View Full Version : Suspension & Brakes
- DMS/Hotchkis drop as compared to mine...
- Is an alignment REALLY needed after a lowering spring install?
- Help needed with C5 brake brackets
- Stock Spring replacement
- What's the difference between Carbon-Metallic and Ceramic brake pads.
- Gripforce cross-drilled and slotted rotors?????
- Tired of the prokit rear sag....
- Play in the steering wheel..Any suggestions?
- UMI 3 Point Subframe Connectors
- Relocated PHB
- Brake bedding
- Post your suspension set-up!
- Pics of my rotors from the Ws6 Store
- Poor Braking during rain storm
- SLP Bilstein shocks and struts
- LT1 springs?
- LCA question
- how much to weld in SFC??
- Best sway bars?
- Spohn TA?
- Manual steering rack on daily driver.
- Got Koni's get Hotchkis springs or stay stock?
- Defective Rotor ... ?
- how low does v6 springs drop your z/ss??
- shock install = hell
- BMR vs Spohn vs UMI A arms
- Hyperoils Springs Shock Options?
- CTS-V owner needs some tech help....
- do i need a panhard bar and relocation brackets i just lowering an inch
- Troque arm question (clearance w/my true duals)
- Squealing after rotor/pad install
- need suspension suggstions
- stock pads ?
- ok new question do i need hals
- how do the hal adjustable shocks behave on the road
- any pics of dbl diamond SFCs installed?
- pinion angle for a lowered car?
- Check this out!!!!
- who has eibach prokit coils? pics please
- old car
- where to find
- ? about upgrading to C5 rotors
- My first driving impressions of QA1 "R" Series shocks
- Springs - Vogtland/Eibach
- Strano/Koni - I'm a believer
- LCA relocation brackets?
- drag spring heights?
- Wheel hop ?
- OFFICIAL ANNOUNCEMENT: UMI Performance #8 CMC Z28
- Any good deals on shocks/struts? SLP Take Offs?
- car turns on its own help!!!!!!!!!!!
- Custom X-Member for Torque Arms
- eibach prokit
- Line lock question
- Rear end problems
- KYB AGX Adjustable Gas shock absorbers? search not working
- Braking w/ 9" Rear???
- what springs lower my car? without sacrificing traction
- A arm mounts
- Your favorite Steering Wheel (with Air Bag)?
- Car grabs and releases ?
- lt n duals
- Need help with alignment
- QA1 coilover owners needed. How adjustable?
- Could This Be The Cause Of...?
- Easy question...do all SLP SFC have the SLP logo on the side?
- Ball joint problem
- Tunnel Mounted Torque Arms
- Cant hook :(
- Power steering cooler
- Bleeding the Brakes......Are there any good write ups/articles on this procedure?
- BMR or G2's!?
- Hotchkis springs
- GTO BMR sway bar?
- controal arm bushings
- Help! Is this way over priced (Hub assembly ect..)
- BMR trak pak
- Red Devil Titanium Brakes....
- Adjustable Panhard Rod
- sportlines+longtubes
- suspension adjustment
- TSP TD's and BMR springs ?
- centering the rear end
- tunnelbrace/midbar thingy question
- Looking for a Tightened Chassis: DD SFCs or a 6-Point Roll Bar
- Revalved Bilstein's
- KYB and Pro-line
- I modded w/o checking here 1st
- Where can I get the best deal on adjustable shocks?
- Drilled And Slotted Ws6 Store Rotors
- springs ??
- Brake Chatter plate?
- Torque Arm Q
- which brand to get on suspension mods
- Shocks? Which ones to get?
- Torque arm tranny mount or body mount?
- front brakes on rear
- Brembo Fbody Brakes?
- aftermarket calipers
- Ever buy brakes from Ebay?
- "Thus" coming from underneath the car
- suspension
- Poly Graphite, Prothane or Energy Suspension?
- bolt size...
- Where can I buy cheap disc rotors?
- coil over question
- Steering Problems!!!!
- subframe pictures
- If you are considering a Spohn Torque arm..forget about lowering the car *pic*
- LCA/SFC bolt size?
- Is the C5 caliper the same caliper as an fbody?
- Koni SA settings for Hotchkis springs?
- sprint suspension anyone>?
- Weird feeling while driving
- Taking off front sway bar
- f-body track handling
- Taking apart Caliper
- Tube chassis?
- The perfect spring/shock/strut combo?
- Not Lower?
- Wheel Hop Bad
- well, broke my end links
- Abs Inop ???
- LAunch ???
- Upgraded suspension. Is this normal?
