- Does my timing seem too low to you?
- Security light stays on, car wont start
- Intermittent DTC code........
- ls1 Edit ?
- My closed loop A/F is normally 14.7 but goes to 14.2 at idle, does yours?
- another code delete question....
- ABS and TC lights
- My A/F Ratio is 11.5 - 11.6 how do I
- Automatic windows
- NEED HELP BADLY :( MAFT and NO change to O2's/A/F with 12degrees at WOT :(((
- I'm upgrading from A-Tap to EASE ?? Where best to get it?
- MAFT question
- LS1 edit question?
- Descreened MAF ???
- HELP WITH 02 SENSOR
- Already have MAF Translator... Hypertech PP3 a waste or benifit?
- hi vs. lo octane timing tables
- HELP! HELP! I am FREAKING OUT MAN!!!!!
- Help me out Please
- How does the PCM determine misfires?
- Desperate for Ideas/Help....
- Explain the Volumetric Efficency Table
- When adjusting MAFT for LTFT do you have to....
- LS1 Edit File Question
- under/over speed for fans in LS1 edit??? whats what?
- STFT's and LTFT's?
- List of PCM Programmers and Contact Info.
- What causes DTC Po171, Fuel trim System Lean Bank 1?
- Installed PACE 85mm MAF w/screen - LOW OIL LIGHT ON????
- Are misfires normal???
- is anyone still using the pcm tricker?
- Wide Band Tuning!!
- Auto Math and Performance Calculators?
- Autotap Questions.... MAFT and Ltrims... Injector puls.....
- Anyone fried their PCM with LS1Edit yet?
- This is unfortunate
- how to lean/richen and raise timing with Edit???
- Gear/Tire ?? on Edit
- what fan on/off temps for a 160 thermo?
- Forcing WOT lockup thru the pcm with LS1 Edit?
- How much for reprogramming??
- need help with ses codes
- beginer LS1 edit ?'s - just to be on the safe side.
- Someone read these a-tap #'s and tell what you think "dont look right" please help.
- LS1 Edit for 2001s any word on when?
- reprogram w/ new cam (not the typical ?)
- What parameters to AutoTap?
- o2 adjustment?
- KR: Decay vs RPM -- Does This Sound Right?
- Ignition timing 24.35 @ idle
- MAFT Question
- LS1 Edit-0 compatability with HPP ?
- Ok Dyno Graph experts........ Is this the infamous KR??????
- Auto Tap ?????????
- Which One?
- DTC's that affect perofrmance
- Autotap Question.
- LS1 Edit & Torque Managment Hell !
- O2 sensor output depends on which gear I'm in???
- How to turn off TM??
- Why dont we use AFC's like the turbo guys?
- Should I add Power Programming?
- Autotap log inside can you help?
- HPPIII
- Diagnostic Trouble Codes (DTCs)
- Cable?
- Max Torque Setting
- H/C Problem, need help...
- knock sensor light
- where can i buy ls1 edit
- try again
- What parameters would be changed to take advantage off..
- Where is Knock Retard in Autotap?
- great ET, but bad atap reading...graph attached...
- help . . . what could cause these codes?
- what does TPS sensor and IAC stand for?
- Heads/Cam cars, what's your ignition timing at at WOT?
- I am going to need a wiring harness ect for an 02 simm. Where to buy "dealer?"
- Ed Wright?
- GEN II PCM pin location diagram for 99 5.7 vortec ?
- Max Allowed enrichment
- hit limiter on 1-2 shift what to do -1mph with hypertech?
- Granatelli MAF
- How lean am I to set a lean code on both 02 banks???
- Will programing cure converter shutter?
- New Post Idea's- Please identify Year and Model
- LS1 Edit/HPP3 for shift points?
- What happens to O2 readings when running super rich?
- New title! o2 readings and time.......
- 2002 version of LS1 Edit
- Is the Average Person Using LS1 Edit??
- A4 Shift Pt UPDATE :)
- Got programming done
- Base Spark Tables
- WHICH SCANTOOL TO BUY
- Help on trouble code
- SES light on after header install
- What is "Bad VSS" and "ETC" for?
- M6, Do I use idle spark tables in drive or park?
- Need help finding/buying a PCM
- Fastchips tuning with a new motor...
- Scanmaster
- anyone else get there 01-02 version yet? for edit?
- Slowhawk....Dyno #'s?
- RWHP/RWTQ on a Dyno compared to ATAP Delivered Torque & HP
- Converters having trouble locking up w Custom Tuning, help please!
- My Ltrims refuse to go to 0 aghhhhh!!!!! Help!!!
- What kind of HP decrease from missing 02 simm... Read inside, here is why I ask.
- Can we clean 02 sensors with contact cleaner?
- Autotap TCC reading changes every nanosecond?
- ? about aftermarket tuning
- TUNING HELP!!
- 02 cars can use ATAP
- Knock Sensor?
- WTF - PE vs RPM doesn't do squat?!
- MAFT Discoveries and Summary
- LS1_Edit & 3:73 gears...
- What Air/fuel ratio should I be looking for n/a?
- 2000 ls1 engine and ecu schematic needed
- MMS - Were You Happy With Their Work?
