PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 [125] 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Why rich a/f
  2. Swapping 120 mph Gauge Cluster for 155mph
  3. Still can't get car to idle right. rpms dropping to 500
  4. OBD II Readiness
  5. i need to remove my jet stage 1 chip
  6. SD vs. MAF
  7. Quick Question
  8. part throttle tune for friends car, need advice
  9. HPTuners Tuning Links
  10. Mafless?
  11. Wideband tuning
  12. EFZI live or HPTunner
  13. PCM tune
  14. Is there any tuning tool that has a wideband O2 w/ fuel inj. to correct AF ratio?
  15. How bad will she run untuned?
  16. pcm tuning
  17. MAP sensor code?
  18. Can someone tell me why truck won't shift at WOT?
  19. I got a hunting problem maybe others have it too?
  20. Hesitation trouble again?
  21. O2's "not ready" on emmissions test.
  22. EFILive will not recognize cable?
  23. What is the stock tune timing set at?
  24. Startup Frictional Airflow? Decay? Delay?
  25. 2 bar volts psi range (for logging boost)
  26. Partial Throttle Problems
  27. Personal Tunning vs. Dynotune
  28. PO327 wont go away :(
  29. 98 part throttle retard?
  30. Timing Jumping Around...
  31. Hanging idle only after WOT?
  32. Problem with tune or my head??
  33. What affects RAF numbers seen by car?
  34. Tunign for supercharger?
  35. Delay before DFCO occurs
  36. Need gauge wiring help!
  37. 408 Tuning
  38. Wide Open Throttle
  39. Hard starting
  40. how to tell if your PCM is bad or the programs has been changed
  41. LC-1 Box
  42. a conandrum if you will....
  43. Fast 90 w/ tpis 90 tb problems
  44. Those using LC-1 what is your response speed?
  45. Does LS1 JET Power Control Module do anything?? or big waste??
  46. lc1 help. can use lm programmer, but wont connect w/ log works2
  47. Svc. tag # for '04 and/or '05 LS1 GTO PCM?
  48. P0134?
  49. Getting ready to do an 06 GTO, quick question
  50. downloading binary files for LS7??
  51. Hp tuners question
  52. SLP Diablo custom tune Results?
  53. How to run LS7 with 12200411 LS1 PCM?
  54. po102
  55. Timing advance????
  56. newbie tuner need some easy help
  57. super rich...loads up, anyone have ideas?
  58. Best low timing ???
  59. is it possible to be TOO lean?
  60. Ls1 Edit and shift speed help.
  61. Year of PC change on F-Bodies
  62. P0155 after cam install
  63. conservative tune?
  64. O2 mV
  65. Safe tuning
  66. where is EFI Live based
  67. Help me out with this issue please guys??
  68. Help with burst knock retard and delta air mass
  69. HP Tuners: VCM Suite 2.1.10 Now Available!
  70. Activation Codes
  71. Vinci Tuner
  72. ls6 intake added, both maf lb/min and map go down!!
  73. efi live...where
  74. looking for good tune
  75. Anyone Willing to make a Trade - PCM tune for leather interior (Ebony)
  76. "Change oil" light comes on and goes off??
  77. Desired shift times...
  78. What do the different TCC modes mean?
  79. Scaning Abilities HP vs. EFILive
  80. C.A.T.S. tuner
  81. po4030
  82. Dial it in a little closer...
  83. Full Throttle TT (need opinions)
  84. LS1/6 PCM, 12200411, initial programing????
  85. Small hole in stock throttle blade
  86. EFILive Tuning Links
  87. Nebie here, need info for setting LS1 in SD mode!
  88. Help can't figure out where wire goes
  89. 02 Z28 Throwing Codes
  90. Differences between bs3 gen 3 and 4
  91. p0410
  92. thinking about getting TREX cam for my 01M6...EFILIVe SD tune...
  93. C6 Z06 tuning problems, NEED help !
  94. Missing coil pack codes help
  95. What is the idael air fuel ratio???
  96. Need LS1 Edit file
  97. Will This help me?
  98. 2bar map sensor install and ?'sss
  99. Bigstuff3 and stock ecu controlling tranny
  100. fluctuating idle??? HELP!!!!
  101. Help!!!!
  102. Some insight would be great...
  103. mail order tunes
  104. Can't Read/Write to a LS1 crate motor computer
  105. Initial start problems....5.3/turbo need help
  106. Racetroinx IFR table...
  107. factory tune might be off???
  108. Tuning After Head and Cam Swap
  109. whats better for begainers?
  110. Best LS1 Tuner??
  111. Weird issue after dead battery
  112. Need Help! Code P0336 CPK Performance
  113. Are G techs ss acurate?
  114. 4% diffrence in bank 1 and bank 2?
  115. Resetting L trims
  116. Stock NBO2 switchpoints...???
  117. rich
  118. EFILive V2 Update
  119. EFILive Pre-Release v7.3.2
  120. Idle tuning, SD, and A/C torque
  121. experts explain
  122. [rant] Maximizer 2 [/rant]
  123. LS7 & BigStuff3
  124. question about tuning software....
