- 2006 c6 reluctor issues
- BCM harness same for v6
- obd2 black box
- LT1 383 Computer change?
- Nelson Perfomance
- Holley domninator EFI for LS7?
- cluster help !!!
- Autotap Express Diy
- HP Tuners in Socal area needed
- Looking for some assistance...again.
- How will car run when going from 28 to 36lb injectors?
- AutoTap Diagnostic VS AutoTap Express DIY?
- Scan tool
- Unknown PCM *Newbie*
- O-2 tuning app
- still getting po327 & po332 after replacing sensors and harness, what next?
- idle timing?
- 6.0 Z71 problem
- Speed density tunes skewed by altitude?
- PCM case
- Need 42# Stock injector data
- Any idea's?
- What kind of timing do you run WOT on E85?
- E85- What changes in tune would yield better MPG?
- Is the exact ECM needed to avoid Tech2 Reflash cost?
- Megasquirt 3 instalation writeup
- HPTuners 2012 Corvette Support added
- Quick Question on Tune for Lq9 S10 Blazer
- This makes no sense
- Please help!
- TSP Tqr V2 and washington Sniff test
- Issue MAF Lingenfelter 100 MM
- O2 sensors max and A/F goes very rich during deceleration. How do I fix it?
- stock pcm with boost
- Burning up o2 Sensors, why?
- A/C idle settings in EFI Live
- Elm 327 bluetooth obd2
- Throwing Codes PO410, PO412 and PO418
- Car throwing p0102 code and wont run
- is a tune needed just from switching from 241's to 243's?
- Skip shift = shift light
- Diablosport Predator question
- Holley dominator guru's
- Please Help With my Code Confusion.
- Wanted: tuner help in Lenoir, NC
- Please Help
- DTC ? Ignition coil 6
- Idle tuning. Car has hard time staying running when hot.
- Air intake and maf needs a tune?
- 5.3 70 nova wiring ?'s
- Diablosport InTune?
- SCT Pro rookie, need help figuring VE, MAF tuning setup
- Is there an issue swapping PCM's
- Cluster swap
- TPS signal randomly goes to 0%
- SD tune to maf question
- Engine surging problem
- EFI Live cable question
- Need Cable NW 102 Scalar #
- No reading from MAF in HPT
- OBD1 To OBD2 Plug conversion?
- Can someone please help me with this code.
- What would cause a miss under load? 98 LS1 TA
- HPtuners Config Files
- Anybody have a cam only tune I can look at?
- Is this normal?
- open port 2.0 for tuning obd II
- would i benefit from a mail tune
- 1999 camaro pcm pinout issue
- I need a walkthrough for tuning out VATS
- PCM losing HP Tuners Tune?
- HPTuners 2012 Camaro V8 Support added
- Maf only tune?
- Any Good Tuners in Northern Utah?
- 2012 Corvette, Camaro SS first to market tune support!
- TPS voltage is bouncing around???
- HPT "Unable to locate PCM" after M6->A4 swap wiring
- Diablo tune (temporary) and shift kit.. Will it be ok? What to adjust?
- PCM failure
- Getting a hlod of BS3
- Tuning Gen 5 camaros
- This might be DUMB, but can you tune a fuel gauge....LOL
- Ls2 runs great cold dies instantly at 185??
- Need Help!!!!!!!!!!!!!!!
- picking an ECU: GMPP vs junkyard
- O2 sensors not ready
- Is there a correlation between AFR reading and rich smell at idle
- throttle body question
- Prob. isnt the right section...screw size
- Intrument Cluster Fuse
- Abuse mode in different OS's
- LQ9 "N" code tuning
- I need a tune file for stock ls6 in a fody with a m6
- High idle at lower altitude or something else?
- Keep blowing Eng sens fuse?
- running rich or dumping fuel
- Emissions readout
- 4l60 line pressure?
- tuning issue...with cam
- what diagnostic software?
- Tuner
- tuning 0411 ecm
- Need help with Lt1 tune and TC apply
- Torquer v2 Tuning Help! Need BIN!
- Needeing a tuner near Tulsa
- Tuner appreciation
- engine misfires only on cold start up
- OBD-II PID for Torque (Android)
- DTC P0704 clutch switch circuit
- Fixing TH350 idle dip when shifting from park/neutral into gear
- How to go about Cam Surge tuning
- Help: camshaft position sensor signal low
- LC1 as Narrowband issue
- Intermittent hot start problem
- What kind of tune?
- any way that tuning can cause PO332 & PO327
- edcmat-l1 tuning in Pittsburgh Aug 29th til?
- what is the max rpm for an ls1 computer?
- Surging on COLD START idle after FAST90 and New Tune [ HELP! ]
- Any one in fort worth have a tech2 scanner? HELP!
- Need help from a tuner with ls1edit
- No start condition, ATAP keeps disconnecting. Is there any way to test the PCM?
