View Full Version : Suspension & Brakes
- Which Slick
- LS1 to LT1 rear brake conversion
- 16x8 Firebird Rims
- Brake Claspers
- Suspension upgrades...
- need pic of brake lines after k member install!
- Eibach Spring Rates
- 1.58 w/ just LCAs at SLP day. How to improve?
- how much for front brakes+all around brake lines isntall?
- abs & tcs lights
- 205/40/17 Tires
- Im trying to put the stock LCAs back on and they are identical...
- Panhard Rod Bolt Sizes?
- Spacers for rear springs ...........
- Squeek coming from Dash area
- will sphon T/A fit slp sfc's and longtubes?
- Advice On convertible SFC's?
- Weld draglite fitment on LS1.
- Cadmium coating - Rotors??
- rotors
- Subframe connectors
- Hal front springs lowered car, what springs to get?
- Speed bleeder help....
- trimin the springs
- Need help setting my pinion angle PLEASE!!
- help me make up my mind
- Poly Spring Mounts?
- So basically all panhards are the same?
- Installing new L.G. Motorsports G-stop Brakes tomorow
- Can anyone help? New brakes wearing in an odd pattern
- What new wheels and tires for my '99WS6 F'bird?
- How to adjust LCA?
- Anyone using these rotors?
- Tech-1 or T-100 scan tool...for TCS system...
- Handling feels messed up. Need help!
- Cutting springs...
- Suspension newbie...input on possible setup?
- No traction....at all!! Need advice!!
- BMR Control Arms And K member
- Stock suspension weight
- front shocks
- Found source for HiPo steering pumps and such..
- Where to buy eradispeed rotors???
- Goodyear Eagle F1 Supercar question....
- Teflon Brake Lines
- Best Brake Pads that don't squeel or dust?
- Check Sponsors & specials for PPC LCAs, PHBs. & TA ...
- Autocross Tires?
- sterring problems
- adjustable panhard rod?
- Anyone run brake ducts from Camaro grill holes?
- how would eibach drag springs be for a daily driver?
- Clearance issues?
- How to Correctly bleed the brakes? Castrol SRF
- 15 inch welds question?Help before SLP day!
- Shock/sway bar ??
- Lowering Springs -which ones will...
- anybody using LGM's G2 coil-over kit?
- Can you get adjustable kits that go with hotchkis springs?
- ground control coil over kit
- Shocks For Drag Racing
- clunk from koni double adjustable?
- SLP Level 1 Suspenios Setup Any Good?
- Brembo OEM replacement Rotors ROCK!!
- GETTING CLOSE
- G2 lcas w/ reloc brackets.. wheelhop question...
- Bilstein BTS Susp Kit???
- Will BMR springs fit on Hal shocks??
- Eibach pro kit good/bad?
- Rim size
- What setting do you have you Hal's (QA-1's) on?
- Upper Panhard Bar
- Can you really tell a performance difference with the Eradispeeds over stock?
- how well does 1LE suspension hook up?
- Wheel hop
- CrossDrilled/ Slotted Brakes -- Why ya'll saying..
- Spring Recomdations
- Can someone please give me a link to...
- Spohn Torque Arm on a Lowered Car
- Gonna buy some 17x11s for the rear got a ?
- ABS help
- Dropping Sierra Denali
- Getting BMR K-member, no PS, do I get factory or Pinto style
- Brake Shudder
- symptoms of a bad wheel bearing/hub assembly?
- DOES ANY ONE HERE HAVE PICS OF
- C5 Brake Upgrade costs?
- Brembo rotors any good?
- What's better front brake kit, Wilwood or Baer?
- need help
- GW SFCs
- KVR Rotors
- KVR Rotors
- removing KB sfc's any tips?
- Which components do you suggest?
- tire pressure question
- New Rotors Eradispeeds
- roll cage question, plz. u must respond!
- BMR sfc's install???
- Torque Thurst II and ET Streets
- hal shock questions
- Bilstein Question?
- Is anyone using the billingsly panhard?
- Front end alignment. Is there any resaon...
- BMR LCAs
- granatelli springs
- Line Lock help?
- 25 pounds unsprung pounds vs. 500 dollars!!??
- Nail in Nitto: Plug or not?
- PA Racings A arms sway bar mount broke at weld!
- Spring question?
- Price for spring install
- Adj LCAs or relocation brackets?
- Good tire for 16's
- rear Hals?
- anyone have global-west stuff on car
- ford 9'' or chev 12''
- Great service at Spohn Performance
- Anybody using this torque arm?
- parts to use??
- If you have been trying to contact PPC ....>>>
- Need Help installing ARP wheel studs
- Help! What brake pad??
