PDA
View Full Version : Nitrous Oxide
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Help LNC-2000 hook up on an 04 CTS V
  2. 3 wire nitrous solenoid drivers
  3. 150 shot plug read
  4. Wanna make my own plate kit, suggestions?
  5. (Updated 3/14/17)Do i need to lean it out? 100 shot .4 tenths and only 5 mph
  6. Nitrous timing help?
  7. Lean condition
  8. wiring gurus look plz
  9. 383 stroker stock head wanting spray
  10. Cost of installing nitrous kit and bottle ?
  11. Truck manifold flow limits?
  12. Cost of bottle refill
  13. couple questions going to 243 heads spraying heavy
  14. Nitrous on pump gas to race gas
  15. Distribution limits
  16. Nozzle position from wet kit
  17. Any tax rreturn sales
  18. Fjo progressor
  19. How big of a shot to take down an E85 Cammed Zl1
  20. LY6 Silverado Swap...WHAT NEXT
  21. Lt1 (gen 2) NX direct port install questions
  22. Bottle Bath Warmer & Digital Fuel Flow Tool Sale
  23. Tach signal 2014 silverado 5.3 l83
  24. Should I pull timing with lnc or hptuners
  25. HCI C5Z, can I handle a 100 shot?
  26. What ring gap for 6.0 SBE???
  27. What's the average install cost for a complete Nitrous Wet Kit?
  28. 100 shot results
  29. New to nitrous, have a few questions regarding my set up..
  30. Fuel question
  31. Need Cam ideas for Mavns new project
  32. Nitrous Outlet Stinger 3 plate ???
  33. 150 shot gains
  34. Autometer Nitrous Gauge FS
  35. The Bottle Bundle Sale
  36. Best set up?
  37. 5.3 with factory cam... how much nitrous?
  38. NOzzle
  39. Pulling fuel from rail
  40. Sneak Peek! Nitrous Outlet ProMax Progressive Controller And Interspooler!!
  41. All New Nitrous Outlet WinMax Window Switch!
  42. 90mm plate thickness question
  43. Brand x any good?
  44. Nitrous pop
  45. Nitrous filter fitting
  46. Am I doing this right?
  47. Head gasket?
  48. 200+ shot fuel pump setups?
  49. switch to lockup converter
  50. Couple Nitrous questions
  51. Progressive question
  52. Which Setup
  53. Help looking to slap a bottle on this bitch
  54. Wiring window switch to nitrous kit
  55. Will I be OK with this set up ? 78mm Nitrous outlet plate kit
  56. 11.4 @121
  57. Hit a wall?
  58. 5.3 with 241 heads Total timing on a 150 shot?
  59. Help Identifying NX stuff
  60. Black Friday Sale NOV 21-28
  61. Torco Accelerator/race gas concentrate vs unleaded rave fuel
  62. WOT activation or Button activation
  63. New to ls1 tech. New to fuel injection. Nitrous
  64. Picking a off the shelf cam for 150-175 shot of nitrous
  65. Pics of Nitrous Outlet plastic stand alone???
  66. Nitrous outlet remote opener
  67. Tapping into TPS for WOT switch?
  68. Ring Gap for Nitrous application
  69. 2 stage timing retard??
  70. Thinking about nitrous
  71. Nitrous outlet bottle question
  72. Blowing through converter?
  73. NX jets with Nitrous Outlet plate?
  74. help needed to finish nitrous setup
  75. Looking for Harris Speed Works "The Interface " install tuninģ instructions.
  76. C7 Z06 Meth Spacer
  77. NO plate. SBE. 150 going up to 200
  78. Anyone use an Innovate Powersafe?
  79. E85 Tune up
  80. Low psi nitrous with efi
  81. How many passes do you have 200 shot and larger sbe
  82. A little help?
  83. Timing retard using IAC?
  84. Some experiences on that NOS kit
  85. Low milage + nitrous = danger?
  86. Question for Nitrous Outlet
  87. E85 in fuel cell?
  88. E85 in fuel cell?
  89. Microedge issues please help
  90. Free shirt with $99+ Order
  91. Recently installed Ms4 cam! Can i run a 50 shot?
  92. New personal best with stock shortblock
  93. Anyone controlling their spray with a standalone MS3Pro or like?
  94. What gauges are you guys using or recommend?
  95. Want to spray but worried?!?
  96. Nitrous Outlet Holloween Sale?
  97. funnel jet ?
