PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Tuning shops in Georgia and north Florida
  2. Troubleshooting & Diagnostic problems.. PLEASE HELP!
  3. NV3500 VSS Signal
  4. Code P0200 injectors circuit *Please Help*
  5. Truck tune, keep AFR correction?
  6. Hp tuners not logging or scanning some parameters
  7. Loss of power accelerating
  8. Function of Oil Pressure Sensor?
  9. Is this a tuning issue?
  10. 408 stroker with 30 deg. timing is it to much?
  11. Dyno Session next friday what should I expect
  12. MAF high question
  13. P1518 at 36% TPS (HPT Log attached)
  14. Surging ls1
  15. Anyone willing to help me with EFI LIVE issue with torque converter lockup? 01 LS
  16. ls2 injector data for ls1 pcm
  17. larger injector programming problem
  18. Untapped horsepower?
  19. 1999 5.7 vortec 350 OS 09360505
  20. Unknown Wire & Holley Help
  21. U0107, red/blue pcm, and dbw question
  22. No OBDII link after DOD delete and cam swap
  23. 5.3/4l80e PCM
  24. PCM is not seeing what gear the tranny is in.
  25. mail order tune suggestions
  26. pinout per connection on 411 pcm 2002
  27. Looking for a tuner in denver
  28. ls swapped car computer questions
  29. Rear O2s high flow cats.
  30. car lays over when shifting from 2nd to 3rd during burnout
  31. Injector pulse ?
  32. New to tuning, looking for timing table advice. Built LQ4.
  33. Let me know what you think about this idea... opposite fan speed programming
  34. misfire has me stumped... Need some help
  35. Basically stock 6.0 maxing out 98 maf frequency?
  36. Flashing check gages light
  37. Engine and Transmission Control Help
  38. Lincoln Nebraska
  39. p0606 (ECM fault) triggers after sustained moderate throttle.
  40. Long Term Fuel Trim 24.2 at idle!!
  41. flashing ses light no stored code?
  42. MAP sensor tuning
  43. Changed the cam, how much tuning will need to be done?
  44. Newbie Tuning Question
  45. Poor gas mileage/SES light always on?
  46. No intake air temp reading
  47. 98 camaro traction control not working after 99 wiring swap.
  48. Fast xfi Sportsman?... Holley efi?...
  49. Drive By Wire HELP!!!
  50. bad pcm?? unplugged maf reads 3g/sec KOER???
  51. TAC/PCM troubleshooting
  52. AFR imbalance from bank to bank
  53. Best computer tuners?
  54. New knock sensors, no where to plug on ?
  55. Error 4L70E Supermatic GEN2 please help
  56. 76mm 5.3 s10 nearing completion
  57. 0411 PCM with LS6 harness
  58. HELP! IAT sensor dropping below zero the more you drive
  59. 10 degreese of timing at wot LQ4?
  60. What is the going rate for tuning?
  61. Reduced engine power!!! Wtf! Help!!! Please
  62. 98 ls1 trans am SES p0131 p0171 after headers & catback install
  63. Dakota Digital Speedometer Interference
  64. CEL is on!
  65. Who is running ID1000 injectors?
  66. Gear Ratio in HPT
  67. Gauge cluster stops working, then works fine
  68. 12V Source while cranking and key on 02 Camaro
  69. Trans blown or did I enter limp mode??
  70. has anyone bought SCT 7416 for their 99-02?
  71. Pcm number identification please help
  72. what exactly is a standalone harness?
  73. IBPW in open loop?
  74. untuned 4l60e cause vibration?
  75. Small VSS error
  76. (tuners please) Quick question about tuning for a UD pulley?
  77. Ls swap+efi live and learning to tune?....
  78. 4l80e won't shift into 4th occasionally
  79. hiw to tune? no maf, o2, knock sensors.
