PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Software that supports both formats?
  2. Dual Injectors, HPT capable?
  3. How to modify cranking advance in HP Tuners??
  4. Looking for a base tune 230/238 cam
  5. Knock sensor adjustment??
  6. Looking for tune file
  7. Overdrive comes in to soon
  8. What are these idle control parameters?
  9. 98 ecu and engine sensor harness
  10. Knock retard @ cruise
  11. 408 with a p0336
  12. 99 Corvette Computer how do I add 4L80 trans
  13. Need to replace map sensor
  14. efilive.com not responding?
  15. Why would O2 sensor get this color??
  16. Stock 99 timing file
  17. 98 Trans-Am
  18. 2000 ws6 complete rebuild, no key on, SES light on, BCM beeping
  19. Warm start, needs throttle?
  20. MAF lbs/minute at idle?
  21. 95 z28 pcm (black connector) what wires are these?
  22. Can i use a stock ecu for timing control?
  23. HP tuner, EFI LIve and Innovate Sale
  24. LS3 TPS/PPS Pinouts
  25. Installing heads. Do I need a tune?
  26. 98 Z28 tuning problems
  27. 04 Z06, installed headers, runs like crap, needs tune already?
  28. Reluctor Wheel/ PCM question
  29. Greater than stock cam, will driving 60 miles to dyno tuner hurt engine?
  30. 2400 stall on a 2800 tune
  31. Strange shutdown that I can't explain...
  32. Most versitile PCM?
  33. Switching PCMs
  34. Newbie - Speed density tune on summer only 66 Nova in Michigan?
  35. I think I killed my PCM
  36. Transam file same as camaro?
  37. Take a Look At My LT1 Datamster file please?
  38. Extreme lean idle and cruise ???????
  39. Corn spark plug reading?
  40. Going nuts.....another in-depth tuner question..$50 Paypal whoever figures it out.
  41. Code scan/clear for 98 Trans-Am
  42. Air Fuel Ratio question..
  43. MSD 6010 wont go over 7500rpms.
  44. funny smell at start up...
  45. 2003 2500 5.3 stalling issue
  46. Idles, but when I give it gas, DIES! HELP!
  47. ls1 w/ 4l60e harness layout help
  48. need help
  49. Tuning for 2-3 WOT shift on limiter..RPM
  50. at a delima????
  51. 5.3 base tune w/ cam etc... Questions
  52. Is HPtuners capable of checking fuel rail psi
  53. Pesky High Idle
  54. Difference in tune using 93 octane w/o ethanol?
  55. 408 Cold Start backfire and hesitation?
  56. MAF problems
  57. Tune on a stock car?
  58. Have a P0420 Code after Header Install ?
  59. Fouling Spark plug Please Help !!!!!!!
  60. 99 Silverado BIN
  61. What should my long term fuel trim % be?
  62. Can a 40-100 O2 reading cause an 80 hp loss?
  63. 94 z28 lt1 no pulse at the injectors?
  64. Random misfire in closed loop only
  65. Email tuners
  66. Would this be possible ?
  67. "Performance Shift" button
  68. Need some help....LS2 GTO 226/234 cam P0106 Code...
  69. Michigan HPtuners Users?
  70. list of what will pull timing???????
  71. 2012 GM truck support now available!
  72. Cooling fans not working
  73. Autometer Wideband Problem
  74. Drive to Dyno-Tune
  75. Found Vacuum Leak- what is it though? Picture
  76. need help programming with my diablo sport
  77. need a tune?
  78. No start...need help troubleshooting!
  79. 416 L92 - timing over 40?
  80. Fans (not cooling fans) on LS1
  81. Spark falling to negative and amost dieing at idle
  82. Using wideband o2's in place of narrowbands?
  83. Anyone using Megasquirt 2 with 58x for ignition?
  84. HPTuners connection issues
  85. 5.3 timing drop to -10 on accelration
  86. Map, baro @ wot
  87. Is my car driveable?
  88. All of a sudden I've got codes..
  89. Secondary Air Problems
  90. Map code messing with TCS
  91. hp tuner and 98 t/a
  92. Need some help. No start issue 24x
  93. 402 ls2 Firehawk dyno
  94. 408 Stroker: possible ignition issue??
  95. Frankenstein engine P0342 camshaft code
  96. Tuning software
  97. pcmforless...hmmm
  98. What is needed to tune?
  99. Running rich and check engine light?
  100. Question on hp tuners standard vs pro
  101. Removing door wiring harness
  102. 99 Firebird O2 simulator for post-converter sensors
  103. will this throw an SES code????
  104. Is this normal anyone help
  105. Need HELP p0101, p0106, p10300, and a pending code p0171
  106. MAF Vs. Speed density
  107. High idle, speedo reading sitting still
  108. 98 fuel system settings after fuel segment swap?
  109. Can/bus diagram ?
  110. does anybody use the FAST handheld programmer?
  111. 1st diagnostic
  112. tps
  113. finally bit the bullet! (FROST)
  114. pcm misfire
  115. DTC 410/412 Check engine light - can't pass State Inspection - HELP!
  116. hptuners PCM shift light wiring
  117. need help getting started with hp tuners
  118. Dyno Tune in SF Bay Area
  119. Brake light and ABS Light on
  120. High IAC count?
  121. 98 to 99 pcm swap fuel level pcm wire ?
  122. Looking for reputable tuner in the DFW area
  123. i have SES codes help?
