View Full Version : Suspension & Brakes
- Independent Rear Suspension into F-body
- Making use of my new welder
- what would help me more
- LS1 Brakes?? Brake Light not going off?
- Do I still "need" SFC's if I install an 8 point cage?
- Which lowering springs would work best in this situation?
- Hyperfirm Brake Line Kit. Rear Center line upgrade kit for Traction Control Cars
- abs inop
- pinion angle on a th400
- camber specs....need quick...
- Which TQ ARM is better Spohn or BMR?
- Kyb Adjustable Struts
- Kenny Brown lowering springs?
- guess what i got today??
- progressive vs fixed rate springs
- Where can I find....??? Help!!????
- #1 thing to help with cornering?
- anyone have kenny brown double diamond sfcs?
- Whats the point of adjustable control arms?
- Good shocks?
- aftermarket torque arm and brake dive...
- New Rims call for a drop
- post pics of your Camaro w/ BMR or Hotchkis springs plz
- Need Help!!!! Brake Problem.
- need question answered fast about dms.
- What Lowering springs and shocks?
- Anyone have these
- Just installed G2 LCAs & Brackets
- Question for those with lowered cars.....
- Anyone installed a BMR Drive shaft loop??
- Question about installing the Pro kit?
- Powersteering pump making loud noise only on startup.
- if your car is lowered, i need your help
- BMR SFC's loose LCA bolt
- H&R springs
- Zo6 Calipers
- chassis and handling ?'s
- Stock control arms?
- alignment range with stock suspension
- bolt or weld in cage?
- Torque Arm & Poly Trans Mount Installed
- Adjustable LCAs, do I need them?
- Good goop for sway bar bushings
- Difference between SLP Bilstein and Bilstein HDs?
- torque arm install
- Anyone have SLP level 1 shocks with Prokit?
- Lowering spring question
- Will line lock keep me from warping my rotors?
- Slotted Rotors
- What aftermarket brakes are you guys using?
- Is this possible?
- subframe connector question, help!!!!
- Alignment or something else?
- please help
- SLP Level 1 & SFCs
- Any tips for removing the power steering rack?
- Will the Spohn Tranny Mount TQ Arm fit with duals.
- 90/10 front shocks/struts
- Swaybars??
- Can I re-use factory bolts for new lca?
- Few questions
- Opinion on road noise for dual rod end LCA's?
- Are adjusable lower control arms needed?
- New improved A arms from PA/Pro Fab!
- What springs to use with HALs
- Question about shocks....
- K-member ride height???????
- SFC question
- Need opinions on some parts
- Guys w/ dms and prokits pls post pictures.
- Elderbrock poly bushing
- will bilsteins for ls1 fit on a v6 firebird
- corvette calipers fit fbody
- Need lowering springs opinions.
- Control Arm Colors...Which colors would you buy??
- ABS INOP light came on last night...
- Problem With Elderbrock Torque Arm Install
- traction control?
- Edelbrock suspension parts.
- what mod first
- BMR rubber lca
- 1LE Sway Bars
- anyone with LCA relocation brackets
- Build your own SFCs?
- Tq arm Question
- dont want to see the SFC's....
- HELP need install cost quotes
- best sub frame connectors for lowered SS?
- how does 15x10 rears and skinnies affect handling?
- New SLP LCAs
- suspension questions..
- Pinion angle question
- Jam nut size on LG Tubular LCAs?
- hotchkis springs progressive?
- Bilstein ultra suspension package questions
- Brakes
- I'm having trouble with my line lock...
- Parking break adjustment
- Where to get SFC's installed?
- Spohn torque arem fit w/ true duals?
- Need recommendation for high performance street pads.
- Is it too difficult install Torque arm for DIY'er
- How much of a difference if any from a 1" to 1 5/16" rear swaybar?
- strano performance
- Global west double bearing LCA's?
- Rear shock lower mounting nut size/pitch?
- Which rollcage best suits me?
- need some advice about the way my car handles.
- Tunnel braces?
- Hawk pads and rotors
- who bought SFC's from Ebay???
- Grease for poly/rubber LCAs
- any one with gc coilovers set up with KYB's
- any pics of cars with 1LE or SLP springs?
- stock sway bar size?
- Caliper is rubbing on my rotor, im about to start grinding!
- any stiffer springs with same height as stock springs?
- Problem!!!
- K-member selection????
- ***Spohn Torque Arm Help!***
- LG Motorsports Speed World Challenge car in the making (pics)
- Need Torque Arm Advice
- LCA install
- TR224 Cam car with 100rwhp shot. Suggestions for improving braking performance?
