PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. EFI Live question OR anyone have a stock 4.8 tune file?
  2. Car has a high RPM "surge"
  3. Idle Dip at Stop help
  4. HPT boost log?
  5. ABS, INOP LIGHTS- D60 rear end
  6. Trouble with Autometer Wideband
  7. F Body Big Power Computer Too Slow?
  8. Fuel surging
  9. Help! First startup issues
  10. Firing order change with HP Tuners??
  11. Need help w/ ls7 on motec m48 w/expander
  12. Should I reset PCM before sending it to Frost?
  13. lq4 tubo tune. runs very rich at any boost under 4k rpm
  14. ODB2 USB Cable
  15. Trouble Reaching Jeremy Formauto
  16. what factory tune do i start with?
  17. Having trouble scaling MAP sensor OS5 SD tune
  18. O/L SD help please
  19. Need help!!! E67 data link connector pinout needed!
  20. Mail order tune for h/c startup and idle
  21. PCM gone bad?
  22. SD tune, but MAF is still installed?
  23. OBDII Car Engine Swappers - How did you pass emissions? Dash VIN vs PCM vin
  24. Using a LQx harness and ecu in a 98 Tran Am
  25. Questions on Microsquirt setup Vs. Standalone harness/stock PCM
  26. Glowshift Fuel Pressure Gauge Owners Come In
  27. torque app help for fuel gauge
  28. Scan and Sensor Data Tool
  29. Coil Pack & PCM Terminals part#s
  30. Before or After?
  31. two wire knock sensors on 411 PCM
  32. LS6 CTSV PCM with FBody Harness for LS6/700r4..will it work?
  33. Affordable bidirectional OBD2 tool?
  34. Scanning MAF and VE
  35. Car cranks, starts, then dies after a few seconds??
  36. Odd Problem With Bank 1 front and Rear O2 sensors
  37. Battery not charging after harness hookup
  38. PCM reflash
  39. Standalone harness
  40. GM connect & cruise problem
  41. how to wire ngk afx to hp tuners
  42. Anyone Seen/Heard Of A Balancer Timing Marks Being Off? Big Mystery!!
  43. LS1 VE Table, Calculating from 15 kPa all the time?? Need Help
  44. OBDII No Communication
  45. After ls swap no o2 signal…what did i do wrong?
  46. is torque management OFF good or bad?
  47. Question about harnesses
  48. Help!!!
  49. Easy 98 to 99-02 f-body harness repin labels inside!
  50. new to tuning and my c5 went into reduced power mode
  51. Which TPS??
  52. F Body Dash cluster swap, warning lights staying on
  53. Good place to dyno tune in Houston
  54. HELP! car wont start need help troubleshooting
  55. Help me ID these connectors please
  56. 99 SS feels sluggish! Help?
  57. LQ9 swap
  58. ls1 motor, megasquirt2 extra and tach signal?
  59. Gearbox map
  60. Firebird V6 - V8 Swap - UI000 Code / Also Emissions cant read PCM but scan tools can?
  61. Surging, Stalling, And Dying After Long Tube Install
  62. 1999 Camaro
  63. Base tune for firing of new motor, options?
  64. LS swapped mustang o2 sensor question
  65. Crank Signal RPM
  66. Aem AFR guages on sale through amazon. $130
  67. *Our Holiday Sale is going on! Great gifts at great prices!*
  68. Buy a used HP Tuner Advice needed
  69. DTC code- P1570
  70. '99 Z28 - P0410 & P0412 - Questions
  71. 24x Reluctor Wheel Alignment
  72. BCM programing (whitebird00)
  73. 98 PCM/harness upgrade
  74. "LSX Powertuning" - great experience
  75. I need a harness and ecu. Turbo build any ideas?
  76. DFW tuning
  77. WMW Computer Throttle Filter Module
  78. wierd misfire thats driving me bananas
  79. brand new PCM, whats it worth??
  80. Innovate LC1 Wideband
  81. Any way to know if a car is tuned?
  82. Thank you jimmyblue!
  83. Scrambler 6L won't stay idling
  84. HP Tuners Credits
  85. HP Tuners Questions
  86. LQ4/4L80E swap.... first fire up.... no luck
  87. LS3 and a 6L80
  88. tune for TU1 cam in a 6.0
  89. 04 zo6 cam in a 2002 gmc denali tune question
  90. AEM First start Vid
  91. HP Tuners or dyno tune?
  92. P0420 & P0455 codes disabled, still pass emissions?
  93. cold O2 sensor output question
  94. LS Swap Harness question
  95. Burst knock tuning 98 c5
  96. Will Any PCM 12200411 Work With A LS1 Swap?
  97. decitions on Holley/ECU/Pro/???
  98. Efilive COS 3 Altitude change turbo e85
  99. cam position error code P0343
  100. o2 sensor issue, left bank rich, right bank lean
  101. Need help or advice with HPtuners
  102. 4l80 lockup issues attached current tune
  103. 98 LS1 Wiring Harness Question (C100 Connector.. TPS Wires...)
  104. Try my first SD tune or have it tuned?
  105. can you use a 2002 v6 ecm on a 2001 6.0?
  106. questions on my re tune?
  107. Wideband question
  108. Need a tune or Ideas!!!
  109. HP tuners question
  110. has anyone got a custom tune by teamZR1?Looking for opinions
  111. can someone help me with maf tuning!
  112. Multiple dash lights on and HPTuners question.
  113. Need some help- P0300, P0301, P0304
  114. Auto tuning ECU's?
  115. Won't start help....
  116. gear change tune
  117. access port style computer??
  118. Tune changes for FAST intake?
  119. duty cycle dropping but not commanded to
  120. Pegged LS2 MAF
  121. ls1 and ls2 pcm pin outs all the same?
