- This can't be right! Can it???
- Predator Tunning
- Can someone edit my LS1edit a4 file to m6?
- car keeps going back lean after adding to p.e
- was told computer would need to be "burned' not modifyable???
- HELP have ls1 edit installed cam cannot get to idle
- Crap...FTC 22 comes up randomly...Bink...Anybody?
- LS1 edit vs. HP tuners
- California Smog Laws
- How do I copy a table/tab from LS1 Edit?
- Bad O2 ? Help please!
- Tunercat Tutoring
- engine misfire
- 96 Grand Voyager P0140 code
- O2 sensors staying low...long post
- What happened to LS1Tuning.com?
- predator computer reflash question
- LS1Edit software
- Reset PCM after changing collant temp sensor?
- How critical is my situation???
- hypertech or diablo? sorry if repeat
- What is wrong with my car? Tuning related???
- ses light flashing
- Need help with my first tune!
- hp tuners vs dyno tune
- New tune shows FTC 22 when engine idles cold?
- WideBand question
- torgue management???????
- How can I tell if I am staying in closed loop?
- What mods that should do tune?
- How much timing with heads/cam & 91 octane?
- ASR light on after service... help !
- Help With Choosing Tune
- wiring diagram
- wideband users: which do you have and how do you like it?
- Trouble Codes - Help Please!!!
- how much can you detune an engine??
- Help! P0300, 6*kr, +16LTFT!!
- Dealer loaded new PCM, car feels weaker
- switching a 98 pcm with 99&up??
- Need a table.....
- What do you think...
- VE, IFR, PE, (afr)
- HP Tuner qustion.....
- diablo for 98?
- Help w/gear ratio shift points
- anybody know anything about the evap system?
- Strange situation -- after shift car holds an RPM then feels like it got kicked
- What to do with knock sensors?
- LS1 Edit guru's. I need help with De-accel Fuel Cut Off and Throttle Follower/Cracker
- question
- Which A4 shift table do I use?
- DTC P0106 H help!
- New heads installed and now the car bucks under light loads under 1700 rpm?
- lean after intake - what to tune?
- acting weird
- What parameters must be met for the pcm to ue the HOT mode tables?
- What should my TPS Voltage be at Idle and WOT?
- DTC test: SES light, why?
- Possible to Re-Flash Computer????
- o2 sensor question
- what all does the tech 2 do???
- P0101 code and superchargers
- How can I reset my computer to the HO Timing Table at the track??
- Need help on a choosing a programmer
- PLASE HELP!!misfire in multiple cylinders!
- AutoTap set up question
- Tach lag
- so what else can the GEN7 do?
- G5X2 tune on a G5X1 cam- lot of questions
- LS1Edit tuning with dual cutouts
- Chicken or the Egg ?? Bad 02 or rich condition ??
- What exactly does the VE table affect during driving?
- HELP!! someone in S.Jersey area
- code po300 and po463 after fuel pump install
- WOT run and the O2's are between 940 and 950, is that lean or rich?
- Where Do I Get Tuning Done ?????help???
- ls1 edit timing
- I really dig TPTuner but what can I read
- Tuning The SVO 30# ??
- Here is help for new tuners
- Gauge Questions - Opinions Needed
- Ok my Surge Problem is the Yank SS4000 Converter,Hp Tuner guys inside Please!
- PE adjustments affecting shift points?
- What made the LTFT's go positive...
- Uploading another vehichles flash file?
- Vette Doctors tuning
- What happened to ls1tuning.com
- Just a quick question!
- Help needed with tuning large cam/high stall converter
- why did I make no power???
- Help! Anyone do PCM repair in/around Dallas??
- Need flash file for a 99 Z28 6spd
- 16 volt battery any good?
- Help can't lean out car in PE !! w/ HP tuners
- Need help fast my WOT run was 13.9.1 A/F ratio
- Right bank LTRIMS WAY off....
- HP Tuners: Can you have a look at my Tune?
- What would cause a P0506 code?
- Help! Negative MAF readings????
- Just want to swap files
- How would you wire Drive By Wire into a throttle cable fbody style car?
- new stall / transmission
- Stumped on high LT's
- Shorted my PCM with edit. What will happen.
- hptuners question but for a v6 model
- My car is F'in with me!! It threw a code that doesn't exist!! Code P0D87?!?!?
- Predator?
- P0154 ????
- Engine pops then dies when going to WOT
- Wheel question
- Where to get a tune in NC?
- hand held tuning
- HP Tuners is making my VE table so purdy :D
- MAF question...
- question: if you descreen your maf, should you change the MAF airflow table?
- Ve Map
- SES light on. Help please!!
- Question about idle
- How do I Richen up my Idle with HP Tuners?
- New Tuning Software?
- HELP! O2 Simulator
- Stock MAF vs. Cal'd 85mm
- Vats problem....Edit not disabling it....
- VE data collecting w/ HPTnr's
- What Will A Tune Do For My 2k2 Ws6?
