- Stock LS1 MAF or LS6 MAF??
- VE table work....
- 2001 PCM on a 99? Will it hurt it?
- Stroker and Superstroker guys what WOT timing are you running?
- ls1 edit on 5.3 sierra
- laptop for HPTuners
- I'm ordering HP Tuners tomorrow or Thurs... advice?
- Sanity check please - seeing some odd things after injector scaling and LS6 MAF
- Is there anyway to bring your IAC
- James (RWTD) ph# for sales ?
- Predator Prog-My LS1 Automatic will not kick down to the lowest gear on WOT
- Z06 Maf
- MAF delete?
- Least expensive way to tune for a torque converter?
- LM-1 WB O2 sensor
- 2001 Z06 vs 2001 C5 VE table...the same...lazy GM?
- 36# injectors good to how much RWHP?
- tune for lean cruse?
- How many people have gotten their 230+ cams
- tune for descreened 02+ LS6 MAF on F-body
- With a big cam If you arent.................
- still showing +ltfts after tune
- Hypertech crapped out
- need hptuner bin file for 2002 'vette
- Commanded AFR
- Need tuning! Need opinions!
- Change to MAF Table w/ MAF Ends?
- Few tuning questions with hptuner...
- what mas to get
- Harlan RPM switch - LED question
- 236/236 .525/.525 110 tuning w/HP tuner
- High idle at stop?
- HPP3 just wont work anymore
- Granatelli and HPP3 get along?
- HP Tuners VCM Suite 1.4.0 has been released!
- SES light came on after alignment was done...?
- Newbie Questions???
- Surges bad in Park...Idles great in gear...?
- need a 97corvette a4 flash file
- New to programming, have a few questions. (HP Tuners)
- VE changes to light throttle, higher RPM cells?
- Knock knock. Whos there? Knock retard who? GO AWAY ALREADY!
- Newbie to HP Tuning
- Whats an acceptable amount of KR?
- Just to clarify before I order, HP Tuners is not....
- Predator malfunction. What is going on here?
- Are PCM pinouts the same on different years?
- stock 98 bin for hp tuners anyone?
- Do Timing Changes Afffect A/F Ratios
- Lost Tach Readout
- LM1 owners does anyone have the other input hooked up with the RPM converter?
- GEN7 no fuel
- Missfire disable how to for hp tuners?
- hptuners
- Would anyone care to see more screen shots of hp tuners?
- PCM change??
- If LTFT's are positive at WOT, what variable is used?
- 02's not switching codes , HP tuners kill this ??
- PE vs. F/A
- Question for LM-1 users
- reprogrammers for that hp?
- 42.5 # Svo Injectors , Experts inside please !!
- HP Tuners, Disabling VATS
- easiest (cheapest) way to scan / clear codes
- Only time I get that 1153 code
- air/fuel ratio meter install tips
- Using ChrisB's Analyzer, my methodology.
- Temperature gauge and programming?
- Does anyone do a mailorder hp tuners tune?
- Low octane mode
- HPTuners - Am I way off with my Tune?
- Idle Operation Part 1
- How can I get my HPP3 back to "stock"?
- James is working on my tune
- SVO 42s injector offset
- LTFT's: VE vs IFR
- reading PCM flash files (not modifying them)
- Stock Tach RPM doesnt match ATAP?
- Planning mods, will it need tuning?
- low timing table in first gear only? m6
- Idle Maxxed out after heads/cam install
- OpenLoop tuning in Texas..
- Who Copies High to Low?
- Tranny Settings (Predator)
- WOT Transmission Troubles
- HPP3 problems/questions
- GTO successful datalog?
- PE delay???
- What Does This Mean?
- Limp Home Mode question
- check engine light?
- Helping somebody else...LTFT negative, but O2s are flatlining from actual lean mix...
- any help with these codes
- Help with atap file.
- computer checking?
- Help tuning with edit on a dyno
- 60# Mototrons/Siemen Dekas
- A/F ratio vs O2 voltage.
- WTF?!?!? WOT is closed loop?!?!?
- Do I need cats for 02's to live?????
- electrical problem
- Did my PCM decide to go on summer vacation?
- Tuning changes when running cats?
- Anyone with Innovative Motorsports A/F meter
- EGT to air/fuel comparison?
- air intake temputure sensor homemade mod
- Where does a tune make its power?
- Is there a good 'how to tune idle for lumpy cams' FAQ somewhere?
- o2 sensor problem
- I want to see your Supercharged timing table..
- Car wont start
- What all can cause P0357?
- VinciHP,can i use it ina 98 car??
- 40-41lbs/Min from MAF =.....
- Anyone else have no tune....running a cam, headers, stall...
- tune?
- white 02's, normal color?
- HPT - WOT fueling - PE and Open Loop
- Any F.A.S.T. information
- Extra length of wire for O2's cause >>>
- O2 Simms Necessary for ODBII Inspections
- my diablo died!
