PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Adjust o2 flow rate with full exhaust install?
  2. P0342 and P0343 Camshaft Position Sensor 24x Swap
  3. My stock lt1 live run file
  4. What are these modules?
  5. New LQ9 Build stumble at half throttle
  6. 4L80E Swap trying to rule out tune
  7. TPS reads 100% at all times
  8. 8.1L vortec - Low vacuum at idle after rebuild - Need expert help for this puzzle
  9. 67 Stand Alone - No Communication
  10. Fuel pump Relay issue
  11. Codes After Head and Intake Swap
  12. tune issues
  13. red/blue or blue/green pcm
  14. knock sensor
  15. HPT 4.0 anyone using it?
  16. Bluecat tuning tool
  17. GENIV software flashes, any aftermarket support yet?
  18. Some ideas on direction for surge after VE/RAF/IAC
  19. Exorcist- tune question
  20. F body operating system VS C5 Corvette
  21. 2000 rpm idle in gear
  22. 4l60e shift to third gear issue
  23. Reduced Power Mode. PCM Swap
  24. No acceleration even at WOT
  25. Speedo issue!
  26. Lq4 tune question HPTuners
  27. HELP!!! HP Tuners MPVI 2 wont connect
  28. Stoich to lean sweep
  29. Any P59's have Tow/Haul mode???
  30. Hp tuners reading issue?
  31. P0108 / P0300 randomness
  32. 2000 Sierra truck starts then dies right away
  33. Massive Lean Spike on Shifts
  34. Mefi4 Ecu repair in uk??
  35. Knock Issues
  36. 12614717 iat sensor curve HP tuners
  37. 06 impala ss ls4 ecm and tcm problems.
  38. Tps issue >>>
  39. Stock 5.3 swap?
  40. Locked pcm
  41. Help! New Built 370 Dies Immediately, Already Tuned
  42. How to disable fans at speed 411PCM
  43. 98 PCM to 99+ lose tcs/asr? what about airbags?
  44. Do I need to buy another E67 ECM
  45. EV6 to EV1 adapters
  46. Question for tuning Gurus regarding O2's and open/closed loop
  47. Overheating coolant a swapped 07 ls2 c6 to ls3
  48. Even Weirder A/C Issue
  49. LS1 vs LT1 (24x swap) Tuning differences
  50. Weird AC issue, Silverado
  51. AFR issues with Atomic EFI 408 LS
  52. TCC goes on off on off on off, etc when I’m 4th gear
  53. VSS Pulses per mile out of range
  54. Idle tuning - Megasquirt 2 + TSP 228R + Milled 862
  55. Upstream and Downstream O2 sensors?
  56. Diagnosing Knock Sensor issue with HPTuners
  57. Need help - tuning for trans brake but my OS doesn’t have any options to control 1st
  58. LS Tuner
  59. 99 Suburban Vats
  60. Remote Tuning an LS3 swapped C5
  61. Stock 02 and wideband placement advice
  62. stumped on a STFT bank to bank mismatch...
  63. 6L80E tuning guide
  64. Peak torque
  65. Stock computer for intial start and break in?
  66. PCM Differences - 411 vs 896 - Functionally The Same??
  67. Can someone at diablosport please activate my account?
  68. Won't go over 4000 rpm (LS1 2000)
  69. Can't reflash TODAY, but could YESTERDAY???, after-new site, new log-on, etc...
  70. Emailing $EEHACK File?
  71. Lean Bank 1, Rich Bank 2 after engine build
  72. 2000 Camaro SS with an RPM NC tune, IDLE HIGH, only with AC on
  73. 4l80e questions for the Dyno
  74. Driving to tuner
  75. Turbo ls1 randomly won’t start/horrible misfires
  76. Please look up my tune. I need help!
  77. Slight rough idle
  78. Computer issues
  79. Boosted Iat on pump gas
  80. No TCC lockup - TCC misfire off
  81. LT4 Gm performance run kit , no throttle
  82. how can you tell if your ecm is progam to drive by wire
  83. AC idle bump 03 LQ4
  84. OBD2 WiFi Wireless and Android Suggestions?
  85. New to tuning. Injector: match set or fast 36#
  86. P0036 and P0056
  87. P0036 and P0056
  88. where in hp tuners is the p1514 table?