- Relocation Brackets on stock height car - great.
- Spohn or G2 Swaybars
- 1LE Swaybars
- Front Brakes Sticking
- Pro's and Con's of Tubular Front Suspension?
- CG height
- New brakes
- Random Tech.
- Tire pressure
- What would a dead shock sound like? Bad Noise under car
- Convertible subframe install... remove stock SFC?
- What front springs to run with HAL shocks?
- Potentially stupid question.
- Alston Torqure Arm
- Dms Products?
- Alston Torque Arm
- what dsl with lowered car?
- Does anyone have adjustable schocks?
- Steering wheel cocked right, wobbly wheel..help!
- ABS INOP light coming on .......
- Gotta fix my car but found out I OWE money on my tax return...suggestions plz
- Grade 8 bolts good enough for LCA relocation bracket?
- Will 98-02 k-member fit on 97s?
- rear thumping noise
- Line Lock?
- Air Shocks- Call me Crazy!
- Can I still turn my stock rear rotors?
- Lowering 2inches any problems?
- Anyone having issues with their tq-arm w/
- Sure Stop Rotor Specail
- panhard bar.....good idea?
- new CHEAP SFC company!!!
- Ok, I was out cleaning the car and noticed this *pics*
- creaking sound coming from the passenger side rear
- Has anyone hear cracked their windshield because of too much torque?
- street strip shocks tech
- any difference between poly/rod vs polypoly suspension
- Brake Pads
- Sway Bar or Adj. PHB??
- What shocks w/ BMR 1" lowering springs
- Opinions on Jegster Bolt On SFC's please
- drag racing susp.
- Which Springs to use w/Hotchkis SwayBars?
- Minimal Brake Dust. Which pad?
- Airbag suspension
- Need reloc. brackets for LCA... FAST !!!
- How bad would it scrape???
- Pictures of installed SFCs please
- headers dragging
- another shock Q muahaha . search? wahts that
- Sam Strano, revalve price?
- Help! Stuck while installing front strut!!!
- Installed Moser 9" what Swaybar to get?
- Which replacement shock for daily driver?
- How to decrease F-Body weight?
- Torque Arm...help
- Spohn torque arm
- Experts comment on my setup
- Is the very 1st setting (all the way to the left) considered 1 or 0?
- Tie Rod Replacement
- Convertible rear shocks - access?
- PA K-Member even lower
- Spring/shock swap - Front strut pieces?
- I need traction !!!!!!!!!!!!
- Help, what is this?
- suspension newbie needs spring recommendations (yes, i tried the search)...
- Crossbrace, TQ Arm, and true duals...who's got it
- Eibach/Sway bars
- Jack up car with BMR boxed SFC's
- Who's having a sale?
- Creaky noises normal with poly bushings?
- SLP Sub Frame Connectors...
- if you have DMS and BILSTEIN HD NON-REVALVED please come in
- need alignment help
- Cures for crooked launches?
- Installed Bilsteins.....Car now sits up higher on the DRIVER's side...
- Sub frames
- Baer Brake systems
- which springs go good w/HD Billsteins?
- 1LE or BMR....Please read....
- People with Hotchkis springs....
- need some very average shock/spring advice
- what else do i need??
- BMR or PA
- 17's or 18's Help???
- Swaybars
- PA K-Member Special
- Installing Bilstein HD's and BMR springs help?
- LCA Help
- riding high in the back?????
- Addco 35mm Front Hollow Bar !!!
- Anybody notice raised height w/ Bilstein HD shocks?
- What DSL with FLP's
- just got my car lowered........
- Explanation needed regarding swaybar balance.
- Hal f and r series
- Installing LCA relocation brackets, what height/holes?
- Will I have to roll the fender lips with this combo?
- Painted cailpers...in progress...pics
- Right suspension setup?
- Left side of car jacked up??
- Rear sway bar for drag racing!
- Manual Steering Rack
- Best Shock/Spring combo for a 1" drop?
- spring installation question
- Good poly trans mount? Which
- Eibach Pro Kit
- Intrax Springs w/LT's?
- Hub bearing noise?
- Best Sub-Frame Connectors?
- Sway bars on WS6
- solid end lca advantage????
- sway bar size on 99ss????
- STB at the track
- Pinion angle?
- Factory installed STB
- Those with Hals, what are you setting the ride height to?
- Custom SFC's
- sprint springs?
- Panhard bar clunking
- Installed LCA reloc. brackets, LCA's, and PHB today.
- ABS noisey and violent??!!
- anyone using the new coilovers for the rear?
- Steering rack clunk
- Getting rotors turned
- Brake Problem
