View Full Version : Drag Racing Tech
  1. NHRA requirements for 10's
  2. Madman TA or double adj. front coilovers?
  3. NHRA superstock
  4. Who has a Strange S60 rear end?
  5. Those who have replaced the stock battery tray/coolant overflow with a catch can...
  6. Hood question?
  7. abs delete / manaul master pics?
  8. 9'' vs. 12bolt whats lighter
  9. where to start?
  10. need help with setting up suspension, cannot get the car to hook
  11. Steel Braided Hose Vs Plastic Looms
  12. Outlaw 10.5 nitrous setups
  13. Traction
  14. [Race Wiring] Rear Lights & Brake LIghts
  15. Lowering A Drag Car
  16. calculating mph for gear/tire combo?
  17. Building suspension?
  18. race brakes worth it
  19. need an easy tenth
  20. 8.94 @ 150 Video with Madman Limiters...
  21. What size wheel studs??
  22. ATI 8" converter on the way...
  23. tire selection....i want my 60 fts back!
  24. harlan 2step
  25. 2007 350z vs 01 z28..question
  26. A4 shift points??
  27. Fire Extinguisher
  28. Those with tranny blankets and long tubes..
  29. who else uses BS3 alon with a digi 7box?
  30. racecar steering wheel
  31. Cut Some Wires ,car Won't Start
  32. Converter offset to full seat
  33. Good 60' w/ slow 1/4 mile time
  34. Recommended tires and rim sizes..Please HELP!
  35. help with drag suspension shocks and ta length
  36. ? on trap times...
  37. Pinto rack / tie rod ?
  38. hows this launch?
  39. Am i close?
  40. Are rev limiters (1, 2, 3 steps) safe for the engine? Cutting spark, not fuel.
  41. What do u think it will run now??
  42. Installed Moroso Oil Pan...pics within
  43. 6 speed suspension setups, whats everyone got
  44. Cage Requirements
  45. G-meter by passport results
  46. Midnight Mayhem!!
  47. Tire brake in
  48. Installed cage but need advice cutting trim
  49. Drag radial rotation
  50. How many of you drive your car to the track
  51. First trip to the track tomorrow launch ?
  52. POST safest way to burn out A4, shift/d/OD???
  53. question about 9'' rears and set-ups
  54. alternator question
  55. A question about insurance (for a race car)
  56. Rear shock question
  57. great idea for tire wells for burn outs...
  58. What is the accepted name brand for drag racers?
  59. Drag Racing Charging System
  60. launch rpm with a 3,600 and 3.73s
  61. order your dana 60 w/ good studs!
  62. Ford debuts new Ford Top Fuel motor
  63. pinion angle vs. instant center?
  64. 11's capable with a 112MPH trap?
  65. high 12 sec car with cage help??
  66. coulda,shoulda but what would have my car?
  67. Wiring Quesion
  68. fuel cell pictures
  69. SFI Flexplate question
  70. Need advice on gearing
  71. Should I switch to 325 ET Radials
  72. Electric/ Air Powered Chute deployment
  73. anti roll bar...
  74. Arizens and a Roll Bar?
  75. Is is safe to run a patch tire at track??? bad experience at track!!
  76. RPM limiter, 2 step, 3 step, Harlan, MSD, etc.?
  77. VFN fiberglass dash?
  78. 2001 SS Cruise Control Questions (search sucks!)
  79. Anyone with 2.73's in the 11's or better?
  80. 98z28 vs 96 v8 s10
  81. What affects acceleration in the last 660ft?
  82. Best 60' with Exoskel Clutch (Textraila Twin)
  83. Mini tub and Panhard Rod Mount
  84. Any GTO drag racers in here?
  85. mounting front strange shocks
  86. What size wheel to fit my front ?
  87. Helment advice
  88. competition engineering shock settings?
  89. Some questions about LCA length and 12 bolt Moser
  90. Percys Speed Glass?
  91. hoosier drag radials
  92. Installed my STAR vacuum pump and belt-drive fuel pump
  93. Okay, how are folks getting down to <2800 car weight?
  94. My teardown has begun *pics*
  95. Bmr Anti-roll Bar Question
  96. Are 27" slicks too tall for a tr224 cam car?
  97. What psi on slicks, to save rear end?
  98. Lenco's two and three speed automatics
  99. high h/p fuel pump choice...
  100. Rear drag brakes, mounting questions 9 inch
  101. Advice on stopping the squat in G-body
  102. Mods over the winter
  103. Cage Build info
  104. moser rear
  105. Torquer v.2 guys. What RPM do you launch?
  106. Drag Light Wheels
  107. using oem seat brackets for race ones?
  108. help with DA ASAP
  109. Roasting the tires in the water pit, how to
  110. Mini Tubbing
  111. Back motor plate for LS1
  112. weigh in time
  113. Front QA1s
  114. How to keep the front end from NOT doing wheel stands??
  115. average open car trailor, how long overall?
  116. Worried about my airbag...
  117. Pre fabbed roll cages...
  118. Hard launch = Car loses electrical power also locker question
  119. Post your wheeli bar pics
  120. TH400 overkill?
  121. Et gains from gear change
  122. Old schooler geting back into racing
  123. which tires
  124. Why does my friend's '00 Vette Vert A4 do 13.80's?
  125. i keep moding but cant run faster help
  126. 29" Tall Drag Radial?
