View Full Version : PCM Diagnostics & Tuning
- change oil reset..no more SES light
- TCC tuning
- Too much timing for summer weather?
- why is it running rich
- P1415 code, DBW question? Throttle body malf?
- Sensors
- Code PO300
- Car is acting funny...
- AEM WIDEBAND YAY or NAY?
- o2 sensors look like they are going bad...how bad
- Stock 98 M6 .bin needed (HPT)
- truck ECU
- air/fuel
- sct flash anyone use it?
- tapping rev limiter
- tr224 bin file.....
- EFlive
- Where to take a "special" E67 ECU to get checked out in the DFW area?
- Predator
- Which ecm is best for tuning with DBW?
- need a trust worthy mechanic/tuner in sandiego
- The car is acting crazy. Can you guys help?
- Oklahoma Dyno Tuner!
- cam/crank sensor voltage
- PLX Wideband istall help
- tune for cam
- Tuning Help Please!
- HP Tuners
- 2000 T/A "Starter Module Relay"
- gutted cat, mileage 8 mpg ?
- hptuner or efilive
- Predetor and 37 lbs injectors
- O2 Simulators
- who will delete my codes?
- A4 to M6 reflash in a 98?
- Wiring
- changing gears >3.42 any shift tables out there.
- reluctor wheel question
- LC-1 wiring with HPtuners
- h/c tuning help
- get a dyno tune or use hp tuners??
- Diagnosing a no start....again
- LS1 timing
- Innovate LM1 Basic Kit???
- surge/bucking 2500 rpm and lower in all gears? Car was just tuned.
- YIKES ! Think I screwed up the PCM.. Is there any hope?
- which tune to get?
- a4 tuning question
- New to tuning and need a suite...help me pick...
- letting off gas, car seems to idle high
- 98 PCM Fried causes Tach Data loss
- SD questions really quick
- deleting too lean code
- Diablo Tuner or custom tune for stock 99 LS1?
- can i run cable throttle with a 58x reluctor
- How many use Diablosport tuners?
- need some info on vinci/crane tuner
- HPtuners newbie with sticking idle
- 4l80 converter won't lock up...
- tuning software for lt1 obd1
- Looking for a cheap hpp3 to change fan temps with until I need custom tune.
- Want To Get A Tune...
- big stuff 3 for trans question
- Car Misfiring?
- Car Misfiring?
- running lean in both banks??
- looking for tuner near South Dakota
- editing mail order tune
- n00b question
- Horrible Misfires and 170 miles per tank of gas..please help!!!
- misfiring under load. no codes
- Efi live
- security light
- Strange throttle issue
- Knock sensors gauge
- Wideband advice
- Running rich on one bank
- LT1: Open loop 2 bar Speed Density. STOCK PCM!!!
- Can o2's really die this quick?
- OBD2 to OBD1 Write Up
- Bigger MAF....Is it worth it and do I need one??
- LT/OR pipe = HP Tuners
- Which tuner..
- plug part # question need help asap
- o2 sensor voltage
- 98 ss with problem
- Cheapest method for tuning idle after cam install on C5?
- SD and NE tuners? Where at?
- SLP Predator feedback
- PP3 Problem!!! HELP!!!
- how much is the factory tach off?
- Need insight about dyno tune, rich / lean etc.
- Are there any good chicago land tuners
- Need and ECU expert :(
- Help coil question asap please!!!
- HPT tunning near Columbia SC???
- Were to send my 1998 pmc for Vats delete
- running very lean
- Crane Cams Vinci Tuner for boltons now and cam later
- my megasquirt setup just passed OBDII emissions
- 00 trans am ecu to 00 camaro SS swap?
- Auto Computer Technologies
- Ecu Swap or can I copy tune
- Security Light???
- cam position sensor
- Trouble code: P1502 - Any thoughts?
- tuning out emmissions?
- autotap
- PN 19166567 LS7 PCM Cracked yet ??
- 02 sensor wiring?
- Help with Codes!!
- P1416 Secondary Air Injection (AIR) System Bank 2. How to fix and find problem.
- stock ls1 tuning
- P0689 engine code please help
- Is this normal..pics inside??? Please respond fast!!
- timimg is being pulled during shifts?
- daytona prototype tuning??
- misfire code
- P0327?
- Benchtop tuning harness
- Poor Throttle Response........
- 94 lt1, bolt ons and boost
- Check Guages
- auto tap to use with ls1 edit
- HPtuner how to tune for 38# injectors?
