View Full Version : Suspension & Brakes
- Manual brakes on DD
- Need advice on my future suspension setup
- Looking to get rid of some of my body roll
- critique my suspension setup
- how to make a car hook on 18" tires... straight line
- Strano Performance--Proven results
- Installing Intrax Springs-Question
- BMR Fabrication Cuts Prices for Lower Control Arms (TCA001)
- steering issue
- stock sway bar question
- strains at launch
- Speed/ABS Sensors
- BMR Lowering Springs - Best Quality for Your 4th Gen
- C5 or C6 upgrade for LT1 brakes
- Adj. LCA and panhard bar installed
- Installing rear Koni's... What to torque the nuts to?
- Truck Rotors with passenger bolt pattern?
- How would a Strange 12 Bolt Affect Handling?
- Parts needed
- How do you change rear shocks on vert Camaro?
- Lowering- New upper mounts?
- New steering rack install.....small issue....
- help with bad tire rub.
- Is a Torque Arm Worth it?
- is $250 for 1 tie rod end and an alignment high?
- G2 f-body coilovers
- My new CTS-V brakes & edelbrock adjustable coilover write-up!! LOTS OF PICS!!
- qa1 rear shocks
- Need some brake help ASAP. Doing brakes right now!
- Broken front sway bar
- Post pics of trans am lowered
- PLEASE HELP! What is busted in this pic??
- 2002 Trans Am suspension and Brake Help
- stains on new disc..vibration and fade
- Any Adjustments needed for Perch and Hose Mod???
- Locked piston, replacing both front calipers
- need new shocks . . . reccomendations?
- lowering car with true duals?
- Took A Few Pics
- BMR Reduces Prices for Lowering Springs (SP001)
- Alignment Specs for DD/AutoX
- "Brake Noise" especially when turning
- power steering question
- Brand new suspension noise?
- body mounts
- Strano Springs... in stock (low, but I have some)
- Help! i need Koni S/A front and D/A rear part #'s
- Strano spring install ?
- umi Double Adjustable Panhard Bar INstallation
- How long does it take you to bleed you brakes? Im about to lose control
- Bilstein Shocks
- first real suspension piece ordered; kind of excited...
- LS1 Brakes on a Gen 3 Camaro
- brakes
- torque arm bolts
- A few new products from UMI Performance
- Inner Tie Rod Swap
- does wolfe ship roll cages assembled already?
- Swapping lowering spring with stock
- help with lowering springs
- Rear shocks for my situation?
- lookingg for traction
- Panhard bar bolt size?
- Why Me?
- UMI K-Member raised my car ???
- Whats an ideal rear shock characteristic?
- QA1 racers enter here...
- confused about lowering a vert
- help
- Spohn new LCA bushing ends
- Can anyone identify this aftermarket rear LCA?
- Bent 1LE end link, better alternative?
- Caliper Bolts
- 600 to spend on suspension. help!!
- Help!!!!!!
- Have new tubular suspension, where to get hardware?
- Handles like jello, Z28 to SS conversion
- adjusting brake pedal
- BMR torque arm relocation kit for 4L60E?
- how good are the KYB AGX shocks
- how much will the Koni adjustable shocks lower the car
- 1LE springs?
- Struts..please help
- lowered car/ panhard bar????
- slp line lock/ abs delete kit????
- how do you center the rearend on a f body
- Clanking noise.
- Dumb Caliper Question...
- Springs!! Help me out
- Any Rear Coilovers for Strange Shocks?
- Looking for Rear brake lines 99-02
- UMI PHB Relocation kit interference
- My UMI torque arm broke . . .
- help with new Shocks
- Pic of Corvette conversion kit from 6litereater
- rear suspension slowly sagging on C5 z06, help!
- ABS/Traction Control Problems
- Which holes to mount torque arm to rear?
- Axle Bump stops / limiters?
- shocks and springs
- LT1 F-Body Rear Brake question
- ? 2.5" true duals, will they go over the factory PHB support or will I need the UMI?
- Where to start with stock suspension
- UMI subframe connector
- Lowered an rubbing
- Which lowering springs with long tubes?
- Need Help with Caster Bolt!!!
- Rear shock absorber review: KYB AGXs
- BMR anti squat brackets and SFC mounting
- Need help with suspension
- ABS Delete ?
- What hardware (sizes?) do i need for LCA brackets?
- 1993-2002 f-body new shocks and springs 4-sale
- What is a good street setup?
- Missing washers on BMR T/A?
- SFC's
- Rear brake question
- power steering leak.BAD
- LS1 camaro steering rack: which is pressure and which is return?
- New Rear Rotors and Pads and a new noise
- Might have screwed up. Which way to adjust for positive caster??
