PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 [190] 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. ls1 edit?
  2. Any Dyno shops in the Los Angeles area?
  3. Did bump stop mod and now Engine Light!
  4. Car Dies in Reverse
  5. Anyone running Standalone Managment? ( Haltech/Tec3)
  6. Should I get the standard Atap or the enhanced version?
  7. LS1 edit,HPIII, or a Diablo?????
  8. IAC Park Position in Edit...
  9. A/F ratio is a bit rich! how much more power will it make?
  10. Programming for two F-bods..
  11. timing table questions
  12. Header bang and false knock
  13. P0155...should I be concerned?
  14. AMS Racing and LS1 Edit?
  15. Tire Size
  16. Can false Knock yield High degree readings?? I'm getting it at ~1750 RPM's ???
  17. Car started stalling this morning...
  18. EASE
  19. Need some help and advice
  20. Please look at my dyno #'s and tell me what you think
  21. HPP3 Experts help !
  22. 02 Question
  23. Dyno, and jagged upper rpm graph
  24. Can Someone answer this??
  25. ENGINE LIGHT ON
  26. Ease GM Enhanced scanner V2.5 shipping
  27. Effects of burnt front O2s
  28. ls1 edit/EFILive timing bug or just me, please help
  29. Anyone selling HPP3 for 98 LS1
  30. Slight poping and cutting out at part throttle acceleration....
  31. Disable Tourque Mang. With Edit
  32. OMG plz help ,
  33. Knock Problems...WTF!!!
  34. Where in NC to get a dyno tune?
  35. Dissabling torque managment in a m6 car
  36. Auto Tap vs. EFI Live?
  37. Custom Tunning
  38. Speedo Reset
  39. scaned car for fist time and need help(update!)
  40. High Octane Spark Advance...Did I forget anything?
  41. Do you reccomend MAF table or PE vs. RPM multiplication?
  42. Maft translator
  43. KR, timing retard and knock counts
  44. *LS1 Edit* Questions Before I Buy It....
  45. FLP dyno tuning
  46. Predator Tune
  47. HELP
  48. Optimal Air/Fuel Ratio
  49. LS1Edit newbie questions...
  50. Trouble shooting Code P0160 ?
  51. lterms
  52. Headers Glowing Orange!!!
  53. Torque Management
  54. What is the benefit of the zero vinfeature on LS1 EDIT?
  55. 58 degress of timing advance???
  56. Any LS1 EDIT Tuners In NORTHEAST OHIO
  57. Finally going to buy LS1EDIT and AUTOTAP but I have a few questions
  58. L-terms +5.1 cruise with 2 WOT runs resulting in .909 and .870 respectively??
  59. incar wideband O2 ??
  60. Autotap screenshot, I need tuning???
  61. Average timing @ WOT for 01-02 SS?
  62. PE vs RPM on LS1edit help!
  63. Injector size for ~ 400 RWHP?
  64. LTFT what cells do you monitor for BASE!
  65. My car = bad news. Can anyone help?
  66. SLP's new dyno testing and tuning facility
  67. System Readiness Test - incomplete
  68. does anyone's exhaust smell real bad?
  69. any dyno tuners in southern ny state?
  70. Easy way to lower rev limiter?
  71. any wireing guru's around???
  72. Mail Order PCM special......with overnight mail included!
  73. How important are cam spec's when tuning?
  74. Want to upgrade AutoTap...what do I need?
  75. TQ Management
  76. WTF bank 2 B2S1is all out of wack
  77. Spark Retard Limit (LS1 Edit)
  78. How to view ATAP log files?
  79. New CAM-need a file
  80. HPP3 doesnt adjust for A/F w/ power tuning?
  81. LS1 edit injector flow rate table??
  82. Ltrim's all f'ed up.
  83. Car won't start - Posible computer problem
  84. Help 4.10 gears A4 car and HPP3 what shift points
  85. how do i copy High spark advance to the low one?
  86. i really need help!!anyone can help me please!!
  87. stock timng and adding it?
  88. How to kill torque managment with M6, to be sure its not affecting anythign.
  89. Possible to delete TCS thru EDIT? Ala skip shift?
  90. L'TRIMS start out @95mv then stablize @ 90/91mv
  91. Still get P0405 EGR light even with it edited off?
  92. Tuning A/F with MAFT on heads/cam car?
  93. engine knock retard
  94. Adjustment to get LTFT down
  95. First experience with Dyno/tuning. Questions.
  96. Will the Diablo work for me ?
  97. Autotap "Timestamp" columns
  98. Please Evaluate Log
  99. how with LS1 edit do i make my car leaner?
  100. timing tuner? worth it?
  101. p1153 ??
  102. Just got LS1 edit, anyone have a good .LS1 file?
  103. 5,4,3,2,and.........
  104. 99 Bolt on C-5 LS1Edit Dyno numbers!!
  105. Will Screen Saver mess up LS1Edit?
  106. ? about diablo
  107. ABS Code and weird ABS problems
  108. Those with SLP fan switch and KO box....problems??
  109. Daytime running lights?
  110. serial to usb converter for ls1edit
  111. Which way is richer or leaner
  112. AutoTap $149
  113. Timing dropped...WTF?
  114. idle question and iac's with ls1edit...