  124. LY6 VVT stock cam tune?
  125. 4l80E will not make WOT 2-3 shift
  126. change computer now car do not start
  127. Brain dead Camaro (HELP)
  128. Trying to Pass Inspection-P0171 and P0420
  129. GM's new PCM's and Tuning them.
  130. PCMForLESS?
  131. PCM Speed signal 100 mph
  132. Won't idle with oil cap on...ideas??
  133. Disable fuel while reflashing? UPDATE: Cyl fill up with fuel, really quick! HELP!
  134. Jeremy Formato tuning & porting in Gettysburg PA October 23-29
  135. Computer keeps resetting itself
  136. LQ4 Low Hp...HELP lol
  137. In need of help with 5.3 wiring harness
  138. PCM or CPS
  139. Take a look at my tune please
  140. Slow speedometer needle???
  141. Retune after switching from ORY to TD X setup?
  142. Tuning help
  143. Recommend tuner in Hartford CT area
  144. Hp Tuners Vs. EFI Live
  145. critique my tune.
  146. Power dropping off above 3500??
  147. Air removal and SES question
  148. maf/tunning question
  149. Diablo Custom Tune
  150. 98 ls1 in a 01
  151. Question EGR
  152. stand alone harness help?!?!
  153. Idle issues, and few codes (live data pictures added)
  154. rich or lean
  155. spudders when i release the trans brake
  156. Need some help Diablo Tunning
  157. terrible mpg and p0171 p0174 codes
  158. Problems after bad Engine Ground.
  159. tuning for cat delete
  160. recomendations for a timing controller
  161. Transmission shifting issue, anyone care to look at my tune file??
  162. having idling issues
  163. Someone HELP!!! Looking for PatG
  164. P0137 p0157 codes
  165. Innovate LC1 problem.... ugg
  166. LS1 lean/choking under hi-throttle
  167. IAC help
  168. driving coils
  169. tuner locked ls1 ecm
  170. need help,timing twister trouble
  171. Here's one for the LS guru's
  172. Hitting rev limiter on 2-3 shift with built trans
  173. Good Tuner shop recommendation in North Dallas/Collin County area
  174. HELP.. TSP 100mm MAF Calibration.
  175. P1637 CAN Link ECM/ABS Control Module Circuit/Network
  176. Security light flashing!!
  177. Trouble at track last night after tune..
  178. Tuning help in Massachusetts
  179. Need Tune advise - Motor Plate & Soild Motor Mount please come in
  180. Can a car lose a tune over time?
  181. 98 wiring harness 99 pcm??
  182. Lt1edit
  183. Changing injector data
  184. Advanced Tuning Question- High RPM throttle cut and limp mode
  185. 2003 truck pcm 0v to knock sensors?
  186. General Tuning Software?
  187. Mass air flow and V.E. tuning advise needed
  188. Need a tune
  189. Questions for anyone with EFI 24x
  190. Can't get it to idle
  191. aem to oem pcm
  192. gutted car/big stuff 3 come with wires?
  193. C5 - Car will crank and not start / Reduced Engine power - P0606 and P1518
  194. Tuning issues RESOLVED!
  195. Hanging and fluctuating idle after head intake swap-help
  196. hahaha....figure this ridiculous sh1t out......**UPDATE**
  197. LMA-2 Setup on LT1
  198. hawaii?
  199. Your tuning solution EFI LIve, HP, Innovate
  200. Which programmer?
  201. looking for dyno tuner
  202. HpTuners ECM swap?
  203. do i need a IAC
  204. P0101 code and O2 sensor bank one sensor one codes
  205. plx air/fuel wideband problem help!
  206. At what RPM should I shift?*Dyno Graph
  207. on board monitor test $07 and $0C
  208. innovate wideband error?
  209. Who sells ALL NEW...COMPLETE wiring harnesses.......
  210. Spark tables question
  211. Thoughts on this build 402ci ls2 w/ 540rwhp
  212. MAF, H2O's, & VATS
  213. 2001 4.8L Silverado throwing lean codes.
  214. sd tune... do i need a t.p.
  215. EFI LIVE Scan tool
  216. 341 rwhp I was expecting more
  217. Spark and fuel look alright?
  218. P0200 "Injector Control Circuit" after heads, intake, and injector swap.
  219. ls1 stating problem
  220. HP Tuners, 01 PCM and E85. Looking to compare tunes
  221. Will putting my pcm in another car lock it out?
  222. Random misfires at idle, all cylinders
  223. HPTuners 2012 Tahoe, Escalade & Silverado Support added
  224. Finally had my car dyno tuned today !
  225. HP Tuners 2bar MAP OS
  226. New Sponsor: Unleashed Performance
  227. wiring dilema
  228. Granatelli MAF performance
  229. How forgiving is a stock PCM?
  230. PCM ECU LQ9 pinout?
  231. Need LS2 Tuner in Oklahoma area
  232. any good nitrous tuners in kansas city???
  233. looking for location of pin connector (pic inside)
  234. LS1 staying in open loop, need help
  235. EFI Live price increase!!
  236. Reprogramming GM crate engine kit controllers?
  237. hard to start
  238. Speedo Bouncing?
  239. mail order or email speed density base tune?
  240. 2006 c6 reluctor issues
  241. BCM harness same for v6
  242. obd2 black box
  243. LT1 383 Computer change?
  244. Nelson Perfomance
  245. Holley domninator EFI for LS7?
  246. cluster help !!!
  247. Autotap Express Diy
  248. HP Tuners in Socal area needed
  249. Looking for some assistance...again.
  250. How will car run when going from 28 to 36lb injectors?
