View Full Version : Suspension & Brakes
- SLP bilsteins/eibachs vs regular
- Anyones Pro Kit lower there car to much?
- Anyone ever?
- anyone ever?
- need info asap F.Swaybar install
- Shock question
- stock spring question.
- QUICKLY what do you guys think of these subframe connectors?
- afco or qa1 r's
- shocks
- SPOHN torque arm ???
- Kenny Brown SFC's
- rear end feels disconnected from the car
- Brakes shaking whole car?
- brake clearancing for Centerline Telstars
- Starting on the suspension..
- Stock Torque Arm Modificiation
- BMR only bolt-in Relocation Brackets?
- Body Kit & Lowering Springs
- My accident... any ideas?
- C5 zo6 caliper question
- Do I need adjustability in a PHR or CA's w/ stock springs/shocks?
- Scary when wet! Help?
- rod end/bushing vs dual rod ends
- Slp sfc's?
- help meee!!!
- Chassis Stiffness
- 1LE Suspension
- poly bushing question
- Need Bolt Sizes-Caliper
- sway bars
- coilovers are they good for drag racing?
- Roll cage question
- ahh nothing like tracking down bangs and other misc noises.
- LG single adj phr arrived...
- Stock shocks?
- LCA Question
- question about ABS and stock brakes
- Spohn Driveshaft loop
- Prothan or Energy Suspension?
- Where to get Eibach pro kit the cheapest?
- New pads squeeking!
- Question about Strange front race brakes
- ordered sfc and panhard rod......
- Yay or Nay: Stock springs and shocks for racing...
- LCA's
- Brakes roters calapers
- Unknown squeeking?
- Cost to Install
- Koni DA's vs. Hal's
- cross drilled rotors for a 9"
- ?????????Who lower his car post of ur pic + which spring u use???????
- Regarding Lightweight Brakes
- Handeling sugestions
- Koni SA Shocks
- Braking problem??????
- Springs for The Firebird
- I broke my Spohn TQ Arm!!!
- Kyb?
- How come BMR.....
- CTS-V Calipers
- U-bolts for sway bar to 12 bolt
- Body kit + Lowering springs = Scrapeage?
- 88-92 1LE calipers
- 1LE suspension, Koni DA's/w-springs
- noise from the right rear??
- Rear swaybar?
- line lock guide + prices
- LG Torque Arm Installation?
- Bob Bishop C5 to F-Body Brake Conversion Brackets
- To Adjust or not to Adjust
- Understanding Adjustments to Panhard
- Which K-member + upper+ lower ca's to go with?
- HELP brake light is on
- Porsche Rotor on an F-bod
- Poly Bushings needed?
- chasis mount torque arm clearance
- BMR subframes
- how to remove rear shocks?
- Do I need adjustability in a torque arm?
- chasis mount or tranny mount torque arm?
- LT1 Pro-kit on LS1 car
- hurst tq arm mount #
- Springs: Ride Height vs Traction.....
- which torque arm to get
- What Hal spring for street use?
- Wolfe, BMR or Spohn for Street/Strip
- HELP! I lost my nuts!! (torque arm)
- N00b inside, lowering springs and thats it??
- decarbon shocks???
- Re-valving SLP Bilstein's?
- how many miles/years on car before a brake fluid flush
- What Springs
- any rear drag suspension without t.a.
- Corvette Line Lock
- Brake Trouble!!!
- Don't want my car to twist like a pretzel...
- BMR rear sway bar: endlinks bent in under 1k miles?
- suspension advice for my camaro
- SLP SFC's or BMR LCA and Panhard Rod.
- Average cost to weld in SFC's??
- KYB 8 way adjustable shocks & stuts???????
- newb over here
- need pix of lowered cars! height dont matter...i need ideas
- Hotchkis SFCs ??s
- New Autozone rotors, have them surfaced before installing?
- 1le suspension question
- Search didnt help...H&R spring owners come in PLEASE!!
- BMR stuff installed
- Which Springs
- What is the best non tranny mounted TA?
- Just got Kyb agx struts
- I have LT's and duals - Which SFC's?
- Are there any
- Big Problem while Bleedign Brakes...
- suspension for comfort
- Stainless brake lines?
- shaking steering wheel...
- Tires?
- Is there a non-trans mounted Torque arm that will clear true duals?
- Suspension Material!
- SLP SFC's and Ground Clearance
- will a stb help with interior squeeking?
- HAL shocks vs HAL QA1 shocks question ?
- Looking for lowering suggestions, spring and shock brands
- Traction control kicking in...
- what is the best k member?? best front lower a-arms? light and strong..?
- Chassis eng. Torque arm??
- Ceramic vs. Semi metalic?
