View Full Version : Suspension & Brakes
- Lightest Front Suspension setup?????
- Air Shocks?
- Which torque arm?
- Tired of Stock Suspension
- Rotor weights?
- Best torque arm and lca's?
- Replaced all rear suspension w/LGM stuff.. whoa!
- Need Installation instructions for GW Trac-link System.
- BMR panhard rod
- Tires/size??
- 285's?
- Eibach Pro Kit on stock shocks?
- Need help on 1LE springs
- Which tire for 17X11's
- Question about MADMANS torque arm
- Hotchkis Panhard rod rattling how do i fix this
- Difference between Z28 and SS springs
- What rotors should I get?
- I have Wheel weights info.. look inside.
- BMR K-member,now alignment is way off.
- Best street/strip tire on tread life and money?
- What Backspace do I need? Draglites!
- rotor install question
- What would you guys do?
- Baer Eradispeed GP.... interested?
- Anyone running Prokit & SLP Bilsteins
- removing rubber above rear coils
- Installing SFC
- Suspension for Auto-x???
- Squeaking issues
- Wheel problems after flat tire
- SPORTLINE SPRINGS/WHAT SHOCKS?
- knocking noise! help me!!!
- Popping noise from new swaybar?
- HELP!! Lug nuts WON'T COME OUT!!?!
- Hal QA1's and aftermarket T/A question
- shocks with g2 super springs
- Which ET Streets - 26"x10.5" or 26"x11.5"
- longevity of front end-links? symptoms?
- Questions with Hotchkis SFC
- Bridgestone RE730 or Firestone SZ50 EP ?
- Nitto 555 ?
- How do you improve braking cheaply?
- What brake fluid to use?
- SFC for a convertible?
- What Tires for MY Set-up?
- taking off front swaybar
- Which 3PT STB to buy?
- Is Fast Toys correct??? Shock Tower Brace...
- Help with suspension bottoming
- Torque specs for spring install?
- What should I torque my....
- Recommendation of tires for daily driver?
- Are Monroe shocks alrigh to have for a while?
- knocking noise?! help me out please!!!
- V6 Springs
- BAD Wheel hop after Moser install! Help!!
- nittos and rear end??
- anyone know of any 275/35 R18 drag radials??
- Squeaking !!
- Spohn Torque Arm killed in action.....
- Which one weighs more? LT1 or LS1 front brakes?
- paging the almighty colonel
- vette brakes on f body
- et streets size ?
- Question on installing front springs...
- Flushing & Bleeding How Many 12oz Cans Needed
- Brake Fluid
- vibration in steering wheel when stoping....
- What weighs more---wheels
- Who Makes Delrin Swaybar Bushings
- Are the G2 springs available?
- Does it HURT to go with the BMR Xtreme Torque Arm
- Installing SFC's before and after lowering?
- Car is very bouncy, need help with suspension inside
- Eibach or G2 springs- Differences?
- G-Stop installation pointers needed
- No grinding please! Better Calipers?
- Adjustible panhard rod???
- Car shaking badly after changing the front rotors
- Lakewood lower control arms
- 1/4 Mile Question
- Best SFC's for daily driver?
- vibration question??
- Bilstein HD's good for Eibach Pro-Kit???
- Anyone order Shocks from Bimmerparts .com
- LCA and relocation mount question
- How Much Can the OEM Brakes Be Improved?
- Nitto's DR 245's or 275's on 16 inch ?
- tire question
- moiser 12 bolt vs strange 12bolt
- Why wont my BFG Drags Hook?
- Slowly accumulating suspension parts...need advice
- Porsche based Big Brake Kit
- Which K member and A arms to choose?
- Eibach Sportline springs
- Traction Action Questions!
- Roll Cages. Bolt-on or weld-in??
- Nitto Drag Radials
- FEEDBACK on wilwood superlites,,,
- Lightweigh Brakes
- Z06 caliper, how many pistons?
- Opinions: Spectacle Solutions Bolt-on SFCs?
- welding SFCs?
- Just got BMR bag of goodies installed!!
- How do you like your Eradispeed Rotors:
- creaking after roll bar install???
- 12 Bolt
- Help Centering rear....
- Help on what to get
- sfc vibration
- how to tell what size springs i have???
- lca relocation brackets necessary
- Hotchkis or Eibach Pro Kit?
- Kenny Brown or BMR SFC's?
- important tire width question.....
- Camber Question
- Sub Frame Connectors good for Drag Racing?
- All those with line lock within.....
- transmission bushing help
- KYB AGX shocks with Hotchkis springs?
- torque arm bushing?
- HELP!..need new suspension!
