PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. dual .48 jets on dry plate
  2. single vs dual stage on a 200 shot
  3. NANO not full..
  4. Should I consider my elevation??
  5. Which kit to use?
  6. Best spot to get 12V switched at????
  7. $4k To spend. HELP ME!
  8. Is there a point where you should.......
  9. should i be worried about spraying a 98 ss
  10. NANO Tuning?
  11. What Nitrous should I use?
  12. i need help with a leak
  13. NX MAF KIT Install pics?
  14. Sprayed for the first time..
  15. microedge wiring 94 PCM, which wires??
  16. Microedge & LM-2 Wideband
  17. 143k....too many miles for NOS?
  18. Too Lean
  19. How bad is it to run WOT with a......
  20. 4000 Stall, MS4, 100 dry shot before MAF?
  21. Routing Nitrous Feed Line
  22. Safety Disk question.
  23. Best Manifold/TB
  24. How much NOS and still be reliable?
  25. Blow Out Garage sale at Nitrous Outlet!
  26. LSX Shootout 2009 275 class?????????
  27. Mallory Hyfire 685 starting issues
  28. wet plate kit
  29. Pictures--- Cary @ Performance Inductions Intake Vs. Victor Jr.
  30. what do i need to change??? ZEX kit v6-v8
  31. i love this stuff
  32. MSD RPM window switch question
  33. Will 75 wet shot be fine!
  34. Setup?
  35. can you guys tell me if this plug looks good
  36. DD with nos?
  37. Injectors for c5 z06 150 dry shot
  38. Input on new setup
  39. fuel pressure switch
  40. So i pulled the plugs after my 2nd n20 pass
  41. Plugs died on a pass
  42. Bottle Dementions
  43. Victor Jr users inside please HELP!!!
  44. HSW Plate kit with Nano at the track video
  45. Installed dynotune dry kit
  46. Planning for this upcoming season. Need some opinions on how much to spray
  47. Using a 2 step w/ a T400 5OOO STALL.
  48. MSD Window Switch......
  49. Be careful with your injector duty cycle.
  50. Final Question About What Kit/Parts To Go With.
  51. check my setup ok for a 200shot?
  52. Problems with Microedge, a few Q's from first times experience spraying
  53. How to fool microedge?
  54. 100% Stock Ls1 .. 100 shot ?
  55. Trick performance V-Gauge. Any one have any experiance with it?
  56. Pushing the limits of stock injectors/pump?
  57. New set up
  58. can someone tell me how to wire the nitrous works pressure switch pic inside
  59. Alcohol w/ Nitrous??
  60. Is my stock pump enough for a 125 shot?
  61. Nitrous gauge Question?!!?
  62. stuck solenoid? HSW kit
  63. Another Newbie Asking Questions.
  64. F.S MSD Digital Window Switch
  65. hsw jets with nitrous outlet plate?
  66. Timing for 150 wet shot
  67. Plate System vs Nozzle System
  68. truck nitrous system on car
  69. Alright Now what?
  70. Dry Nitrous ?
  71. bottle heater
  72. Holy Crap!!!!!!!!!!
  73. microedge sensor connections
  74. Nitrous controller?
  75. dry system for c5 a4 vette
  76. Need Hints And Tips On Nitrous Install.
  77. Venom VCN-1000
  78. Do you have to purge a DRY system?
  79. 1/2" or larger head studs? Materials? O-ring?
  80. MS4 , LS6 heads , cometic gaskets
  81. I am back!!!
  82. going to be spraying a 300 in three stages need some advice
  83. Keeping the heads down on a BIG hit
  84. People with NANO Pictures *Please Enter*
  85. LT1 (wet) nozzle location??
  86. Looking for a sponsor who can wire my nitrous
  87. sprayed a 100 shot!!!
  88. HSW Nitrous Jetting Sizes... No clue which ones to pick. Need help!!!
  89. Please help with wiring!
  90. questions about spraying 400 and above set ups !
  91. Help with power ring!!
  92. Think about doing a wet kit couple questions...
  93. FJO TPS and RPM on C5 z06
  94. Hsw interface?
  95. Need help fast about TB!!
  96. Lunati Pro Mod Rods
  97. nos/head gasket question
  98. Nitrous Help!!!
  99. best complete afr kit to buy?
  100. How good/well will this Zex kit work for me???
  101. Nitrous Pressure gauge sensor location?
  102. New to N2O.. Need Line size Suggestions.
  103. FS heater & Opener
  104. is HSW dry basic kit similar to dynotune 4-6cyl dry basic kit?
  105. Big Nitrous Purge Question
  106. Ordered my HSW Plate Kit!!!!!!!!!
  107. two bottles vs. nano....
  108. timing retard on demand??
  109. classic nitrous install
  110. Anyone ever use a Top Shot? **Carb guys only**
  111. What CR would you go?
  112. No2 for medium grip car....
  113. Nitrous Outlet was at it again (Direct port Pics Inside)
  114. Safety question for nitrous
  115. Radiator Question
  116. how many spray thru shift?