- Someone tell me what this means!
- Connecting 3 bar MAP to TBSS harness.
- Weatherpack Connector
- First ever dyno
- IFR table for 63lb injectors...is this right?
- scan tool
- adjusting 2-3 shift only on A4
- Still Stuck
- wiring for a brand new engine
- A4 to M6 Tuning
- Adding BS3 and a Racepak?
- HELP!!! car stuck in open loop!!!
- Is Dyno tuning really worth it?
- Reluctor Wheel For XFI or Big Stuff
- tuner
- Dual wideband vs Mono wideband
- Tuning DFI with 1500 CFM 4150 TB
- p0172 and p0175
- LTFTs questions
- Help! Ses Codes P0102 P1416
- Passed Ca smog but not OBDII
- very weird problem
- big stuff 3 users!!!!!!!!!
- LTFT and E85?
- can u do the same with street tune as dyno?
- 02 Tables Set To 250
- need a good tuner in san antonio area
- Please Help !!!misfire
- hp tuner question
- Mail order tune for H/C Ls1
- Speed Density Q
- No spark please read
- trans or tune problem?
- Gm Mdi - Sae J2524
- looking into a FAST setup
- GM Part # needed
- Diablo EGR question
- OBD1 scanner cant log into PCM
- Tachometer error
- Check engine light on s-10 extreme
- Big Stuff 3 and Drive by Wire
- Tuning out all O2's
- Anyone Tune The New Racetronix 79lb Injectors Successfully?
- No open loop at WOT, what is wrong?
- Throttle pedal postion sensors ETC
- case relearn
- ECT Sensor Question?
- M6 PCM to A4?
- Clear P0401 Code
- MAF seems way out after VE table tuned.
- Tunning the Formula
- New to tuning....
- need help with tune for "BabyCam"
- need a little help
- Crane Cams/Vinci Performance Tuner vs Unichip Piggy-back ECU
- idle problem when coasting
- LTFT and secondary VE table
- Programmers for an m6?
- Absolute best deal on HPTuners?
- Dynojet wideband commander price info
- Misfiring problem HELP
- Threw a Code, need help.
- possibly going with an SD tune got a few questions...
- another check my tune
- Do I Need A Tune
- To SD tune or not?
- DTC code help
- Tune Problems? Need some suggestions...
- Can someone w/HPtuners view my tune?
- please help which pids for auto ve w/o2s
- Did the price of TSP's mail order tune go back up?
- wire diagrams
- high/low octane and SD mode
- Does battery disconnect affect PCM program?
- Computer for 2004 Drive by Wire LS6
- tuning the car for 100 octane.
- Different use for MAF Translator, question...
- Clear SES Light
- Clear SES Light
- can you change your computer
- Having issues with PCM (GM Techs plz enter)
- Anyone in Dallas?
- Problem with HP Scanner
- Pre Tuning Log????
- daily driver w/ 100 wet kit not used much. street tune or n2o tune?
- Caspers TPS for LS1's
- P0300 & P507
- P0171 and P0174 codes???
- LS1Edit software
- Hi Guys, Ill be in Houston texas this weekend PM for free tunes all weekend.
- Database of Tuners in your city
- How to get firmer shifts
- PO713 Code Help
- Tuner in the Austin area.
- Tuning ?
- Jeremy Formato Gettysburg Tune/Port Session 3/6-3/11
- Moving PCM to other F-bodys
- whats the best hand help programmer or tuner?
- probably a dumb question...
- Got a question about efi live or hptuners
- tps
- Wideband questions
- Review my nitrous tune strategy 150 wet.
- aem wideband with efi live
- AEM UEGO or Innovate LC-1?
- Need EFI Live Tune for 99 Camaro
- Did I lose my tune?
- what programmer should I get
- carb style tb
- How to tune for 4.86 gear?
- Need help, poor acceleration
- are these normal??
- Autometer Weird install issues.
- So fucking lost>
- LC1 software download
- rpm gauge doesn’t work after cam instal
- 97' Spark Question-Power High vs Low tables
- Looking for a good Tuner
- Handheld Scan Tool Advice - Equus Innova 3110?
- Is GM's ASA ECM Locked?
- Check engine trouble
- What does Patrick Use
- Few more tuning Questions
- Can i buy a pretuned PCM for my 1999 TA A4 with an LS2 engine
- lean tuning for mileage?? anyone try it or know anything about it?
