- G spot on power window motor
- power steering
- Creak noise turning left?
- Power window motor Q
- Idle going up and down when stoped at red lights
- ABS INOP/TCS OFF lights
- 2002 T/A Won't Hold Idle.
- Power Window Problem
- Driver's seat belt
- Gauges stopped working and now car won't turn over
- Weird Dash Lights Incident
- How hard is it to put your own freon in?
- Exhaust rattles like crazy after WOT run
- Ignition won't turn.
- Cooling system riddle...
- starter solenoid replacement DIY???
- Left turn signal always on and highbeams
- Air conditioning compressor
- No low end torque car feels slow
- a/c is not working
- Bad vibration when decelerating
- Windshield replacement...
- starting problems
- P0300 on Highway cruise
- Water pump advice needed..
- Window won't roll down?
- Chevy S10 pick up door glass question..............
- stalling shortly after startup
- Help 2000 Z28 Door sagging
- Help!!! Major turn signal problem!!!
- Over heating
- All warning lights came on for a few seconds?
- Gauge Light goes on and off
- Misfires with Humidity/Rain & Other Stories
- Camaro soundin weird
- Cabin Air Filter install 4th gen (if anyone cares lol)
- Electrical Problem????
- a/c dont work have some questions
- Dash lights help!!
- Loss of power
- Window rolls down but gets stuck an make a thumping sound when going up
- riddle me this
- 00 Trans Am almost dies when coming to a stop
- trouble when breaking
- engine light won't go away
- Runs like crap map sensor maybe?
- Radiator adapter
- power steering fluid mixing into my coolant help
- How accurate is the oil computer in 4th gens?
- Motor oil drip
- White residue Inside exhaust tips????
- Turning signal adjustment
- Problem w/Gauge/Radio Lighting
- Possible Short in Electrical System! HELP???
- Ls6 swap cranking with no pcm?????
- car turns off while running
- Right turn indicator light stays on in dash...
- lube job
- Window Won't Roll Up (window motor is working)
- Hard start, surging idle, and some times will not start
- ac pulley squeal
- firebird engine running too fast!
- a.c question
- 2000 trans am help
- Help...2002 TA will not fire...
- LS1 Rough Idle
- huge clunking noise help please
- mass air flow
- Freaking door won't stop creaking!!!
- need help with an AC vacuum line (where to get)
- How to check possibly bad pcm?
- non LSx question.....about octane and a Dodge Hemi truck....
- Gonna buy a new fuel pump for my 3.8L
- 98 vette ls1 swap into 02 z28
- So my headlight cover flew off on the highway
- car isnt starting???? clicks and new batt but nothiong...
- bad fuel pump or starter?
- driver's window rattle
- AC Issues
- Leaky pinion seal, made it worse
- Daytime running lights-possible deletion task
- My car feels loose after alignment
- Fuck the stealership. (motor mounts)
- annoying squeal under load
- Replacing window motors for the first time....
- Need help SES light on and Tach gauge not workin :/
- Belt tensioner again...
- Pop Pop caused by exhaust leak?
- Camaro 92 air conditioner problems,
- Help with DTC Codes.....
- my car is back firing at low rpm while accelerating
- I Have an electircal bug some where..
- 02 S10 4.3, misses under load
- 40+mph car shakes violently with light gas
- Ok, so how much engine "tick" is normal???
- need help with rsar main
- 2001 WS6 idling issue
- Rough idle at stop, dies. Ideas?
- Rear main or Oil pan?
- Rubbing/moaning noise
- Key in Ignition..No Warning Chime when door is open??
- Rear End Leak
- SES light flashing, no codes, and a low end miss
- fog light connector / harness
- I filled up my tank and 100 miles later it is on half empty/half full.
- Nice!!
- Window problem - not motor
- Fuel Neck/Cap Issue
- Idle RPM way too high
- Heater hose question
- Body Ground Strap
- Help diagnose mount problem
- air bag light
- ac compressor idler pulley
- Pinion seal parts?
- Is a prothane trans mount a must when doin prothane motor mounts?
- 1998 SS wierd PS leak into coolant?
- Bad coolant temp sensor cause the engine to die?
- Battery Disconnected long time
- Wiper go up when turned off!
- No Prime From Fuel Pump
- Pop when backing up
- Please help identify this noise on my 2000 SS
- Security Light / Car Not Starting
- Blazer is trying but just wont fire
- Got a weird one for you guys
- Electrical Problem!?