  127. tire or gear question
  128. Will the 390/40R17 MandH tire fit with mini tub?
  129. madman... brady update?
  130. Been using slicks...switching to drag radials. What PSI??
  131. Is a 97 LS1 block as strong as a 01-02 block?
  132. Here is my weight savings from aftermarket hood
  133. how much did you pay for your cage?
  134. Street 60'
  135. what heads up series do you run?
  136. Belt Problem after Wheel Hop
  137. 122 MPH Trap
  138. Went To The Track Today
  139. madman suspension questions
  140. Launching Technique
  141. Have you completed the airbag delete?
  142. Borla owners; open exhaust or closed?
  143. LS1 Drag Racers Unite!
  144. Finally went through and cleaned up the harness today....
  145. why windows need to be rooled up??
  146. thinking im gonna be disappointed.
  147. Fuel Supply/return && Cable routing
  148. opinion on 60' & et
  149. ratchet shifter ?
  150. T-Brake + Gearing ?'s
  151. good converter for my goals
  152. "In the XX's"
  153. Drag Radials w/ Sportline Kit????
  154. anyone have a caged S10?
  155. joe van firebird hood?
  156. Breaking in gears for a race car???
  157. Bogging off line TC or ABS?
  158. who all sells joe van overbeek parts
  159. Wheel Balance & Launching
  160. Will this roll cage certify?
  161. roll cage?
  162. Who is running a manual trans other than a T56
  163. Mickey Thompson 9" slick
  164. 99 T/A Vs WS6???
  165. Positive Battery Cable
  166. Whats the MIN in sus mods for building a low buck setup?
  167. 250+ N2O A3 guys...... how bad are your times NA w/ your Nitrous Convertor?
  168. what will 700rwhp get me in the 1/4?
  169. Glide/converter question.
  170. Parachute question
  171. Cutting out front section of shock tower.
  172. What to expect w/ kmember
  173. Effect of air?
  174. ? for all lsx racers
  175. Drag Radials and tubes
  176. Battery Relocation + Cutoff questions
  177. Low MPH Help!
  178. Anyone Get Better Than a 2.0 60' w/ Goodyear GSD3's?
  179. BS3 Alternator and oil pressure question
  180. Seats large man ready info/opinion requested
  181. Handling Issues...
  182. rules???
  183. anyone have pics of a f2 in a lsx 4th gen fbody?
  184. Roll Bar Padding and tire pressure
  185. How wide is the section of a 325 50 15 on a 12" rim
  186. Throttle controller
  187. Hoosier Dot drag radial
  188. lower dr tire psi killing et at the track?
  189. Madman...Can you look at this
  190. running out of steam at the top of first
  191. Cage install
  192. almost 2.5+ tenths faster today. does weather+temp make a difference??
  193. Bracket Racing Info
  194. Finally ready for the track.
  195. What is the difference between the Wolfe single and double Anti-Roll Bar?
  196. Faster times!!
  197. Spohn cage???
  198. Car jumps hard then falls on it's face?
  199. Help Shifting
  200. Need some education on converters. loose or tight
  201. I need some suggestions on setting up suspension
  202. How to set valve lash with promags ane LE1HL?
  203. Wolfe Sway Bar & 9" Axle
  204. What should my mph be?
  205. fastest stock stalled LS1 NA
  206. Neck Brace?
  207. Dashes
  208. PSI for tubes compaired to no tubes?
  209. Drysump Oiling Vs Wetsump + Accusump
  210. Alcohol Cars & Coolant temp
  211. Vehicle Weight Question
  212. Best 60" & best ET = low MPH??
  213. 5pt harness and jacket
  214. Post pics of your Cage !!
  215. Can someone tell me what year this block is?
  216. DA question
  217. Is it OK to drive a big stalled A3 on the street?
  218. 25.5 cage + nose bar questions
  219. Adjustable Drag shocks vs. Adjustable Coil-over
  220. Front Wheel Studs
  221. get'n it done on 275's *video*
  222. Tubular K...
  223. Need wheel hop help, a4 car w/full suspension
  224. HP gain
  225. Lowering my ET. What and what not to do?
  226. Teaser pics,wifes new race car...
  227. first time to the track
  228. 17" ET Streets
  229. is 3/16" drill bit the one for all rim screws?
  230. McLeod bell-housing/allignment pin?
  231. Fastest carbureted LS1
  232. aerospace rear drag brakes
  233. Which trans,powerglide or 350 turbo?
  234. Suspension help needed, settings to get into the 10's
  235. Guys I'm building a 383 and would like a little advice.
  236. how much weight does minitubing an Fbody save?
  237. Ohio Boys?
  238. Will putting VHT on street tires help??
  239. A3 Guys,Throw it Neutral at the end of your run??
  240. gear, tire combo
  241. Congratulation to PSJ and the Pinks car
  242. N E one running a carb plate with injected lsx
  243. Running Bullets off Colectors,Need a RETUNE??
  244. Fastest on real street tires?
  245. Write-up: How to adjust your t-tops. *PICS*
  246. Any of you clean the welds on the inside of Kooks collectors/o2 bung?
  247. 325/50/15 MT DR guys, break in and burnout/psi ?'s
  248. Trying to figure out what's wrong - help
  249. What flows better.....
  250. Fabricated lines for Strange manual master cylinder? How do you connect SAE to metric
