- Guys, PLEASE HELP
- My LM-1 sensor died, I think, need a new one...
- what code would a plugged cat be
- Bad knock sensor causing weird KR readings???
- "readiness" and emissions testing
- I need your help !
- hypertech flash tool
- timing
- Ls2 Maf Vs Ls1 Maf
- SD and smog
- can a .bin from another year be used?
- TPS WOT not reading 100%
- Air Bag Light
- TH400 Swap... do I need a VSS signal?
- comparing tunes....stock vs mine
- P1637 and p0102 started yesterday in the rain
- sd tune and maf
- Help! Code PO442! Replacing gas cap does not fix it!
- A4: will I have to go low on my 1-2 shift MPH?
- Hpp 3
- Diablo Sport II........
- won't start, what'd I do?
- Most user friendly tuning program
- DCT P0336 Code any one KNOW, how to get rid of it?
- A little something for your guys without a WB
- How to re-enable my TCS
- How to set TC to only lock up in OD
- Knock retard at part throttle
- when do you guys cut out enrichment? and go to 1.00 mult? ECT wise
- help with oil change light
- cranking ve, do you guys change this?
- Z06 with cam will not idle correctly when moving
- what would make fuel trims lock + in open loop start????
- A4 to M6 Swappers inside...
- Map reading question
- What is the cheapest way to log my car?
- Bucking / "missing" with a P0161
- Fitting larger injectors, what table to change?
- Wide band O2 install location?
- Diablo vs crane powermax
- IAT and AFR - my theory
- Adjusting the A/F Ratio
- VATS resistance chart
- My tune seems to go away everytime????????
- Need some help please!
- MAF Extension??
- Passing gear...
- i need help fixing my ses problems
- o2 sensor throwing codes
- What High Octane Timing Table do you use?
- drive by wire and effective area?
- stock timing table
- code number 121 ap/tp sensor?
- how to make this in histogram
- Need help with SD tune..
- Ses Codes Obd1
- Help with 4l60 and new gears
- EFILive FlashScan & LC-1
- P1460 code?
- Will this shift time setting destroy the 4L60E?
- 98 z28 and flashscan
- LS1 edit and trans PO757 code question???
- Can't get proper VSS signal from PCM
- LM-1 and gauge
- recalibrating
- Problems installing HPT 2.0
- tach inop help please
- PE time :)
- Help with Timing Tuner
- wanna confirm ve stuff
- P0171 And P0172
- 15:1 a/f = more hp than 13:1???
- 80-e swap problems....HELP!
- Temp effect on AFR?
- 98 & SD Tuning on A4
- Flashing the Flash chip
- Kansas City MO needs some Scanning help......
- hptuner 2.0 cable
- Effects of running speed density using only Secondary VE table?
- What happened to the Lean cruise threads ?
- 1992 RS Speed Sensor.. HELP HELP!!!!
- Passenger Compartment Warm
- ? bout stoich a/f
- Write over canned Predator tune?
- How to convert a 99 OS to a 01,02 OS?
- I/F question about HPTuner 2.0
- Do you have to reset Computor
- VCM Scanner 2.0 - Not allowing me to assign a user defined WB to Air Fuel Sensor
- Is OLFA table used for any normal operating conditions ?
- Pcmforless
- Hypertech POWER PROGRAMMER
- Tuning Software for Apple
- Need Help with EFILive
- intake temp 85 degrees and up ping , ping , ping
- i have code Proplem ?!!
- P0137 is still pestering me...
- Still Bucking Around 1500 RPM.
- preditor
- SD and EFILive Auto VE tune with Returnless fuel system?
- P0171... Bank 1 lean.. Is this the drivers side?
- 02,s smoothness
- 98 tach wire help
- a bit confused and got some questions.
- converter removal on 5.3L
- Speed Density..pros and cons?
- VE & MAF: How do the Pros do it??
- Need help with re-calibrating my MAF meter
- How can i fix the Reduced Engine Power ?
- Lost and confused... help
- anyone experience this on warm starts?
- LS1w/ VDO GAUGE SENDERS
- help with low rpm bucking
- hptuners cable problem
- Help, gonna burn this LS1. (detonation issues)
- Repin Diagram!!
- Questiong regarding MAF and running Lean
- 98 z28 pcm automatic to work with a t56
- ls1 edit locked pcm?? read and write with HPTuners??
- SES Light Went Off!
- LS1edit questions
- hpt graph
- What is the best wideband for EFILive ?
- bored and need some info please!!!
- Could running with these codes harm my engine???
- Need help tuning a 93 LT1
- what is loss of low pulse resolution, opti-spark code 16
- Seattle Area, Hypertech needed for gears
- Is there anyone with a big cam who doesn't have low rpm surging?
