- Just ordered my Cage and Back half kit tubing! all 4130 Chromoly
- Mini Tub Guys
- formula drag car hood choice
- M6 guys with drag radials, come in
- what rpm do you guys shift the MS3 at?
- k member and 60'
- Which springs for my drag car?
- Few Miscellaneous Questions
- Lower Psi take "shock" out of DR's?
- PA Racing K-Frame bad fit.
- weight
- Any pics of QTPs tread lines?
- will 315nittos fit on ws6 wheels
- Next biggest bang for the buck thread.
- Does offset matter for drag tires?
- Is there a 6 speed drag radial record?
- '02 Z06 in the 1/8th?
- 346ci 6speed record??
- set-up times?
- Question for those with the wolfe adjustable rear spring mounts
- finally got my wheels on *pics*
- Any guess on what my idea will run
- NMRA Drag Radial Setups?
- NHRA required parts per E.T. class
- can you mount these to a cage and be legal?
- Is 1000cfm big enough to support 600-625 NA hp???
- LSX Mustang Videos
- gauges R done whattaya guys think?
- If Chromoly can be Mig welded, Why all the Fuss?
- Can I put a 28" slick on a 8" rim?
- 60' Question
- drag struts 90/10???
- cutting bumpstops
- Symptoms of Converter Failure?
- Helmet question, I wear glasses, which one?
- rear girdles?
- Will this car ever go down the 1320?
- Where to get 2 step?
- Will this suspension help
- adding a delay box
- Roll Bar question
- Floor modifications for 9" rear?
- What should I do to get my car to hook up
- My first time running...Advice?
- fabbed door panel pics.
- Will I notice any difference?
- How's my TA running?
- ride height with qa1's
- Is a 325 M/T drag radial too much tire?
- Need Some Predictions
- What length QA1 springs?
- more rolling resistence? 325 radial vs. 10.5 slick?
- Hey Dopefed Z
- M6 guys, what 60' broke your 10 bolt?
- Tire treatment
- qa1's
- Mustang 5.0
- Need HELP, LS series engine with a Pro-Charger
- Got my thru the floor SFC's, doesn't look so good.
- Whos gone M6 to A3?
- Anyone who's run a Carb'd LS1/6: info needed
- qa1 spring choice
- Need Advice I Am Stuck
- How much nitrous will I need to run 8's?
- Can I pass tech
- rear seats
- will 15x10 prostars fit on my car with 3-1/2 backspacing
- Summit "prostar" weights vs real prostars
- I Don't get it. Inconsistent times with M/T et drags
- Help me choose a tire
- tips for keeping engine cool?
- Biggest Nail in "Street Car" coffin?
- help please
- attn, MADMAN,picts on 25.2 stock susp [lots of picts]
- How do I know what converter speed for the track?
- What is the Fastest.......
- How much faster would I be
- best spring rate front and rear?
- Slowing down on the big end
- Guys with ATI 5500 8" ls1 th-400
- Whats your best 60' on M/T Drag Radials with an M6
- Front coil overs strange or qa1
- First time questions...
- 9 Second guys. What size tire?
- Cam only numbers.
- 6speed Ls1's with 4.10s
- Project 02 Silver Z Update 8/23
- Steering wheel recommendations
- track times...launching problems
- How to Launch a cam only, full bolt on, 10 bolt, with 342's
- Powersteering Delete questions
- pulling the wheels at the track
- My thoughts on M6 drag racing for the newbie
- Stupid Weld Prostar Question
- 4.33 or 4.56 w/TH400 N/A!!!
- how fast have f-bodies gone on 26x10 slicks?
- Bulkhead
- Weight transfer..
- a few suspension questions...
- Cage Question
- help with 60's
- Best weight reduction yet, dropped 70lbs....
- Help with 25.5 Cert
- Newbie to the f-body ?'s
- Serious race help needed, no haters please
- 16 Volt Battery, Fix Starting Problems?
- Alumastar question
- Failed 25.5 certification
- BFG DRs at track
- Help me pick a veter?
- Weld Wheels - Bankrupt!
- lakewood traction action bars
- ET Drags Question
- Log books
- Level car?? then set pinion angle??
- List of NHRA Legal Batteries?
- Help with launching with an auto
- Disappointed with 1/4 Mile Times
- i need your info!
- ? about draglites
- Project 98, Pt. 2
- Stock Z06 1/4m results inside!!
- Best way out of the hole fast??
- Engine Damper instead of motor mounts
- Weight Reduction?