  89. Jerky in first gear.
  90. I think I bricked my PCM. Help
  91. Newbie Questions regarding HP Tuners and Injector/MAF swap
  92. Stock .hpt File for 99 M6 Z28
  93. P0135 and P0121 after hvac delete
  94. FAST EZ-EFI No Start Issue
  95. Turbo 5.3 possible tune issues
  96. are these o2 sensor readings right? Also how to disable dfco?(1999 firebird)
  97. P0200 after injector swap
  98. How to LS3 DBW TB to LS6 pcm
  99. Ls2 idle problem.
  100. Help getting a 3 bar setup, no stock file
  101. Normal knock retard on l92?
  102. Total PCM and Tune Noob needs to decide and start learning NOW,to ready for NEXT year
  103. Ls1 fans
  104. General Question
  105. New built engine won't idle
  106. Tuning help- am I doing it right?
  107. Powder flat after 6000 rpm
  108. Noob question
  109. Mail order vs dyno tune after cam swap
  110. No throttle response
  111. Holley EFI & 6L80
  112. Error code issues
  113. Idle Airflow config ?
  114. 95 Z28 with 02 Tahoe 12212156 OS
  115. 4L60E will not shift into 3rd or 4th unless I command it to do so in HPTuners
  116. Taking out my rear o2, egr, and air pump
  117. Ls3 swap computer question
  118. Trouble with 58x to 24x conversion
  119. Off Topic, Dodge Q...
  120. Who can reflash my ecm? A4 to M6 swap
  121. Car only surges in motion off throttle
  122. LQ4 tune wanted
  123. Unorthodox knock sensing ?
  124. LS3 - Long crank(5 or 6 seconds) with no spark, THEN it starts. (RESOLVED)
  125. maf issue
  126. Cam harder?
  127. Is it my tune
  128. HP Tuners 3.2
  129. Knock sensor delete
  130. LS2 GTO Alternator Witing with Aftermarket ECU
  131. tune problem? WOT power loss
  132. please critique my current tune, any red flags?
  133. Holley dominator tuner
  134. Tuning out p1810 trans code
  135. Converter unlocking when I am about to come to a stop.
  136. turn on readiness monitors
  137. Hassle free live data logger?
  138. Heads/cam light throttle issues tune attached.
  139. Snap, Crackle and Pop
  140. GTO check alternator light nightmare
  141. 6l80 swap
  142. Crank sensor RPM to call for fuel
  143. 99-07 LS 24x PCM - DIY Tuner Lock BYPASS
  144. Passlock 2 code values
  145. 12v+ Power only when engine is actually running
  146. 0411 pcm bench tune need done
  147. Good tuner Chicago northside
  148. heavy cam won't idle when cold
  149. Help logging or seeing commanded WOT shifts
  150. ECU Help
  151. knock at low boost HP Tuners, BE table users please step this way
  152. C5 comm problems
  153. Making improvements, tune info appreciated.
  154. Afr
  155. Video- Engine bogs in 2nd gear
  156. Flip of a switch runs like garbage
  157. need help for truck coil gm harness ?