- Oil pressure and battery level
- Belt squealing after P/S pump install
- Rack and pinion
- Ls6 swap?
- starting car with EVAP solenoid unplugged?
- Battery issue.
- Alternator low voltage?
- Noise coming from driveshaft where it goes into tranny
- convertible top
- Noise coming from under car
- A/C pressure switch
- ls1 lsx gauge cluster ?
- lost throttle body shaft lock washer
- Coolant in P/S fluid reservoir
- Driveline removal
- Disconnected Plug in Engine Bay
- SES flasshes. Code P1406
- Water Pump Gaskets
- Possible use for A.I.R. pump ?
- Fuse box cover..
- A/C is a Pain in my ASS!!!
- Cluster of symptoms
- To remove or keep
- Leak At Cowl Screen
- How much should an engine analysis cost? (Misfires come back until pcm gets reset)
- 3rd Brake Light Out, No Voltage to it...
- How do you reprogram the keyfob?
- need help
- power steering whining sound
- Passenger Air Bag Cover=Warped
- Air conditioning + Southern Heat
- Rear main seal question
- Damn vibrations!
- idle problem any ideas
- Oil filler cap
- Squeaky clutch pedal lol
- Not sure how to proceed.. mini starter....or battery....
- Tips and tricks for exhaust manifold bolts?
- Burnt Oil Smell
- Squeaking after turning off engine
- really low idle
- Replacement license plate lamp
- Wiper motor bad or whats going on????
- Engine Oil Additive Question
- Some sort of rattling is happening but I can't figure where it's coming from
- What is detonation?
- Help misfire lost
- Exaust Mani. HELP!!
- A/c not blowing out the vent
- loud vibrations
- Service Vehicle/ASR OFF/Brake/ABS INOP
- HELP Car voltage issue, now no start
- What is this weird hollow knocking sound?
- Oil leak behind timing cover
- Replacing Blinker Switch
- Rattley hatch
- car won't start
- Headliner
- Burnt plug?? can't tell what plug?
- car got Refed ...
- P0151
- Car fell flat on its face, lacks power = plugs fouled?
- need help
- high pitched screech on startup
- Will Anti-Seize effect torque values
- should i be concerned?
- Installing new Throttle Cables... Need some help and maybe a pic or two
- Top Ten Best Performance MODS?
- clueless
- car starts then shuts off after a few seconds
- Here we go ago!?
- Remote Starter Switch Install questions
- I have no idea?
- Quick questions concerning my car (3.8 V6 Firebird)
- Speed sensor leaking???
- Spare Wheel Compartment Leakage
- Creaking Noise when oil is Low
- annoying clunking sound , help
- Seafoaming a 3.8L F-Body?
- Security issues will not let car start.
- Oil pan leaking after new gasket. updated* Cracked block...
- Part # - fan pulley tensioner - LS1 ?
- Need Help with Misfire.
- Compression Testing
- AC Iridium Spark Plug Gap
- Engine shaking at idle
- No Oil Pump O Ring?
- wiper arms please help
- weird problem
- What is the name is of this part????
- Radiator Crack
- Alternator Charge
- Interest in NGK Wires?
- Terrible idle
- Will a 98 camaro MAF be okay on a 02 Camaro?
- Anyway To Make My Speedometer Out 15 mph-
- car accelerates son its own!!!!!!
- Bone Stock '00 SS PO420 code?
- battery connection
- Door pushes out when window goes down
- Help: engine bay noise
- Maybe now you can diagnose the problem with my car (VIDEO)
- Cranks but no start?
- Coolant leak?!
- Anyone familiar with these, or seen these before???
- 1996 Firebird 3.8 P0304 Cyl #4 Misfire Issue
- Gauge cluster repeat problem...LS1
- Replacing my thermostat
- What temp is stock thermostat?
- P0507 code
- Please help me diagnose mysterious coolant loss
- Rattle on accel?
- p1153 problem
- Service vehicle light??? car acting strange
- car smells rich...gas mileage gone to hell
- Electrical battery (problem)
- AC help. Please!
- 90k 98 ls1 car maintenance
- P0171 P0174, Intake gasket?
- driveshaft humming?
- Need some help with coolant leak, anyone?
- 5.3 with lifter problem
- Replacing O2 sensors (Pre-Cats)