  80. 1999 Silverado Passlock woes
  81. thinking of going from one ss3600 stall to another brand ss3600
  82. EVAP still functioning?
  83. Error F3
  84. Innova Quicklink?
  85. Wideband going bad? HPT Log file and Tune attached
  86. Random Missfire
  87. hp tuners maf turbo tuning have a few questions
  88. Changed injector size, will car run with old tune?
  89. trying to update MAF tables for 85mm but freq limit is 67
  90. No SES light but codes show on a scan tool
  91. ls3 map on ls1 and sd?
  92. 5.3 in Lemans swap, won't stay running
  93. Does the E38/LS3 Read Oil Pressure / Temp?
  94. Intermitten Problem
  95. Transmission acting weird after cam install
  96. Noob here with a question regarding the scanner
  97. Mail order tune through email?
  98. Help! electrical problem
  99. Get the Best Price on Hp Tuners @ Hinson Motorsports & It Ships FREE
  100. Car will NOT do a burn out. Something limiting my setup
  101. Help Disassembling E40 Delphi Micro-64 Connectors
  102. just completed 99 harness on 98 and need a little help.
  103. Any trusted tuners in okc area?
  104. a4 to t56 swap know my tune is jacked up
  105. VATS disable, car won't start
  106. 07 Z06 startup tuning
  107. Please help!! Ls1 swap, 1st start and drive good now won't rev
  108. mail order tune problems obd1 memcal /g1
  109. 5.3 Thirdgen, New cam, Heads, and Dyno Tune.. I think i lost power
  110. Florida Tuning Supporters
  111. No Activity on the Rear O2 Sensors...?
  112. 98 to 99+ pcm swap with 99+ harness
  113. leaving car with tuner??
  114. PCM signal for speedometer ??
  115. TT auto c6 maf tuning
  116. 2004 GTO LS1 flex fuel
  117. Ls3 Swap SD tune or MAF
  118. 295/35/18 with 4.10 gears
  119. backfiring during initial startup
  120. Surge at light throttle. Suggestions?
  121. Hardware does not match vcm
  122. A/C compressor won't stop running
  123. Yet another LC1 Wideband thread
  124. can I change 08 LY6 E38 ecm to older, simpler
  125. Long Term Fuel Trim = 0.0%, always
  126. 414 LS3 loosing power early
  127. GM files patent for remote ECU reflashing
  128. new to tuning. should i get a mail order or a handheld?
  129. best OS for 411 pcm/w 3bar, 80e, A/C, e-fans
  130. 05 GTO knock sensor problems
  131. North carolina RPM tuning
  132. 411 ECM with LS2 DBW TB Question
  133. efi live help tune h/c
  134. Car stays running without keys in ignition - Help
  135. 0411 ECM Programing
  136. 47lbs GT500 Injectors in an LS head?
  137. Little help on wiring
  138. Holley Dominator EFI ECUs On Sale w/ Free Shipping @ Hinson Motorsports
  139. Looking for tuner in southern Wisconsin or northern Illinois
  140. Can't get into SD because MAF codes won't set
  141. 4L80E Building Up Head (Data Log File Posted)
  142. 99 ls1 cam sensor wiring order
  143. Emissions - DTC
  144. o2 sensors and exhaust leaks
  145. Help - which PCM is which
  146. Looking for an EFILive Tune.....
  147. Holley Dominator in '98 WS6
  148. P0154 & P0327 with new build
  149. newbie question
  150. Need a Pcm Tune for 98 A4 to M6
  151. 4l80 table to fix holding 1st gear
  152. most power out of intake & full exhaust?