  98. Nitrous should hopefully be great
  99. New to N20 - LS3 408ci (pics)
  100. Controller change, vs. Jet change for power level.
  101. Nitrous/motor build gurus
  102. Corvette filter/regulator?
  103. Which fuel for nitrous????
  104. how to pull timing for 2nd kit with stock computer and coils?
  105. Anyone see a way to improve this(Nitrous Outlet)/
  106. Ls swap Iroc h/c 150 shot - e85 - first time user
  107. Lean condition Ls1 nitrous outlet plate 150 shot
  108. Help me out 5.3 build
  109. Record holder for t56 on spray?
  110. Need help with nx express plate kit
  111. Throttle cable bracket with 102mm nitrous outlet plate.
  112. How much left with a cam swap?
  113. 98 z28 with n2o outlet plate kit , need help asap
  114. Purge line keeps blowing off solenoid
  115. Plug suggestion
  116. Budget 4.8 build questions
  117. Lnc-2000 backfires when I shift ????
  118. Innovate Powersafe , any users ?
  119. What plate for zex kit?
  120. Lingenfelter RPM-003 wiring
  121. question with low pressure dedicated
  122. 98 z28 m6 lid and catback only supporting mods for 150-200 shot
  123. 450 rwhp n/a full weight what shot to achieve high 10's?
  124. Nitrous venders at LS Fest.. NO/NX?
  125. New F-Body Stock Bottom End LS1 Nitrous Record!!
  126. LS9 - 200 Shot Plug Read
  127. Jetting change?
  128. Initial test runs
  129. Which heads would you run?????
  130. f bosy specific bottle bracekets for trans tunnel ?
  131. Rev limiter using Nitrous
  132. Nitrous Outlet Stinger 3!!!!!!!!
  133. Plug gap
  134. 1998 Trans Am Nitrous 5177 Kit Help
  135. Someone tell me how to get a Nitrous Mother Bottle
  136. Maximum Safe Shot
  137. Cam/heads vs nitrous outlet 150 shot
  138. Newbie to nitrous..want a kit...help please
  139. Question about window switch/TPS activator & NOT spraying through gear changes.
  140. Beta testers needed - Timing retard/fuel ratio modifier module for nitrous etc
  141. [VR] 10% off ALL Nitrous Outlet products through August!!
  142. Nitrous TA and other questions
  143. Which kit?
  144. Special thanks to Nitrous Outlet
  145. Nitrous Outlet Summer Sale!
  146. MSD BAP wiring
  147. Dry Nitrous without MAF
  148. Nirtous Outlet Stinger and a progressive?
  149. Nitrous Consumption vs Fuel Consumption
  150. Nitrous outlet fast 90 plate kit install on my hardtop 99 hoss
  151. Nitrous Outlet System Clearance
  152. Anybody spraying on a circle d 5c converter?
  153. Nitrous refill stations Austin Texas ???
  154. Nitrous outlet fast 90 install? Will stb still work?
  155. Anyway to wire 2 step to clutch so the nitrous isn't activated when nitrous is armed?
  156. Jet chart for dual NX shark nozzles
  157. N2O Leak on NPT fitting
  158. Max Effort Nitrous Cam for a Jet Boat
  159. Nx or Nitrous Outlet
  160. HSW dry kit and micro edge controller.
  161. high miles + nitrous?
  162. wet plate kit, lnc-2000,nos window,pure, line lock wiring ?