  158. Building a bench harness with VATS
  159. HPTuners Real time tuning wideband disappearing
  160. E67 ECM start mode issue and advice
  161. 1998 Z28 PCM Swap too 2002 0411 PCM
  162. Tuning out po106 after cam swap
  163. Microsquirt & SD 60 data?
  164. Lq4 cam swap problem
  165. Lq4 cam swap problem
  166. Help Disabling Flex Fuel with EFI
  167. WOT shift point changes in tune not responding
  168. HPTuners channel config questions
  169. looking for HP tuners VCM suite 2.24
  170. MAF 3 wire to 5 wire
  171. i think im ok, but can u guys tell me how my map numbers look
  172. Psi harness and can’t get it to start
  173. TPS for switch on off?
  174. 2002 5.3 ect sensor issues
  175. Fresh Rebuild, LS2 CAS P0343 Code Help Please
  176. Mounting ECM LS3 1967 Corvette
  177. replacing TB
  178. Learning the basics
  179. cadillac cts 2004 code B1001
  180. KR during shifts
  181. Open Loop Tuning Or Speed density? Tune review
  182. Separate system for switching tunes on the fly?
  183. I want a file 2001 express van
  184. 98 PCM Repinning Swap Cable
  185. Cooling fans always on
  186. Holley EFI - Set timing without dyno - Turbo, high comp.
  187. problems with CLSD idle fueling
  188. Which MAF Sensor
  189. Saw this on another forum. It's worth trying - GIVEAWAY: Win a Haltech Elite 2500 ECU
  190. dirty maf?
  191. spark at idle jumping
  192. Speedhut Gauges - what Computer to use
  193. Code P0507 Help
  194. Cheapest place for an email tune?
  195. What could it be?
  196. Siemens Deka 60lb Injector Data FI114962 107962
  197. How does one get an “email” tune?
  198. HPTuners and General Tuning Questions
  199. 5.3 swap with no start and a weird spark issue
  200. Dead gas pedal trying to drive when cold started and not warmed up
  201. tuning or trans going bad
  202. How to know when WBO2 needs replaced?
  203. Benchtop Harness help
  204. Review my wot log file
  205. EFI Live demo download???
  206. Temp sensor
  207. 2000 Trans am Airbag issue
  208. Trying to turn over 8000 rpm with 0411 ECU
  209. Cammed lq4 not making power?
  210. Crate LS3 with ASA cam - idle high and revs hang
  211. DBW Throttle position sticking
  212. Gen 4 LMG - Failure to start (VATS maybe?)
  213. LS2 W/E40 ECU & Peddle, How to Add Cruise?
  214. LQ4 swap - very strange issue on first startup
  215. Car won't start after swap to 2 bar OS
  216. Testing Crankshaft Position Sensor and Wiring
  217. does ecm and abs\asr module works together?
  218. 93 rx7 5.3 swap wont start, unlocked pcm
  219. FOR SALE: DiabloSport Trinity T-1000...
  220. Unknown EFI Be Used
  221. Using a Diablo Tuner for a cammed 2002 Escalade & 30lb injectors
  222. 4th Gen and HP Tuners 3.6.26
  223. Hptuners 2 bar to 3 bar
  224. 4.8 tuning newbie cutting out in gear please help
  225. Wayyy too rich at idle
  226. derp can't get fan 2 to turn on in the tune
  227. Ls7 power
  228. idle
  229. self driving Camaro
  230. Bank to bank .50 afr difference open loop ????
  231. LS2 Swap Fuel Trims maxed out after warmup
  232. FOR SALE: DiabloSport inTune i2 i2030 GM programmer with 7 GM licenses.
  233. Koeo map reading ls1
  234. Odd inconstant logging with HPT scanner
  235. First Start Issues..
  236. Lost TCC lock up when MAF enabled
  237. WTB Tunercats
  238. spark adder question for you p59 3bar flex fuel guys
  239. RPO code for tow/haul option?
  240. Gas gage 98 camaro
  241. Diablosport i3 Platinum
  242. P01
  243. PCM serv # and hardware #s compatible with ls v8s
  244. Anyone want to part ways with a Greg Banish Calibrated Success DVD?
  245. Fast 92 & Ls2 TB on Ls6 limp mode HELP
  246. Weird looking VE Table 100kpa. Any ideas?
  247. Case grounded O2 sensors not grounding
  248. Question about 3 Bar Map sensor for ls6 intake
  249. E38 PCM ECT no 5v
  250. 411 ecm narrowband simulation?