- Does your SLP MAF "flatline"?
- VE tables the best way to tune?
- any problems with using a 98 pcm and 99 A4 tranny ??
- fuel trim lean????
- Clockspring R+R?
- FFV Program How Does it Adapt?
- PCM help pls?
- Should I disable Torque Managment with my setup?
- open loop tuning, timing???
- How much does the exhaust system
- Car stumbles terribly with MAF unplugged
- Need some advice on parameters to change
- what LS1Edit tuning do I do for the mods I have
- Edit readout my a/r?
- What causes an o2 sensor to go out?
- O2 readings .995 to 1.000
- Can Stock Cam Run on Aftermarket Cam Tune?
- WTF is up with my SES light???
- 2004 Chevy Colorado LS1
- lt fuel help
- New code tonight - HELP!
- Whats the best software to tune LT1's??
- Thanks to Jason @ TSP
- Need HPTuner help, quick!
- HELP with 2-step install
- Reading timing on efilive
- running lean #5 cyl. only
- go buy hptuners/ls1edit or just use the $500 to get a dyno tune?
- HPtuners for the 98's
- Knock sensor code. What do i need to do
- HPTuners - MAP to KPA Vac?
- Tuners?
- PE vs RPM Question
- Open Loop Tuning W/O Wide Band
- Flashing Ses Light?
- Big Stuff have a website
- does iac track rpm or massflow
- Who carries the HP tuner?
- Code after Header Install - Help!
- Can you check you MIL status with ATAP?
- HPP3 & Granatelli MAF issues?
- hpp3 ?
- new to tuning....
- Engine shuts down in 20-30 seconds
- Fair?
- RPM sticking when car is taken out
- ZO6 MAF Table?
- Required time delay not expired
- Anyone ever use Chip Master Revolution??
- NY ODBII Inspection?
- Pulled my MAF tonight
- HP Tuners .bin file Repository -- Search for bins , upload your own bins!
- Help with autotap V2.05 for windows please.
- Cam tuners help! Car sporadically shutters with TR 224-114
- Not happy with Granatelli Predator
- What RPM to spin my stock ls1
- Total newbie quesiton for "what product do I need"...
- Electical problem or pcm problem or both?
- Open loop tunes
- Edit file for HotCam
- Another + For HPTuners
- How slow does the ve table move
- HPtuners vs. Ls1edit
- Direct port & tuning?
- Diablo Question
- EFILive's New Scan/Flash Tool
- 98 HP Tuner in Detroit area?
- wow no one can figure this one out?!?!? PLZ HELP
- 98 PCM To 99???
- TA's got electrical(?) problems
- Need wiring diagram help ASAP
- HPTuners and ID Numbers...
- Maft Settings Question
- Need a primer on tuning a cam with LS1 Edit.
- Any tuning changes needed when going to TH350??
- Will unhooked fuel gauge cause low octane mode?
- Do any scanners act like the GM tech 2
- Diagnostic codes
- Scan logs, need help.
- multiple misfires
- Code Po430
- Any F.a.s.t. Tuning Help - 5.7 With 13.5 Psi
- Looking for help!!!
- exhaust leaks and tuning problems
- Wtf?? 02 Voltages
- G5x3 tune with an A4
- What WOT 02 Voltage do you shoot for???
- Code p0412, im clueless, PLEASE HELP!!!
- please help this idiot
- will a wiring harness for auto work on 6sp?
- Surge while cruising, and (unrelated) dropping revs too fast...
- TCS Issues? WS6 TA vert gas mileage? Possibly modded?
- Something I just noticed going through logs, adding PE affects Ltrims
- g5x3 / hp tuners anyone?
- Measuring and Recording Boost
- What is needed for stock PCM, HP Tuner
- Advanced Predator question
- 85mm MAF....4 wire vs. 5 wire?
- how to lean car wean coasting
- 6.0 swap... What do I change?
- Why am I slower???
- Cam guys quick question
- WTF? Car is throwing 1134 and 1154 codes?
- ifr usage
- Crazy O2 readings: offscale rich or super lean?
- please someone help
- Are LTFTs directly applied to the VE table?
- Mis-fires at WOT
- 02 Sims Not Working?
- bin file sharing?
- What to tune? (Basic Tune)
- realy dumb question
- p0412= bad check valve???
- Uneven fuel trim readings between banks. Why?
- Converter not unlocking
- Injector tuning with a manifold vacuum regulator...
- Please define, total misfire count and history.
- A few words about Diablo Sport customer service.
- HP and IFR question, idle use 80kpa value?
- Cheapest way to adjust Idle speed?
- Verify Knock Sensors Before Engine Goes In??
- pcm reading question
- Care to critique my newest timing table?
- Need help with basic HPTuners tune tomorrow!
- IAT's, ECT's and tuning
- N/A and Dry Nitrous in the same tune?
- WTF o2 bank 2 sens 1 reading 225mv
