View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52
  1. LS2 402 with headers stock heads and intake?
  2. mystery block?
  3. LS7 Dry Sump on LS2 block?
  4. 6.0 + L92 Heads + Carb = streetable build for under $6k?
  5. L92 Crank in a 6.0 block
  6. What's with the TQ dropoff at low RPM's?
  7. who built your 408?
  8. LS2 + 10W-30 Oil?
  9. trick flow heads put down the power!
  10. LSX Block or L92 block
  11. GTO LS2 Diesel
  12. torquer 7 on L92 408 ???
  13. Will Harland Sharpe redo factory L92 rocker arms like they do stock LS1 rockers?
  14. Is it bad to have more stroke then bore?
  15. 427 (4.125 x 4.0) cam Intake/Exhaust split???
  16. l92/l76 setup on order for my ls2 whats the deal with cams?
  17. LSX block will use any LS head...
  18. Saturday night special.
  19. L92??
  20. Opinions on new motor???
  21. 408 cam
  22. Bare Vs Assembled L92 Head Purchase: Which one?
  23. 433 cid on the stock sleeve, L92 engine
  24. LS2 block fitting?
  25. Ls2 Timing Chain Dampner
  26. Help Calculating DCR
  27. Sleeved LS2 v. LS7
  28. LS6 to LS2
  29. motor mount bolts
  30. Texas Speed 402/LS2 crank pulley question
  31. Livernois Stage II Cam
  32. Will the new LSx block use plastic lifter retainer cups?
  33. Looking for Carb Style Intakes on Vettes
  34. LS2 rods versus LS1 rods
  35. Slp Zl-402 ?
  36. part number question
  37. Planning out my next engine (370 w/ L92/L76 setup)
  38. Warhawk 12 deg head breaking news
  39. Where can I find information on a LS2 swap?
  40. GMPP Camaro & GTO
  41. thread about dirt in new engines?
  42. cam sizing
  43. Patriot Performance Christmas Special ! 243 Heads, $350 per pair... Gold Springs $225
  44. Single plane manifold part numbers
  45. Injected LS7 single plane w/ Kinsler 4bbl [pics]
  46. Livernois Stage 3R Head/Stage 2 Cam C6 - 472 RWHP/412 RWTQ Video
  47. What Is On Your 2007 Wish List For New Products??
  48. Help please with L92/LS2 HEAD GASKETS
  49. New GM LSX Block (500+ CID)!!
  50. Where to Get coated Rod bearings???
  51. L92 head gaskets
  52. L92 valve covers?
  53. Drive by wire throttle movement
  54. LS2 Info: Specs, Physical Dimensions,etc...
  55. Wagner Manifold
  56. ls2 blowing coolant
  57. DIFFRENCES BETWEEN WARHAWK BLOCK(biggest one) AND THE LSx BY GM PERFROMANCE PARTS
  58. anyone running a sale on a forged ls2 short block?
  59. L92 head gasket bore size???
  60. LS7 Ti rod durability
  61. How much abuse can the LS7 Ti rods take?
  62. New LSX Block!!! 8.3L (merged with other thread)
  63. Just Balanced 402 Rotating Assembly from SDPC
  64. Will an Accel Gen 6 or 7 run a built L92?
  65. ls2 will not fire up, any suggestions>?
  66. QTP Quick Change Front Cover for LS2
  67. 4.25 LS7 crank?
  68. Might need some help.
  69. Knowing about the Warhawk Aluminum, and heads
  70. L92 availability?
  71. So has anyone put l92 heads on a ls2 yet that was actually in a car?
  72. 6.0 lq4
  73. c.r. for 93 octane
  74. Anybody running torquer v2-3 w/ stock heads?
  75. Solid LS2 w/ TSP L92 and 11.5:1
  76. LS6 port molds.
  77. Block Machining questions (Line Hone, Cylinder Hone..)
  78. Would LS2 to L92 head swap drp CR?
  79. TPIS CORN 427 w/L92 Heads & Custom Intake (56K, beat it)
  80. l76 intake/throttlebody....