  163. Nitrous Outlet Summer Intake Event!
  164. Non resistor plugs with lingenfelter box.
  165. Nitrous Outlet Custom Wiring Harnesses
  166. Enough Timing Pulled?
  167. Looking to see if this is good combo for nitrous
  168. dynotune bottle opener
  169. Nitrous Oxide Systems Mini 2 stage Progressive Controller setup
  170. HSW MicroEdge Controller
  171. Explosion
  172. HELP: NOS WOT/window switch
  173. Did i get jipped on my nitrous fill?
  174. Using a NON-Adjustable bottle pressure switch?
  175. Nitrous dual nozzle placment.
  176. solenoid bracket for four solenoids...
  177. nitrous pressure and solenoids
  178. Throttle cable linkage issue after plate install
  179. Nitrous control by gear for m6 99-02
  180. Where to hook up Nitrous Pressure Gauge
  181. NOS Mini Progressive II Problem
  182. H/C/I 100 dry shot 36lb big enough?
  183. Plugs for a 250 shot?
  184. nitrous 5.3 fuel pump limit
  185. Need a wiring diagram for lnc2000,nos mini, trans brake and n2o kit
  186. Need help reading plugs. Getting mixed signals...
  187. 100 shot PB
  188. How do these plugs look
  189. Can my Fuel system handle a 150 Wet shot?
  190. I need help!!!!!
  191. Bought a lnc but kind of skeptical on using it for pulling timing...
  192. Timing
  193. Nos window switch help...
  194. SBE LQ9 on a plate questions
  195. Post MAF Nozzle Dry NOS
  196. My nitrous install with pics
  197. long shot but looking for pics, vic jr, 4150, stinger plate with hood on
  198. LNC 2000 quick 2 questions
  199. Suggestions on my Nitrous setup?
  200. Fuel pump limits
  201. Which Ignition Signal for NOS window switch and tps box
  202. Is Holley/earls performance a sponsor on here?
  203. Looking for advice, wiring MSD timing twister
  204. Header change
  205. Possibly hurt the motor
  206. SBE Nitrous car goes 9.30 with 4l60e
  207. NOS EFI LS1 plate kit question
  208. 2002 Z28 Camaro
  209. Nitrous install advice c5
  210. Nos questions in my 2002 Z28 Camaro
  211. C5 nitrous feed line routing
  212. Ptc nitrous converter??
  213. Daytona sensors vs maximizer 4
  214. Fuel pump size for nos carbed lq4
  215. Stock Aluminum Bottom End
  216. Nx nitrous plate
  217. first time results from track,now what ?
  218. 12v Keyed ignition source options
  219. Schrader valve limits
  220. LNC 2000 and NOS mini progressive wiring look correct?
  221. New to NOS!
  222. E85 and carb plate system
  223. Nitrous Outlet Open House/ Car Show
  224. DIY direct port
  225. N2O 200 shot budget setup
  226. NX vs NO 90mm plate kit and other ?s
  227. Direct Port or TB plate?
  228. Maximizer 4
  229. Nos, Dry system with Methanol injection
  230. Hidden bottle mounting?
  231. Super Victor fogger
  232. Nos 16080 fuel noid overheating?
  233. Nitrous oxide ls1 wet efi jet size
  234. Nitrous Outlet Plate Kit Questions
  235. Ls 6.0 iron block 150 shot
  236. Enough pump for 460rwhp and 150 shot?
  237. Z06 on Direct port. Timing Retard questions
  238. Wilson crossbar plate on carbureted 4th gen?
  239. Super Vic PIcs
  240. 15974 NOS mini - faulty? wiring? grounding solenoids when armed
  241. So many diagrams!! NOS MINI and LCM-2000
  242. Interested in gauge pods for Nitrous. Which gauges?
  243. What nitrous controller?
  244. The Importance of a Nitrous Filter
  245. Is adding some 104 vp Oxygenated fuel ok????
  246. Nano Fill line -> 6k Nitrogen mother
  247. different nozzle location
  248. hsw solenoids
  249. need help on fuel side adding regulator for nitrous
  250. Nitrous Z06 at the Texas Mile
