View Full Version : Suspension & Brakes
- Did I adjust my Koni SA's right?
- Adjustment tips for my stange da shocks automatic car.
- Torque arm for Dana 60
- cheap brake upgrade
- installing strange dual adjustable in my 99 TT do I use factory dustboot /bumpstop
- drilled and slotted rotors that don't cost a fortune
- Will 2010 Camaro SS Brake Rotors & Calipers fit on 98-02 Fbody??
- Drag/Street suspension ???'s
- How do you center a Moser 9 inch rear end housing?
- Hotchkis lower trailing arms.....bushing failure, need replacement bushing
- What adjustment setting is your front Koni Adjustables.
- Torque arm setting on relocation bracket
- Subframe Connectors
- Some Koni's in stock... But very, very limited....
- Questions about SFC s subframe connectors
- What GM Brake pads are good for daily driver ss
- Have Eibach front lowering springs, whats a good drag race strut?
- Lost my bolts for my rear ls1 brakes need help now :(
- v6 vs ls1 hard brake lines the same?
- on car adjustable LCA's?
- jegster trq arm
- 2010 SS camaro brembo calipers vs 2004-2007 cts-v calipers?
- clunk from rear after LCA install
- Lowered In The Rear
- Aftermarket panhard bar question
- irotors with heat cracks.
- Differences in the 4th Gen Rack & Pinion.
- Buying used suspension parts
- Will Base model C6 brakes fit under 89 Vette 17's ?
- steering shaft install help
- WTB z28/ss stock springs
- drag spring and shock setups?
- picked up some fun stuff today
- Read that there is something to clean your brake pad easily???
- Which Rotors?
- Tunnel vs. Trans mount Torque Arm?
- NEED HELP? Whats causing this-->
- Rear end centering question???
- BMR Launches New Product - 2010 Camaro Rear Cradle/Diff Bushing Kit - Street (BK020)
- Help on KYB AGX Shocks
- Help with rear springs choice
- Strange SA struts w/ what springs?
- my experience with roto-joints...
- 2000-Z28 QA1 12-Way Adjustable or Eibach Drag Launch Springs?
- new pads/rotors brakes are way to tight.
- K-member bolts removal
- Side to side... my suspension is WAY off..?
- SJM LL wiring HELP!!!
- Front Brembo calipers off GXP G8 for 02 SS
- Need suggestions on adj. PHB and LCA relocation brackets
- Qa1 adj front shocks??
- Torque arm insulation?
- Need help with pics please SJM KIT
- Which Drag bar?
- BMR TQ arm?
- Need some help picking out shocks
- LCA Question
- Front brake caliper bracket
- Body mount torque arm and LT's
- Creeking noise from rear brakes..
- what can i do for clearance?!
- Where does this bracket go? I'm out of ideas
- Horrible squealing from rear end....
- hooking
- Strano Spring delivery status--as of 7/8/10
- swapping lower front control arms.......
- Car sits lower in the back than the front
- hardware????????
- high speed problem plz help
- Finally took some shots
- Replacing your rear pads? I need your old ones!
- Mini-Tub kits...who has them............
- Having a problem with rusty brake dust!
- Lowering springs on dragcar
- Koni DA w/ stock springs question
- Bilstein shocks up front and Koni SA on rear OK?
- Who to trust with sfc install?
- Shaking Steering Wheel
- brake fade
- lol....question about re-installing upper control arms....
- Madman Torque arm ???
- diff. between hard brake lines with/without traction control
- All around performance shock/spring combo
- Bleeder screw?
- Grease a-arm bushings....or put the bolts in dry
- Rattle and thump comin from rear after adj.phb install
- Weird vibration
- Proper rake angle?
- Electric power steering kit for a corvette C5
- Strut-Tower Brace?
- Best lowering springs for 315 rear tire
- thread sealer on hard brake line threads?
- summit lowering springs??
- Help! Front too low
- Installing SLP Bilsteins... where to get lower spring perch?
- umi ta questions
- knocking sound from rear
- Brakes grinding (video)
- Rear shock mount mod?
- Which LCA
- Strano Swaybars Chrome Moly?
- Sway Bar (Front/Rear) size?
- Master/Booster for LS1 cars
- WS6- squealing when turning slow
- Panhard Bar Bang
- Brake fluid qty and PSI capacity.
- DMS lowering springs???
- Another Spring rate?
- Comp engineering for the street?
- Car wont hook!
- Shocks for stock springs?
- Stock height performance springs, etc
- LS1 Prokit/Decarbons fit LT1?
- car wont stay aligned
- ebay lowering springs, $100, bad idea?
- Am I going to have a problem with Eibach Sportlines?
- Anyone tried Ebay LCA relocation brackets?
- Sway bar end-links...question.......
- Looking for new aftermarket suspension for my 99 v6 camaro
- Front sway bar alternatives
- Closed: Going racing/for July 4th weekend
- Tunnel mount TA issues??
- Bumpsteer
- Ls1 brakes on Lt1 now abs inop
- My experience with Koni
- Shake in wheel when braking
- '97 Z28 Brake lines size ???
