PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. fat at cruise and timing is at 40*......
  2. Megasquirt II problems(long... tune/logs/video attached)
  3. Idle Problems on a 2010 Camaro SS
  4. Starting problems
  5. Anyone got a HP Tuner config file for logging through the AC?
  6. trying to tune and tps flikering %
  7. To pcm swap or not to pcm swap that is the question? 98 to 99-02
  8. Jeremy Formato tuning & porting in Gettysburg PA June 11-17
  9. Looking for a affordable scanner,,, and basic tuning would be a bonus....
  10. H0108 ETC speed govern shreshold
  11. need help with tuning please
  12. Need help w/ base tune.
  13. Cold start issue
  14. car sometimes gets a dead pedal feeling
  15. what would you do?
  16. Missing problem. Need help
  17. problems need help
  18. 98 pcm swap to 02
  19. Who do you recommend for a mail order tune?
  20. Crash Course in Tuning
  21. Spark Plug Gap issues need some help
  22. is it worth tuning?
  23. Can't get OH monitor to set ready
  24. A bunch of stuff going on after turbo build. HELP. VID INSIDE.
  25. Need Help Unlocking a Diablo Can tune...
  26. two different map readings same car
  27. Please help me ! SD or MAF tune
  28. EFILIVE pls hlp ????
  29. help fouled plug ?
  30. Need help deciding on a tuning solution
  31. New big injectors and now rpms going up and down
  32. Problems with Diablo
  33. Wideband O2 Sensor Placement
  34. diablo super chip? questions.
  35. Throttle follower decay question
  36. gauges dont work after heads cam install
  37. Want to go back to stock
  38. check engine light code P0803
  39. Hp tuners or EFI live - Which one is better - Looking to buy
  40. is hptuners scanner helpful if car won't start?
  41. VCM read Failed at loc 6000 error checksum
  42. Can I Fix A Tune With A Handheld?
  43. What is wrong with my tune / do I need to send my computer off? Professional help plz
  44. chip burner eprom tuner? tx
  45. Todd @BlueThunder2racing
  46. Can't stay connected to lap top
  47. Looking for a Tuner in the PA WV VA MD area.
  48. looking for a e85 tuner in nw indiana, mich, ill
  49. Nelson Tuned PCM, what is the Tach setting? 4Cyl or 8Cyl?
  50. Hp tuners how old are you?
  51. did 99+ pcm swap in a 98 car..no fuel guage with fuel segment
  52. The Buck Stops Here (cam surge gone)
  53. finally got to the track
  54. Mailorder tune , big problems after cam.
  55. need help getting HTP to download
  56. HP tuners question
  57. Eliminate 3rd gear lockup with hp tuners?
  58. Changes in weather effect tune?
  59. Help With Stripped Down Control....LM7 in a Jeep, Very Basic
  60. 1993 Pontiac Firebird LT1 w/major problems!!
  61. 402 stroker hp tuners help
  62. Question bout maf tables
  63. Ed Hutchings still tuning?
  64. fast injectors do u like em?
  65. being to rich on the afr hurt boost levels
  66. ses
  67. need help LS3 in 02 Fbody
  68. 2000 a4 wiring harness, what goes where?
  69. O2 sensor question
  70. Multi-tune options?
  71. Drive by wire vs. drive by cable and tps
  72. need help bad
  73. help! n2o tune setup
  74. timing question
  75. anit-theft mode help
  76. Service engine light
  77. P0220 adjustable
  78. gauges and codes
  79. map only hits 50 kpa??
  80. cat O2 sensor computer trick to read good emissions or what?
  81. How to turn off dash lights....
  82. HPT Trany Help please
  83. commanded afr at wot
  84. tuning software
  85. whattype of tune will i need?
  86. Will a 99+ gauge cluster work in a 99+ harness swapped car
  87. Fuel trims out of range sometimes
  88. bucking V6 camaro
  89. 3 Bar Map
  90. high idle, tune related?
  91. tune parameter
  92. buy hp tuner
  93. New DiabloSport Trinity Update! 1999 - 2006 vehicles now supported!
  94. Is this a dumb idea? Wideband wiring idea...
  95. Service engine soon
  96. flutter between 1300-1800 rpms?
  97. tuning issue?
  98. Ngk Afx wideband
  99. Tune out ASR
  100. Dual Fans - dual problems...
  101. P0157 Long Tube no Cats
  102. Painless wire harness
  103. No signal from ALDL (DLC) with engine running.
  104. PCM Electrical Question
  105. HP Tuner or EFI Live?
  106. heads up display!!!
  107. 402 stroker tune
  108. Anyone wanna take a look at this tune?
  109. 98z28 with 2000 wiring harness and pcm no gauges work
  110. Start up help.
  111. 98 harness and pcm on 02 lq9...hp tuners
  112. Cant get injectors to fire - w/ driver box
  113. 99-02 harness into a 98
  114. Bad experiences with 1_bad_ls1 mail order tunes?
  115. ODBII port working now. Pls give some advise on this tune/scan
  116. What wideband should I get???
  117. Do I have to get a tune?
  118. tuner vs scanner
  119. Twin turbo 404
  120. loking for a base tune
  121. Lean Misfire
  122. Tune out codes??
  123. 58x to 24x Wheel
  124. rough running but rich?