  115. How do I delete Skip Shift Solenoid codes with Edit?
  116. Sensor Signal Test Points
  117. Need help with timing issues. LS1 Edit experts inside please.
  118. SES diagnosis
  119. Best way to add timing across the rev range on Edit?
  120. FAST/Edit together
  121. Ls1edit and windows xp pro
  122. ltrims
  123. Palm scanner - any interest?
  124. LS1 weather pack connectors
  125. OBD II
  126. switching to larger Maf from stock 98 Maf
  127. MMS 229 cam tuning ....plz ?
  128. wideband results
  129. Wiring up a Harlan twostep?
  130. What Next?
  131. Where I can find LS1 EDIT ?? and what's its price ??
  132. What fan settigns to use for stock thermo?
  133. ltrims
  134. Do ltrims really need to be negative if they are 0 at wot?
  135. Injector Swap help
  136. Help! 00 Z28 only uses fuel cells 20,21,22?
  137. Need help badly! 2nd gear shift code?
  138. Help me trouble shoot my piece of *&#@ car!
  139. Need HELP ASAP MPH wire off pcm!!!
  140. AutoTap/Laptop Questions
  141. switch 4 on maft with slp 85mm maf
  142. ls6 computer info
  143. Is it bad to run a SLP MA with Edit?
  144. Looking for LS1 dyno tune - Montgomery AL
  145. Help Please
  146. Disabling V.A.T.S.
  147. I think dealership is trying to screw me....help needed
  148. need help with ls1 edit !!!!!!!!!!
  149. will ls1 edit read dyno tunning???
  150. AutoTap 2.03 rant update
  151. Still getting sloppy shifts w/ truck
  152. G- Tech Pro
  153. how do you reset the pcm???
  154. Help me hook up a air&fuel meter
  155. Ouch Dreaded ping!!! Need tuning pointers
  156. WTF! LS1 edit won't connect?
  157. Possible solutions to car running rich, which is best?
  158. AutoTap for Palm - Free Upgrade
  159. Idle and temp in LS1-edit
  160. timing and resistor?'s
  161. PCM experts come inside
  162. MAFT dip switch settings
  163. Dynoing
  164. LS1 Edit file for Hot cam & headers
  165. will ls1 edit read dyno tunning????
  166. Ltrims at idle?
  167. Safe?: HPP3 tuning, GMAF, and 100 octane fu
  168. Laptop question
  169. Laptop question
  170. How to determine SES codes?
  171. how to unzip files?
  172. Best Real Time Diag
  173. what shall i do?, screwed up with laptop purchase for LT1edit
  174. 155 mph z28 gauge overlay on a v6
  175. What is Tech 2 ?
  176. Just what have I found with EFILive?!?!?!
  177. Looking for 1998 edit files
  178. Setting Rev limiter with preditor...
  179. Auto Tap 2.03 caution rant inside
  180. AutoTap for Palm v2 screen shots
  181. Would this work on an ls1? This thing makes a MAFT look like a dinasour
  182. ls1edit and duramax
  183. "fast data packets"???
  184. LS1Edit - Electronic Throttle Limiter Function?
  185. LTFT Bank 1 VS Bank 2
  186. What side is Bank 2?
  187. Whats the difference between OBDI and OBDII
  188. paging Ryan Karasek
  189. EFILIVE/HPPT3/LS1EDIT
  190. LS1 Edit in S.A or Austin area
  191. P0172,P0175
  192. scanmaster mounting...
  193. new tazzo best with predetor
  194. EFI Live Vs LS1edit
  195. P0155??
  196. Bigger injectors
  197. MAFT v5.2 with Granateli MAF...is it ok?
  198. resetting change oil light?
  199. Vin# For A 1998 LS1 M6
  200. tuning
  201. Where do I go to delete EGR and AIR code???
  202. Hi flow cat??????
  203. Here is A-Tap N/A What do You Think?Please Help!!
  204. disconecting o2 sensor, what happens??
  205. Can I wire my car or use LS1 edit to send more power/heat to my o2 heaters?
  206. speedo colaborating with predator
  207. Ordering ATAP, need opinions
  208. Put the Stock MAF on and STILL have popping at attempted WOT :( PLEASE HELP
  209. Dyno Tuning
  210. Injector size
  211. P0340, P0102, P0441 Help!!
  212. injector question, i think i got shafted
  213. MAFT needed with LS1 Edit???
  214. Question regarding MAFT, 30lb inj, tunning
  215. #7 cyl misfire need help
  216. Autotap questions
  217. LS1Edit - Any Way to Adjust Enrichment vs. Air Temperature?
  218. I'm a tuning idiot. Someone explain timing.
  219. Computer tuning
  220. A4 to T56 Conversion
  221. MAF--Port,descreen,or leave stock
  222. Is a MAFT worth the money on a bolt on car??
  223. need help with DTC's
  224. help!! just got new injectors and ltrims are peged at +25, what am i doing wrong?
  225. What is the PROPER way to delete TM?
  226. ls1edit 2k1 and 2k0 PCM
  227. timing help ls1edit/efilive5
  228. What should custom tuning entail?
  229. code p0430
  230. Hypertech and custom tuning questions??
  231. Why does my trip odometer keep on resetting??
  232. Holy FREAKING POPCORN BATMAN!!!
  233. ls1 edit
  234. ABSINOP light!???
  235. timing problems ??????
  236. PAGING NEVRENUF!!
  237. Security Light
  238. ls-1 edit torque management/shifting
  239. SES light help
  240. Auto trany question
  241. Is there ever going to be a USB connection for LS1 edit?
  242. Dyno'd with wideband O2-results..??
  243. Raging Motorsports now offers mail in tuning
  244. Misfire detection
  245. Why is my car throwing the cmp sensor circuit code p0340
  246. F-body vs. C5 PWR/GND PCM pinouts...
  247. WHo does ls1edit dynotuning in pa,md or nj
  248. Service Engine Soon and Security Lights
  249. Throttle position angle throwing out different percentages
  250. problems with the hypertech programmer