  122. Wideband o2
  123. who should i have it tuned by in houston or tune my self?
  124. Fast 2.0
  125. Speed Density Approach
  126. Help read my plugs
  127. Anyone use this tuner?
  128. Hotcam tuning suggestions
  129. *HELP* Northwest Louisiana Dyno Tune
  130. TPS will not read 100%, only reading 60% (3.0V) at WOT
  131. Intake Backfire?
  132. Ls1 crank sensor wiring question (please help)
  133. tuning book
  134. 3 trouble codes after a tune up
  135. RPMs rise during shift
  136. Need help getting the 5.3/Holley HP running
  137. AEM Wideband (what wire to tap into for power source)
  138. Ecm 12211031 hdw 09386530?
  139. Very unique Column Lock issue PLEASE HELP!!!!
  140. 2008 chevy 6.0 trans plant
  141. LTFT Issues, need some help.
  142. Assistance please asap, Procharged CTSV closing ETC when WOT
  143. holley hp efi with a 58x 5.3 without dbw
  144. 98 Z28-no start after accident
  145. I may have a problem with my throttle pedal and trans due to tune? please help
  146. Will 02 wiring harness/PCM work on 2000?
  147. Ignition switch gone bad?
  148. 4l80e stand alone contoller
  149. Brand new to HP Tuners, now... about the tune repository
  150. Help needed Mast m120 tuning..
  151. what do you think of this scan?
  152. Speed Density & Inspection
  153. High rpm spark rattle ls1
  154. DBW to DBC?
  155. Stand alone harness
  156. Frost Tune
  157. tuning, what to expect?
  158. High fuel trims problem
  159. Newbie question
  160. SD tune Suddenly 1 point leaner- weather change?
  161. Selectable tunes
  162. Built engine, no start! need 99+ wiring swap help
  163. ls3 231/236 base tune
  164. Emissions question
  165. Weird TPS voltage issue, causing hanging idle
  166. GMPP computer
  167. knock
  168. Harness question
  169. couple ve tuning questions,ls1 and hptuners.
  170. 4l80e Swap Help!!!
  171. One last bad idle thread
  172. maf question
  173. Different steps in tuning process
  174. Segment swap for 411 pcm
  175. 4l60e to 4l80e need help
  176. best tuner for ls motors
  177. 2bar sd tune
  178. LS1 tuning 10* overlap on cam - any surge?
  179. KR at 5200 even with timing dropped way down
  180. What lambda for E85 and meth for 11-12psi?
  181. Why is my desired idle airflow so high?
  182. reluctor wheel issue or bad PCM??
  183. Strange IAT problem need some help!
  184. Rock crawler 5.3L spits and splutters HELP
  185. Lingenfelter 58x to 24x trigger box
  186. anybody have Dr.phil contact info?
  187. Tuning Noob in need of some advice
  188. Need a tranny tune for 4L60e with 2800 stall. Who are the pros to go to?
  189. ls1 th350 problems
  190. e85 lean after cold start
  191. HELP! 98 Z28 tries to start and throws crank sensor code. Please help
  192. HPtuners scanner AEM wideband pegging high/low nonstop
  193. Security Light
  194. Cranks but won't start
  195. Want to learn how to TUNE my car
  196. P0334 code can't figure out.
  197. Has anyone used Watson Engineering, Inc for a tune?
  198. How will no o2's effect running
  199. B1001 Code after replacing Instrument Panel Cluster; Help
  200. cheapest way to log LS1 ckp sensor signal ?
  201. Stuck In PE/Open Loop after wot
  202. P0140 caused by bad PCM?
  203. 2011 Camaro/LS3 Crate engine-best tuning software?
  204. Fly by wire help
  205. Using computer for just gauges?
  206. PCM sometimes pulls timing but can't for what reason.
  207. p0200 code traced to grounding issue please help!!!
  208. Stand Alone Fuel Injection for LS3
  209. Wideband O2 sensor only for ms2??
  210. hptuners program vcm problem
  211. tuning help
  212. AEM UEGO Replacement Wideband Sensor
  213. Holley HP Conversion - Need required PN's
  214. Tuning 12 vett
  215. High/ low octane tables
  216. 12' SS tons of knock ??
  217. E40 pcm with GEN III motor
  218. My VE Table / Opinions
  219. pcm tuning reluctor wheel 24x 58x question
  220. Low idle, slight miss not throwing codes?
  221. Anyone in Toledo or NW Ohio AREA. COME IN
  222. Laptops and Tablets.
  223. LS3 A6 Minor bolt on- Tune in a nutshell
  224. Cooling fan Activation temperature???
  225. How to put a 8.8 in a G-Body
  226. Downshift tuning
  227. dtc no data displayed
  228. Ecu reprogramed? Who does it
  229. ODB2 Scan Error
  230. Codes P1416 with P430
  231. who is doing stand alone pcm tunes??
  232. hypertech III power tuning question
  233. Fast 92 and other upgrades. What could I have done wrong?
  234. Injector vs. Voltage Offsets
  235. ls1 reluctor wheel problems
  236. MAF sensor...keep or remove screen? Debate.
  237. 411 PCM Connectors
  238. Best Tuning DVD?
  239. Turbo LS1 idling issue
  240. Ls1 conversion, problem with O2 need some advice!
  241. 98 harness and ecm differences....
  242. Advise on what to tune a conversion with
  243. Need help with 411 PCM
  244. P0300 P1380 P1381 Help
  245. Quick question about LTFTs updating past 4k rpm
  246. Am I good to get my car smogged now???
  247. Another p0507 code
  248. HP Tuners Activation code
  249. Best tuner for a stock 99 vett?
  250. Error Codes P1518 and P1516 under higher boost