  125. HpTuners 5.3 w/'02 ls6 cam no emissions looking for tune file
  126. p0101 & bogs - What next?
  127. What to change for just injectors? I forgot.
  128. Strange Idle
  129. Ls1 camaro turn off after warming up. Need help.
  130. Programming PCM for Swap
  131. Autometer WB gauge and HP Tuners ??? How to
  132. HP Tuners SOS from Florida
  133. Bad WOT Backfire-Turbo-Need Help-HPT Scans Included
  134. Tuning Software
  135. Bolt On Tune Sale
  136. pros cons of removing maf
  137. ETC Throttle Oddity? Scan inside..
  138. best sponser to buy hpt?
  139. Never Tuned, input appreciated
  140. efi live misfire pids wont monitor.
  141. What questions should you ask your tuner?
  142. speedometer recal only with diablosport
  143. Wideband sensor and gauge Qs
  144. P0327 knock sensor code question
  145. 2 bar map question
  146. What pcm is this?
  147. Tuning for e85
  148. Idle related problem...would need some direction
  149. Tuning at Idle - Open Vs Closed Loop
  150. Disconnect MAF ?
  151. 408 intake backfire issue help!
  152. HPT suite 2.22 install in Window 7
  153. Point me in the right direction
  154. Where Do You Find That Table?
  155. HP Tuners EIO
  156. I got a mailorder tune...but (problem, need quick help)
  157. HP tuners VCM Suite v1.0 Questions
  158. STFT Question??
  159. PLX wideband question
  160. HPT,E40 SD--tables that control AFR@startup & first seconds of run time
  161. Truck wont start
  162. Closed loop makes car go LEAN
  163. 95 lt1 - obd1 pcm
  164. Quick Question.
  165. SD back to maf
  166. lq4 & zo6
  167. Went lean on bottle, could tuner have added fuel?
  168. Where should I mount my wideband sensor
  169. Dead spot part throttle
  170. Mastach aldl pinout help
  171. SES code PO155B. Help please
  172. what is the exact reason(s) speend density is better?
  173. Surging & car kills
  174. LT1 - OBD1 - 4L60E to TH400 swap - PCM need flashing?
  175. no start issue
  176. Need help TPS problems
  177. Vats bypass???
  178. Reset air bag system after DERM replacement?
  179. turning off O2s with HP Tuners
  180. Oxygen sensor problems
  181. For Sale: Superchips Flashpaq
  182. datalogging with autometer nexxus gauges and hp tuners pro
  183. swapping PCM
  184. Aftermarket MAF causing problems?
  185. P0452B Fuel Tank Pressure Sensor Low Voltage
  186. Looking for a tuner in MI
  187. can my wideband commander be fixed?
  188. mods and no tune question
  189. PCM code reader and tuner
  190. Anyone have a copy of Calibrate Success DVD for sale?
  191. ANOTHER SET BACK, wire harness??????
  192. File Error
  193. Need help with PCM swap. Willing to pay. Need ASAP
  194. MAP code
  195. where I can get or order??
  196. Please help O2 and knock sensor prob (screw NY state inspection)
  197. pcm tuning
  198. Weird Security Light Issue. NEED HELP
  199. anyone know the pcm connector part numbers?
  200. LS3 in LS6 CTS-V ECM compatibilty issues?
  201. N E 1 Use a Autometer W/B 4 Hp Tuners?
  202. ASR off and still get the Trac Light, I need you insight!
  203. Converter Locks/Unlocks...Tuning Advice
  204. Who Can build me a Tune for my Truck?
  205. dyno tune or buy hp tuners
  206. Quick programing question, 4L80E
  207. 5.3L/4L60E in a 67 C10 issue...PLEASE HELP
  208. Is my MAF/tune FUBARed?
  209. speed density tuning how do u like it?
  210. Still Running Lean...
  211. I had 16 codes showing!! HELP!!
  212. 98 Trans am with 2002 computer
  213. P0300, just a tune needed????
  214. cold start question
  215. New to this
  216. FAST 90 Swap Idle Issue. Speed Density Tune
  217. help
  218. Turbo timing
  219. Finding the right BCM
  220. Which programmer 2 use..?
  221. wide band with 0-1v output
  222. 94 camaro gauge issues
  223. dyno tuning in iowa???
  224. automatic headlights
  225. Rob Raymer at Evans tire in Richmond Ky yesterday
  226. PO327 & PO332 Knock Sensors
  227. tune questions
  228. Electrical?
  229. Injectors in Banish DVD?
  230. Dyno Tuner in near Nashville????
  231. Handheld tuning options for '98 cars?
  232. Ford style TB (TPS)
  233. Low Impendence or High?
  234. stockish running lean?
  235. What would cause no fire on cylinders 2,3,5,8
  236. Auto to manual help
  237. Props to cunningham motorsports
  238. Tuning after LT's and LS6 Intake?
  239. Rich / Lean Codes
  240. Question bout EFI live
  241. 98 pcm
  242. Changing parameters with someone elses diablosport?
  243. datamaster
  244. what to set timing table? cam, heads,
  245. Unable to communicate with OBD
  246. MSD Timing Twister shutting down
  247. Ubuntu?
  248. Fan issue - they just wont turn off
  249. Frost Tune Question
  250. P0430 help!! Won't go away!