  125. In a Jam anyone have LS1 edit software
  126. ETC and IAC?
  127. Did GM update F Body Soft Ware recently
  128. Chip my Camaro
  129. LS1 harness for BS3?
  130. where is the IAT sensor's stock location?
  131. BS3 owners inside
  132. Whats the difference between an SAE tune and an STD tune?
  133. Guys who have gone wideband -> narrowband sim..
  134. HP Tuners std or pro ?
  135. SD tune with FI worth $1000 more
  136. Where to buy?????
  137. Yank SS4000
  138. Eprom installation
  139. prior tuning?
  140. Can a Predator tune good enough for a turbo?
  141. P0171 & P0174
  142. 98 Pcm
  143. how can i erace a ses code from my pcm.
  144. VE still not right!!!???!!!?? WTF
  145. Need some help with electrical...
  146. trex / big cam guys, how much timing?
  147. Vehicle milage reads "ERROR"....wtf?
  148. My LS1 Diablosport Predator Experience...
  149. Wideband...DYNATUNE or AEM?
  150. HELP! I keep blowing the 20A ENG SEN fuse???
  151. shifter...screwing up shift times?
  152. Personal or Commercial version of Flashscan?
  153. ill confused
  154. trans am missing
  155. Difference between 00 and 01 MAF?
  156. I can't seem to lean her out.
  157. pcm input to log WB o2 on 2006 silverado??
  158. misfire #7...removed cats...help PLEASE
  159. MAF ends question
  160. Dtc 1415
  161. longtrims at -9 at wot
  162. Best Tuner?
  163. What advance table used on startup?
  164. Can I just buy the EFILive cable and borrow a CD w/ extra lic to use this software
  165. ABS Documentation?
  166. computer requiremnts for HP Tuners?
  167. E38 vs E40 PCM
  168. ABS experts...stumped?
  169. Burn outs, now ABS lights on urgent !
  170. High Idle & Lean Codes
  171. Will engine braking taint log data?
  172. Fuel trims alittle high
  173. car threw a ses code for the TPS need help?
  174. good A/F ratio target for big hit of spray???
  175. LS1 Edit
  176. Can our cars Run on e85
  177. EGT Gauge
  178. I need some help!
  179. I love fedex....
  180. I think I may have figured out fueling issues at idle
  181. BLM Cells?
  182. Slow o2 switching in only 1 bank
  183. Tsp 233/233 Cam: looping and surging help!
  184. Need some advice just got my EFI-live..
  185. Air fuel Ration
  186. 9 Codes cleared... were they serious?
  187. Scaaarrry AFR on startup!
  188. HPP+ and 10% Ethanol
  189. wich coil is "G"?
  190. Help please with P0410 code?
  191. need some info
  192. Computer swap for hybrid...
  193. Help with pcm pin#s
  194. Anyone using the latest HPtuners with Windows 98SE?
  195. Tuning for headers
  196. I need tuning 101
  197. Which tuner to get?
  198. wideband tunning w/ HPT
  199. USB ~> 9pin adaptor for XP
  200. AutoVE Tuning Issues (Lean) Not going to OLFA table?
  201. Using Gary's "HP Tuners Basic Tuning 101" on an LS1
  202. Supercharged Z06 coming soon..Programming?
  203. MAF recalibration, PE enabled?
  204. Code P0601 showing up after I incorrectly flashed my PCM w/ new 2Bar SD from HPTuners
  205. Shift Solenoid Help
  206. question on a maf code
  207. Gotta love the pushbutton TC lockup!
  208. Tuning for Nitrous
  209. Converter lock up mind of its own
  210. Hypertech Problems!
  211. 98 v6 camaro problems
  212. How to Log your wideband with HpTuners without a EIO
  213. Which operating system to tune ve
  214. PCM controlled 2 step for MN6 cars??
  215. removing injectors, comp. just for timing
  216. questions about spark advance at idle
  217. laptop tuning on LS1?
  218. what AFR? w/o PE or OLFA
  219. Tuning with Vinci VHP tuner
  220. reading bin files
  221. Newbie questions about HPTuners
  222. PE delay RPM
  223. HP Tuners and non-GM vehicles
  224. Tuning Questions
  225. What is the highest VE value...??? (HPTuners)
  226. Warranty?
  227. Can you change individual banks or injectors
  228. My O2 sensors just don't last.
  229. 1997 guage cluster signal
  230. Finally broke down and bought a tuner
  231. Slp Tcs Delete module any good?
  232. wideband installation
  233. Opinion on OBDII scanner!!
  234. iac counts high at cold idle
  235. ac= surging when cold
  236. Predator file
  237. Off idle hesitation...any ideas why?
  238. silly wideband question...
  239. a4 computer flash to m6?
  240. sponsors that use SD for FI
  241. Car Bogging inconsitantly
  242. Throwing a new code.
  243. Tunning Trouble
  244. 9.8:1 Afr
  245. 1998 pcm
  246. reprogram?
  247. 02's...i see why OL works for people..
  248. Need Dtc Help
  249. Anyone have the wiring diagram for the radiator fans?
  250. Best Programmer for LS1 Camaro?
