- "tip in" detonation and KR
- hmmm...
- hmmm...
- ed wright mail order tuning
- dyno
- Anyone use EASE Diagnostic software
- Help, P0102, How To Fix
- Anyone with any altitude knowledge enter!
- Low dyno
- What to tune?
- Locations of LS1 dyno tuners?
- got a problem
- cost of fast management?
- (2)Trouble codes I need to know how to troubleshoot..
- Big Cam needs help with Tuning!!!
- Has anyone else had this happen after tuning?
- IFR for 28 vs 26
- paging NOGO
- po336
- Will My HPP3 work on a 99 Camaro Also?
- Pcm Learning time...
- Gear change with LS1 Edit
- Car keeps going with no throttle?
- cruising air/fuel ratios??? What's typical?
- TB Idle hole for 346 vs. 388?
- p1055 p1035 code
- Tuning
- EFI-LIVE prices
- ?????Finding LS1 Edit??????
- Detonation at High RPM
- explanation for P0121?
- any one have the 1.3x version ls1edit software?
- Just got a cam installed and now a P0300?
- P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
- LS1Edit Question about Timing
- Torque management in action - graphs inside.
- How to clean maf sensor?
- Auto Tap OR LS1 Edit
- ANyone have the edit fuel:air ratio table worked out to air/fuel raio?
- Injector Duty Cycle Calculation Does Not Work in EFI Live?
- head and cam swap= no power increase
- Can A-Tap help with tranny
- Information on DiabloSport Predator and Custom Tuning
- Ltft At Wot
- adjustments in tune, quick question??
- How does LS1edit hook up?
- i need a file
- lts not going to 0 at wot
- Can I swap the rear O2 sensors with the fronts?
- Low Octane table?
- How to find small vacuum leak with A-tap??
- Ls 1 edit
- Predator for $250
- why the hp difference between mustang and dyno jet?
- MAFT tuning
- Misfire
- Carputing's (LS1Edit) phone number?
- LS1 Edit Question
- Drilling Throttle body?
- anyone in san antonio
- LS1edit or dyno tuning ....
- Code read Procedure
- P0107, P0154 and P1571 codes
- Predator in conjunction w/DynoTune
- My friend has "Extra" spark advance in his truck, no matter what we do.
- Key points to make sure you don't wash the cylinders when tuning with LS1edit?
- Proscann anyone use it
- malfunctioning o2 DTC help please...
- Props to ChrisB and his LS1 Analyzer!
- predator question
- I just noticed that my MAF table.......
- How to make custom EFI Live tables?
- Any One Know
- Scanners
- ls1 edit Tuning in NY area
- power loss
- Autotap ???
- How Exactly Do Custom Predator Tunes Work?
- Another Predator Question
- Hypertech #385752?
- help pliz(every body read)
- VE used on LS1?
- SES Light question?
- Looking For Good Turner In Kentucky
- Ls1 Edit ?
- Missfire on 1 & 8?
- about tuning
- PCM preference
- ls1 edit laptop question
- No WOT downshift...
- Who Can Tune My Car In Central Fl.
- upgrade fuel injectors? do i need to change my tune?
- PO704 & P0155 Codes
- Can you buy the serial remote LCD for the LM-1??
- LS1 Edit Fast question
- Any new updates on the LS1 Log analyser
- Pulls all timing under boost
- www.ls1tuning.com
- Automatic tuning in a M6 car...
- P0140 and P0160 Codes?
- How is a/f calculated by the PCM?
- Help w/ DTC P0430 (Cats)
- F.A.S.T for LS1
- GEN 7 DFI a plug n play my arse!!
- tuning Issues with new heads and cam
- Car seems to have no throttle response?
- OBII check engine soon
- Long term fuel trim's
- how much to adjust PE? running rich
- Flashing a 99 PCM with 00+ VIN?
- Can someone send me full version of Fast ccom
- GM 85mm MAF - Hz?
- '01 and '02 PCM's interchangeable?
- Not ls1-EGR question
- Having issues with a Holley 50# injecter in a turbo
- Checking O2 crosscounts, w/ EFILive to see their condition
- need your helps folks...what is best aftermarket fuel management system? and why?
- quick ls1 edit question...
- Predator and its new features vs. Dyno tune?
- predator and tm on the base tune
- PCM - acting weird?
- Can i use a 99pcm on 01 motor?
- EFI Live?
- I got 24 more HP over MTI's Mail order tune
- Why does LPE have unlimited access to ECU while other tuners don't?
- Using Corvette Oxygen Sensors in F-body
- detonation on run 1 but not after, and o2 ?'s
- Anybody know how to get ahold of the people that make Predator?
