- 4.8l truck throttle issue
- Aftermarket Auto Parts Installer Directory
- removing air deflector
- 98 Camaro - odd occurence when starting
- Voltage from alternater won't stay steady (video)
- lost spark plug in engine bay!!
- Clunking while driving (steering wheel and seat)
- Car will shut off while driving and can be difficult to fire
- A/C clutch replacement help needed
- Pwer steering cooler hoses leaking?
- coolant flush
- vibration under acceleration
- split oil pan
- anyone know length of brake booster hose......?
- electrical tape to re-wrap wiring harness............
- Wind noise
- anybody try one of these Dorman "easy drain" oil pan plugs.......
- Overheating!! Please help!!
- P0332 Knock Sensor Low Circuit Input- Checked Everything
- Won't Turnover!! AGAIN!! (VATS Bypassed) EDIT: VIDEO!
- 2002 camaro rear end substitute
- how much coolant does ls1 take?
- pulley replacement video
- passenger headlight lowbeam
- Nice size oil leak?
- High beams wont come on.
- Strange WOT problem
- What does this sound like to you?
- Why is my car running hot?
- Lots of trouble codes need some help!!
- parking brake light
- Toy in ac/heater blower (location of blower)
- un-obtainium, WTD: schematic for GM computer: p/n 15063578
- Have a n00b question sorry =)
- ~ Front end and hood latch support bar broken - need advise ASAP ~
- Unresolved rattling- a lot going on
- Window stuck down from broken switch
- No A/C after a couple of days.
- Holy heck Batman! Big Oil Leak!
- Front left turn signal is toast?
- Overheating
- I know this has been beaten to death...
- 2002 Camaro fuse size standard or mini ??
- Tune Up
- Car Was Broken Into Need Help fixing window & locks
- Motor Clucking (video)
- Bucking stalling out at stop signs...
- Exhaust Leak
- Help Code P1415
- Intermittent Air Conditioner issue
- how to diagnose valve guides/seals
- PCV valve relocation link needed or advice!
- Wiper blade Installation
- Interior squeek over bumps? Ideas??
- A/C CRUISE FUSE underhood is cut. Where does it go?
- Steering wheel moves up and down
- Driver's Seatbelt Issue
- LS2 block repair?
- Help ID Broken Tube
- Dumb question - Engine Idle
- my car wont accelerate right..
- Misfire help!!
- royal purple rear end fluid
- Misfire diagnosis help needed.
- Recommended Maintenance
- Tranny or rear end shot? Clunking.
- Vapor Lock Issue City Driving
- re-ring or wait?
- dropping column for ignition switch
- EXTREME LOUD very very hi pitch scream from somewhere in engine, HELP.
- grinding/rubbing noise from rear
- hose that goes from driver side head to top of radiator
- Changed intake gasket now p0102 code
- 2002 ws6 pcv help
- Passenger window will not go up. NOT the motor or the switch.
- Misfiring really bad
- What size belt do I need??
- Turn signal issue...need help/advice fellas
- Weird power window problem 2001 Z
- A/C problems
- Slight whistle at 2500 rpm
- Any tips fo mainting car !!
- HELP! Symptoms of a bad TPS but no check engine light
- whining noise
- Justice Brothers Emissions Cleaner
- Need help with high idle on my LS6
- A/C experts..........
- Starting Problem
- Flickering lights, big three fix?
- Stock Rear End
- A/C Clutch Bearing Replacement?
- Check engine
- Locating the multifunction relay
- Vaccume hose
- weird noises
- 2000 Camaro not running properly. Please help
- backfires and shuts down under acceleration
- Pulls to the left #$%#$%
- Cranks but doesn't always fire, not enough voltage?
- Rear main seal remove cover or not?
- intake leak or fuel pump issue? help!
- Window motor part numbers inside
- EGR/Air Delete problems. Help ID this.
- amperage gage ?
- wipers do intermittent wrong
- P0118, replaced sensor, reset pcm, still no working temp gauge
- Where can I buy molding for the rear hatch glass?
- Chirp noise at low rpm
- 02 Z28 Starting Issues
- Question about Cats
- Leaking fluid near oil pan, please help
- Trans Am loose steering at the column
- belt/idler/tensioner squeal?
- P0412, P0418 Help?
- faint white smoke
- Can you repair a cruise control cable?
- Croaking / Popcorn / Rattle Noise...
- Im stumped!!!
- Backfire at idle after motor mount?
- Rain leaking in car
- Slow windows
- Backfire & Pop @ Hot Idle?
- Weird left turn issue
- Problems!!!! Car idles fine but dies when accelerated
- flip up lights grinding
- Busted Coolant Tank
- possible fuel pump?