  117. pls help Ls2 plate
  118. quick NOS Kit question
  119. Zex nitrous
  120. Bottle warmer decision
  121. Made a bottle bracket for the ds hump...
  122. HSW air/fuel interface question
  123. Cant find a plate kit for 08 silverado
  124. Time for new nitrous solenoids? Rebuild? Pics inside
  125. MAF Plate Kit's
  126. for you nitrous guys
  127. direct port, fogger nozzle placement
  128. HSW MicroEDGE controller mounting in 2000 Camaro SS cabin...
  129. HSW Vs Dyno Tune Nitrous kits
  130. Guys need help here with N20! PLEASE!!!
  131. Need answers to questions about dry nitrous system...
  132. brands of jets compatible with hsw and 3 to 5 wire maf queston
  133. What an awesome Christmas!
  134. window switch question nitrous newb
  135. MICROEDGE AND INTERFACE together
  136. will this work
  137. 2 stage
  138. NOS Window switch
  139. Bottle heater fuse size
  140. MS3 + N20..need help
  141. 100 shot without pulling timing on camed ls1?
  142. How much is nitrous kit worth?
  143. Nitro Dave and Crew...NITRO OUTLET
  144. Head Gaskets For NOS
  145. Summit Window Switch HELP!!!!
  146. Does the Nitrous Outlet Have any Holiday Codes??? I need some stuff! lol
  147. Anyone need a Msd rpm activated switch
  148. NANO refill Station??
  149. HSW Nitrous Holiday Hours
  150. Nitrous newb here
  151. Single or Dual Stage
  152. wanna know who builds good bottom ends
  153. NOS Sniper
  154. 383 lt1 on da bottle for 1st time
  155. one question :)
  156. Newb to nitrous, got some ??'s
  157. Setup pics of NANO
  158. People that Know nitrous in here
  159. Do open cutouts affect A/F ratio?
  160. will a LS7 clutch hold up to 150 shot
  161. plugging direct port holes
  162. free nozzle and jets
  163. HSW plate and custom smooth bellow
  164. deedeedee moment the other week... :(
  165. blow down kit question
  166. anyone running nitrous on the stock fuel pump?
  167. nitrous help
  168. Effects of Progressive Controller on solenoids?
  169. FJO writeups?
  170. TNT & mini controler ?????
  171. Boredom Build what do you think is it going to melt lol.
  172. Nitrous Outlet at it again... Dual Stage Perimeter Plate pics inside......
  173. Who is running E85 and Nitrous?
  174. how to work the full throttle
  175. Using nitrous for the first time how big of a shot for a beginner
  176. Any stock bottom end vindatcor cars w/ bottle?
  177. Must See!! Amazing Custom Products!!
  178. is it safe ?
  179. Bottle Pressure Sensor
  180. Big shot N2o engines. How fast are you NA.
  181. Need Inexpensive Progressive Controller
  182. About to purchase from HSW, need help!
  183. What else do I need?
  184. Custom painted Nitrous bottle
  185. HELP: newbie to timing retard for nitrous
  186. new to n20 and going crazy
  187. torquer v.3+100 shot =?
  188. Harris speed works please come in!!!
  189. Solenoid failures?
  190. need help soon
  191. 200 shot on stock lt1 long block?
  192. Do i need nano
  193. Bottle between the seats brackets
  194. Who has sprayed the most with stock cubes?
  195. Harris SpeedWorks Wet Kit in my 2003 Z06
  196. Thought about trying to go 10's with just bolt-ons+spray? Might run e85
  197. Microedge users, in here!
  198. 150 shot with sunoco 104 octane how much timing?
  199. where is your bottle mounted
  200. Forged stroker LS not built for nitrous
  201. New LSx Tunnel Ram Intake Hits the Market-Check this bad boy out
  202. Nano Question
  203. Need help with NOS jets
  204. 150 shot Harris Speedworks system!
  205. bout to use a 150 wet shot for the first time what should i expect
  206. window switch?
  207. props to Nitro Daves
  208. PLEASE HELP!!!! want nitrous but dont know what i need
  209. quick question... HSW and NOS plate
  210. can high mileage engines handle nitrous
  211. 2 valve help
  212. Need some help from the WET guys....
  213. My new switch panel
  214. who is building/tuning your nitrous engines?
  215. Crank and Rods??
  216. Paging 383lq4SS, can't hide no more, lol
  217. I'm Back, and You Thought You Got Ric of Me, lol
  218. what companys wet kit would you recommend?
  219. 125 wet shot ls1 questions ?
  220. Nitrous questions for a different car. (Non F-Body)
  221. nitrous outlet Brand X???
  222. DynoTune Wet kit installed in my car
  223. 200 N.O. Wet Plate what plugs?
  224. C16 and a 200 shot....TIMING?????LOOK
  225. wiring guru's!!!
  226. Using relay to send ground?
  227. What do i need to safely run nitrous on a street car?
  228. Dedicated fuel pressure reg. question
  229. Calling all stock motor people for list
  230. NAno Systems on vacation?
  231. switch panel SHOW YOURS !!!!!
  232. Need Nozzle help with my Nitro Dave Plate (Sizing information needed)
  233. FPSS Question
  234. 6 speed guys with big hits, have a question
  235. Dynotune masterblaster purge vid
  236. How warm is a bottle heater get ?
  237. NANO Poll
  238. does nitrous brand affect performance
  239. opinions on 150 wet shot...
  240. Nitrous Wiring Question
  241. 125 r.w. shot
  242. Jet placement question
  243. Which N20 Plate?
  244. Christmas sales?
  245. What RPM are you guys starting to spray at???
  246. How much nitrous you guys go thru?
  247. dont know anything but nitrous please help me decide a set-up
  248. Where can I get a new O ring for TNT's power ring
  249. Stand Alone/Nano Pics
  250. Do i need to re-tune if i get the bottle??