- need help... replacing optispark distributor
- hesitation in every gear 1100-1600rpms?
- Tach Signal
- EFILive Help
- hp tuner help
- Anyone been thru So. Cal. Smog test with headers/tune...?
- HP Tuners checking in from SEMA
- P0135/P055/P0300 - Help, what should I do next?
- Can someone post a stock ve table please..
- My first tune after LTs couple of concerns
- CKP System Variation Learn Procedure?
- Please help codes after header install!!!
- tuning for long tube headers?
- 05 Gto
- Got Knock
- If you spin the engine past 7,000 on stock PCM......
- Intermittent Stalling.........
- Change DFCO with a Gear Change?
- Why Knock Sensors?
- NA vs Nitrous Tune...
- anyone make this part
- post your high octane tables!
- Using a NTK wideband sensor ?
- Code P0108 help needed!!
- HPT 2.0 probs
- Open loop always?
- SES light: P0135 code
- PIDs to Log Via Edit to Tune VE Tables
- MAF calibration adjustments from LTFT histogram
- Histogram Not Woring In Hpt Vcm Scanner 2.0
- Necessary programming after 2.73 to 3.42 swap?
- Tuning for a cam without a dynotuner
- Weird Misfire, anyone?
- occasional momentary fuel cutoff while shifting
- Filling these cells is hard !
- anyone been to SEMA yet?
- Car idled at 2,000 RPM's for the second time!
- Tuning The 06 Ls2
- Scanner for 05 Corvette-suggestions?
- WTF is goin' on w/ my car?
- tried The New Maf Translator Pro Yet
- Need help fast
- injector duty cycle 70%
- Missing
- Wide Band without an interface
- LC-1 serial cable recognizes but does not......
- Need help with hp tuners..
- VE table question
- Dyno Tuning Locations.....Need Help!!!!
- Using LT1 Edit, how do you turn off the knock sensor?
- Quick question about hp tuners..
- help
- How do you guys set your WOT shift points?
- MAP Problems???? 90 plus KPA at Idle
- Help Question!! Car Misfires/Won't Idle
- Is the EIO needed for wideband tuning?
- anyone ever turn off front O2 sensors?
- HPT Noob ques / Chevelle LQ9 Conversion
- tuners 2.0 % afr histi not working?
- Why do the newer temp gauges read fake values?
- Is mileage stored in the PCM or gauge cluster?
- pe and ve
- No MAF signal? Problem, won't run!
- LS1 Edit stupid, where can I go for help?
- Knock after shift... Any one ever seen it?
- Torque Management in A4 C5
- Startup Friction Airflow Correction table?
- Buying a programer to change wheel settings worth it? Help
- Paging Truck guys: PCM Question (PCM Compatibility)
- 5.3 Computer
- P0153 and P0133
- switch from LS1Edit to EFI live
- GM/Bosch V6 S/C Injector table or info needed.
- Temporary tune? Possible handheld?
- throwin code 0420 , need help!
- Crazy idle, starting issues
- Misfire & coil #5 problems
- Problem after header install!! keeps throwing codes
- Need Help..
- Quad Driver Module
- Need Advice
- Diablo sportII
- Mega Squirt
- high and low oct tables
- Can i reflesh my pcm by the ls1-edit ??
- How can i delete my ASR ??
- Dealer lock my PCM :(
- Tune now... or later
- SLP 85mm MAF
- Blown Cats
- Desktop Dyno 2003
- LTFT help.
- Best place to buy LSM11 O2's and is there better?
- Tuning w/ cats in or out?
- won't shift into 3rd gearat full thottle
- Need Help And Advice!
- dissapointing results!!
- laptop for hptuners?
- sd ve tables for big cam please
- Big cam causing SES and misfires?
- Benefits of Various Tunes??
- noticed hesitation during WOT
- Always lean in 1st gear then straitens out
- Is blinking SES always Misfire?
- Tuneing LT St fuel trims 99 SS ?
- HELP!!!!! F#*King PassII IGN lockout
- need tuning solution for 402cid and FI
- injector flow rate calculations ?
- p0300 and the cold
- Recalibrate CPU with diffrent wheels?
- WB tuning with AFR % error ?
- Which tuning software have you guys had luck with?
- Code 1639
- Car won't start after PCM reset
- wanna play with excel sheets, but
- i have a problem when i raed my pcm ???????
- How do you tell the car?
- 2 Bar MAP's
- someone with a similar tune?
- FAT idle wont change...can you help?
- Bone stock Z28 idles smooth at 500rpm?
- LS1 PCM used for older EFI conversion?
