View Full Version : Carbureted LSX forum
Pages : 1 [2] 3 4 5 6 7 8
  1. g body 6.0 build questions.Long post.First timer
  2. ls1 fox mustang conversion
  3. proper piston-cylinder clearance
  4. Cam Help
  5. carb cam - can I run this cam, should I run this cam
  6. How did you mount and route your msd harness
  7. Build Opinions
  8. first start w/ carb
  9. Lq4 carb'ed help!!....newb
  10. msd 6012 miss
  11. Need help please
  12. msd 6012 question
  13. LQ4 6.0 Cam Question
  14. Edelbrock and MSD
  15. Help needed
  16. Need opinions
  17. really need to sell whats it worth
  18. 5.3 nitrous build
  19. 63 nova stock front end header issue
  20. picking a cam for a 5.3 foxbody
  21. is my security why my car wont start?
  22. Transmission adapter plate question
  23. 86 IROC 6.0 shake down pass
  24. parts need
  25. borg warner super t10 four speed?
  26. Anyone using Nitrous and a stand alone?
  27. anyone have an SV1 on large cube motor?
  28. 5.3 vs Vortec 350 in a Jeep
  29. Changed direction on project.
  30. A1000 fuel regulator questions
  31. Fuel boiling....
  32. Breaking up at 5k and above RPM
  33. what plugs does everyone run?
  34. victor jr + 4 barrel
  35. stall speed
  36. 6.0 with LS3 Heads
  37. 5.3 heads
  38. 5.3 cam sensor question and swap Q's
  39. Edelbrock performer rpm intake ?
  40. is this a good cam for mostly stock 5.3
  41. Ordered custom cam surprised with new specs but looking forward to how it runs
  42. Pre-Detonation when I step on it...
  43. fuel pump questions
  44. coils
  45. new nitrous and fuel setup
  46. radiator and hoses for a body ?
  47. Corvette ls1 cam
  48. Gonna test this new carb spacer....what do y'all think?
  49. Prepping for first start of carb'd stock LS1 w/ MSD 6010 and Pro-Systems 750 carb
  50. Ported heads
  51. which flywheel do i have ?
  52. L76 Camshaft suggestions
  53. LSXTV published a web feature on my car.
  54. really high timing help
  55. carb stumble at initial WOT
  56. Ls4 on carb upgrades
  57. intake swap?
  58. 89 fox gt lq4 carb'ed build!
  59. Trying to get 500hp out of my LQ4.....
  60. Any regrets for converting to carb?
  61. Vic Jr l92 efi intake porting ?
  62. Which Regulator with Aeromotive SS Pump?
  63. 94 S-10 lq4
  64. 94 S-10 lq4
  65. Victor JR for L92s?
  66. rebuild or get a differt motor?
  67. Need alternator and front pulley advice
  68. Head Gaskets
  69. Shift light with 6010
  70. vvt with a carb setup question..
  71. bigger accelerator pump needed?(vid)
  72. 1st street pass!!
  73. Expert Carburetor Advice needed, video of issue
  74. Transmission help
  75. 5.3 with torquer v2 cam.... Dart 225cc heads too much??
  76. Holley Red pump going to be enough?
  77. 87 mustang carb'd lm7
  78. Lsx?s need your advice
  79. cam choice
  80. rod and main bearing clearances?
  81. LY6 Build.
  82. Merry Christmas
  83. cam for blowthrough turbo car?
  84. Video of my Mustang vs. my Camaro yesterday
  85. Fast ez efi
  86. Speedodmeter on Carb conversion
  87. Popping when accelerating
  88. Vic Jr intake
  89. Bleeding ls clutch
  90. Plug gap?
  91. 408 Ilde clip.
  92. AES Announces Our First Year End Sale!!!!
  93. Ful system questions - 5.3 with Spray
  94. Carbed 6.0 swap thread
  95. New plans with the 6.0
  96. thoughts on my planned 5.3 build
  97. Cam Help 408 on the spray
  98. carb and 4l60 with stock ecu
  99. How much vacuum at idle?
  100. which aeromotive street/strip pump does everyone run
  101. 5.40 is it possible
  102. New to LSx need some advice
  103. N/A vs N20? I'm TORN
  104. boost
  105. better cam
  106. Looking for opinions of carbed 5.3 s10 build
  107. changing heads and maybe cam what would u do
  108. msd 6010 + boost
  109. Alternator wiring
  110. 99 Z28 + L76 + Nitrous
  111. Super pissed...
  112. 87LSX Monte SS shakedown pass
  113. Crank snout runout?
  114. anyone running a carb 402 or 408?
  115. Cam choice for carb'd 5.3 coupe
  116. Stock 5.3 93 coupe mustang what time should I run?
  117. Tiiming for N2O
  118. Stuck between the 2!! Blowthrough or N2O?
  119. Looking for cam
  120. Why does blow thru not seem popular for LS motors?
  121. help
  122. proper plugs?