- Can the BMR adj. TA handle sub 11 sec pass?
- What is the most streetable and longest-lasting performance shocks for stock springs?
- 98-02 T/a Corvette Zo6 Brake System ????
- I go through brake rotors....
- When to use a tranny mounted ta and when to use a x-member mounted ta
- suspension and 1/4 mile
- Got the Spohn A-arms
- suspension set up..."sway bars"
- Need line lock help please
- 01' WS6...3 chan or 4?
- Abs problems.
- How do Hals behave on the street?
- why is an adjustable phb needed..
- LG APHR rod ends
- Konis SA question.
- C5 Brakes
- startling discovery about TA's
- Ground Control Coilover?
- Setting an adjustable Panhard bar?
- Porsche brake questions and more
- how much do slp bolt in sfc improve handling?
- Installed 2 front rotors-Lft frt binding Help!!!
- Hawk pads or something else ?
- Sub-Frame Connectors
- Bad Vibration
- Eibach pro kit
- The best rotors and clipers?
- mileage out of rotors
- "How-To" w/pics - Bleeding with Earl's SoloBleed bleeders
- How low before factory camber adjustments don't work?
- 315s 17x11 prokit and rubbing?
- Best Auto-x setup??
- Swaybars and G2 Springs
- e-brake cam adn prawl
- What setup would you suggest? (lowering)
- BMR adjustable chromoly vs bmr non adj
- question about LS1 power steering cooler
- drag bar help my 60 fts?
- installed rear LCA, TA, SFC, and Panhard now i have noise at launch!
- Thinking of doing the hose mod but have a few ?'s
- HELP! ST 35mm Front Sway bar!!!!!!
- bleeding with Earl's SoloBleeders
- Zo6 Clipers On An 02 Ss?
- Bonehead needs suspension support
- Clunk while steering cold, uneven turning betwen the wheels
- need help
- having a problem with wheel hop
- Wilwood super 6.. anyone have it?
- ABS Delete/Line Lock
- Roll cage or sfc?
- Who sells painted calipers??
- Question!!!!
- Time to lower the camaro opinions needed..
- Any drawback to SFC's?
- Fender height from ground on your lowered car with pics?
- Lowered cars... how much ground clearance?
- Ran over wheel stop in road
- F-Body Rack & Pinoin...
- Can I use a non adjustable TA on a lowered car?
- relocation bracket
- Signs of a bad torque arm bushing?
- Let's talk pads
- Cheapest Kenny Brown Sub Frames?
- Stock Torque arm
- Racers edge performance torque arm
- Formula to calculate spring rates?
- Will a BMR Trak Pak work with a lowered car?
- Suspension Build up!
- Zinc coated Brembo blanks?
- picture of bmr subframe connectors
- will eibach/bilstien setup ruin my weight transfer at the track v6 setup worth it?
- Buying new rotors. Which ones?
- V6 Springs
- Bumpstop Spring Rates Inside
- Subframe Connector Sale!
- What Shocks?
- Poly bushing sets - install difficult?
- Wheel Hop, have done every suggestion ALL FAILED
- Please help, at my wits end
- My race car project
- Easiest way to change power steering fluid?
- What are the best overall springs?
- Which Strut Tower Brace is best?
- Need a torque arm for use on a lowered car with duals. Need suggestions.
- BMR Panhard rod nut size?
- Why????
- Eibach Sportline's.....
- Anyone heard of KYB AGX?
- Cross Drilled/Slotted rotors
- What shocks for cut springs?
- Shocks?
- help on lowering springs
- Bmr Sfc
- 13" Rotors on C4 Rear ???
- Holiday Brake Kit Special 4-Cross Drilled Slotted Rotors And Pads Kit 299.00 Free S&H
- Goldline Lowering Springs? Pictures?
- What torque arm do I want?
- HAL QA1 shocks
- BMR or G2 SFC's for low clearance...
- H&R Springs and QA1 shocks?
- Help me Please!
- sportlines with koni DA's
- ? about sphon SFCs
- Bmr adjustable panhard bushings?
- PW to manual rack weight savings.
- anyone have pics of a chassis mount torque arm?
- SLP Powder Coated Springs Question
- napa rotors rusting
- What next, Hals in back, or an adjustable Torque Arm
- Strut Tower Brace For Drag Racing?
- How bad is my setup?
- Need Pics of KBDD installed
- C5 rotor upgrade
- 1LE Koni's the same as regular DA?
- on a scale of 1-10
- front lower control arms (lca's) aka "a-arm"??also what good is it to replace stocks?
- Installed Bilstein HD's and Pro-Kit!!
- Sphon LCA's PROBLEM
- 02 SS pops and squeaks
- eibach squeeks???
- rotor wont come off...
