View Full Version : Drag Racing Tech
  1. Do I need an underdrive crank pulley when running an EWP, no AC, or power steering?
  2. Finally going to the drag strip
  3. k-member gusset
  4. Battery relocation with pics.
  5. wolfe spring relocators
  6. Suspension Guys, put subframes on the car=hard as Heck to hook
  7. Rod End Size on Wolfe DA LCA's
  8. Q's on 275-40-17 DR's 6spd cars
  9. My car is in the August issue of GMHTP magazine.
  10. Finishing my suspension mods - Springs/Shocks, Bags/Sway Bar?
  11. how to launch with radials and moser 12?
  12. Another guess my time slip
  13. weather da difference
  14. 28x10.5
  15. From 440 to 300 lb. front springs on a 50/50 shock, difference?
  16. Which Race Shifter to buy for 2000 Camaro?
  17. trapping 125mph in 1/8
  18. Any pics of Burkhart rear w/sway bar option installed?
  19. Roll bar foot/floor plates.
  20. Heater hose mod and 28" Slicks
  21. 4000 stall / 100 shot.
  22. hoosier qtps
  23. Stealth Pro Ratchet Shifter YOUR THOUGHTS
  24. New rear coming, what else would I need???
  25. T-brake button mounted on factory steering wheel?
  26. Another spring rate ?!!
  27. new tires worst 60 foot.
  28. Grinding Calipers.. (Thinking about 15" Setup)
  29. 10.5 EZ Street build
  30. True Street Set up...
  31. Night Racing
  32. almost there: part 3
  33. drag seats in a street car
  34. Can you patch a MT Drag Radial???
  35. 2006 EVO IX MR, 128,000 miles, at the drag strip
  36. NA 347 Exhaust Backpressure Measurements
  37. Back Half, fab 9", 4 link Build (with pics)
  38. What do you think?
  39. New Drag rims on Greg Welds all around :)!!!
  40. Question about drag tubes??????
  41. How is my race weight?
  42. Big embarassing traction issues, need help!
  43. Strange DAs, need help tuning!
  44. need some help on lt1 setup
  45. More weight reduction help
  46. sale at KYSPEED.COM
  47. Anyone here run the 15" Kirkey Pro Street? 6'0 195 will I fit?
  48. Help With Drag Shock/Spring Set-Up!!!
  49. Rear Drag Set Up opinion
  50. Took a door bar out today!
  51. my first sra to 4-link conversion done
  52. NHRA Helmet Requirements
  53. Optimum Tranny temp at the track.....
  54. Post pics of your Kirkey seats
  55. anyone use pimp juice?
  56. Where would you shift from looking at my graph?
  57. Kirkey Pro Drags Installed Pictures
  58. One set of Hoosier 29.5 x 10.5Ws
  59. Burkhart Chassis Drop Spindles
  60. New Billet and Champion wheels Bead Lock
  61. TA vs Anti-Roll Bar
  62. Adjustable Shocks
  63. which tires to use with 16x8 plz
  64. weight reduction VFN frontend
  65. Grinding calipers Need help now please!
  66. c5 corvette drag race tire question Need suggestions!!!
  67. 10 point cage Air conditioning?
  68. Launching the 2010 A6...
  69. New Tire rim combo
  70. trap speed, same with gears
  71. what stall is right for me.
  72. Help with strange brake set up.
  73. what tire.....
  74. Bias ply tire growth
  75. Suspension Help
  76. track results but questions
  77. which spring/shock for me?
  78. something going wrong when launching....
  79. What Do You Weigh?
  80. how much can a 6l block take
  81. Question for cage guys
  82. Swapping from 3.70 to 4.30 - what gain in ET can I expect?
  83. VFN glass dash install tip
  84. Help with chasis setup, full weight M6....
  85. Roll Cage advice
  86. My cage progress pics
  87. Fed up with my times..whats wrong?!
  88. d think the key to Pacific-style carrier warfare is going to rely on having a superio
  89. My ProStars came in!! *PICS*
  90. Peak Power vs Broad Power Curve(1/4 mile)
  91. HELP! Racing operation stolen from Waldorf, MD
  92. True dual 4" exhaust anyone?
  93. will i need to trim the bumper to run 28" et drags?
  94. C5 suspension help to run 8's
  95. scaled the car today!!! driver needs weight loss....
  96. f-body and c5 brakes...what skinnies ????
  97. goin to track next weekend want 12's any pointers?
  98. Help launching a stalled TA
  99. Need help and starting point on adjustable strange shocks
  100. My First LS-1 car and needing some help
  101. windshield trim/ rear hatch glass trim cheapest place to buy?
  102. Need some advice
  103. How high is your head/helmet w/what seat?
  104. tubular k-member question...
  105. Stock width 9-inch, no mini-tubbing... what size wheel studs?
  106. LS1 to a th350
  107. Driveshaft Play Question
  108. Why can't I hook?
  109. truck oil pan good for drag racing?
