- Stock pcm help
- harness hookup question
- Tune time.... Who?
- Mega squirt for ls motor
- Stock PCM or aftermarket stand alone
- need contact info for blue-cat tuning in ashland ky,
- hp tuner question?
- Good scan tool???
- Body harness firebird vs transam
- Retune needed after converter install?
- Tuned by Jeremy Formato Yesterday!
- HP tuners VCM controlled shift light
- Measuring injector duty cycle.
- Injector scaling table
- ls3 spark dwell table for 01 f-body pcm
- Dyno tuning my car
- high rpm miss and have replaced everything!!!
- Wondering who people are taking there higher hp cars to for tuning
- Can I use the tapped holes at the front of the heads as ground?
- can an LC-1 replace stocker?
- FIX FOR: Win 7 + HPTuners = no install
- Formato's Fasterproms Gettysburg, PA Tuning From Friday Aug 20th Thru Sat. Aug 28th
- wont idle in park/neutral after tranny swap
- going from maf to speed density tune
- SLP Predator help!
- P0171 and 02 sensors after motor swap....
- Calibrating speed in Tunerpro RT V5
- efi live cable
- Help truck all of a sudden started acting crazy!!
- HP tuners wont load into laptop with vista??
- Modifying someone else's tune
- Help I have power everywhere but car wont start????
- Taking Your A6 to The Next Level - Tuning to have the best of both worlds
- Efilive turbo tune - getting less timing then commanded
- Got my WS6 dyno tuned by XP Racing (Oklahoma) today!
- license a mixbread using hptuner
- i need a tune
- What Wiring harness and PCM to use?
- How long will it take the computer to "relearn" after bad o2's
- Stock PCM w/ EFI Live vs AEM EMS
- im getting come gay codes after 98 to 02 pcm swap.
- autometer guage question
- 408-D1SC, tuning questions
- '98 M6 car. Swapped PCMs and now no Speedo?
- did a dyno.
- Can I drive it?
- for the colorado springs area
- obd2 lt1 newbie Questions.
- hp tuners VCM Suite pro tuner
- Rev limiter?
- Question and I need a tuner
- P0480 Fan error... out of ideas
- Stock Alarm sets automatically
- new motor swap wont idle right, help?
- Help with my error code! P0121!!
- New 98 PCM, how to flash so I can start tuning
- Check Engine Light, P430 Code and Car cutting out at full throttle
- Speedo help
- Predator U7198 Questions
- Very basic tuning/scan tool question
- Who checks or fixes ECM's
- Car has a misfire at high rpm (5000+) and threw 2 codes
- MPG gain from hptuner
- Need a little help
- genIV dbw.all hooked up..not responding..
- Mail Order Tune
- First Start Up
- SES code P0704 Malfunction in the input circuit for the clutch switch
- Evap Canister solenoid circuit question
- L98 tuning question
- New cam, intake, TB, and injectors and car want start?
- Which engine management?
- Tune needed bad!
- Cylinder Volume
- I need some numbers badly.
- key or cylinder (VATS related)
- Ignition problem
- map kpa
- efi live and turbo 400
- odd question
- Handhelds for 98
- Wiring problems or maybe bad ECM ??
- 92/92 tuning advice
- richer or leaner
- Strange Electrical problems (cags,maf,oil press)
- Tach stopped working P0654
- Does anyone have the injector flow table for 83# injectors?
- 98 vette pcm vs. 98 f-body pcm
- What's wrong with my car... help??
- VATS issue
- what happen to james at rwtd tunning
- Individual cylinder fuel trim ?? LT1
- Shift point settings after 3.42 gear swap a4
- Car Surges when ac is turned on.
- Another VATS question.
- is it worth having a pro tune it?
- 1998 F body computer swap to newer computer
- These o2 readings look ok given my combo?
- AEM EMS on 370ci PT88 Turbo Setup
- How to replace ignition switch?
- How to get PID's into V2 handheld
- Timing for boost
- What besides TPS voltage would make a tranny short-shift?
- what do you think of this wideband??
- Tach not working right
- HPT and LM1
- 98 Camaro
- backfiring thru intake, no power, crank sensor code..HELP!!!!!!!
- tunner in st louis
- Noob PCM Question
- v8 tuned to a v4
- WTF codes 1221 and 1278
- MAF tuning and AFR correction
- What MAF?
- Need a Tune!
- Tuning Delphi 95's
- Kill Switch
- EFI Live 4l60 to M6 tune conversion, different OS
- How do I make it start?
- help tunning my cam ..
- Low vacuum and weird fuel trims
- help new gauges wire for oil pressure? and h20 temp?
- Tune for which Octane?
- Who tuned my car?
- HELP ENGINE WONT START**fire missing
- e38 ecm 06 gto speed density
- LC1 & Digital Gauge
- tuners, help me out please
- What ECM / OS would you use?
- O2's not cross counting
- OK It's gettin' deep now!