  81. What cam is in your stroker?? Thanks in advance!
  82. Quick question...
  83. L92 Heads Or Ls6
  84. looking at building an ls7 with low end torque
  85. Camshaft Bearings For An LS2?!!?!?
  86. Quick ls7 questions
  87. L92 Sectioned Head Pics.....Porters beware!
  88. what size cam do i need?
  89. Can you put the L76 intake on the LS1/6?
  90. Life in a forged daily driver...
  91. 2007 Z06 LS7 HPE Heads & Cam Results
  92. HP > RWHP vs Flywheel HP
  93. 03 chevy k2500 heads
  94. Hey Gunnar!?!
  95. cam sensor question
  96. What Rockers are Available for ETP LS7 Heads?
  97. Injectors, fuel rails for l76 intake
  98. LS2 Valley Cover Dimensions
  99. L92s and deck strength Q
  100. Gen IV truck engines??
  101. Is this 6.0L a blem block?
  102. L76 intake vs. L92 truck intake
  103. A few questions about doing big CI NA motor in a C6 vette
  104. head flow with different bore sizes
  105. max high octane spark on a LS7
  106. Cam Timing, UMI90mm and Piston slap?
  107. LS7 swap in a C5 vette??
  108. L92 Truck intake questions -
  109. Cam Gurus Help (DCR)
  110. First impressions of my L92/L76 408 (a little long)
  111. L76 intake work with LS6 heads?
  112. L76 Vs. L76
  113. L92 heads: Rocker and spring ??
  114. LS7 in a 02 Z28?
  115. 408 with msd
  116. Single Plane L92 Manifold
  117. ETP Heads= Problems?
  118. LS7 dry sump system supply pump function?
  119. Ordered TSP 427 LS7!!!
  120. 03 Zo6 cam and spring???
  121. looking to upgrade a maf
  122. Ls2 Install - 69 Camaro - Ny
  123. L-92 vs LS7 block strength
  124. Pistons...
  125. FIRST WARHAWK BLOCK BUILT and RUN.
  126. Help me pick the best combo
  127. MS4 cam enough for a LS2 402-418
  128. Buying a cam for my C6 Z06!!
  129. LSx head valve angle?
  130. Something Interesting we found today
  131. who all runs 1/2 inch head studs?
  132. LME L92/LS2/LS7 shortblocks
  133. Question about the LS7!
  134. Best place for LS1-LS2 conversion stuff
  135. Will LS7 Exhaust Manifold work on L92 Heads?
  136. Just got my LS2 block... now what?
  137. SDPC says LS2 = LS6 intake valves?
  138. Are the throttle body o-rings for the LS2 car and truck intakes the same?
  139. Eagle Crank / Rods? Need your opinions
  140. New engines in 2007?????
  141. Stock crank bore size of an LS2
  142. L92 = 1.8:1 RR Offset Intake and 1.7:1 RR Exhaust, correct?
  143. LS2 Front End Impact Damage
  144. Thread "Price Reduction on the GMPP LS7 Bare Block" is gone
  145. Potential problem with new build
  146. AFR225/FAST on LS7
  147. LS2 forged vs LS6 forged
  148. Milling head & thinner gasket ?
  149. Just a quick question?
  150. L92 Cam Guestimates & Opinions
  151. Which rotating assembly?
  152. Simple Internal Question, Oil?
  153. Can the l92 heads l76 intake be used on a stock bore LS6?
  154. 6.0 shortblock
  155. L76 MAP Sensor P/N
  156. Is SD emissions friendly
  157. Ideal AF ratio on a NA motor?
  158. Does the LS7 use knock sensors?
  159. my 60lb er's in l76 intake?
  160. LS7 Intake "Hiss"
  161. waterpump picture ?
