View Full Version : New LS1 Owners - Newbie Tech
  1. Thoughts on cars that have been in accidents?
  2. Another pathetic question: 5.3 vs 5.7
  3. Spun Bearing
  4. Clutch drill mod link?
  5. day time run'n lamps
  6. Weird squeaking noise
  7. 69 camaro 2001 ls1 cam choice?
  8. Some Quick Qeustions
  9. need some ignition help
  10. shock tower brace- pros&cons
  11. ignition q's
  12. LQ4/LM7 build questions
  13. What to pay for a block.
  14. Sewing machine...gone?!?
  15. More Horsepower
  16. Finally, i bought ls1
  17. Intake manifold noise? Help?
  18. Start car w/out Front O2s?
  19. 10% or 18% oil pump?
  20. just a few ls1 questions
  21. What Y Pipe should i use ?
  22. Catback install question
  23. Too much Power?
  24. Need help with ls1 question
  25. ::Engine Knock & Oil sensor bouncing::
  26. Where are the classified ads?
  27. Cleaning Block
  28. belts and pulleys
  29. LS6 MAF for an LS2 ??
  30. Alternator/PCM question
  31. MAF 3 pin connector question
  32. crankshaft?
  33. Th400 parts list?
  34. Which Gen III engine would be best for our CJ7 & International Scout?
  35. TOO MUCH pressure!
  36. 2001 SS, first mods. Opinions?
  37. 99 Trans Am into 98 Z28?
  38. LS1 newbie concerns
  39. Thinking of building a new motor for my Hawk Give me your knowledge
  40. How long do ngk plugs last
  41. SLP Lid fitment question...
  42. which tb?
  43. Is it ok to drive after back fires?
  44. best bang for $$$?
  45. Need Advice... i hope the new motor isn't messed up
  46. spark plug question
  47. o2 extensions needed with hooker LT's?
  48. Figuring Motor Build threshold (LS6)
  49. new to ls1's
  50. header install HELP!
  51. ngk tr6
  52. Help oil presser is driving me crazy
  53. what is the point of a throttle body bypass mod?
  54. Car shuttin off at stops!
  55. Stock parts on the 2002 camaro ss
  56. TPS, IAC, MAF ends, valve covers
  57. Hesitation during accelleration
  58. 01 TA motor in a 02 SS
  59. question
  60. Good place to purchase tail lights?
  61. Best Daily Driver!
  62. need help from the pros who know there cars!
  63. looking for cody in belle vernon pa
  64. New Tranny/Stall Now Exhaust Popping
  65. header install
  66. went for a road trip yesterday and have a few questions now.
  67. headers, y pipe, cat back? what else
  68. Solution to LS1 with No Power Steering?
  69. challenge?
  70. oil
  71. cleaning maf
  72. Early LS2, making it fit.
  73. Cam/heads help please.
  74. I'm rich!
  75. Sweet spot for 4.10s
  76. Weird Scraping noise?
  77. Ls1 with M21 tranny
  78. Help! Dim headlight problem on Trans Am
  79. How do i tell if my car is running rich ?
  80. cold air intake off c5 on 00 TA?
  81. good cam set up?
  82. Headers/exhaust
  83. Best way to spend money on an LSX series to make great power?
  84. Coil pack help
  85. License plate frame?
  86. 98 Z28 with No pump
  87. Where's the paint code
  88. Darn headlights!
  89. non adjustable borla exhaust
  90. How long until SES turns ON!?!
  91. I'm Cam Confused!!
  92. ls1 build need help
  93. Turbo or Supercharger???????
  94. ls1 question
  95. Building my first engine
  96. speedo question?
  97. Spark Plug and Wire Installation Help!
  98. Cam selections for D1SC setup
  99. oil problems???????
  100. Swapping From L36 to LS1
  101. Exhaust Question. Help.
  102. Rear Brake Noise
  103. new intake ls1 in trans amĦĦĦĦ
  104. plug gap
  105. do mufflers rob HP
  106. oil change gone bad
  107. magnaflow?
  108. Software for new gear tune?
  109. What year motor and tranny?
  110. Normal oil pressure on a 02 TA WS6?
  111. 2 way momentary switch for cutout
  112. cats?
  113. A couple exhaust questions
  114. Poly Motor/Tranny Mounts good thing or not so much?
  115. 04 corvette cam?
  116. Performance mods, looking to the future of a power adder
  117. How much power...?
  118. Help with buying CETA *Lein?
  119. Will a good set of Roller Rockers free up any HP on a stock LS1 ?
  120. catback removal
  121. LQ4 Upgrade???
  122. Looking to purchase an O/R Y, suggestions?
  123. AC delete
  124. what causes backfires?