- removing abs
- Fiberglass Hood vs Stock - Weight
- How to launch a turbo ls1
- aftermarket racing seats
- 4.10s=Out Of Gear By The Traps?
- What kind of battery setups are you guys running in back?
- Peeps with no bumper supports...
- looking for 5point harness pics
- possible to run 3" x 0.5" wheels studs up front?
- DR's on 18" Wheel?
- Pics of 315/60/15 MT DR's with mini-tubs
- Looking for feedback from people with a glide...
- Whos has tried these efi direct port nozzle systems?
- need suspension advice
- Alumastar BS
- Removing power steering
- What are current NHRA rules on roll bars for 10.00et
- Critique my launch
- Rear spring/ride height/weight transfer Question
- pics of my cars progress/cage pics
- diamond piston sales rep.
- Whats the best way to shift in a drag race?
- Stock ls1 water pump(heater lines)
- What Kinda Times Am I Looking At???
- Whats a good 3" muffler for true duels thats not too loud
- Traction vs Gearing question...
- I need a 5 point roll bar!
- Subframe connectors ?
- Help me figure out what happened to my steering...
- N2o and stall question.
- Too much rear squat?
- i need help with requirments under 12s
- long wheel studs in the front with aerospace drag brakes?
- New times.
- Wolfe Torque arm and true duals
- Trak times ( comments please)
- Pic of Trans Am rear exhaust inserts for true dual turndown set up
- removing brake booster?
- First Track Times
- Autometer shift light problem.
- Anybody DD a Roll Cage?
- Stock tire air pressure for the strip?
- Rossler Trans Brake 4L60 Trans
- Problems with BMR kmember
- What's with V6 rear springs?
- Tire selection with new stall
- Madman Manual Rack fitment question
- 10s for cheap
- air pressure and Qa1 settings.
- Wheelie almost flips!
- t56 bellhousing
- COld Air intake question?
- Mickey Thompson 255/50/16 DRs
- Fuel Cell Pics?
- guys with no HVAC and stock water pump
- a4's at the track...
- 28x12.5 ET street or 325/50/15 radial?
- Trans am weight?
- Solid motor mounts ???
- The best and cheapest lightweight seats
- Some nice local racecars (pics)
- No hood
- Air pressure in Nitto drag radials?
- This Friday (8-11-06), US41, Milan, or Norwalk???
- Need a helmet... nice one for good price?
- The fastest anyone has gone with a TNT ring kit & LSx F-body?
- How much will my 27" ET streets grow @ 120 mph?
- Running ET Streets..
- What size MT radials?
- Lanching problems
- Alcohol LS2 drag car
- girdle
- interior setups..gauges, cages, etc.
- hal springs?
- Help W/launing My A4?
- Will spacers clear 15x3.5 Prostars w/o grinding?
- How do I launch a Turbo car?
- PROGRESS PICS:Got the interior done
- Stagging lights
- Gears/convertor revisited..
- Radiators
- National Street Car Association web site?
- help best gearing for my set up
- lost 5 mph???
- M6 guys, best 60' stock on stock tires?
- 9 Second combos on ls1 F-bodies??
- what the hell?
- Can't lower 60' to save my life, someone help me!
- TCI Trans what fluid..?
- What Should I Be Running??
- 500rwhp on a 275/60/15 MT DR?
- Need to squeeze out another tenth or two...what mod?
- does anyone see anything wrong with my setup?
- QA1 Settings?
- Guys with roll cages and carpet come on in
- Newbie Heads Up Race Questions
- ATTN: Drag Car for Country music Video
- Launching on nitrous
- What is the bolt circle measurement on the Fbody wheels?
- flywheels for ls1+ 350 turbo
- disabling airbag light after installing aftermarket steering wheel?
- heading to the track for the first time!
- what should my pinion angle be set at
- cold packs?
- battery relocation write up?
- Roll Cage: What do you have? (I need one soon!)
- LW fan mod...
- Launching with McLeod Twin DIsk
- what rear drag swaybar-wolf or BMR xtreme duty?
- Check out this car..
- Best ET/MPH for cam only A4 w/ stock converter
- gearing with a th350
- route 66 IL conditions
- help figuring da
- Madman, harness question
- how many single digit guys with no upper panhard???
- Drag car exhaust?
- I need stronger wheel studs, any suggestions
- Low ET with High HP T56 tranny,s?
- Windshield Options?
- are swing-outs NHRA legal??
- Need wheels/tires for track... 16" TA wheels or 17" WS6? MT's....
- What will give me the best gains?
- Drag Racing Experts Get In Here Please!