- UMI K-Member questions...
- HELP! UMI T/A wont Fit 9"
- Why Konis Instead of Full Coilover Setup?
- Koni 4/4s or DAs why or why not?
- Backing Plate Parking Brake Dust Seal?
- strange adjustable shocks
- ATTN SUSPENSION GURUS: Need some options/opinions... thinking of air ride
- Tunnel Brace with Headers?
- Polishing Calipers, can I remove my calipers safely?
- HELP with brake lines
- 7500 series PENSKE double adjustable nitrogen filled shocks
- rear rotors
- Camaro/TA spring fitment question
- Best Brake Pads for Street/Strip
- PST driveshaft hitting UMI torque arm bolt?
- Koni 3/4's - How to...
- 6 Liter Eater C5 Conversion?
- Summit Racing Pads
- changing lca bushing?????
- ABS deleted now I have Service Veh. light
- 300lb aftermarket spring vs 296 stocker??
- lowering spring question
- drag set up
- Brake Proportioning Valve
- Any F body (SJM) ABS Deletes? Pics/comments
- Spacing sway bar down?
- I'm sure this thread gets old...
- sway bar size
- Prothane Motion Control (Total Kit's) Advice Please !!
- I will slam my ss.. What spring rates with GC coil overs?
- Would this drop be ok to run with LT's and ORY?
- What's the weight RATIO on our 4th Gen F-Bodies?
- setting up anti roll bar
- KYB AGX Up Front w/ Koni SA In The Rear On Strano's?
- Which Strut Mounts '02 Camaro? DeCarbon failure
- brake line from abs module to drivers front
- Need some stock DeCarbons (front)
- has anyone in here used adj coil spring spacers in rear
- AP Racing Track Kit | C5 Z06 | Install/Pictures
- whats size sway bar do I have....in mm....
- relocation brackets
- Alignment #s
- Vibration in the wheel!!
- 97 Z28 Brake Caliper bolt size?
- Spohn 1inch rear swaybar
- swaybar removal questions...
- Could this be causing my rear squeaking?
- Koni's on Back Order ?
- Autocross/drag Suspension help
- What is 02 WS6 Rear Sway Bar Stock Size?
- Line Lock Question
- Question about installing SJM abs delete and new lines
- ES Poly trans mount
- bmr drag bar need help and parts now
- Need help installing front shocks quick!
- KYB AGX strut question
- "knock" type sound..
- Brake Fluid Leaking On Booster?
- Best budget drilled and slotted rotors?
- Racing Brake Rotor special---98-02 brakes only: $375/set
- SJM ABS Delete
- I have a ? about my rear control arms
- Wheel Grabbing
- 6LE Harness Bar... ON SALE NOW!!!
- problems with calipers moving and clunking
- Brake fluid?
- Bushing install questions..........
- Question about wheelbase...
- Let me tell you something...
- umi upper a arms
- Who makes killer coilovers
- Blank rotor with Zinc plating?
- is there a tool i can rent to compress the front spring on my 99 trans am?
- clunk in the rear
- Broken KYB's. By broken I mean F#&KED
- How bad is the Eibach Pro Kit for drag racing?
- 2002 Trans Am Emergency Brake Adjustment
- Rear-end AREA "Clunking"
- 4th Gen Firebird 8pt Cage
- Brake Pads
- Shocks
- LCA adjustment question.
- tie rod ends and ball joint boots
- UMI Torque Arm Relocation Bracket Install Issues - Bolt holes don't align to the body
- Possibly stupid brake question. Wheels possibly "sticking"
- Going from solid link control arms and panhard rod to poly ends?
- PHB End Question
- spohn torque arm Y pipe problems
- Strano Performance Parts Announcements--6/16/2010
- no rear brake after 9" install
- Thoughts on my truck ride... need input!
- alignment after lowering
- endlink bushing
- Advice for best street shock/springs setup with H/C/N2O
- Installing shocks
- BMR K Member VS UMI K Member
- lc's relocation brackets?
- Might get a torque arm w/crossmember.....question
- I need to purchase shocks...would like adjustable, QA1 vs AFCO vs Strange
- Brake and Rotor Install
- Caliper Mounting Measurement Question
- Help! Fast 102 Install Now Strut Tower Brace Hits
- Reinstall Torque Arm bolts up instead of down???
- Package deal, hawk hps + rotors
- Best Suspension for a Straight Line Street Car
- Rear spring isolator part number?
- Need help with front brake noise
- Car pulls to the right need help.
- Torque Arm Question
- moving a car with no tq arm?
- New Stance, what is necessary
- brake pads wearing at an angle help
- Strano Swaybars--in stock and ready to ship.
- Brake Pads won't fit on Passenger Side
- Max torque (HP) to the road(street not strip) for a 4th gen fbod?
- what power steering hoses will i need?
- swapped K now steering messed up
- Control arm questions...
- anyone ever cut spings on a 99 trans am
- A little help
- tunnel brace
- Back right tire
- Just finished lowering, a few ?s HELP please.