- Fuel Injector Duty Cycle, EFI Live please help.
- Another flashing SES!!!
- Kind of don't understand EFI Live, how to setup different tables (logging)?
- who on the east coast should I have tune my car?
- Deleting TM issues.....
- trans pressure?
- Need Help!!!
- Predator application????
- Got a code I can't figure out
- What is a good shift time with Edit?
- Anyone know when the AEM will come out for our cars?
- Ahh Help Save My Eyes!!!
- Personal Tuning via LS1 Edit vs. Shop's Dyno Tune
- Flashing SES....
- computer doing wierd stuff when i start the car
- Predator Questions
- Knock Gauge
- LS1 Edit question... PLEASE HELP!!
- ANy way in EFILive to make this PID?
- P0300 Is this the fix for it?
- Mail order tune?
- TM with Predator
- Anyone that has ED W. Tuning have problems with him returning your PCM back to stock?
- Reset the Air bag light?
- o2 sesnor -Help
- tuning turbo 427 with ls1 edit?
- How long does ls1edit take
- Has anyone ever seen this?
- G-TECH COMP HP Ratings HELP
- P0121 code. what is it exactly?
- Car starts making hella power then...
- Looking for a stock PCM program for a 99 F body with an A4 and 3:23 gears.
- what temps to turn on fans with 160 stat
- Strange fueling problem...
- lm-1 opinions
- Crankshaft Position Sensor
- Can I Use A Pcm Form An Auto Lt1 For A 6-speed Lt1 Car
- new 373's, will i hurt anything
- ? about falshing PCM
- Predator confusion
- P0101, I have no idea what is wrong.
- predator customer service
- Trying to shake the cob webs.
- getting knock on one run then not again?
- o2 simms question???
- What enables COT? Rear O2 inputs?
- cold crank and really high air fuel??
- why do headers make u run rich?
- Got a lean bank 2 code - need a little guidance.
- easiest (cheapest) way to retard timing
- how high is too high for rev limit
- Code Reader for $39, is this one ok?
- Can you use a Corvette PCM in an F body?
- Help with Code P0138
- pinging/detonations questions and WOT fuel
- hp &TQ predator base tune
- Diablo Rev Limits On/Off ???
- Traction Control question
- edit fails read ?
- 4L60E and Edit Tune-Any Way This Could Happen?
- Innovative Wideband users...
- What MAF table do i use for a SLP maf?
- timing is adjusted, i loged some numbers...can i get some help?
- PCM Question?
- 2-Step For LS1s
- Anyone use TTS?
- dyno'd in open loop?
- Which option from autotap to get...
- Were can I buy Accel Gen 7 DFI
- Dialbo Predator Programer
- My timing is doing its own thing....
- LS1 Edit order form question.....
- predator performance tune in California
- catalytic code
- 98 99 fbody comp question
- a-tap software?
- Laptop for tuning
- Anybody have the dyno sheets for the various programmers out there?
- Why are my A/F ratios not consistent?
- EFI LIVEv6 which is better
- airbag light
- Can't Get A Data Stream Or Codes Out Of My Car
- tune in OHIO
- low rpm timing?
- engine temp to go into closed loop?
- Wot Advance..... How Much Is Safe????
- Wideband going lean??
- P102 MAF low circuit Input Code
- LS1 Edit Newbie
- Help With SES Light (Code P0121)
- P0300 random cly mis-fire
- Predator & SLP MAF
- How do you import spark/fuel into EFILive v5?
- timing?@wot
- Wacky LTFTs at idle???
- What Laptop is everyone using for EDIT?
- Be careful with EFIlive V6
- Aftermarket Coil Packs?
- deleting rear o2 sensors???
- SES question
- ls1 in a miata
- Fan On/Off settings 180 t-stat
- Predator to pc help
- So, finally got this dang Z06 in the - LTFT's, but seems like it took too much.
- need help asap
- EFI Live, No Inj. Duty Cycle? How long pulsewidth is too much?
- Help me figure out what is wrong w/ this car
- Accel gen 7 or FAST??? Will be selling edit.
- Hard time holding idle > please help
- Anyone have trans issues as a result of lockin the converter on the dyno
- Ported MAF ends
- Diablo Predator Programmers
- NON OBD2 Codes...Dealer Codes???
- connecting predator to pc
- MAF Table ?
- predator and quartermile time?
- predator and tourque management
- GMAF and predator
- jet power control module
- P1416=Air system bank 2...question inside
- P0449 code ( HELP)
- Do I need larger Injectors