  123. Carbed lq9 project help
  124. Windshield wipers... carbed 4th gen, ideas from anyone welcome!
  125. Edelbrock 2215 and 2216 cam
  126. 13:1, 150 hit and pump gas
  127. Intake change
  128. Carb over flowing.
  129. carb stumble
  130. 862 vs. 243 Heads
  131. Holley Tunnel Ram
  132. Easiest way to rig starter?
  133. perf rpm
  134. 5.3 teardown/build
  135. started my swap
  136. Help with Rad Fans
  137. FYI for Performer RPM users!!
  138. 6010 no fire....please help!
  139. Carb air filters for F Body
  140. My Ls3 Powered Dime
  141. my quest for the 10 NA
  142. Carb good for my set up??
  143. Balancer Installation
  144. 10.96 run
  145. New Best
  146. Turkey day
  147. Z32 570zx LS1 swap
  148. cam choice?
  149. horse power
  150. Black Friday Deals and Sales
  151. Carb setup under a stock WS6 hood?
  152. lq4 timing chain too loose or is it ok???
  153. msd boxes.
  154. Questions about blow thru 5.3
  155. thinking about getting a cam
  156. MSD 6010 - MSD to PC: Data mismatch: 9
  157. 4.8l nitrous build/ carb lsx
  158. 6.0L/t56 in 64 nova
  159. Question on cam manners
  160. Two stages of nitrous using a MSD 6010
  161. Should I replace my Mighty Demon for a custom Prosystems Carb?
  162. advice about timing?
  163. Lets Play "Name That Cam!" And the Winner Gets A Free Camshaft!!
  164. Help to find the right size carburetor
  165. My LSx Notch
  166. carb bog
  167. Gen iv 5.3 help
  168. How much compression is safe on pump gas?
  169. please post pics of your map sensor setup
  170. knock sensors on top of motor..
  171. Best way to wire grounding system ?
  172. Head gasket question
  173. Best cam for stock LS3
  174. New Carbed & Sprayed 440LSX - Build Thread
  175. Timing causing dieseling??
  176. pro's and cons on this switch
  177. What intake gaskets for vic jr on LS
  178. I need a little advice with my 5.3L S10.
  179. New PB
  180. Whats going to be the best bang for my buck?
  181. 87LSX Monte SS VID
  182. New best on the motor 11.43 @ 118
  183. milling 706 heads
  184. Over The EFI Set up Need Advice on the Carb Set up for a F Body 95
  185. What will it run?
  186. poor man' s fox mustang
  187. valves
  188. 87LSX Monte SS nightime burnout vid.
  189. my engine
  190. Blow Thru Carb Turbo 5.3 Foxbody Build
  191. 4.8 cam
  192. tinkered with the stang again
  193. Are Dart 225cc heads too big for 5.3?
  194. A body's wheres your fuel pump mounted ?
  195. new tire size pic
  196. 1st 1/4 mile pass
  197. Hood clearence with carb set-up?
  198. Dyno Report...LQ9 Mustang...
  199. 1ST Timer
  200. 1ST Timer
  201. What intake gaskets should I use
  202. head change how much pickup
  203. headman hustler s10 long tubes
  204. Ram air set-ups
  205. Nitrous Stand Alone Fuel Systems with Race Gas
  206. manual water temp gauge
  207. L92 Victor Jr users...step inside please
  208. Anybody using an EFI fuel pump??
  209. first time at the track this year
  210. 2 wire alternator, what goes where ?
  211. 5.3 paper build - any advice appreciated
  212. Hooking up the 6ls 6010?
  213. Lq9 swap with Carb need help with pump
  214. main cap's torque?
  215. I'm back!!! thanks to 3pedals i'm super motivated about this LY6 swap and a carb
  216. lq9 on alcohol
  217. Backfire Issue
  218. Making the drive to test 1/4 today.
  219. 5.3 1/8th mile testing
  220. 6.0 Build critique
  221. Holley setup advise please.
  222. Holley, Barry Grant , Quick Fuel??? Which would U Buy??
  223. Carbureted L33 Help in my Caprice
  224. Carbed or efi? Seeking input
  225. MSD Box that comes with the Victor Jr. kit
  226. A different fuel pump question
  227. My 5.3 retro fit
  228. Input on my ideas...Carbed Lq4
  229. Performer intake and nitrous?
  230. is their an adapter plate to mount carb sideways
  231. 4.8 carb advice
  232. electric fuel pump question
  233. Aero vs trap speed
  234. BG holley carb
  235. Help picking a carb
  236. Another oil leak thread (sigh)
  237. going carb on my 98 ls1 transam, sick of my tuner
  238. help me reach my goal
  239. cam sensor for MSD 6012
  240. carb maybe....
  241. Selling my 1975 C3 Corvette with ls1
  242. LSX G Body Run Video
  243. What kind of numbers?
  244. 50cc acc pump
  245. engine advice
  246. cpl last things and its ready! few ?s
  247. too big of cam?
  248. Another PCV question thread
  249. New eps cam specs!!!
  250. Hooked up my lock up torque converter
