View Full Version : General Maintenance & Repairs
  1. AC clutch air gap question?
  2. code
  3. Gauge cluster
  4. Leaking on passenger side floor mat, what's happening?
  5. Replacing fuel line in engine bay?
  6. headlight motor cover glue
  7. Maximum Time Front End Up On Ramps?
  8. Whining noise coming from engine or steering?
  9. locks.
  10. A/C belt
  11. 04 gto a/c compressor on a 98 z28?
  12. Head light screw problem
  13. Flashing SES light - no codes
  14. stripped lug bolt NIGHTMARE!!!
  15. DS window help
  16. a/c compressor replace advice
  17. Growl/ clunking noise, I cant find it!
  18. Any better ideal to keep the battery from moving around ?
  19. Power mirror issue
  20. Alternator Won't Charge Battery
  21. Moving a car into garage without wheels/axles...
  22. Is my radiator hose about to be explore ?
  23. How is the factory body kit attached on a ls1?
  24. Window motor help.
  25. busted radiator
  26. Checking for AC leak
  27. Maintenance
  28. Next Steps for AC?
  29. coolant bubbling overflow *FIXED*
  30. How much does a tune up cost for 1998 Firebird
  31. Sewing Machine...
  32. Adding Cruise Control?
  33. Ticking, misifing, exhaust smells like raw fuel
  34. AC - Hissing from dash when turned off
  35. help! :(
  36. Coolant guage outta whack...
  37. A/C vents
  38. Freshening up a frequently stored car
  39. anyone know the part number for the little screw around the antenna?
  40. Wierd problem with steering
  41. Cabin Filter.....How often do you swap?
  42. pulling e-brake up hard make it come lose
  43. starting issues
  44. Leak Where Oil Pan Meets Transmission
  45. 2002 TA rear end going out
  46. Drops to Low Idle or almost Dies!!
  47. Can you identify this plug?
  48. 1994 LT1 EVAP system questions, strong fuel odor!!
  49. how to tow a 4x4 truck
  50. 1999 Camaro SS sluggish, hesitates, WTF!!!
  51. Problem!
  52. 99 T/A Starting Problems
  53. Gas Gauge Stuck on Empty
  54. oil dipstick tube loose ?
  55. AC Problem
  56. replaced my rack and pinon, now lines leading to power stering pump shot...typical?
  57. Car acting Retarded!
  58. Car running very hot....electrical gurus come in!
  59. LT1 and mopar combustion chamber cleaner COME ON IN, LS1 welcome
  60. Oil pressure gage low
  61. VATS problem
  62. Surging at low RPM's?
  63. "while i'm at it" power window motor and speaker
  64. Car not running right and throwing codes.
  65. A/c Experts
  66. Rear View Mirror Rattle
  67. Glove box keeps falling open...What now?
  68. electrical problem
  69. Oil Consumption Question
  70. changed oil now change oil light comes on
  71. Rear tail light issues
  72. Wheel/ Suspension Question
  73. wiring problem....
  74. Fog Lamp Connector and pigtail
  75. Good Exhaust shop in Mid Michigan???
  76. LT1 Oil Leak
  77. A/C Compressor is shot... Just pulled the orifice tube *PICS* what now??
  78. Trying to replace coolant level sensor.
  79. Anyone have have a rattling coming from behind like the radio dash area?
  80. 99' SS Starting issues
  81. stalling problems, any insight please!!
  82. Car cranks, but refuses to start
  83. LUMBAR seat leaks?
  84. Squeaking in between gears/turning
  85. Engine rattling?
  86. Werid Problem
  87. Noise coming from back end of car
  88. Quick headlight Fix
  89. where does the Vacuum line go into the cabin from the HVAC?
  90. Aftermaket torque arm relocation crossmember and torque arm
  91. Which replacement window motor for D.S.?
  92. Why does my ashtray lid stay open !!! 02 maro
  93. Alternator amperage?
  94. Coolant/Water pump question on my 2001 Olds Aurora
  95. A/C cluth removal
  96. Tricks to take out ac compressor on C5 vette
  97. broke my ignition keys in half.....now what?
  98. A/c not working in the dd, charged but no clutch
  99. car wont start...im stumped......
  100. is the power antenna motor serviceable? (ie can you easily get into the internals?)
  101. Blinkers Not Working
  102. headlight noise, please help
  103. I need pics of where the crank position sensor is.
  104. AC blowin' warm air on the coolest setting?
  105. Strange Problem Help!
  106. ls1 flooding on startup
  107. Sputtering Engine Under Load -
  108. OK SERIOUSLY WTF....Car acting posessed!
  109. SES Light - P0171 Code
  110. A/c Compressor clutch not spinning ? system is empty
  111. Hard start when cold?
  112. thermostat stuck open or not there?
  113. Where to find a part??
  114. What the hell could this be??! (video)
  115. Pass Side Sail Panel Loose
  116. All right I am in need of some electrical help for a '97 Z28
  117. A/C drain help
  118. Repair Head Gasket?
  119. Car won't start...
  120. Coolant Leak
  121. Starting issuesss
  122. You ever hear of this oil?
  123. SES P1416 could it be an O2 checked the valve
  124. Leaking passenger side t-top
  125. So, it's been raining virtually non-stop here
  126. *SES LIGHT BACK** after tune and MAF replaced!
