- Wideband Install
- What on YOUR favorite tables list?
- Low Vacuum at Idle - in the tune?
- LS7 Swap/Crank Relearn
- buy the wideband sensor or the whole kit
- Loggin Boost with HPtuners
- Tuning with open headers?
- GTP injectors
- kind of a weird ? someone might know though
- Hypertech Problems
- what chip to get
- Diablo Predator or HPTuners???
- SD tune help
- REV limiter on 2000 RPM's
- lc1 wb02 using nb02 stock harness
- Ls1 swapped into fox body.. computer issues yet again
- What to look into & log?
- Tuning prefrence???
- obd11 & efi live
- What would make "Absolute TPS" read 17.4% at IDLE?
- were is the computer
- I want to read boost in EFI Live.
- Superchips Max MicroTuner for 99-02 Z28/Firebird/Trans-Am
- wtf??
- Logging injectors with hptuners
- AFR at WOT 12.7 12.8 good
- Getting tuned on a mustang dyno vs dyno jet
- EFI LIve timing
- Getting IAC counts down
- Acceptable % between LTFT"s
- 2 O2 codes creating SES light, help
- Anyone Need a Vinci/Crane tuner for 98-up ls1
- Need some code help
- Efi Live,Does anyone have a converter/shift file?
- MAF effects on idle tuning?
- Mailorder Tune or Dyno Tune, which do i need?
- LC1 Wiring through rear 02s
- codes
- Which LM-1 is ideal for EFILive/Roadrunner?
- Advice....dyno-tune or HP Tuners since they are same price?
- Help please - getting started on SD, new LS2 402
- My tune... HELP PLease.. HPTUNERS..
- HELP...will these DTC's make my car low on power?
- speedo signal wire?
- Help white face install needle off!
- E38 Mil Light
- Radio and Windows stop working?
- MAF vs SD Stock Internal???
- Does Anyone Know If Ed Wright Locks His Computers When He Tunes Them?
- car won't idle
- is pcm going?
- Runs rough
- Those with EFI Live V1 scan and tune
- Tuning question, searched and now confused
- O2s SLOW TO RESPOND
- Electrical problem???
- Racetronix/Lucas/Delphi 42# Injector Settings
- WOT Wideband
- Car wont start please help
- diablosport predator spark advance for nitrous
- What's my reflashing program options for a 95LT1
- Computer reset problem!! PLease help!
- pulling timing with HP Tuners
- FS: FAST B2B setup for LSx engines w/ EDIST, WB02, and stand alone wiring harness
- Anyone using the Max Energy tuner from Hypertech? what do you all think?
- question about ecu
- Edited out vats with hptuners still won't start
- loosing fuel pressure up top?
- p1133 with stock car
- BS3 and RacePak...
- HP Tuners
- Practical RPM limit for BS3,Pectel with stock triggers?
- knock and timming
- Fuel pump relay control
- GM Tuner
- speed density open loop ???
- dyno tune or not??
- affects of untuned 90/90 setup???
- 02's and tuning
- Need tune download '99 C5 with cam & exhaust
- EGT install WHAT cyl?
- Electrical gremlins from hell
- A couple of questions for you seasoned vets...
- The Dreaded DTC gremlins .Just looking For Input
- af and pressure guages
- Stock Ws6 Tire Height????? Anyone?
- how much does a good tune cost
- Big Stuff 3 Schematic
- PE and VE table with the tunercats
- Anyone want to Tune my car??-NJ
- Narrowband Output on UEGO
- Starts great cold, but struggles to start/find idle when hot
- I need 2 license to tune my 06?
- ABS INOP, ASR off, Brake lights on. HELP!
- hptuners shipping
- Bosch 13111's good or not?
- Need a wideband?
- Are there any scanning or even tuning tools that work on a PDA/SmartPhone or similar?
- Itb Ecu
- no start unless scanner is connected
- Need a good MAF file
- Using a GM Tech 2, Tuning??
- who's put a cable driven throttle pedal in a c5?
- Anyone using the racepak dash for the BS3?
- MSD box ?
- What happend to Injector Scaling Calculation
- Where's the extra timing coming from??
- unplugging 02's ??
- Retune???
- Anyone want Hptuners?
- h/c tuning question with a preditor
- 06 C6 P3001 ? Anyone
- what cause mph and tach to stop working?
- IPC no abs or tcs
- P0102 will not go away
- please help with p0412&po418
- Lockup Tuning
- Have To pass Emissions But have 2 Codes
- Need Help with misfire
- Oil Pres sensor & ECU..NOT used?
- will a 2002 ABS control box work in a 2000?
- coolant temp sensor -40
- EfiLive smoothing question................