- High pressure a/c sensor
- Just ordered HP Tuners
- help with diagnostics....
- LT1 Tuning Options - Need Suggestions
- Learning, Maybe?
- help no start
- Need help/advice.poss pcm failed?
- HELP! h/c/i swap...no guages or fire...
- no spark....help please
- P0352 & P0650 (have already ruled out coil/wire/plug)
- I need to learn the PCM?
- Bad gas mileage
- hptuners checksum 4280 error
- resetting fuel trims
- where do you get the PCM pins for cheaper
- 1998 Firebird running issues
- Can someone please point me in the right direction?
- WTF is up with this 2001 camaro speed density
- p0101 help
- high idle!!!!!!!!! help please!!!!!!!!!!!
- Thoughts on IAT/ECT tables
- 55 chevy Ls3
- Hp tuners, LC-1 and 2005 cts-v question
- Several Codes and High Idle
- hesitation question.
- Anyone wanna double check a tune for me?
- What's the verdict on EFILive 2 step (Valet mode)
- Tripped a bunch of SES codes after !cats
- Dyno Tuning trouble
- rewriting 03 s10 pcm to 03 express van
- a few noob tuning questions
- help with tuning with hp tuners
- Slow Camaro
- EFI live... I don't understand.
- Diablo Predator: "Maximum knock fast spark" the same as knock retard?
- LS1 99-02 with AIM Sports MXL Strada
- '01 WS-6 intermittent stalling and power loss
- High Idle
- Where is a good place to get your car tuned in illinois near chicago
- OBD2 to OBD1
- Modifying LS2 harness 24x to 58x
- Help! Bank 2 50% More Fuel Then Bank 1
- dyno tune and diablo predator
- Looking for E38 Speed Density Cam Only Base Tune
- FI tuning. What is safe and too safe?
- Header Install, Cat delete, tune edit required?
- looking for a local tuner
- Spark Plug Spreadsheet
- 4l60e shift points with 4.11 gear
- a4 to m6
- LT1 cold start idle tuning
- LT1 383 Tuning Requirements???
- LS1 swap part throttle miss
- Surging with base tune, tune the main issue? *Video Inside*
- erratic starting issue
- GM SCT guys, need help
- Weird problem help please
- Need Tuning help in Wichita Falls TX
- Question about changing wheel diameter in hptuners
- 46 degrees of timing. STOCK LS1 tune
- Getting weird knock
- Codes p0102 and p0803 Need help..
- SES code check with out scanner?
- p0102 code after tune.
- Trailblazer ss pcm
- why PO327 after a Tune? this seems to happen alot
- Bogging at WOT or under load
- Alternator
- swapping PCM's
- disparity in my 02's dangerous?
- ETC scalar question
- EFILive and AEM UEGO showing different readings?
- best tuner around......was closed??
- ses Light comes on after 70mph
- Tuning after rockers install??
- 30% tps at wot
- help tuning questions
- 02 z28 error during writing tune. PCM fried.
- Need major help!!!!
- EFILive error message w/ pictures
- I bet you can't figure out why I'm running rich (datalog)
- MEFI4b, Ingenius 2.2 and Vista
- Trans going into limp mode from time to time need help
- rev limiter
- aeroforce scan gauge
- what sensors are required to run motor?
- MSD 6010 for efi
- Question About Timing being pulled.
- Idle issue
- need help with engine codes
- MegaSquirt Plug and Play project
- 04 GTO MAF different then 99 F-body?
- newbie tuner
- Ned help with some ses codes
- 2004 envoy 5.3L engine starting issues. Any suggestions?
- Reading Wideband Questions
- first tune
- HELP! 36lb/hr GTP injector hp tuners
- Disable LTFT
- what is all needed for proper DIY tuning
- knock retard question
- EFI Live & HP Tuners on Sale plus LC1 for $129shipped
- OBDI PCM Issues?
- injector size question
- Email tune?
- 4 codes after tuner has it???????
- OBD2 Blowing Fuse
- Accel Gen 7 IAC issue
- Best tuner around..........
- Can setting the P1626 to "no mil light" cause these issues? Ideas?
- Old (serial) hptuners interface question
- HPTuners VE Tuning issues...
- FS: Tune Tuning School (LSX Specific)
- passing inspection with a efilive2 bar OS
- harness swap question
- Did I kill my PCM?
- Need help please..
- reduced engine power
- Nebraska Tuner help me turn off VATS
- Question about map sensor linear and offset 2 bar map hp tuners...
- What side to mount WBo2??
- Not getting full timing for some reason????
- Hptunes general setup help (fuel)
- P1637 - Can Link ECM/ABSCM Circuit / Net Help
- Brand new to tuning need help
- Homemade cable from wideband to logger?
- Colorado MAF Part# 12579352
