 and 200 shot cam ?
  152. New to nitrous, stock bottom LS1, want to do a 150 plate kit, help with setup
  153. Nitrous help ?
  154. Timing Controller
  155. does headers size matter for a 200 shot
  156. Fuse Box - Fuse location in Diagram
  157. zex 5th gen camaro kit on ls1?
  158. Nitrous LT1
  159. comp ratio vs nos ??
  160. 150shot on jegs converter
  161. Farmtruck and Nitrous Express at PRI 2013!
  162. Carbed LS1 200 shot
  163. what plugs to run and gapping?
  164. Jet question
  165. LS3 block. How much N20
  166. Nitrous Outlet @ PRI in Indy
  167. Best Nitrous Tuner in Midwest???
  168. Nitrous pistons/rods/rings for 250hp shot
  169. NX Express Customer service update
  170. How do my plugs look?
  171. Fuel Pressure Safety Switch
  172. Nitrous help and suggestions please.
  173. difference between ctsv plate kit and c5 plate kit. answers inside
  174. Nitrous intake!! Help or Hurt???
  175. Max shot on DP 102 intake manifold?
  176. school me on progressive control for 6 speed
  177. 150 shot getting knock keep bumping down timing?
  178. Fjo Pmnc problem
  179. 5.3 Nitrous Cam Question on Trex or MS3 cam
  180. 78mm plate to 102mm
  181. what gears and tire size you guys running with your shot?
  182. question on a nitrous plate
  183. Big nitrous guys 300 hit question
  184. 10.27 @ 131, 150 shot, BTR cam
  185. who's running an HSW interface? I need a favor
  186. lnc 2000 mounting
  187. 11.8@115 n/a going to spray a 125
  188. what is up with nano nitrous?
  189. Black Friday Sale!
  190. Pics of plugs. Need input.
  191. 200 shot set up
  192. How much is N20 per lb in your area?
  193. tuned my car 200 shot stock long block video
  194. Nitrous Tune input
  195. Mistakes you made
  196. Nitrous Outlet Stinger Plates are now available!!!
  197. Safe? Or not
  198. 98 Camaro w/nitrous outlet plate 200 shot
  199. Stock block 383 350 shot
  200. I need help guys wiring up nos mini and transbrake
  201. newbie to nitrous have some questions!
  202. 50 shot vs 100
  203. dumbass question...nitrous exhaust sound???
  204. Stock tank for standalone fuel system
  205. Need bottle placement help
  206. rings
  207. Performer solenoid
  208. Meth thru a Nitrous plate
  209. 1 Week Sale! Nitrous Outlet Hot Water Bath Bottle Warmer
  210. Think it should hit mid 9??
  211. 50 shot new PB 10.97 @ 125
  212. would I be able to run nitrous safely with my mods (z06 ls6)
  213. nitrous express question?
  214. Lost .5 and gained 6mph 1/8mile on a 75 shot
  215. LS1 NOS plate and 80mm throttle body?
  216. Newbie S10/5.3 Nitrous/Fuel question
  217. Building my own kit have a couple ?s
  218. FJO Gen 2 early version 5.1 software
  219. need a little advice
  220. SBE Fox Body 5.98@114 63 jet
  221. universal wet kit truly universal?
  222. Ls3 top end on 99 fbody, Need a nitrous plate
  223. Hit the 8's
  224. Low nitrous numbers, where to look?
  225. Read My Plugs from thread below. Cell pics.
  226. Another 5.3 nitrous run
  227. Nitrous help===fouling plugs i think.
  228. questions on nitrous possible build.
  229. Help !!!stock blok big shot
  230. Dedicated fuel cell with race gas questions
  231. Timing tuner n2o controller
  232. What will my Gains Be ?
  233. Pile of Junk- my beater nitrous car
  234. 10lbs bottle question
  235. Question on nitrous hit
  236. Big thanks to ATVRacer, Carter, John at Nitrous Outlet
  237. Few pics of how its turning out
  238. new to nitrous need some help
  239. Time for a 2 step
  240. New track results 10.61@127. 150 shot
  241. Bumped up my shot, getting a flashing SES light
  242. Nitrous: Fastest way to kill your car
  243. nitrous noob... big question!
  244. Plug pics....what do y'all think?
  245. New PB at the track on the 150hit
  246. Need Help Urgent
  247. N20 controller recommendations
  248. Advice
  249. Nitrous Outlet__ 104 / 156 gain on a 100 hit from nitrous outlet
  250. Get Your Nitrous Outlet Shirts, Hoodies & Fleeces Now!