- Mail order tune
- Turbo A/F Ratio before boost on SD tune?
- diablo ?
- Vacuum leaks and tune?
- handheld or hptuners, ls1 edit
- FAST Flash
- SD check question
- Line Pressure Offset vs TPS vs Gear
- MAF sensor going crazy?
- Reading my in car wideband?
- WTF +25 ltrim 1 side
- hp gains???
- AFR graph
- help
- tune vs taller tire
- MS4 installed now getting 0106 code!
- Bolt-On VE and Inj DC
- replace MAP sensor how to?
- Question about VATS and installing remote start
- Applying & Using HP Tuners Real Time Tuning Custom Operating Systems
- Auto vs. Manual ECU, couple questions...
- help me out
- AEM, DJ wideband sensor repalcement part #?
- Cold start problems
- Loosing all boost,could it be the tune???
- EFI Live: BIG Auto VE problem - Tune files attached
- Any ideas?
- PCM internal differences, cable vs electric throttle
- P0171 & P0174 Question
- DTC p00108? I just got my car tuned too!
- Autometer Wideband Gauge.....
- Buying injectors, which is the best way to tune?
- with these mods...what do I need tuned
- Tuning Variable Valve timing in a 07 TBSS
- EFI Live compatible with previously tuned car with HP Tuners.
- HP Tuners 1-2.5 bar E38/E67 ECM's features
- 2007 Trailblazer SS communication problem while writing with HPtuners
- TB Hole size - MS4 Cam, IAC maxxed out
- PCM issue w/convertion
- help me please! car wont start
- How to install a 2 bar pressure sensor
- Help! New 408 will crank and backfire but not start
- Laptop Hook Up
- I am looking for data that puts a narrowband and wideband log next to each other
- Gen 7 question
- Virginian Pricks...
- Can custom tune in the PCM be saved to my Predator?
- Problems with car... Comes on And off tuners come inside
- did lt1 swap. need HELP!!!
- Big stuff 3?
- Need Help Tuning My Isuzu Ascender
- uning Help with MS4 cam!
- I think I killed my PCM... HELP!
- One bank super rich, other stoich?
- Quick Question about MAP readings
- 98 pcm question with a solid roller and victo jr
- California Emissions in Tennessee??
- 160lb injectors
- 2 step
- Tow Haul indicator PCm pin?
- toasted the pcm...?
- HP Tuner Question
- VE table scale up by how much?
- 85mm SLP MAF resistor cut or not to cut?
- Popping during WOT runs
- P0327 - specific question
- Check my tune
- Need Help With Running Problem
- Paid Good $ For Prof. Tune & Car Still Won't Launch!
- injector scaling problems
- iac issues
- computer cant be found!?!?
- Car wont start
- TPS on LS2 TB
- Did I fry my PCM?
- At the track troubles..
- Logs showing less than 100% WOT?
- headlites
- Turning off EGR controls???
- Upgraded to HPtuners MPVI Pro - having LC-1 issues
- Hand held tuners??
- 98 trans am pcm wire question
- HP TUNERS for new injectors?
- HP Tuners for new injectors?
- Lean Code Problem
- o2 sensor linking
- Formato tuning and Porting in Gettysburg PA 10/17-10/20
- 408 going in, base tune for initial fire-up - critical
- To MAF or not?
- whats causing ltft to shoot up at idle?
- LTFT's ---> adjustment confusion!
- Check out my logs/tune..
- This is a weird one....HELP????
- Puzzle for the smart guys...
- VE table tuning question??
- What affects fuel trims?
- Leaning out on quick TPS movements ... I need some advice.
- Idaho Dyno Tuning
- Question about emission delete....
- wiring harness question?
- which tuner does this ?
- Cross Ref Chart - vacuum to psi to kpa to bar
- Crank Position Relearn
- Need a Tuner
- 08 Corvette sputters in CL, ok in OL
- help with PCM please..
- maf code
- help with tune
- Reprogram PCM or LIVE Tunner?
- Bosch 13111 sensor anyone use these
- stumble,balck plugs no 02 code
- Signal WIRE for oxygen sensor on ECU
- Idle smells rich but all sensors say lean.
- Spark Timing for New Heads and Cam
- Truck vs FBody
- Anyone forsee problems convering a C5 to run on an F-BODY OS?
- Idle/VE tuning order
- Need BS3 402cid base map...
- backfire on DFCO exit
- fueling issues, please help
- Help Car keeps dying after short trips!
- Going crazy!! Car will fire but wont respond to throttle
- A few issues, no fuel or spark... a little help please
- Quick Question/Quick Response, Reseting SES Light
- Dumping fuel - Why?
- stock 02 file onto a 99 pcm with hp tuners