- Service vehicle light
- Vents only blow through defrost
- Huge ls1 problem help
- High RPM miss, LS1, UD pulley related?
- 98 SS M6 cuts off on sharp turns
- 3 jaw puller that's worth a shit
- Driveline vibration decreases when fuel added?!
- maf fuse keeps blowing
- Instrument cluster needles bouncing
- P0430 & P0332 help!
- 2001 Camaro Smoking at WOT and Expressway, not city
- dtc 1153
- Strange high oil pressure
- need help diagnosing front end problem
- So I had my car dynoed...
- A/C, outside smell entry.
- Ebrake light won't go off
- Need HELP-stalls at WOT and check gauge flickering?
- Please help! Overheating Issues
- Fog lights not on when headlights are?
- car running extemely lean!! help meh!!
- Compression test cost?
- Custom A/C Lines. FL shop or SS Braided?
- ls1 rebuild
- Intermitent radio shuts off no power windows
- Speedo and Right Blinker.... What ground is it
- Window rattles, is jerky when it goes up, and doesn't go up all the way.
- will 99 and up knock sensors work?
- Car Cutting Off
- replacing compressor, dryer, and orifice tube
- those of U w/ DMH Electric cutout and borla exhaust
- Please make a video on changing spark plugs on ls1
- A/C - Fans question
- HELP!! need car running by end of month
- Heater core hose block off
- Should have went with VORTECH!!!
- so.....im stumped and its frustrating!!!
- new plugs, rough idle
- Z28 Miss
- Window Not working HELPPPP!!!
- Faint tick at 1500-1600 rpm
- Not your average spark plug question??
- under bumper plastic, where to buy?
- LS1 burning oil/smoking when WOT
- sputter after base tune
- Major Power Steering Issue...Guru's Please Step Inside!!!
- question about a bad knock sensor.
- EGR air leak help
- Wont start interment issue
- Royal Purple Purple Ice coolant additive?
- Is there any any relation betweel the egr & cam sensor.
- How do you get the #8 wire back on easily?
- Is there an idiot light for
- how to get these things to stop tickin
- Do I have a vacumm leak?
- Rattling noise with AC on at IDLE only?
- instaling rear coolant crossover pipe
- Fog or Turn signal?
- surging at low throttle input
- surging ls1 2001 vette
- LS1 acting up. Fuel issue?
- why is my car dying?????
- NEED HELP!!! weird problem
- Squeak from front left
- power window needs replaced
- Oxygen Sensor Bank 1 Sensor 1 SES code.
- Anyone ever leave their factory Platinum plugs in for 100k miles? I did.
- IAC valve related to a/c issue??
- turn signal light help
- Cuts out at 3500 rpm in third gear at wot?
- Bad Belt?
- LS2 Swap, Boiling coolant and pouring out fill/reservoir cap ???? stumped :(
- 99 Z28, Very odd... will not crank after sitting, then will crank after several tries
- Mobile 1 Extended performance 15,000 mile oil???
- Missing out! HELP!
- catalytic converter failure
- Uh oh. (videos)
- 5.3 head oil consumption issue?
- "Low Oil" Light
- AC Compressor Blowoff Valve?
- Whine from power steering pump??
- Pesky fans and coolant light! Help please.....
- 5.3l LM4 overheating and blowing hoses
- Fuse problems
- Both knock sensor codes
- 2002 LS1 mystery wire?
- Code P0704 Clutch Circuit - Control Wiper Washer?
- Electrical
- 95 Firebird Power Lock Problems
- Got the engine codes PO420 and PO430.
- Holy crap!? - Disappearing coolant mystery!
- Annoying oil leak
- I need to replace cats which should I buy??
- Ground wire or? (pics)
- Power Steering noise?
- 4.8 issues. Stumped
- rear end noise doesnt change
- I need colder a/c!
- Who has replaced their own side window glass?
- Several codes and problems all at once....help
- ETC issues on my 99 z28 help please!
- Camaro getting hot only while driving not idleing
- Knock sensor bank 2 problem
- Chirp/squeak from rear right tire?
- another window motor problem
- Dexcool
- LS1 Clutch is soft and falls to the floor
- My ls motor has hard start...
- can't find torque arm bushing on rockauto
- Water pump gasket
- Where is this noise coming from? (Vid inside)
- 98 camaro ls1 o2 sensor codes
- Won't start at first
- threw a P0327
- Magnaflow catback hanger questions
- Water in floorboard.
- Which is my low beam bulbs?
- So Many Issues....Where to start??
- headlight problem...
- Wont start at first
- engine messing up HELP
- Can't get rear lower seat bolt out?!
- New Wiper Motor and ?
