PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Pics need ASAP!
  2. How much did I spray?
  3. good place for install
  4. Nitrous Help??
  5. Lights on the FJO?
  6. bottle heater speed?
  7. System putting out way more than it should?
  8. 30lb injectors good enough for a 200 wet shot?
  9. Nitro Dave's Stock TB plate Dyno and ET comparison.
  10. Any negative side effects of a direct port system? Other than $...
  11. Solenoid pulsing very audible, is it a problem?
  12. Adequate bottle pressure?
  13. safely spraying a 200 shot
  14. 31 March and/or 1 April...
  15. bolt on car's time slip before and after nitrous
  16. Spraying out of the Hole! Help me with this...
  17. '04 GTO 100% stock + dry 100 SHOT : No tune?
  18. LT1 direct port kit
  19. Did some Bench Flow testing
  20. Nitrous Low pressure fuel system ?
  21. 94 z28 with 150,000 miles want no2
  22. Bandit finally Sprays at 1/2 Mile Help evaluate (Pretty Cool!)
  23. Nitrous on older car?
  24. help
  25. New Spray Works Great
  26. 2003 ZO6 with MS3 and a 150 shot wet tnt
  27. My cage and shoot is in!!!
  28. might spray my car, what do you think
  29. Post pics of dry installs on a C5
  30. Quick C5 Dry Shot question.
  31. A few Q's about running C-16 and its effect on my LC-1?
  32. My first nitrous set-up!
  33. Limit on stock injectors
  34. pinks/nos
  35. Help with identifiying noids!
  36. How much Nos will my fuel pump take?
  37. 408+ET 245`s+90mm Nitrous Dave Plate=
  38. How long does BH take?
  39. i have been spraying a 100 shot
  40. 125 dry set up
  41. Tony Here is your Pics. 454 C5R Corvette
  42. Possible budget bottle heater (50 bucks max) if this is correct.
  43. 02 Z06 and 150 wetshot + cam
  44. Can I convert my
  45. What Fuel Pump
  46. -3an 90degree fittings
  47. 300ftlbs from 150 jets?
  48. Flow restriction
  49. Fuel Pressure safety switch
  50. bottle valve/siphon tube comparison
  51. Where to mount a 15 lb bottle?
  52. Some hardlined plate pics.
  53. NOS5177 Kit
  54. n20 refill in michigan?
  55. What N2O setup are you using?
  56. Would a victor jr. intake & NW tb be overkill on my setup?
  57. How Much?
  58. Do you need an AN wrench?
  59. why did this happen?
  60. DP set-up on my 6-cylinder?
  61. Just got my laptop- Now i need a holder
  62. Plug question
  63. Ebay: 868 rwhp 408 nitrous car FS
  64. Cam selection (N2O Car) NON DD
  65. 75 dry shot
  66. A few pics of my finished single plane DP
  67. nitrous..12 bolt.. or tranny
  68. Tested my fuel solenoid
  69. bottle heater prob
  70. bogging when launching with juice
  71. what fuel system upgrade is needed for a 75 dry shot?
  72. n20 backfire
  73. NX's "NXL" System
  74. High Compression and a 200 shot
  75. Nitrous Help
  76. New Noyzee racing mascott!!!!!!!
  77. Nitrous System Help Please
  78. How important is bottle angle?
  79. For The racers!!!
  80. FJO to Tune out Lean Spikes
  81. Nitrous on the way!! Couple questions...
  82. >Nitrous spark plug experts in here<
  83. bottle opener
  84. when to spray
  85. 224 581 cam and 5.3 heads....how much nos can?
  86. FJO WB Single vs Dual Channel System
  87. Ready for an upgrade 75 to 125...
  88. New FJO installation and new bottle pics :)-
  89. TNT ring ?
  90. sc ws6 question.
  91. Help on new NO2 system
  92. Will the Tranny Hold Up?
  93. How do I remove the siphon tube from a NOS 15 lb
  94. LT1 switch panel
  95. What should I be expecting?
  96. gonna let the 150 shot rip soon....
  97. Blowdown tube help
  98. Nitrous kit need help finding.............
  99. hey guys new to ls1 tech have a question
  100. NOS and My tranny?
  101. how much nitrous can go in a 2 stage?
  102. does nitrous go bad over time
  103. Fuel questions
  104. Bottle Jackets
  105. Wow!!!
  106. wet? dry?
  107. How to??
  108. Any dry kits rated @ wheels?
  109. I want to spray but....
  110. Remote bottle opener decision
  111. Can't find the fitting I need
  112. 50 shot?
  113. Bottle Blanket
  114. Lt1 Fpss?
  115. Solenoid "ON" status LED
  116. Need a Good NOS System
  117. thinking
  118. help with 2 stage dry kit (diagram inside)
  119. NOS 125 Dry questions
  120. OK back to the dry problems
  121. How to hook up a FPSS
  122. DP almost finished
  123. Bottle Heater Wiring Question
  124. Why Doesn't EVERYBODY Run One?
  125. Finally found out Why the Dyno Mule DIED.props to GM.
  126. NOS 5177 question
  127. What Can I do
  128. Dry guys which way do you have your nozzle pointed?
  129. picked up 1.3 seconds and 12 mph with NX 100 shot
  130. cam with 125 shot?