- Brake Rod
- Emergency brake problems
- Any suggestions for brake pads? Is install simple?
- K-member and Subframe ???
- correcting roll center?
- Baer Claw System installed -- Pics and Issue inside
- NO TRACTION! HELP!
- bad ball joints?
- sfc's help fast please!!!
- wheel hop
- Is Factory Power Steering Cooler Adequate?
- Stock SS Swaybar sizes?
- OK to just replace front shocks when lowering?
- Need a good alignment shop in South Florida
- Cutting stock springs, searched still have questions
- 12 bolt ?'s
- Front end alignment necessary?
- oh my . oh nooooo.
- How fast can you run the 1/4 mile with regular street tires?
- Wanting to buy a STB
- Bmr lowering kit?
- Torque arm info...
- QA1 Shock?
- Tunnel Brace
- Will a bigger rear sway bar with the stock front sway bar hurt handling?
- Help
- Boxed LCA's ????????
- Eibach Pro Kit
- Eibach Pro Kit
- Are BMR Lower A-Arms worth the weight savings?
- OEM stock brake pad part numbers
- Help Please...BMR K-Member doesn't fit.
- manual racks
- Which drag radials
- wolfe racecraft
- what springs do i have..
- NEED HEADER HELP!!!!!!
- directions
- jounce stoppers ???
- handling with 315's?
- Toe-In Gauge or Toe-In Boards-Which Preferred
- SES light for rear ABS sensor, help
- cross drilled and slotted rotors
- What mods are required to mount ET Streets on stock 16inch rims?
- SFC question
- QUIETEST torque arm that actually WORKS?
- Road Racers In Here Please ,Caster/Camber Gauge Question
- Weight of Fikse Wheels?
- Nitto 315s or 275s will 315s fit
- How long did it take you to change front brakes?
- car droops to one side...what the heck??!!!??!!
- Please Help -- car tilts to the right.
- Another Sway bar question???
- ok my list is out, need some help here
- EBC Rotors? PowerSlots? What Doesn't Warp?
- DRAG LAUNCH SPRING ?
- slp sub frames and headers?
- Does Strano still post here?
- I just installed revalved bilsteins..
- anyone using Lakewood
- Help me decide between mods...
- Opinions on these tires, time to get some new ones
- rate this setup!!!!!!!
- Any Dif. Between Prothane and Energy Suspension?
- new upper ball joints, need bolt size?
- chromemoly ?????
- Opinions between KVR and Power Slot Rotors
- Bent Spindle
- HELP??? ABS INOP/TCS/Brake light on
- addco swaybars?
- sway bar
- 255's on a Stock rim ok????
- Which Slick
- LS1 to LT1 rear brake conversion
- 16x8 Firebird Rims
- Brake Claspers
- Suspension upgrades...
- need pic of brake lines after k member install!
- Eibach Spring Rates
- 1.58 w/ just LCAs at SLP day. How to improve?
- how much for front brakes+all around brake lines isntall?
- abs & tcs lights
- 205/40/17 Tires
- Im trying to put the stock LCAs back on and they are identical...
- Panhard Rod Bolt Sizes?
- Spacers for rear springs ...........
- Squeek coming from Dash area
- will sphon T/A fit slp sfc's and longtubes?
- Advice On convertible SFC's?
- Weld draglite fitment on LS1.
- Cadmium coating - Rotors??
- rotors
- Subframe connectors
- Hal front springs lowered car, what springs to get?
- Speed bleeder help....
- trimin the springs
- Need help setting my pinion angle PLEASE!!
- help me make up my mind
- Poly Spring Mounts?
- So basically all panhards are the same?
- Installing new L.G. Motorsports G-stop Brakes tomorow
- Can anyone help? New brakes wearing in an odd pattern
- What new wheels and tires for my '99WS6 F'bird?
- How to adjust LCA?
- Anyone using these rotors?
- Tech-1 or T-100 scan tool...for TCS system...
- Handling feels messed up. Need help!
- Cutting springs...
- Suspension newbie...input on possible setup?
- No traction....at all!! Need advice!!
- BMR Control Arms And K member
- Stock suspension weight
- front shocks
- Found source for HiPo steering pumps and such..
- Where to buy eradispeed rotors???
- Goodyear Eagle F1 Supercar question....
- Teflon Brake Lines
- Best Brake Pads that don't squeel or dust?
- Check Sponsors & specials for PPC LCAs, PHBs. & TA ...
- Autocross Tires?
- sterring problems
- adjustable panhard rod?
- Anyone run brake ducts from Camaro grill holes?
- how would eibach drag springs be for a daily driver?
