View Full Version : General Maintenance & Repairs
  1. Dirty/faulty EGR Valve, HELP!!!
  2. security and Airbag lights... i hate them, how to turn off?
  3. AC Delete?
  4. Disabling VATS
  5. Ls1 radiator same as a v6?
  6. I need help!
  7. Finicky DRL's
  8. Shortcut to codes?
  9. Check Gauges light
  10. Passenger door lock issues
  11. Wipers driving me crazy
  12. Maintenance Basics
  13. 2000 Camaro Wiper Blades
  14. AC blowing but not COLD!
  15. trans is slipping or something wired
  16. ABS, BRAKE lights and rattling sound from rear.
  17. plugged hatch drain tubes??
  18. (Video) E-brake Handle Rattle
  19. Leaking PS pump drive seal
  20. trans am door helppppp
  21. Why would my car surge and stall like this?
  22. whiny power steering pump
  23. Power Steering and lights after the knife
  24. Tail light Housing Removal
  25. oil pressure question
  26. Oil leak Starter Side! :bang:
  27. little oil at rockers
  28. Strange squeeling
  29. Shop cost to replace AC compressor
  30. Right rear tire misaligned
  31. Security light stays on
  32. PCV or Breather Valve?
  33. Need some help, evap issues
  34. Norris catch can installed with pics...
  35. turn signal won't flash
  36. Power Steering pump noisy and whining
  37. 02 camaro front end questions
  38. my dd is rusting by the minute.
  39. Upgraded to lt1 radiator and deleted PS cooler (with pics)
  40. Misfire in rain. (new plugs/wires) water getting in coil?
  41. P0530 help
  42. I’ve finally conquered the P0507 code!!!
  43. Engine squeaking
  44. Can anyone please help
  45. I guess my water pump is going out?
  46. Replacement radiator & condensor
  47. Fan Comes On When Ignition Off
  48. lq4 engine fuel system problem
  49. 97 Z28 Power Steering Question
  50. driver side door.....just a mess
  51. (video) Jittery oil pressure needle?
  52. Brake Light Issue
  53. SLP lid install....
  54. MAF Sensor
  55. Car broke down away from home. Cranks but won't start.
  56. LS1 engine problem
  57. Window motor
  58. heater not gettin hot
  59. Progressively louder ticking in Drive Train and LT Gasket Question/Concern
  60. Misfiring Again
  61. cooling fans won't come on
  62. Bad Oil Leak, NEED HELP!
  63. Ticking noise when cold and only in gear?
  64. Where to rent/borrow time serts
  65. pulley system making noise with higher rpms
  66. Need help! Car will not start!
  67. What to do with MSD wires near Kooks LTs?
  68. A/C clutch bearing help
  69. Is this an issue...
  70. i need to get to the fuel tank how can i drain it
  71. Front Suspension Repair
  72. Coolent System?
  73. The one thing I neglected...
  74. evap system trouble
  75. Check out my spark plugs.
  76. 97 Doors interchangeable with 02
  77. Rear hatch glass 2001 trans am
  78. Problems starting... not ignition imo?
  79. Hatch weatherstripping came off
  80. loud clicking / gear noise from rear end.
  81. bank 1 lean and both sensors low voltage Helps??
  82. Removing body wiring harness
  83. 99 T/A, Did Ls6 intake mani swap, now have an extra electrical connector, Help!
  84. Radiator issues
  85. so the SES light back on
  86. coolent change
  87. ?????????
  88. Blinker problem.
  89. Codes: P0133 & P0153 (Sensor Circuit Slow Response)
  90. ASR won't turn off
  91. awesome! an oil leak :)
  92. Changed AIR gasket
  93. High RPM stumble, almost like a governor...
  94. Losing coolant, but no leaks
  95. Bigger washer fluid tank?
  96. clunking ad grinding underneath car
  97. Help me fix my oil leak!
  98. 12 bolt moser issue!!! Neeeed help!!
  99. Hatch release arm!
  100. Burnt up a couple wires.
  101. Purple smoke under heavy deacceleration
  102. Replacement ac compressor?
  103. Rack and pinion play
  104. water pump ?
  105. Starter issue
  106. just got a 2000 ss need help.
  107. Blinkers dont work, need to replace flasher
  108. Squeak from Passengers side front wheel hub
  109. a/c help
  110. i know your going to hate me!
  111. Wipers adjustment
  112. Hatch not shutting
  113. Power Steering System Replacement
  114. Better choice of epoxy for headlight motor fix?
  115. idling issue
  116. Please advise por 15 help
  117. Intake manifold gaskets ls1
  118. Gas Tanks--Steel vs Plastic
  119. Flywheel bolts threaded?
  120. Clicking on Passenger Side
  121. Whats this noise? Sounds like a Blower after New Alternator.
  122. backfire? or need a rebuild
  123. German Castrol
  124. 1988 jeep cherokee fuel level gauge problem
  125. preventive maintenance?
