View Full Version : New LS1 Owners - Newbie Tech
  1. new car
  2. First timer
  3. Need help!! Odd T-56 symptoms
  4. c5/c6 fuel pump-obs/nbs truck fuel pump ?????
  5. 99 TA sat for 3yrs.
  6. LS6 Cam P/N?
  7. Engine swap Question
  8. 24K trans cooler help
  9. What Will It Take To Reinstall AC in a 2002 Z28
  10. How long can I go without a tune?
  11. what the hell?
  12. Throttle body install issue..
  13. What do they change?
  14. gto oil change
  15. Next step
  16. Lowering springs
  17. Exhaust leak at the Y pipe
  18. 5.3 build, what am I missing??
  19. Donor car
  20. I need help
  21. need help on trans
  22. Need some quick answers
  23. looking for headers
  24. Car is flooded won’t start.
  25. LQ4 injectors too small for LS1 intake?
  26. Trans Cooler question... *VID*
  27. Weird issue after audio system install, need help *Vid*
  28. Modification ideas???
  29. Exhaust ideas
  30. Trouble starting every once in a while
  31. Will I gain anything over this ram air?
  32. LS Engine Dimensions
  33. OEM Zexel Torson Carrier Questions
  34. 5.3 twin turbo?
  35. Desperate for help!!!!
  36. Motor mounts advise
  37. immobilizer vette c5
  38. ls1 proformance help
  39. Difference after tune...
  40. where do I go from here?
  41. ADVICE 135000 mile ls1 engine
  42. Ram Air Kit on a WS6?
  43. P&P TB worth it?
  44. LQ4 questions
  45. 5.3 newbie ?
  46. Do-it-yourself catback install?
  47. New 98 Trans Am... A few problems
  48. wierd blinking red lights under car by transmission?
  49. Multiple codes coming up
  50. power steering help
  51. Heads
  52. new to ls1 here
  53. Need a cam what would be the best for my 2000 ws6?
  54. Best cam for basically stock application
  55. ls2 intake manifold with 243 heads
  56. brake line help.
  57. too much money for no power
  58. headlight actuator help!
  59. LS1 monte carlo
  60. Power steering pump aftermarket or dealership?
  61. headlight help! 3 DAYS AND 3 MOTORS LATER!!!!
  62. Oxygen Sensor issues after header and ory install
  63. Thinking about sellin my cammed 96 ta for gto!
  64. What to do with my 06 GTO
  65. what valves should i put in my 243s
  66. 10 bolt rear end help :/
  67. Car failed inspection - need front tie rod
  68. Coolant leaking by driver side header???
  69. which oil?
  70. tps sensor special case
  71. Slight Ticking Noise....
  72. Removing Calipers
  73. MY HUGGER ORANGE SS After my FAST 102mm intake manifold install SHIT RIPS!
  74. Gears & Stalls
  75. sts
  76. LS1 cylinder wall thickness question
  77. starting the build on my 02 z28
  78. Will these pushrods be of any use?
  79. Bought a 2002 camaro SS LE!
  80. Help I am new
  81. O2 senors
  82. Question on an auto's rpm/speed ratio
  83. Automatic trans, filter and gasket which one to buy?
  84. New ride 1998 Camaro Z28. I have questions.
  85. SLP COLD AIR INDUCTION Qs!! :)
  86. EPS 230/238 cam; what do I need?
  87. ls motor swap into 2nd gen camaro
  88. Wanting to go with new head's/cam 02 LS1- Noobie Questions
  89. Loose rear passenger wheel, not accelerating as quick as before. Any ideas?
  90. New to the forum, in search of lq9 advise
  91. Getting a tune up Monday or Tuesday
  92. air intake tune
  93. Best mods for newbie
  94. traction control
  95. Help me please
  96. need help finding a used ls6 cam
  97. External fuel pump?
  98. LS6 cam
  99. novice needing suspension advice
  100. weight of a T/A hatch
  101. Super Bright Reverse Lights
  102. 1998 trans am ls1 automatic help??
  103. Where can I get an SS spoiler?
  104. Fire in the air pump lines?
  105. Poll For Swap Vechile
  106. Made a deal *new mod*
  107. holes in bottom of ls1 intake
  108. Can someone run this Vin# possible rare find?
  109. Problem with injectors or something fuel related?
  110. 10 Bolt Chances of blowing....
  111. Quick LQ4 question
  112. Tuning question
  113. seafoam and high mile engines (220k+)?
  114. Best street cam for stock 1999 ls1 m6 camaro
  115. '02 SS LS1: How to Pull Motor
  116. Buying a 1999 LS1. Best Mods
  117. Need flywheel help please
  118. Accidently may have got water in the oil...Need Help
  119. Can't Quite Find what I'm Looking For
  120. Loudmouth vs dynomouth?
  121. Question about lifters
  122. Back to the basic questions...
  123. header question
  124. LS6 intake questions?
  125. Fuel pump in a 02 ws6 TA
  126. Few Newbie Questions, PLEASE HELP!
  127. 98LS1 water in engine bay
  128. lq4 swap question
  129. Fog lights wont turn on
  130. ls1 injector ?
