View Full Version : Nitrous Oxide
- FJO PNMC wont connect......
- Getting warm on 100shot
- What do you guys think of my finished solenoid brackets....
- Harris Standalone guys, what pressure?
- MSD switch
- Guys Im back....50.00 paypaled to person who finds this nitrous backfire *UPDATES!!*
- nitrous help
- 100 shot and MAF
- Nitrous Bottle Parts
- A few direct port nitrous pics
- stupid ?
- jeez did the car pick up alot on a 100shot
- what plug???
- Finally 9's with my 347
- Need 2nd bottle cheap!!!
- Pressure senser and heater pressure switch inline or on bottle?
- weight of a empty bottle
- Tach wire?
- LT1- Fuel
- DUDE WTF!!! 5 bux a pound??
- Which is abetter window switch? digital or pills
- LS7 and spray how does it hold up?
- New to N2O, need some help please
- Max safe shot to run on my truck?
- pipe reamer?
- Thinking about jumping into the nitrous group...
- backfire question
- NX remote bottle opener install help
- Need some Nitrous Express MAF Setup pictures.
- Couple of quick questions
- v6 Firebird w/Nitrous
- Noid problem????
- WOT switch mount? Fpps
- stupid question
- Nitrous question help?
- Trick performance products
- Is this a good cam for spray?
- Some questions about NX...
- nitrous controller for sale
- Need some help...something with my set up not working right
- solenoid fittings
- Question on Msd window switch
- 100 shot nitrous
- just wanted to say Nitrous outlet rocks!!!
- need info: TR6 and LS2
- what makes ZEX soo different or better then all otherS?
- can i leave the bottle on all nite ?
- Bottle Mouting Question..
- Dynotune and question...
- best sparkplugs for 125 wet shot???
- tr55 ok for 100dry shot
- How Hot is your Heater?
- HSW Noids
- Engine Temperature Rise with 150HP wet shot
- stand alones
- nitrous work solenoids
- thinking about spray
- enlighten me on stand alone systems
- DCR question when spraying! ADVANCED GURU'S ONLY PLEASE!
- Lower Limit
- Digital window switch crazy?
- Opinions wanted
- Where are you mounting solenoids? PICS
- New GMHTP magazine
- E.T reductions by shots (75,100,125,150)
- Nitrous dealers dont buy from manufactures?
- building a 370
- 50 dry shot help
- question bout a nitrous cam
- NX STORE Bottles, Cams, Key chains.
- iridium & n20
- Q about timing tuner????
- GAP on a TR6 NGK FOR A 200 SHOT
- nitrous problem, need some help!!!!!(nitrous experts)
- Dynotune question
- instalation question??????
- SPECIAL on NX shirts. FREE
- Help for a Dry guy....
- 1998 Nitrous Wiring
- Custom helmet airbrushing
- nxl kit....need help
- Nitrous newb, trying to clarify before purchase.
- nitrous newbie ?
- guys please help...correct answer will get 50 bucks paypaled to them
- Yummy-NOS
- NEW Bottle Heater
- Where to mount solenoids?
- new best on spray today
- Good idea/bad idea?
- where to put the bottle...
- Nitrous rings? Coated pistons? Ring spacing?
- Timing tuner installed,Feels slower now?
- M6 nitrous drag racers inside please!!!!!!
- wet shot question
- Can't decide where to put...
- Lean on nitrous run AGAIN, help please!
- has anyone ever mounted their switches here
- High Mile Cars spraying?
- Finally hit a decent sized shot again!!!
- LSA/ Lobe seperation for Nitrous
- Quick question!!
- Just recieved my HSW Standalone!
- "Big Shots"
- need help. where to mount relay????
- Little Wiring Help
- Why do we need nitrous when we have Ram Air?
- Have the bottle now what?
- how much spray on forged 347??
- Nitrous sponsors
- How much can soft plume nozzle flow?
- Dry kit nozzle selection?
- What are your favorite Nozzles, wet and dry?
- How can i make sure my noids are good?
- solenoids
- too much tire for the bottle?
- New to Nitrous...Need help
- opinions on burst panals?
- fuel cell question
- What plugs to use for nx
- What is the suggested jetting for Daves plate system??
- Window Switch Wiring for a 98
- SPAYING ON MY TUNE 36lb Lucas Injectors
- Dynotune WOT switch?
- Too much fuel? NX Dual Nozzle Kit
- What do guys think of this zex product?
- Help me decide which way to go
- Whoever said nitrous is cheap is an idiot...
- took my first step towards a sprayed LS1, now I need help!