  126. camaro rack and pinion install
  127. What drains the battery over night?
  128. Window problem! Help!!
  129. Need help
  130. weird box wired into my car.?? help
  131. Power steering cooler mod question
  132. Electrical Problem???
  133. Radiator upgrade all alluminum fitting ?
  134. exhaust backfire and black/blue smoke from pass. side exhaust pipe
  135. Trunk Release Button?
  136. Rust problem
  137. Another window issue
  138. ASR - not "functional" until car starts?
  139. pypes exhaust system on 6.0 with ls3 heads
  140. Turn signal problem
  141. Hard to start when hot???
  142. Wiper blade problem
  143. No power steering
  144. PCV concern
  145. Key Fob help
  146. Weird problem
  147. Removing Motor Mount Pedestal
  148. another electrical issue.. car wont start
  149. gauges don't work after swap
  150. 02 Camaro wiring
  151. 2002 Camaro Heater Core
  152. Any advice is appreciated!
  153. Engine Reving Question
  154. Ls 5.3 truck cruise control
  155. firehawk failed smog test
  156. help diagnose
  157. Cheap Tie Rods on Ebay?
  158. Rebuild shopping list.
  159. P0300 Arrrgh!
  160. HELP 2002 Camaro SS whine !
  161. Whine sound coming from engine ??
  162. Just fixed my bad headlight motor and noticed something slightly odd....
  163. Foamy Oil!?
  164. T-Top Leakage??
  165. Revving up for some reason?
  166. Possible short?
  167. Slave cylinder??
  168. Clamp that hold the lid on?
  169. SES light came on after installing LS6 Intake?
  170. Driver side t-top lock/cylinder is loose
  171. Power Steering
  172. 98 z28 po134
  173. Holy s%^# stains batman, my car dies @ highway speeds.
  174. how to line up steering shaft and u joint
  175. Electrical Problems (several things died at once)
  176. Rear end howl?
  177. No injector pulse... need help!
  178. getting a bunch of different noises
  179. Overheating Engine or Bad Coolant Temp Sensor?
  180. Cleaning engine
  181. high idle, glowing red headers and occasionally sound like its knocking
  182. 3rd brake light, abs
  183. Windshield Nozzle
  184. replacement screws and nuts for engine bay?
  185. Loud whining noise
  186. Looking For Photos of AIR & Grounds
  187. Fuel pump start then stop..help
  188. knocking sound
  189. 06 Silverado Crewcab getting 13.5MPG!!
  190. P0418 driving us nuts
  191. bad mileage, what to do.
  192. P0420 w/strange O2 indications
  193. Cooling fan comes on for no reason
  194. Potential Trans or rear problems?
  195. problems replacing A/C drive idler pulley
  196. bad low throttle performance
  197. Right Blinker Problem
  198. Rear End Noise?
  199. Belt Squeal Issue?
  200. Still got a squeak!
  201. Weird Clunk when going over bumps
  202. P0102 need help!
  203. Experience with Optima Digital 1200 Charger
  204. Tail light
  205. Scratched upper dash panel
  206. Brake squeak when not pressed
  207. "Service Engine Soon" light, ideas?
  208. How to clean surface rust off of ls1 spindle?
  209. Coolant issue. PLEASE HELP!!
  210. Massive wheel hop's .. help
  211. no start
  212. Rear Differential fluid replace.
  213. Oil catch can for decent price?
  214. Squeaking when rolling
  215. Loose steering
  216. Car acting STRANGE when its cold.
  217. GM CS alternator charging article
  218. Idle clacking sound
  219. Code P1635 Should I worry or not?
  220. Running rough between 1800 and 3000 rpm
  221. 99 z28 rear hatch glass is loose?
  222. exhaust "clank"
  223. Power steering and some other issues
  224. Horrible mileage questions
  225. Replaced O2, now it runs...worse?
  226. Please read, need help, crappy running LQ4 in 03 Silverado.
  227. another coolant question
  228. Vacuum at idle
  229. Oil pressure gauge still dropping to 0 after replacing
  230. A/c vent fell back into the duct
  231. Help identifying metal needles
  232. someone please enlighten me on this situation
  233. another winter storage question...
  234. MAF question?????????????
  235. Vanishing engine coolant?
  236. Strange Noise
  237. loose drive train? What do you think.
  238. Umi torque arm and driveshaft issue or.. pics
  239. Engine knock at idle
  240. Air pump fuse question??
  241. Code P0443 - Can't put gas in tank!
  242. AC Delco oil filter?
  243. Can't fine ps return hose?
  244. storage in extreme cold
  245. Replacing Denso O2's..
  246. P0101 103 803 & o2 sensors
  247. need help - rear heat shield
  248. Hatch won't stay up, new struts needed?
  249. Steering wheel replacement
  250. routine oil change turned into guessing game