- how often to grease LCA's?
- Slicks?
- Slicks?
- post pics of cars lowered with g2 springs
- Baer Eradispeeds vs Powerslots
- ? on tires
- Should I put Pilot Sports in the back instead of Nittos?
- tailshaft vs tunnel brace for torque arms
- Please, I need pics of your weld-on reloc brackets, help
- Rear is squeaking.....
- Skinniest tire on stock rim
- Can I remove these? Any probs?
- LOWERING CONCERN
- Long T/A or Short T/A?? What was the verdict??
- 16x8 with E/T`s enough tire?
- manual steering rack and handling /and other weight loss related ideas
- Hows This Suspension Set-up?
- Where to buy Nitto 555 R2s?
- Drag radials
- LCA end question.
- Torque Arm
- EBC rotors - initial findings
- SUSPENSON PARTS ?'S
- Shocks, various makes, opinions?
- Traction mod
- spohn torque arm ok for 9-10 sec car?
- No Grease fittings on BMR front control arms???
- Polygraphite or Polyeurathane?
- Wolfe RaceCraft 6 point roll cage weight
- So I'm getting some chromemoly subframe connectors. Anyone got em?
- slp level 1 ??
- WTF is this squeeking noise???
- Wheel hop?
- Traction...17" vs. 16"
- good torque arm?
- Rebuild rear calipers (What's involved)
- Cold tires..beware
- Spohn Roll Cages - Anyone have one?
- A-Arm Replacement
- Which part for lowering?
- g2 lca and phb
- rear suspension ?????????
- Passanger side sits lower and hitting the rear wheel, please help
- need some traction and brake advice
- 98 ws6, warped rotors, 40K miles.
- What would I need to avoid loosing traction with street tires with an 8# ATI SC?
- Anyone tried PPC LCA's?
- suspension help
- Whats the diff. between these swaybars
- Help looking for Poly Kit for my Sway Bars
- rear slides over when doing a burnout?
- Need info on brake kits.
- Installing LCA relocation brackets
- Who sells Tokico Illumina 5 shocks F/R???
- Steering rack replaced... best way to bleed.
- Questions for those who cut their springs.....
- Pro-Kit Install
- My PS pump went out, hard to install a new one?
- Which One First
- LGM Rear Suspension Parts are In
- Which shocks TB on a Budget???
- BMR K Member: Does it lower the front of the car?
- Bad ABS sensor?
- Bleeding Power Steering
- Is this a good slick/skinny combo?
- Improving braking...best bang for buck?
- LCA poly/rod and rod/rod
- brake pads
- Question on tires.
- Changing Tire/Wheels help out wheel hop?
- BMR subs & strut tower bar
- BMR LCA Relocators with stock LCA's?
- K-member and Alignment
- Tires follow road ruts
- 335 street tires on rear and 295 on front, whatyathink?
- In need of better tires
- Question on greaing suspension??
- Delco Durastops
- Car hard to steer
- upgrading from poly bushing lca's to rod end lca's
- rear brake rotor measurements
- Other Springs?
- Will 18x10's fit on the front???
- Strut Tower
- Finding some middle ground
- Kumho MXs: good tire?
- How to remove front sway bar?
- Locking Lug Nuts
- HAL's w/ Eibach sportlines?
- Removing front sway bar
- How hard to remove front sway bar?
- Comp Engineering Shocks
- Did suspension go out
- Any experience with Wagner brake pads?
- Lakewood traction action lift bars?
- Another brake pad question
- BMR double adjustable LCAs
- drag racing/ BEST lca's? metco?
- The best lowering kit for Ls1?
- sway bar end links
- Dynamic Motorsports springs???
- Lightweight Wheels
- SLP 21mm rear sway bar
- adjustable Vrs. fixed LCA
- DMS SFC's
- Relocation brackets for LCA's?
- weight limits
- kyb gas-a-just !
- Got EBC Rotors, check in here
- What could cause a sudden increase in brake pedal firmness?
- DR's...which ones to buy??
- problem with bmr adj. torque arm!!
- Anyone with BMR tubular SFC's??
- "Wonder Bar" ?
- Braided steel brake lines & TCS?
- "Low trac" light comes on, but no TCS?
- sfc's and headers?
- 315/35/17's do work on 9.5" rims! Measured footprint of 275 vs. 315 on 9.5" rims!
- Weld Pro-Stars Sizing, Backspacing etc...
- Those with P315 35R17 in the Rear???
- Wheelhop help needed!!!
- Seriously pissed......
- Removing calipers question....
- anyone's steering wheel do this?
- SLP headers & Eibach springs, clearance issues??
- If stb do anything when...