  162. tbss l92 heads
  163. 402 L92/L76 is on the road
  164. why 427 why not 454? LS2
  165. Exp. LS Short Stroke advice needed
  166. L92 with LS7 heads & intake
  167. Texas speed 402 , switch to L92 HEADS???
  168. So... could you put an ls1 block in an ls2 car (05 gto)?
  169. Awd Tbss cam install and tune????
  170. LS2 Intake Vs. LS6 Intake
  171. Dart LS Blocks
  172. has anyone used this yet??
  173. New GM LSx iron block and heads on 1969 Camaro, 454cu in, 641 hp...
  174. L92 head dyno in GM High Tech
  175. Which cam for a 403 LS2
  176. ETP 4" Bore LS7 results and more testing at LGM
  177. L76 Vs Ls7 Side By Side
  178. Iron GMPP LSX block
  179. Ls7 and a C5 ?
  180. Milling the L92 heads
  181. will these head gaskets work???
  182. Precision Race Components Ported 6.2L Cylinder Heads Almost Ready!
  183. L92 heads, custom grind cam and -10cc dome pistons?
  184. SAM school Graduate
  185. L92 heads clear custom cam?
  186. What is needed for LS7 heads and LS7 intake to install in 2003 Z06??
  187. L76 Injectors And Rails
  188. L92 Head Damage Question
  189. If I built a new LS2 402, what do I keep from the LS1?
  190. ls1 conversion to ls2 question?
  191. L92 head gaskets
  192. Lifters: Morel vs. GMPP
  193. Katech Torquer LS7 cam 557rwhp on a dynojet
  194. GM Direct Blocks
  195. How about this intake
  196. cam questions
  197. nitrous heads on L-92
  198. LS2 into Fbody, shimming oil pan needed?
  199. LS7 cam in a LS2
  200. TSP 5.3 stage 2 Question?......
  201. tuner, vendor, speedshop?'s
  202. LS2/LS7 90mm drive-by-wire throttle body
  203. GREAT no dipstick hole on ls2 block I installed
  204. L-92 questions......
  205. L92 heads on a LS2 cam help
  206. What spring for L92 solid roller?
  207. Who makes aggresive cams for 402+ ci LS2's?
  208. Rocker arm problem?
  209. how big on an LS2?
  210. Deleting PCV system, knock sensors, & switch to SD tune?
  211. can the 317 6.0 head be machined down to 64cc LS6
  212. LS6 pcv plug....
  213. Piecing together an LS2?
  214. Tech 2 -> Crank sensor
  215. Does any body have a set of LS2/Lq9 pistons and rods for sale.
  216. l92 vs ls2, weight & strength
  217. basic LS7 Balance question
  218. Tsp 427
  219. Lets talk about the cam position sensor on the LS2
  220. L92 pushrods
  221. What size cam for Turbo build?
  222. LS2 injector measurement needed
  223. to SD or not to SD
  224. stock cube ls2 power
  225. got me a 402ci w/l92 ported heads and l92 intake.
  226. Bad Tuning blows up '03 Z06/ Bad LS7 crate motors
  227. Any Progress On Ls7 Intakes/ Sheetmetal
  228. ls2 402 heating problem
  229. Any Gen 3/4 engine schools around
  230. Has anyone milled L92's heads for compression yet?
  231. GM lsX 6 bolt head
  232. Who is using the GMPP carb style intake??
  233. L92 heads with 1.8 ls7 rockers (pics)
  234. Who sells the l92 intake?
  235. Removing Heater Hose Fittings in Block
  236. Carb intake for C5r heads
  237. A step closer, my L76 intake kit!
  238. PCV upgrade??
  239. ls2 nitrous
  240. LS2 specific h/c guides
  241. Ported LS6 vs. L92 oil pump
  242. anyone know anything about this intake?
  243. Performance Manifolds for ls1 ls2
  244. Degreed cam,-2 degrees off. Worth correcting?
  245. fm12 in a ls2
  246. 400ci?
  247. Why no LS7 shortblocks using stock rotating assy?
  248. Which engine?
  249. Please help!!!!! LQ4???
  250. LS7 dry sump on a LS1?