  131. Fuel plumbing with custom rails and cell
  132. engine knocking on highway
  133. Any quick ideas to loss of power!!
  134. Whats up guys - 2000 z28 ls1
  135. Tough Decision
  136. Headlight gear repair. Somethings wrong!!!
  137. 98-99 lid on an 02 camaro
  138. '05 z06 cam on '03 5.3l???
  139. LS1 mock up block
  140. my throttle got stuck open and kept the pedal floored. why? HELP!?
  141. Ptv
  142. What are all these connections for?
  143. Few cam question
  144. Hot Start Probem - NEED HELP / THOUGHTS
  145. Check engine light problem!!!!
  146. Clutch Question
  147. Buying some parts Friday, but need advice.
  148. Underdrive pulley question
  149. Just Installed OEM Magnaflow Hi Flot Cat Converter
  150. camaro-in need help with plz
  151. First Engine Build
  152. few random questions
  153. peace of mind
  154. !EGR question
  155. Bypassing emissions?
  156. 317 LQ9 heads
  157. K-member bolt bottoms out
  158. power steering and coolant problems need help
  159. GearHeadDeals.com Daily Deal Thread 2-27 to 3-4-2012 (Updated Daily With New Deals)
  160. Another differential question
  161. hello im new here
  162. Coolant leak
  163. A/C Recharge simple question
  164. throttle body
  165. ls1 mod
  166. What should I do?
  167. How hp with this parts? i need tune?
  168. ok, give me a break here
  169. What rpm's with what gear?
  170. Repair Guide
  171. 98 ls1 Computer vs 99+
  172. Y2Y RPO code help
  173. Ls1 Problem Fire in the Hole
  174. Throttle body question..
  175. Which was a harder install... Poly Mounts and Headers or Cam and Springs??
  176. New Trans AM Owner/Anyone Tuned with Trinity Tuner?
  177. Anti-Seize?
  178. Questions about lids
  179. Difference between the 99-02 ls6 and the 02-04 intakes
  180. Trans am RPO Sticker Missing
  181. Too many ?
  182. Upgrade from mid-tubes.
  183. Trap Door Mod for Fuel Pump?
  184. Bolt to plug rear O2
  185. SLP FloPac or K&N
  186. will it work
  187. ls1?
  188. Root supercharger with intercoolerintercooler on my LS1?
  189. Best ORY Pipe for LS1 Trans Am daily driver?
  190. !AIR & !EGR write-up??
  191. motor mount swap
  192. Technical Question
  193. Stock tb sticking...any ideas why?
  194. Possible New F-Body Owner? Need experienced advice.
  195. Best stall for M6
  196. SICK CAM for LS Cars
  197. Ms3 Cam or EPS Cam
  198. MAP Senor
  199. 98 m6 engine swap newbie questions
  200. Dealership inspection?
  201. Powerbond 10% underdrive pulley?
  202. lq4 in a dirt late model?
  203. Long tube headers? Tune
  204. Need help identifying my motor please
  205. Finally back in the ls1 family!
  206. Engine and Tranny swap question.
  207. Finally got one!
  208. Really head machine shop????
  209. Fuel Pump Question
  210. Vintage air. what year gm ac compressor to use?
  211. 100 shot info
  212. Thoughts on GMMG Catback?
  213. Installing FTP lid..98 camaro question
  214. LS1 question..2000 ta
  215. 04gto stainless steel braided brake lines
  216. 24 or 50?
  217. firebird/trans am rear end swap??
  218. Help identifying cam
  219. Noob Exhaust Question
  220. Suspension question
  221. Dyno temp
  222. What do you guys think???
  223. will this shifter knob work?
  224. Might be a stupid question
  225. Removing headlights on a camaro
  226. Corvette fuel rail covers: How to install on Camaro
  227. Need help identifying engines
  228. Lq4 or LS1??
  229. headers to bassani
  230. SLP lid & K&N
  231. FREE MODS ON a 98 SS
  232. LM7 ID help
  233. New guy
  234. Lou's Short Stick & Window Motor Kit
  235. Broke in yet?
  236. 5.3 cam question
  237. $500
  238. What do you guys use to recharge the A/C?
  239. Auto-X
  240. longtube headers EGR/AIR block off plates
  241. turbo or cam?
  242. Tb help!
  243. Rear seat back rest removal
  244. need advice/help
  245. WHat is the small wire connected to the back of the slp intake?
  246. Headlight/Foglight Problem
  247. Disconnect power steering belt?
  248. stock mass airflow sensor
  249. Dumb question about headers
  250. Sub frame connectors