  153. Hesitation and Sluggishness
  154. Huntsville, Al Need Tech 2 Help.
  155. Ls3 WOT timing?
  156. Anybody in the Charlotte NC area that can disable passlock for me asap?
  157. Ls1 swap egr/evap/misc pcm delete with efi live?
  158. Reality check before purchasing credits
  159. LS1 standalone wiring
  160. Engine stutter, low rpm, WOT
  161. Replacing spark plugs every 250 to 500 miles! Help!
  162. Help with pesky P0301 code
  163. p0171 and p0174
  164. EFI live v's hptuners
  165. Diablosport Chipmaster Revolution Chip
  166. Issues after 383 build
  167. p1153
  168. Shifting problems?????
  169. BCM and ECM gurus's
  170. Starting Only Issue - What to check
  171. Values for LQ4 coolant sensor
  172. Tci Ez Trans controller!
  173. 2 bar to 3 bar through Hptuners
  174. tuning boosted ls7 - 230-240 ECT while cruising?
  175. New PCM, new tune..
  176. Safe Timing.......
  177. Keith McCord
  178. good "universal" scan tool
  179. newbie// sorry if im posting in the wrong thread
  180. Tuning AFR at the Drag Strip (gear)
  181. Confusing Lean Code Problem
  182. HpTuners Scanner Issue
  183. intake/headers tune
  184. Stock idle Fuel Trim's whats normal?
  185. pcm
  186. What MAF do most tuners like
  187. no starter after pcm swap?
  188. First time EFI Live help.
  189. Programing a/c compressor
  190. hp tuners questions
  191. 98 z28 a4 to 02 t56 pcm and harness
  192. things needed for tuning
  193. Easy stand alone for LS
  194. Diablo tuning question
  195. Service engine light
  196. maf porting good or bad
  197. New to HP tuners. what's a good starting point?
  198. Bank 2 running rich, Bank 1 fine?! OUT OF IDEAS
  199. m6 to a4 swap stalls with desired rpm 0
  200. NGK AFRM in hptuners help
  201. Power Steering - Affect on Idle
  202. Bank 1 ltft high
  203. Anyone using Hawks Third Gen Mail Order Tune?
  204. P0300 code question
  205. Preparing tune for LS1 to LS2 swap
  206. LQ4 Tuning, no knock sensors?
  207. MAF or SD for twin turbo 5.3 build
  208. Ls3 swap, Knock sensor and timing question
  209. Who can unlock tuner locked pcm
  210. How to get Aeroforce Interceptor to read A/F???
  211. need help with a code
  212. O2 sensor signal - does this look ok?
  213. Why are the values in my VE table so high?
  214. LS2 GTO PCM in a LS1 Camaro
  215. Going to buy a new wideband whats best???
  216. Not your same knock sensor thread.
  217. Tuner experience needed for Drive by wire throttle issue
  218. High LTFT at part throttle bank 2
  219. Turbo LS1 pulling timing at specific rpm..
  220. fuel sender min max specs hp tuners
  221. Hp tuner TCC need advice
  222. Northern Virginia tuner needed
  223. over fueling wont run
  224. Using MAP to determine intake restriction
  225. Which IAT sensor for Holley HP EFI harness
  226. No Spark or Injector Pulse.. Need help
  227. Tuning 101
  228. High idle
  229. Race chassis problem - Urgent help request
  230. Need help locating 80e segment swap
  231. Timing wont go any lower
  232. No WOT 2-3 shift only after downshift.
  233. Tuning help
  234. timing
  235. Possible to tune VE Table from MAF with the 3rd Gen PCM?
  236. Rough tune need advice much appreciated
  237. A/C Fan Settings with 160 Tstat?
  238. HP Tuners
  239. MSD atomic ls VVTand boost?
  240. Crane Power Tuner settings
  241. Hand held tuner question
  242. Heat sink Truck coils and FAST XFI
  243. What is this part called? clicking hose?
  244. cam tuning
  245. 96 Buick/pontiac ECM 16211539 computer harness fit a LS1?
  246. hp tuners vats, please help.
  247. Tuning help in eastern nc area
  248. First start tune, what else do i need to do?
  249. Target Shift Points
  250. In search of a "Tune" shop in NC