- anyone want my tuner?
- Car starts, then dies
- A good tuner using HpTuners San Antonio
- which would be better?
- Swap PCM's ??
- I'm looking for a pinout for a 12576106 PCM For wiring fans
- LS6 dies briefly on acceleration. Data log attached
- WOT manifold question
- p0135, p0171,p0174 after mail order tune
- FAST programmer issue
- po-151 issue
- HPtuners - Flash someone else's stock tune?
- DoD with Manual Transmission
- 4l80e segment swap northwest indiana
- hooking LM-1 to EFI live
- dyno tuning in dayton ohio or thereabouts
- Can't Load my mail order tune
- Throwing Codes
- which pcm can i used?
- High RPM miss
- retune needed?
- m6 to a4 problem
- Help !! Dead on vacation!!
- Looking for a 100mm Maf table
- Boost timing
- Have LS1 PCM but 5.3 under the hood
- DB Gauge reads differnt then efilive pid and cant connect to lc1 using lm programme
- HELP Fast!! - AFX Calibration question, confused!!!
- 2011 Camaro/Corvette support is here!
- Running very rich... NW Indiana tuners?
- Speartech?
- Wiring diagram for under the dash.
- flashing check engine light after tune?? not cool..?
- NEed Accel Gen7 DFI pingout for connector
- electric fans staying on.. pcm tune problem??
- Electrical Gremlins... SS won't start...
- 2002 Z28 check guages light when accelerating
- mulitple misfire ses light set an flashing but car runs fine?
- has anyone used the Beeprog+ device programmer
- tuning issues at idle on maggied LS3
- Need wiring diagram
- ECM Reflash questions.
- trying to decide on a wideband
- Trans Swap/Converter Install tuning info.
- de-pin PCM?
- ls.. specific bs3 tuners st.louis/memphis?
- ls with bs3?
- Speedometer vs. Rev Limiter PCM Tuning
- Engine Knock with 93 Octane??
- Tune or mechanical problem ???
- "hc value" Help
- Looking for a tuner
- Got a free Vericom, is it decent or junk?
- Developed a miss and lean Bank 2, HELP!
- Car randomly dies like the pcm is losing power
- Is there a way to test the IAC?
- PLEASE point me in the right direction.
- Need help identifying
- ls1 missfire
- TPS sensor gone bad..
- intake backfire
- Quick question over tune and LSA
- 5.3 wire harness to 3.8 harness
- Gen3 to Gen4 knock sensors?
- I have an old LS1 Edit cable throw it away?
- Stripping PCM/Body Harness of unneeded wires. Pros please check out and advise. TYIA!
- Any good tuners in New York area?
- Any good tuner in west Tn area
- ECM/Wiring issue
- Hesitation
- from ls6 to ls2 " knock sensors"
- Do I need the cd in the laptop to use HPT?
- L92 early rev limit, trouble with VSS....
- Formato's Florida Tuning Schedule for July:
- Rich on both banks after tune.
- For WOT AFR : VE or MAF?
- Dying alternator? What are the symptoms?
- A/C problem - PCM related
- Can i ''tune out'' the knock sensors??
- BEYOND DESPARATE! No O2 signal after starting! Does work before starting!
- Wideband single senor... best placement??
- LS1 running rich on bank 1
- 2000 z28 random miss
- sputting under light load with lean spikes
- Best o2 sensors for ls1? (lts+ory)
- Storm . . . HELP
- o2 sensor switch and test.
- help with going to a 99 pcm in a 98 car
- How to deal with Oxygen Sensor Circuit Slow Response?
- Hypertech Power Programmer Tuning on 98
- anyone use accel dfi gen 7
- ac surge and then die issue
- Speed density tunes and sensors
- Single Turbo Ls1---- Change of Plans...Motor is coming out:|
- Need replacement for LC-1, what options do I have? AEM, Fast?>>
- Megasquirt + 36-1 Wheel + Truck Coils = What is needed?
- Best Tunner in Michigan
- Best tuner for the money
- ls3 cranks but no start when hot in f-body
- need a trans tuned in chicago. any help would be great.
- Knock... maybe?
- please hlep car shuts of when launched at the track
- Mass air system VS speed density
- Car ran without a key ????? HELP!
- P1637 with rough runnning..
- New motor - bogs terribly off idle, undriveable
- Air Fuel Ratio with RPMs
- Anyone know what the abs sends to the pcm for spark retard siganl?
- Online Log Book
- Feedback on Hypertech programmer 3
- HPT or EFI Live phone contact.
- Connecting an LC-1 to HPTuners MPVI
- How many HP Tuners Credits to tune 2008 Grand Prix GXP, and where to buy?
- Map sensor relocation kit ?
- Lm7 running on ls1 stock tune?
- Someone help me out please
- Has anyone used a Predator to adjust an hp tuner dyno tune?
- Ls1 tuners around philly who's good!
- Experienced tuners, need opinions & help