- Parking brake help needed
- Power steering goes out when it rains??
- no more wheel hop for 60 bucks
- Rear shocks fully extended?
- 12 C ABS Codes!
- front lowering springs
- Some noise after installing some suspension
- Koni SA rear - torque specs?
- Question on Stock shocks and coil springs
- Relocation brackets
- Watts Link makes my Torsen quieter?
- Brake Question
- Torque Arm Bolt Size?
- Adjustable LCA?
- Brembo rotors and Hawk pads
- Right way to bleed the brake ?
- Wheel stud issues!!!!
- Torque Arm Install Problems
- Right rear brake locking up on hard braking?
- Brake Calipers question
- Awful braking issue, scary.
- Duralast Bushings
- next suspension mod?
- Easy way to flush brake fluid
- Which Torque Arm is this?
- replacement shocks
- Dual rear caliper write-up????
- Tranny mounted torque arm vs tunnel brace mounted
- drilled/slotted rotors... need them or not?
- Can't find someone with this combo - stoptech 4 piston fit this wheel?
- URGENT!!! ABS INOP Light when EBrake it Down
- Need help with brake lines!
- where to buy anti rattle clips for brake calipers
- umi k member
- UMI Sway bars too much?
- 2010 Camaro Brakes....
- cutting spring to lower car???????
- Spohn TA Snapped
- SLP SFC mounting hardware
- Easiest way to measure MM of sway bars
- Spohn Torque arm wont clear exhaust. :cry: What to do?
- Front end "creaks"
- Jacking from aftermarket K Member
- startin to make noises!
- Help: Need more caster
- What lower control arms should "I" buy?
- Delrin bushings instead of urethane or Heim.
- Installing SFC's...How do you get the LCA bolt out?
- Lt1/ls1 rear brake swap
- Wheel hop
- Upper Strut Mount
- stock front control arm bolt size?
- sjm abs delete kit? need alittle help!!
- Alignment issues
- Whats the difference???
- Suspension: Shock settings & ride height
- Panhard bar install ... gone wrong. How to fix?
- I added suspension then I slowed down. Help
- where to measure
- I have a (potentially) brilliant idea for a BBK for 17" rim guys!
- need help with struts please?
- Need info on steering rack bolts for rack install
- Do I need c5 brake lines for my c5 z06 caliper brake swap onto my 99ta
- Upper and Lower Ball Joints
- suspension mods ?
- Explorer Brakes on a 9"
- Clank noise in front end?
- jegster torque arm?
- 95 different than 02?
- Rear shocks and springs?
- what do I need to pull a wheelie
- Rear brake help
- Line Lock setup pictues needed ! ! !
- C6 Calipers Installed
- Has anyone had this...
- stb vs fast
- What difference will C5 rotors with stock calipers make in Braking ?
- quarter panel dent
- torque arm noise finally gone
- Lower car or not for track ?
- ? On calipers
- BMR torque arm install problems
- interior door bar question
- What to do first? Watts or Strano sway bars?
- Adjustable rear ride height without coil overs
- Easiest way to install LCA's??
- Reinforcing factory torque arm??
- A brake Question BUT on a Nova......Yes a Nova
- Installing Fays2 Watts, have some questions...
- Question for folks with 1LE front LCAs
- Check your Nuts!
- wow i bought the wrong CTS-V calipers :( please help!!!
- Relocation crossmember & torque arm
- Opinions on Tokico Hi-Performance Shocks?
- v6 to v8 brake system newb q
- suspension n00b. school me.
- WTB: Lowering kit for an '01 WS-6...
- A bunch of swaybar questions.
- CETA with Strano/Koni combo
- Evolution rotors
- Brakes for clearancing drag wheels
- installed eibach pro kit and no difference in front end height?
- I got rid of the clunking from shifting.
- How Long do Bistein shocks last?
- Alignment after lowering?
- Watts Link Installed
- Post install questions
- weird noise
- How hard would it be to adapt some 996 calipers to an F-body
- What suspension parts to replace?
- PMT control arms? what u guys think?
- replacing front brakes, input please!
- m6 qa1 guys come help a fella out
- Need help picking shocks/struts
- Need help with Koni install, come in please
- Do i need upper a arms?
- umi tq arm relocation and lca's instructions?
- Got some used Konis, what hardware do I need?
- ABS INOP and TCS dash lights on
- the joy of replacing brakes
- Newbie needs brake upgrade advice !
- Moser 12 bolt and stock brakes
- Lower Control Arms and panhard rod...Install??
- K members
- Question about Dual Caliper setups
- Suspension Questions..
- remove the bump stops?
- something broke today!!!!
- Brake question..