  127. passenger side floorboard pool
  128. Coolant on the Underside of my Hood??? HELP!!!
  129. Non LS Cooling flush ?
  130. Bleeding
  131. How to turn off SES light without tuning software
  132. new camaro owner with problem
  133. A/C chattering when turned off
  134. really need some help...
  135. Trouble Starting - Clutch Switch?
  136. Clutch Problems
  137. throwing some codes....HELP?
  138. headlights are popping up when i lock my doors???
  139. AC problems
  140. I smell gas when i turn on my AC
  141. anyone here with a aftermarket hood?
  142. convertable motor?!
  143. what to check for after a car has been sitting?
  144. Car ran rough for a while....pulled two codes
  145. Need help replacing ac lines
  146. broken waterpump i think
  147. fireing up problem :/
  148. Super Seal seems to have fixed my leaking A/C
  149. PO430 SES light
  150. gas in oil, car won't start?
  151. Ignition problems killing me. Help please.
  152. Fbody Flip Down Visor Fix
  153. low oil light
  154. Play in column... Tilt I think
  155. From 22 mpg to 8 mpg 01 Firebird LS1 please help
  156. Squealing above 2k RPMs
  157. Knocking sound from pass. front wheel under light braking only? Hope someone can help
  158. Car randomly dies
  159. Replacing passanger door window, help appreciated.
  160. ~~ Quick Question! SS spoiler fitment?! ~~
  161. My 96 Firebird Tail Lights Issues! Help!!
  162. motor hesitating after shifting, please help
  163. Water pump or thermostat
  164. Metal pieces in oil drain plug
  165. Need some help with A/C parts
  166. Another "ticking" thread.
  167. i need some help with a vacuum leak
  168. Few questions O_O
  169. Need Low profile ramps!
  170. Fuel Filter Question
  171. Throwing Codes P0171 and P0174 and bogging
  172. window problem
  173. A/C prob
  174. Transmission Fluid & Rear Axle Oil
  175. 99 steering rack bolts
  176. gonna die at an early age over this car... fml
  177. A/C Issue
  178. A/C diagram
  179. A/C gasket??
  180. Noise coming from here
  181. Rear rotor stuck to ebrake
  182. passenger side miror prob
  183. Looking to buy some R134a gauges and quality refrigerant.
  184. need help, 911 starter?
  185. Trouble starting engine on warm starts only?
  186. Need help. 911. starter or electrical
  187. Insane amount of blowby with great compression
  188. 93 clock spring
  189. How to Adjust Driver Window!?
  190. Need help with cooling system.
  191. a/c is not working
  192. Clutch sticks to the floor loud clunk and grinding sound
  193. T-Top weather stripping
  194. Car is Sputtering
  195. MAF P0171, P0174 issue
  196. I have a leak.(what is this part.picture.)
  197. Vibration in the wheel!!
  198. Little plastic piece on my throttlebody cable broke.
  199. headlights motors on firebird
  200. weird driving issue
  201. How to replace a passenger side wheel bearing?
  202. How to replace a front main seal?
  203. passenger side fan !!
  204. Cross between rattle and grinding sound coming from rear. Help!
  205. need help with 97 WS6 transmission
  206. best place to get a battery from?
  207. whinning noise when turning
  208. change oil light
  209. AC Belt Replacement.
  210. car dies when i stop
  211. Rough Starts??
  212. Borla Adjustable Catback
  213. A/C Compressor Oil
  214. fuel pump?
  215. A4 Torque Arm Bushing How To? (seen install univ)
  216. Car wont start!!
  217. A/C question
  218. Pigtail Part Number
  219. snapped valve cover bolt
  220. Any one using this clutch?
  221. How to properly clean IAC TB Valve without damaging it?
  222. Help!! out of town and car wont act right
  223. not sure if it's the water pump or wp gaskets
  224. Having problems plz help
  225. TA don't like steep inclines!
  226. Another day, another rattle with the SS
  227. Windshield wiper replacement
  228. HVAC control issue
  229. Serious (maybe) Engine problem
  230. Cooling System issues
  231. ~~ Lag in accel, then none. Dont know how to explain... ~~
  232. About to repair cooling system... need some input
  233. car starts bogging while driving and cuts off
  234. 1997 C1500 Vortec 350 Question
  235. Convertible probs?
  236. Is my TC fried??
  237. no oil pressure
  238. ~~ 0 Oil PSI on startup | Tapping!!! ~~ Input Please
  239. ~~ No Dash Lights! ~~
  240. Anyone cleaned their interior knobs?
  241. bad ground?
  242. low beam headlight bulbs dying way too fast
  243. help with overheating
  244. How much is to much?
  245. No power steering to the right
  246. Car died at stop light !
  247. Crank pulley installation problems, seeking advice and tips
  248. Help me diagnosis this noise - video inside
  249. 2001 trans am dying and throwing all of these codes.
  250. Sqeaks when started and may eventually stop