- Dynotune window switch wiring...
- Nitrous with aftermarket fuel rails pics needed.
- Another Free Dynotune 10# Bottle!!!!
- Switch question
- The Winner Of A Free Dynotune Bottle Is......
- Quick question about the Nitrous Outlet plate kit.. -4 or -6??
- Where to get tach signal on 99 TA???
- question bout a Auto trans
- Need a little Feed Back VOTE!!
- Wet Plate
- 107 RWHP from 150 shot?
- bad window switch?
- where is the TPS wire?
- Nitrous Explosions
- 12lb in a 10lb bottle
- Let me see your dual bottles in your f body
- 1 10lb enough for dual stage
- bottle heater not working
- LT1 Plate System Group Purchase!!
- Came accross a cheap Dry kit. Use it or wait for plate :)
- for those with wideband
- Need motivation
- ringlands and nitrous
- dry kit questions
- Anyone accuratly explain why the TREX cam doesn accomodate big N20 doses? 3 part Q.
- Any big dawgs coming out this season?????
- Bottle opener switch input needed
- ?Purge through SS Hood? ??How-to??
- Good results w/ Nitro Dave's Plate
- what all needs to be done to run a 75 shot
- fuel systems for nos
- Purge Through Firehawk Nostrils
- some nitrous parts and other stuff for sale
- What compression are you running on your N20 370?
- Mini freezer for chilling bottles before filling?
- Which nitrous kit will put me in the 11's stock?
- Real dumb question
- ignition box
- LS7 Clutch & Nitrous
- 100 shot on heads and cam
- pic's of my rollbar, and bottle mounted
- HSW solenoid bracket problem
- nos plate above or under the spacer
- FPSS Adapter??
- spray patern
- Pictures of WOT Sw. on Fast/NW90
- Installing all the wiring?
- Msd Window Switch
- Noids + Heat
- fjo install , now a throttle problem
- pictures of my direct port
- Newbie....im lost
- solenoid pressure ?
- DYNOTUNE diagram!!!
- Nitrous and pressure gauges.
- Nitrous Outlet Plate Kit Pics!!!
- breaking 10's on juice?
- FPSS vs. A/F shut down switch
- how do i
- good start?
- TNT 150 shot Gains
- Rules for N20 at the track
- HELP egr sims avalible
- |Started working on the cars!!!!!
- Spraying fly cut pistons...
- Hsw Plate Kit?
- Can you run a FPSS and FP gauge together???
- nos nozzle maxes out at 150?
- 408 vs 418
- If it burns gas
- Octane requirements for 13.5 to 1 compression 408 and a 300 shot?
- Looking for a FPSS and some gauges
- Actual rwhp from nitrous
- hey guys, I'm fameous !!! Nitrous Outlet Customer cars
- heat and solenoids
- Nitrous Plate Kit for 85mm
- Nitrous Line question
- wiring question
- Solenoid Help??
- nitro dave plate kit?
- ls1 guys an n20
- LS1 intake and 125 shot...Good OR Bad?!!
- nos soft plume jetting and thread size?
- Anybody running the LC-1 Wideband Air/Fuel Ratio system for Autometer
- do i have everything now?
- Nitrous ????
- 250 whp shot, need advice
- Cold Fusions Direct Port Kit???
- Detailed write up on heater install?
- Few questions from a N20 Newb...
- Spray on a 4000+ Converter?
- How much shot to beat turbo cars?
- how much do you pick up on a 75 shot?
- Using LS6 ignition box to pull timing?
- Installed my Nitro Dave's plate kit
- Options for Direct Port tubing?
- is my bottom end in jeopardy?
- New Pb,
- Need some install feedback please
- A pic of my 90mm TNT F1.
- MAF screen issue
- Need HELP with Noid Placement (pix 56k beware)
- New C5 Z06 Stock LongBlock Record
- I'm preregistered for Pinks All Out at Moroso Motorsports Park...
- Nos ?
- Date on bottle?
- Nitrous newb questions, Im confused!
- wiring tips
- NOS two-stage nitrous controller
- Is it okay to put to nozzle before the MAF??
- 125 shot on Heads/cam will stock tranny hold
- MAF kit, for an LT1..
- Nitrous Daves Direct Port
- ZEX kit just installed need help!
- SCE ICS Titan Gaskets...
- Att Noyzee !!!!!
- 11.0:1/N02 who's doing it
- NITROUS users help please...
- HSW Nitrous plate Whens it coming out?
- 2007 Nitrous ET List
- Broken Schrader Valve...
- looking for a nxl kit