- knock sensor
- hptuners question
- Nx Maf Kit\codes
- Cruise LTRIMS and AF after injector scaling
- comp cam programer
- A4 owners, what WOT shift points did you pick?
- New to LS1's and Programming
- Code P0327
- where to get ls1 edit / hp tuners?
- HELP ME ... My Car switches cells and Ltrims go +25 ( in cell 22 )
- threw a code, EVAP?
- How can you tell if your MAF sensor is bad?
- Someone Please Help!!!
- how to turn off air bag light with tech 2
- 02 sensor question
- On a 99 PCM, is there a 12v switched lead anywhere?
- new to edit
- FTC 15 vs 22
- Question for those messing with the ve table
- So who's gonna write the book??
- Best Way To Tune ???
- A-Tap and data logging software
- LTFT help please
- Decent ECM diagnostic set up?
- Bring idle down
- Need help. P1637 code
- HPE is the place to go!!!
- O2 voltages - narrowband to wideband correlation
- Whats more important...correct idle airflow, or correct IAC counts?
- Help me understand something about tuning
- Setup my LM-1, WOW something is off (dyno or LM1)
- Mototron ECU for LS1's
- A4 + Cam + 4.10s = Screwed Shifting
- IFR scaling on PE vs. RPM tables too?
- Pass side window doesn't work after motor swap
- PC crashed - lost LS1Edit software??
- Car runs like crap
- I am about to bundle this ls1 edit stuff to a rock an sink it in the river!!
- hptuner-ls1edit
- What causes these 2 annoying things?
- big stuff website.
- will a gauge cluster from a93-97 lt1 hav the same pinouts as a 95 3.4l v6
- HP Tuners cable won't read PCM "HELP"
- Free Beta LS1 Scan software from carputing
- Are my 130 degree IAT readings normal sitting still in 77 degree ambient?
- Is their a book on Tuning PCM's or a Tutorial
- Dave at Ramchargers is #1 in my Book!!!
- Do I need to tune my car?
- How much is to much?
- Anyone ever use this HP Tuners Spreadsheet?
- wondering what would couse my tach to jump?
- HP Tuner log file, 1st time user, just want some advice
- low speed cruise effect.. how to stop it
- BIG PROBLEMS , +25 LTFT's on BOTH banks
- Why is my car missing, sputtering, popping through the exhaust at WOT
- fuel trims vs. timing for closed loop
- Best/Cheapest to buy new stock PCM for 2000 Camaro??
- does this look like false knock??
- help with changing shift points with HP Tuners
- Zeitronix WB
- How long before readiness test are ready?
- changed oil psi sender and now I have problems
- Extra PCM, how do I program VIN# or get VIN# programmed into unit?
- HP Tuner Question about IAC
- dyno tune
- Need cable for ecm
- Who tunes the Accel Gen7+ ?
- Qua Pasa
- MAF question
- false knock?
- scaled the injectors last night
- Best Place for wideband O2 bung?
- TRex Idle Tuning On A4
- eeprom flashing.
- Where is the Fuel Inertia Saftey Shut off Reset Sitch?
- Differences between A4 and M6 ecm and harness..
- A4 road course shift tuning
- just got hp tuners
- Can you stack an performance mod. with a programmer?
- Anyone running HPP3 after header install
- Pcm Help!?
- Problem ... need advice / guidance
- Code help??? P1626
- HPTuners on order, need "getting started" advice...
- Running Lean!
- Paging ChrisB
- before I spend the $$$
- Code P6714?
- Ported MAF ends... HPP3 tune?
- overtuning?
- HP Tuners-Removing AIR, EGR, and rear O2's, did a search, want to be clear...
- LM1 harness pinout requested
- torque management: does it affect M6's?
- Help What Is Making Me Go Though O2 Senors?
- Noob ? - HP from HP Tuners
- how to make tc lock in all of 3rd gear?
- books on LS1 tuning?
- Considering HP Tuners
- Open headers and o2
- Possible Causes Of +25 LTRIMs?
- If the engine is always going for ideal fuel mixture, how do mods lean or richen?
- Anybody seen this wideband??
- Large LTFT imbalance B1-B2
- Interest In C5 Laptop Mounts?
- how much will high flow cats skew air/fuel reading?Replacing stock post cat o2 w WBo2
- Whay are timing values negative in the Edit timing retard tables??
- What is Lean cruise?
- With HP Tuner what do the VE Numbers mean?
- Yet Another HP Tuner Question about EGR
- How did you install your Autometer Oil Pressure Gauge?
- 98 PCM Pin Assignment?
- i can see the spark plugs fire
- Mode 6 help.
- will 01/02 pcm work
- Using LM-1 as wide AND NARROW band? IE removing stock o2
- Paging NoGo:Question about adding timing at WOT
- SES Question
- Accel Gen7 & MSD 7AL-3 Ignition Box
- See if you can figure this out
- Can Someone Help Me Locally With Hp Tuner
- Pcm Question?
- Predator rev limiter....
- tunning with a diablo
- Low rpm KR after cam install.