  125. Noisy diff
  126. What is the color of stock 01 head gaskets?
  127. Seeking advice for compromise on a DD
  128. check engine light due to headers...
  129. Installing new 02 LS6 in 2000 Camaro SS
  130. Wires going to empty ASR switch spot?
  131. shuts down like in safemode....
  132. 1st set of newbie mods chronicled!
  133. next mod help
  134. TSP or PACESETTER ORY???
  135. Headers, catback, or tint?
  136. ls1 Headers....ory? slp...with???
  137. painted headers
  138. question about tb port/polish
  139. Is it my rear end?
  140. Gears blew up at track...
  141. oil pressure gauge
  142. ls7 cam in 00 ls1
  143. Weight to Horsepower
  144. PA Racing Motor Mounts
  145. ls1 Headers.....Is it realy worth it????
  146. Descreening the MAF
  147. Quick gauge cluster question
  148. Questions on SLP CAI & 02 SIM's
  149. head gasket help!
  150. Need help finding out where to get this:
  151. Clutch Problem 2002 Trans Am
  152. Altitude problem..
  153. exhaust backfire-whats the cause?
  154. Engine Coolant Temp. Sensor
  155. What intake is this?
  156. headers
  157. True Dual exhaust recommendations
  158. what whould you do?
  159. Need help please
  160. Where to find an LS motor
  161. "Free Mod" Section?
  162. Water sizzling from cat converter
  163. Possibly a stupid question...
  164. Not a newbie yet, but...
  165. Did I get the right pushrods?
  166. Intake manifold question
  167. Opinions on this set up!
  168. Typhoon Intake Manifold
  169. SLP Loudmouth 1?
  170. Advice on what to do!!!!
  171. lost thread
  172. Looking to purchase new exhaust tips. Suggestions?
  173. I need help please!
  174. car problems pls help
  175. High mileage cammed ls1s
  176. valve springs
  177. Need some motor opinions!
  178. Just bought 2000 Trans Am w/WS6 A4
  179. need answers!!
  180. engine wont idle
  181. SES light on after throttle body swap
  182. motor mount templatesI
  183. 2002 Formula
  184. buying 02 WS6, any red flags?
  185. pics of sfc's??
  186. Will it be ok to drop from 3" pipe to a 2" glasspack?
  187. 3 most important gauges
  188. 2002 ws6 rims
  189. where to find 224 cam
  190. Exact hookups for the ls6 intake on 2000 TA
  191. T56 Shifters?
  192. Slow return to idle after rev
  193. Bought a 02 Torch Red T/A - Update w/ Race
  194. Do my LQ9 build specs sound OK?
  195. Newbie question
  196. Cats on ORY
  197. helppp!!!!
  198. Best exhaust for stock ls1
  199. Rod Knock, Repair or Run Away?
  200. 00 ls1, 243 heads, ls7 lifters, stock rockers, correct pushrod length?
  201. Air Bags or not?
  202. First LS, need some direction..
  203. Cat help 1998 trans am
  204. lq4/lq9 What's the difference?
  205. Need some advice on modifying car
  206. Need Part Number
  207. stock heads
  208. ticking sound
  209. can i put my t5 behind my 5.3
  210. P&P'd LS1 TB & LS6 Intake
  211. not new but lost
  212. Lq4 questions
  213. Exhaust,Exhaust,Exhaust!!!!!
  214. 02 sensors always fouling...?
  215. turn downs and puddles
  216. Tune after headers and catback install?
  217. O2 Sensors needed?
  218. L92 Casting Number
  219. Most Cubes In An LQ9
  220. Rear O2 sensor placement
  221. I need a list of parts
  222. 2000 Z28 Engine pings
  223. Where did my thread go? PO442 and misfire at idle.
  224. 78 Formula LS1 motor
  225. Aerodynamic CD numbers for F-bodys
  226. Intake manifold questions
  227. Considering running electric cutouts
  228. Just got my first ls1...
  229. Ls2 Misfire - comes and goes
  230. throttle body
  231. true duels
  232. What size bolts for air dam?
  233. Exhaust help, dont want to make a costly mistake
  234. Changing lanes in a 4th gen Trans Am
  235. What it is that makes an LS sound different from SBC?
  236. any way to tell if it's an actual 383?
  237. top of ls1 intake manifold
  238. Exhaust Question with Language
  239. ls9 cam?
  240. Back pressure
  241. ls2 accessory functions
  242. WTF is a free mod?!?!?!?!
  243. Storage - 9mo.? Too long?
  244. Engine Cleanup
  245. 02 WS6 LS1 PCV Gromet Bad
  246. so i bought an ls6 intake manifold...
  247. New LS owner
  248. My 2nd Ls1. Still a noob
  249. Anyone running MSD Coils ?
  250. Rearend question.
