View Full Version : Drag Racing Tech
  1. elec water pump vx man one....
  2. header size?
  3. what rear shock settings are guys having
  4. best cathedral drag head for big cubes
  5. 16 volt battery on 12 volt system
  6. Which gears for my car and the 1/4 mile???
  7. vfn lift off hatches
  8. Drag Racing Parachute Info
  9. Weighed the car tonight
  10. Roll bar, done and painted
  11. need help for tonight
  12. New Camaro Body For Drag Radial Car.
  13. Cage install is done.
  14. Which tire would you choose? (M6)
  15. Witch 16" DR hooks better??
  16. Hardcore Motorsports Trans-Am
  17. what widow net set up?
  18. ORSCA Racing season kicks off March 27th in Alabama!!! EFI Hot Street to debut!!!!
  19. Funny Car Add-on to 10pt?
  20. MSD 7531 Setup
  21. whats the deal? cant hook
  22. What gears
  23. 3rd gear in the 1/4????
  24. battery box ?
  25. PIC THREAD: "Lightest Looking" Engine Bays....
  26. what k member is this?
  27. For The M6 Guys With 410'S
  28. Quick License Question
  29. What Throttle Cable for Carbed Fbody..
  30. Roll Bar Padding
  31. New Plans for 08 G5X3 N20 279lbs lighter !!!
  32. pics of ps/ac delete/ewp and or coil pack reloc?
  33. hows this race going to turn out?
  34. ???KIRKEY economy w/o ROLLBAR.....
  35. kyb adjustment with strano spring?
  36. Took 15 lbs out of the stock carpet
  37. Loss of rigidity due to armrest metal?
  38. The feel of a good 60 ft.
  39. Tire size & N2o??
  40. Trans tunnel mount TQ arms
  41. Which Catch Can???
  42. Body Control Module/Air Bag Module
  43. PAF chute / release system installed.
  44. What do you Guys Think
  45. Wheelstands and front end alignment ???
  46. best dot tire for a 550+ rwhp 6 speed car
  47. Going to the track tomorrow
  48. Stall question N20 guys.
  49. Mostly stock suspension
  50. Installing hunsaker synkros on stock brackets?
  51. Car is going to Midwest Chasis!
  52. rear drag v6 springs what is the height diff then a v8
  53. Side Impact Bars?
  54. last weekends carnge
  55. ???SPEED INC still make the FUEL TANK for FACTORY LOCATION.....
  56. midplate pics
  57. M6 guys with HALs
  58. BMR Alternator Bracket
  59. Pics of door bars for roll bar install
  60. balanced drs
  61. How much 60ft improvement with adjustable shocks?
  62. Why switch to 4th on a t56?
  63. If I'm trapping at 94mph in the 1/8th...
  64. Help! Car runs faster in 3rd gear than in drive!
  65. rear spring help
  66. Unleaded race fuel??
  67. Help me squeak out .13 for an 11.99!!
  68. Temp sender
  69. PVC Delete
  70. When should I switch to a glide?
  71. 20 Years at Burkhart Chassis
  72. contemplating drag car vs. street/strip car
  73. new tune will it help.
  74. ET Street or ET Drag
  75. Madman Tax Season Sale!!! Part 1
  76. Lightweight brakes that are also fine for a daily driver?
  77. any one using unwelded anti-roll kits to save a $
  78. 28 RWHP gains with just a cam swap
  79. Roll Cage Padding Opinions
  80. 60ft?
  81. vht?
  82. wheel studs?
  83. need help does anyone have pics of seat brackets
  84. rear bumper
  85. Brand new Chiseled Performance Combo Tank!
  86. 6 point rollbar question?
  87. Did you delete your PCV stuff. On your drag car
  88. munual brakes, how does your pedal feel?
  89. Tinted windows for racing?
  90. short belt part number
  91. Kirkey Pro w/ Racecraft brackets
  92. 2009 Build-Turbo 98 Cyber Gray SS-Updated pictures March 17th
  93. New bracket/index/pro test and tune car for 2009 almost done
  94. Mounting rear QA1 shocks
  95. Hurst Quarter stick vs. B&M Pro stick
  96. Roll Cage Height Issue
  97. Speedtech Nitrous 4150 Diffuser 2-Stage Plate System
  98. Retorquing ARP head bolts, have questions
  99. ET FRONTs 27.5in
  100. 5pt harness
  101. Shift Lights
  102. need help bad
  103. Aerospace Brakes!?
  104. Harlen vs Rapter
  105. What is lighter than a 10 bolt...
  106. M/T Drag Radial 235/60/15 or 255/50/16
  107. Heater Core Delete Question
  108. Do you drive your car to the track? And fastest?
  109. Mounting a Hurts quarter stick shifter?? any pics??
  110. Is a T hook the best way to tie down? location?
  111. Any e.t 1/4mi loss going to taller tires?
  112. Under Body Aerodynamics
  113. Anyone been to the track with cam and stock converter?
  114. Competition Engineering Rear Drag Shocks?
  115. LS6 manifold
  116. chasing the intake temp
  117. coming along...
  118. Who has clearanced/hacked a SS hood?
  119. SBC mounting in 03 Cobra chassis
  120. Got Hook? I Do, Thanks To Madman!!
  121. My weight reduction this weekend w/pics.
  122. Curious Question?
  123. Front drag brake option?
  124. true trac
  125. bias-ply w/ radials ??????????