- A-Tapp Averages
- Need a map from a Twin turbo car
- O2 readings
- timing table load units
- computer
- WTF - Deleted TM w/ Edit and still get .......
- Air and EGR, computer related..Please Help.
- Stupid ?? Can I modify the main window before I save a file?
- Ordered LS1 Edit for my 99 C5
- Got a question after getting my 4.10s on !
- Newby PCM reprogram/replacement question
- PAGING RYAN KARESEK
- Granatelli MAF any one get a SES
- Fuel cell and WOT
- TCC Lockup @ WOT??
- Maf causing check engine light to come on
- N2O ATap Results. Problem?
- LS1 Edit ?
- A4 won't shift above 5400 in first????
- Odd observation.. see inside.
- Open loop and closed loop????
- Paging Ryan Karasek
- Uneven ltrims
- ls1 edit and top speed??
- Throttle Position error.. Low voltage????
- MAF circuit low frequency? What does this mean?
- Newbie Question.....Hp & Torque gains...
- Re-Programing and battery power levels
- A4's: Changing desired shift time??
- rev limiter different in 2nd gear?
- SuperChips MicroTuner???????
- o2 sensor queston
- Part throttle pinging with LTerms at 0. Help.
- 'lil help with edit problem please ...long
- knock sensor question
- Which would you do and why???
- Purchasing LS1 edit for my 99 C5
- Is there anyone in the charleston SC area that can do custom tuning?
- Changing Converter Lock-up
- Torque Managment!!
- TRUE OR FALSE?
- MAFT and Nitrous - kinda long
- Has anyone had this happen???
- Quick computer tuning question...
- Knock Retard Concern?
- scared of auto tap
- Tuning for cam?
- Weird Problem Driving Today...Please help...
- KR sensor attenuation
- Need LS1 Edit HELP for fuel and codes and Shift points
- Dash/radio lights go out when I turn on the headlights
- Where to buy the software like Ls1 edit
- Which ATAP data will enable me to verify gms/cyl in LS1_Edit High Octane Table?
- Superchips programmer on order please help!!!!
- Everyone with a MAFT
- Help on code P1571
- O2 reading .002??? Now that is LEAN!
- Effects of Changing MAF rate...inside
- Do You Know TM Also Can Limit Fuel??
- "This is not a Supported PCM" (2000 4.8L)
- Let's Start Sharing Some Conversion Charts
- Coverter lockup prob solved!!!!
- anyone know all the codes for deleting the EGR??
- maf error and ls1edit
- PE vs RPM how much?
- PCM Manufacturer
- Results of First MAFT Adjustment
- What are O2 Sensors ?
- New here, starting off with MAF question...
- Any shops that know how to tune w/ Ls1 edit?
- Anyone know all the codes to delete rear O2 sensors?
- anti theft key ?
- low dyno #'s before/after edit (long)
- whats up with this code?(P1336)
- my LS1 edit saga ends... 60 minutes to read pcm
- MAF flow rate vs MAF frequency
- What is the ETC limit in the Engine Limiter's Tab??
- A4's: Let's discuss using MPH to set shift points
- Difference in LTRIMS?
- LS1 Edit- Adjusting AFR.
- Help! Throwing a code about infrequent switching of 02s
- flashing to Z06 specs
- After editing do your gauges flip out?
- How do I get rid of the Airbag light?
- First ATap Results...Input Needed.
- Getting the best dyno numbers possible?
- Auto Tap (windows) not working every time?
- A4 3500 stall converter info....
- Max allowed enrichment?
- P0171 Fuel Trim System Lean Bank 1
- Adv. Timing kits, anyone with exp.?
- What is Gms/Cyl measureing?
- Looking for supercharged edit files
- Just got LS1Edit, have a few questions...
- LS1 Edit for Heads and large cam?
- How do I calculate injector offset?
- maf
- Car is throwing codes about 02s switching infrequently?
- Increasing revlimiter
- Replacing 02 simms, going with a cat, need opinions
- ls1-edit and emmissions question....
- wish I knew how to use a tap/or ls1 edit/or scanmaster
- can you use a z06 MAF on an '01 C5
- P1571 Code
- Anyone get Edit software in pieces?
- anyone got a dtc list?
- Just got my LS1 Edit cable, couple questions
- Few LS1 edit questions...
- How long does it take ya'll to download your pcm to puter with ls1 edit?
- SES
- motor stalling need help s10 with LS1
- Where should I put the Wideband 02 when dynoing?
- Idle issue after WOT
- What can a dynojet tell me that autotap won't?
- Will custom tuning give me any more power?
- Which Gms/cyl do I change timing in for WOT?
- '01 and '02 LS1 Edit beta testing begins!
- Tuning program ?`s
- hypertech 75% shift firmness safe?
- Haven't found any horsepower using LS1 Edit
- How much effect does the O2 Sensors behind Cats have on Air/Fuel ratio?
- Need instructions for a MAFT 4.0.....
- Should i delete my TQ management??
- Does Hypertech PP3 work
- Auto Tap Question
- Split Second Air/Fuel controller. Anyone uses it?
- How should I go about tuning with an atap and maft
- Dyno help!
- 02 Sensor harness bad? Getting SES
- Any hiccups with LS1-Edit and Windows 2000?