  131. Anyone running a Zex kit w/a digital window switch?
  132. This is gonna sound crazy, but....
  133. My Plate Install pic's
  134. rpm question
  135. bottle mounting on driveshaft hump
  136. NGK TR6 Plugs ok for N/A?
  137. Nitrous Air/Fuel?
  138. gunna get bottle heater
  139. You can say "NOS" now.
  140. sponsors I need some jets
  141. Need Some Analysis Help
  142. Any switch besides the BMN have 1st gear lockout?
  143. need wiring help
  144. What is a good basic window switch?
  145. Need fitting to mount fpps&guage off fuel rail
  146. NGK TR55 or TR6
  147. AWESOME Nitrous Bottle Sale!! - WOW!
  148. 10LB Nitrous Bottle Sale !!!
  149. 1/8 allen head plug ^ oil filter ok 2----
  150. help???
  151. What is the window switch for in a nitrous kit??
  152. anyone know where to get a 2-5 shot of nitrous
  153. Nitro daves plate Dyno #'s
  154. Which cam would be better for a 100 dry shot?
  155. FAST 90mm with TNT Kit *Pics
  156. how safe is a 50 shot????????????????????
  157. What fuel pump?
  158. N20 Question
  159. Flycut pistons VS N2O
  160. First time with nitrous... check my tenative setup...
  161. Used N2O kit, new wiring?
  162. just a few ?s
  163. Tuning for nitrous w/ only HPtuners and larger injectors?
  164. Tuning with nitrous ?'s
  165. intake teaser shot!!!!!!!
  166. First time I melted
  167. Project 1 Sweet Goat..
  168. Move update info.
  169. 2 stage controller
  170. Should i throw in a two stage for the hell of it?
  171. FJO Wiring Diagram
  172. i need some help
  173. Nitrous Controls
  174. Why does a wet kit hit harder?
  175. Nitrous Dave's Trick Window Switch Wiring
  176. multi stage.. poor mans first gear lockout?
  177. FJO wiring questions
  178. Gained 12mph with a 150shot :)
  179. Where can I get replacement t-stats for my NOS heater
  180. A4 + stock rearend vs. 100 dry shot
  181. where's the thread with the progressive controller comparisons?
  182. New Best E.T Boltons/Nitrous
  183. I need a little more help fellas!
  184. Routing of nitrous lines
  185. Nitrous install question, pics inside, please help.
  186. Rumor has it!!!!!!!!!!
  187. TNT 150 hit on stock tune- discussion
  188. Nitrous scale?
  189. Dry Kits Users Please Step In…
  190. Is 4.30 gears too much for 28" tires and spray?
  191. Stock Clutch vs. Nitrous
  192. ZEX POWER RACER plugs
  193. 90mm Ring? Where can you get one?
  194. Need A New Bottle- Zex Bottle Is The Worst!
  195. What fuel pump for a Wet Kit?
  196. results...eastside shortblock and tuning on the squeeze
  197. Solenoid clicking but not spraying?
  198. Flowing nozzles...tech question for the manufacturers
  199. Plate kit
  200. Msd Digital Window Switch
  201. What's a 100 DS feel like?
  202. Blow down tube for zex bottle?
  203. Powerblock
  204. Pro charger and nitrous a good idea??
  205. NOS 5177 questions
  206. Probable injector size?
  207. nitrous gap, compression, and size of shot?
  208. How much Nitris can a stock LS1 handle
  209. nitrous trouble shooting
  210. lt1 dry kit
  211. Speedtech Manifold Pressure Relief Panel...
  212. Does the FJO have a timing retard function?
  213. Bye-Bye Nitrous; hello Turbos
  214. Help install ZEX Nitrous Kit w/Purge
  215. Does your NX bottle opener get stuck?
  216. is my guage good?
  217. LT1 ZEX nitours kit?!?!?!
  218. 110 octane and spray?
  219. INSTALLTION INSTRUCTIONS FOR...NOS LS1 Dry Kit NOS05177
  220. need help!
  221. need complete bottle valve assembly
  222. C5 Direct Port Take 2.....
  223. Setting up for 5177 Questions
  224. Tuning for N2O Questions..
  225. Bottle Mount Bracket?
  226. Fill station pump question
  227. more progress last night!!! pics!
  228. More progress pics of the stang
  229. spraying 175 or 200 shot on LS1?
  230. Rail to Noid Question
  231. WS/WOT question?
  232. NX Fuel Solenoid Problem
  233. momentary contact switches
  234. NOS Blowdown fitting?
  235. does anyone make a tb plate for fast 90?
  236. 100-75 shot safe on my h/c setup?
  237. Stand alone guys: Using alternative fuel?
  238. Anyone runnig a full throttle Timing Tuner?
  239. Wet kit for Camaro
  240. Closed Friday/ 03-10-06
  241. Hiding the FPSS on a DRY Kit?
  242. got some work done!! progress!
  243. is nitrous worth it?
  244. What do I need to do??
  245. How to wire 2 stages of dry and 1 NX Wet???
  246. My Fjo Ordered! NEED SOME HELP FROM coldfusion -
  247. Nitrous Help!!
  248. Nitrous Stall Help?
  249. bottle size.
  250. Nitrous tuning with IAT