  110. Need some tire help DR VS bias plys
  111. Wiring diagram for a battery disconnect.
  112. yank questions
  113. Formula gets certification for 8.50 this weekend
  114. what tire for 500rwhp m6 launching on a shot
  115. My new weight as of today
  116. Tires for a M6 Bolt on car
  117. Outlaw Racing hits Montgomery Alabama June 12th-14th!!
  118. Pics of Cut-off swithch mounting
  119. Anyone make their own door panels?
  120. Converter/Gear/Tire Question
  121. Anyone cut out the Trans Am front bumper part for more airflow???
  122. Carb guys, how much to convert from efi???
  123. Putting come rear QA1'a in the car what springs?
  124. 5 point
  125. Which is better for weight transfer?
  126. Framehorn Pictures.... Can I cut more???
  127. Summit seat
  128. M/T's 255/50 16's with a 10-bolt M6 car opinions please!!!
  129. Window Net Pics
  130. Difference In Launching An A4 Vs. An M6????
  131. Battery relocation with dry cell
  132. Need more m6 help Guys
  133. Burnout-Tire Smoke
  134. Street Legal Race Weight
  135. 10 bolt
  136. Please Help...
  137. 3.89's m6 and runnin out of gear
  138. wiring behind front brakes?
  139. What does your race car weigh?
  140. Anyone have a Write-up on How to Remove Windshield Fluid Resevior?
  141. ATV vs Side by side
  142. rear bump stops really needed?
  143. 5pt harness questions - shoulder and submarine
  144. 3" or 3.5" Exhaust???
  145. Why do my strange brakes not work right?
  146. How to adjust bmr trac pac torque arm
  147. B&M SFI Tranny Shield???
  148. build estimate 25.2 or 25.3
  149. Batt relocate wiring diagram??
  150. MT street radial tire growth?
  151. Which aftermarket K member for daily driving?
  152. spindles + drag brakes
  153. I think we've solved our wheelstand issues...
  154. sub frame connectors and roll cages?
  155. Noob question about MTs
  156. 28x10.5/28x10.5w????
  157. Driving in rain without defogger.
  158. Need help looks like i am unloading?????
  159. Anyone COMPLETELY gut there Z28
  160. Frame Horns (!bumper support)
  161. What Gauges Would You All Go With?
  162. Can Some Explain Density Altitude For Me?
  163. what do you guys think
  164. coolant questions.
  165. what should i expect????
  166. 4L80E to a Glide?
  167. Anyone need a "good" used set of drag radials
  168. cam/gearing/tire question
  169. Bumper Support Questions
  170. tips for using street tires at the track
  171. How Do I Get My MPH Up?
  172. Help on how to drag race at the track
  173. temps after a pass....
  174. racing a auto question.
  175. Putting 1 Fan on a Switch?
  176. If I Open The Exh, Will The ECM Go Crazy?
  177. What ET gains could I have going from Bilstein HD shocks to QA1's in front?
  178. Lt1 shifting into o/d in 1/4
  179. Recommended Tire Pressure for Nitto Extremes?
  180. Couple cage questions
  181. Midwest Chassis Cage! Pictures Inside
  182. how tall of a tire?
  183. Strange shocks
  184. closest track?
  185. Any tips for a newb racing a Stalled A4 at then track
  186. !ABS... light weight option for hubs?
  187. Lowering springs up front with stockers out back???
  188. Vibration/Shaking once TC locks up
  189. 3 way Competition Engineering rear shocks
  190. got one of those lightweight batteries
  191. M/t et drags or hoosiers for my combo
  192. I busted my output shaft! Anyone else?
  193. Ozite question
  194. MADMAN/Pros help me dial my suspension!!! Please!
  195. Transbrake wiring problem
  196. I need some advise
  197. Converter tip/reminder
  198. My new Vibrant "mufflers" pics inside...
  199. ARP Rear wheel stud part#?
  200. Airbag INFLATOR delete?
  201. any pictures of TA w/o fog lights (after !bumper support)???
  202. advise
  203. Foam bumper supports???
  204. Diet safe?
  205. hp/tq+weight= qtrml time?
  206. what options for aftermarket fuel tank?
  207. My Cage Install
  208. Battery Relocation, Alt. Wire Size Question
  209. How long has your 12 bolt lasted?
  210. Ypipe to bullet then dumped
  211. Which DOT Tire is Faster?
  212. how long to heat up M/T street radials?
  213. 60' help
  214. how tall of a tire??
  215. D/S Loop Bolt Zize
  216. Drag brakes on stock 10 bolt?
  217. Camber adjustment when lowering with coil overs?
  218. !cc and tcs
  219. cutting on either side of shock towers...
  220. ******warning******
  221. Car is wrecked! Don't count on solo runs!
  222. Finding the right 5pt harness
  223. Slicks roll out size diffrence????
  224. C5 Z06 Drag Car built by Vengeance Racing hitting the track.. Pics/Video inside!!!
  225. Just loss some weight woohoo!......The car... not me
  226. 6spd guys please come in!
  227. Timing pointer
  228. I wanna lose some weight.. 3966lbs
  229. Solid Motor Mounts - Manufacturers?
  230. What times do you think i could expect?
  231. Question about front end limiters.
  232. 4.10s and a 27" tire??
  233. Post up your rears!
  234. track tomorrow
  235. Sunoco Wide Hood (Pics)
  236. Finally our new Ballast pics!!
  237. Grant steering wheel..LOOK INSIDE please..
  238. Cheap 4340 H-beams
  239. How much weight to add #/ET question
  240. Rear sway bar
  241. My LSX TT supra runs from this weekend
  242. 2gauge battery wire for relocation?
  243. Opinions: Powerglide vs 4L60E/Leaded Fuel vs Alcohol
  244. left confused after talking Spring rates with AFCO
  245. So not only is the car dead, My clutch still isnt in
  246. Track Newbie, educate me!
  247. M6 drag racer's need some input
  248. Street/ Strip suspension setup?
  249. Strange SA Rear Shock Adjustment
  250. Need just a few more tenths..please advise