- Upgraded My Suspension
- Sitting on rear bump stops
- Subframe connectors installed.... WTF???
- Can I just replace 1 strut?
- Replacing brake lines
- '00 corvette and '99 fbody brakes interchangeable????
- LT1 springs in a LS1?
- best pricing on aerospace brakes??
- Strut won't come off!!!!!
- Alignemnt Specs?
- Good Setup?
- Creaking in rear
- SS braided brake lines - improve pedal feel?
- 1le springs pictures???
- Clattering noise from the front calipers
- What will work better with my factory springs--SLP Bilsteins or regular Bilsteins?
- LCA's and P-rod Ques
- Need New Brake Pads!!
- 1LE suspension bushing question
- setting up rear suspension.need advice
- Grinding calipers....
- brake fluid
- Just got my Strano bars!
- I need to fix rear coil spring sag, what coil springs should I use??
- My Car Is Gonna Fall Appart!!!
- just replaced the rearend with a 9"..now abs inop
- Lt1 Hubs The Same Size Etc. .... As Newer Model Hubs ??
- Will I need an alignment after replacing my front factory shocks with Bilstein HD's?
- Accelleration, Braking, Question: Turbine Sound Unit
- Sub Frame Connector Worth It??
- DMS or Sportlines w/ 11" ZR1's (post pics plz)
- Bang your doors after lowering?
- do v6 springs lower,raise?????
- RS springs
- bolt size needed
- What local place would you trust to work on your brakes?
- sportline spring and shock combo
- bushings installation faq/guide
- qa1 shock settings
- LT1 Springs on an LS1? (need help fast!)
- Complete Z06 Brake Kit?
- Pads for cross drilled and slotted rotors?
- Can you drive a car with out a torque arm??
- would it benefit me any to just buy front hal Qa1's?
- swaybars and shocks
- earls solo brake bleeder screws?
- Comp Engineering Rear Drag Shocks
- Correct way to bang in fender wells
- will just a 1 in. drop hurt traction?
- any rollcages that dont have a big bar across the doorway?
- afordable shocks suitable for a lowered car?
- HELP! Still have really bad wheel hop
- Replacing Calipers and Russell Line kit.
- What lubricant?
- DMS springs low as shit
- Are there any "how-to's" for K Member install?
- car leans to the passenger side
- Anybody Just Change Rear Springs on WS6??
- Brake pad suggestions for stock brakes.
- Changed rear shocks, still have knocking..
- street/strip suspension
- Tag or Identifier for stock SS springs
- installing shocks??
- looking 4 Dimple Drilled and Sloted Rotors???
- So.....slotted/cross drilled rotors????
- WS6 drives different everyday!
- Suspension upgrades.. Now or Wait?
- Which Lower control arms for my setup?
- What brakes do I have?
- Where can I get performance coil springs that are not lowered???
- How are the SLP boxed SFCs?
- Whats the difference in confort ?
- question about 4th gen brakes on a 3rd gen
- Steering Problem HELP!!
- BMR bolt on LCA relocation brackets??
- How much should front rotors weigh?
- Solid Motor mounts
- getting 1LE sway bars..how much better?
- Question for ppl with lowered cars
- Question for Mr. Strano
- Suspension Recomendations
- ? about Bendix Brakes
- Chassis Engeneering
- DD with aftermarket K-Members?
- Anthony Jones K-member
- Help with strut spring assembly
- Bilstein and BMR
- 1LE LCA Bushings
- Hotchkis springs help
- Pick out suspension parts for me!
- Brake Pads?
- Replacing bushings
- squeaking noise, possibly bushings?
- front and rear suspension in my 69
- how to tell
- need help with Spohn solid Motor mounts
- Ways to make TA quiet?!
- How do you stop car from wheel hopping?
- UMI Subframes from BYUNSPEED
- does the UMI stb fit with FRC's?
- brembo slotted
- Finally made the call
- Kenny Brown out of business!
- stock ride height, DD performance?
- UMI SCF's and FLP headers / Y pipe ??
- Brake pedal extrememly soft after brake job
- Any Experts on Baer brakes?
- control arm help
- Control Arms?
- Rollcage
- Torque Arm?
- BMR lowering springs
- whos not happy with bilstein HDs?
- stock height - new shocks
- Anyone familiar with Dick Miller Racing torque arm?
- leaning to one side
- Anyone ever removed the back insulaters on coil springs
- Trans mounted torque arm ok??
- squeeling brakes after brake job
- Shocks
- Removing front sway bar help?
- LCA's, and which hole on the Relocation Bracket
- unlevel lowering
- QA1 shocks w/ stock springs?