  126. Hot Cam Users???
  127. Which 2 step launch controller?
  128. need 60 ft help
  129. What MPH and ET changes do you expect from this kind of Weight Reduction?
  130. Fuel Pump Limits?
  131. mild steel or CM
  132. gearing selection with nitrous.
  133. Battery killswitch mounting...
  134. Need help with fuel system 02 camaro
  135. Moroso vacuum pump
  136. need advice!!
  137. Help with aerospace rear drag brakes
  138. Kirkey, Race inc. brackets,I/O port racing brace,5 point harness install w/pics
  139. Drag Brake DD Question
  140. Installing vic jr intake. MAP Sensor???
  141. spring help
  142. need help tuning my suspension
  143. Kirkey seat mounting pictures
  144. REAR V6 SPRINGS do you know the spring rate or codes
  145. Driveshaft saftey loop distance from yoke
  146. no mufflers-hurting me ?
  147. Need advice on lowering car
  148. ???strange BRAKE PAD ques.....
  149. Fast 92 1/4 results?
  150. fast 90
  151. Check out what UPS dropped off at the door today :D
  152. Got a question. Does this sound right?
  153. Bias-ply vs. radial fronts
  154. Header coatings, Houston area....
  155. Slicks BAD looking at new brand
  156. Which belts to order
  157. where to buy a prebent aluminum dash
  158. 5/8 Wheel Studs
  159. needhelpwith275 17''MTet dragradial
  160. Wiring Question... Searches futile
  161. Seatbelt bolt
  162. some intresting info from rehr morrison
  163. help with tire shake hoosiers
  164. How to delete Vats? Not bypass...
  165. bbc in ls1/lt1 car??
  166. Who makes a one-wire alternator for F-body?
  167. Do 6 speeds benefit...
  168. Why no Hoosier 18192D05 allowed?
  169. Need to re-cam?
  170. Questions about tuning
  171. Solid Motor Mounts with aftermarket K-member...
  172. 60ft blues
  173. dip stick plug Help.
  174. Best pricing on kirkeys?
  175. looking a fuel line piece
  176. An brake lines?
  177. Crane Cams doors closed
  178. Fat Tuesday sale at Madman & Co!!!!!
  179. Manual brakes on a 3rd gen???
  180. New toy for the Turbo TA!
  181. Lightweight Battery or Rear Mount???
  182. Intake choice?
  183. Anyone Using.. Super Victor Intake w/ Nitrous Plate & Carb/TB?? Pics inside..
  184. Still having launch traction issues
  185. Another roll bar question
  186. Airbag fuses and sensor removal?
  187. My new setup...
  188. How quick with stock exhaust manifolds?
  189. Bolt on LT1 with TH 400???
  190. Progress Pics... Mini tub, Firewall, weight reduction
  191. Progress Pics.. Carb'd ls1 swap-slight weight reduction.
  192. Launching with a transbrake, advice needed
  193. Koni shocks on front????
  194. How to delete ABS?
  195. When do you replace drag brakes pads and rotors
  196. Best factory placed drag exhaust, period!?
  197. swing out ?
  198. Has anyone tapped a block yet?
  199. Wolfe mini tubbing questions
  200. Anyone tow with a 2500 suburban?
  201. Getting alignment next week. NEED HELP!!!
  202. Torn between tire sizes :(
  203. swaping zr1's for skinnys on the front. gains?
  204. Solid axle c5
  205. What are you guys doing with old wiring?
  206. Cage is done!
  207. need a help on a base tire psi, shock settings..
  208. Need help on Battery post Adapter
  209. My Fox Body LSx Headers 1 7/8 to 2" work!
  210. 25mm rear swaybar?
  211. Cam only, winter upgrades. Bitch in on a diet
  212. New Jaz Seat Brackets
  213. QA1 Coilover Spring Replacement
  214. To Screw or not to Screw!
  215. ??? VFN Pin-On hatch Pics/Install ???
  216. 570WHP M6 launches - airbag issues?
  217. New Firebird Hood Design
  218. anyone delete their center counsle?
  219. what springs for qa1 12-way struts street/strip
  220. Motor plate setup with Log/Turbo
  221. Help! MAP Sensor getting clogged with fuel!
  222. shock, coilover, spring QUESTION
  223. help with SLIGHT RUB on rear LCA's
  224. project pics!! 97 camaro.
  225. looking for pics on how you mounted your pin on hood??
  226. Towing question
  227. Varishock coilover kit
  228. Take Care of Your Clutch--How to Prevent or Cure Pedal Issues
  229. what gear for a 560hp supercharged 6sp ta
  230. Bullets or Sweet Thunders
  231. Rent a Top Fuel ride......
  232. Strange rear dual calipers??
  233. My wheelie bars and trunk mods complete
  234. Not happy with my Wolfe 10 point so far
  235. Effects of Rotational/Unsprung weight Loss
  236. Drag Brakes
  237. prostars and summit star question
  238. Upright Radiator and remote h20 pump questions
  239. Launching at the track with a stick shift...
  240. MADMAN in Iraq!!!!!!
  241. Time for a drag radial...Hoosier or M/t?
  242. Is there a rule....
  243. Hurst quarter stick pistol grip/ 4L60 type installed
  244. for thoes who have a EFI vic jr intake
  245. which helmet
  246. Which tire to get?
  247. Any other Rear suspension needed?
  248. stock weight
  249. How many of you use a "blinder" at the tree?
  250. LS1 TH400 flexplates...
